Note: Guide Updated May 2017, as I realise that /dev/input/event3 may not always be the IR receiver device on your armbian installation.
Hi All,
I recently bought an Orange PI PC and the best thing I ever did was install Armbian straight away (and donate). Now that I have a bit of spare time, I wanted to configure my Orange PI PC to do something ridiculous like play Rick Ashley 'Never going to give you up' upon pressing the 'red button' on some generic Chinese IR remote for an LED light strip I have in my living room.
Thanks to Armbian, most of the pieces are in place (such as the SunXI IR package) with the distribution, you just need to glue it all together.
However there are few configuration issues with the default Armbian install on the Orange PI PC that need to be adjusted, otherwise you'll encounter infuriating issues such as:
  • No IR device existing or being detected (root cause: sunxi-cir module not loaded)
  • No LIRC 'irw' output even after successfully using irrecord (root cause: DRIVER=devinput doesn't work, though it could be my remote), like this poor sod was experiencing.
I should also note that this guide on the terrible Orange PI forums, helped me with my issues.
Step 1) Adjust /etc/lirc/hardware.conf
Updated: This guide was originally written for Armbian based on Debian 'Jessie'. The latest Armbian (as at September 2017) is now based on Ubuntu Xenial. This introduces a new lirc package which yet again comes with a broken hardware.conf
For Ubuntu Xenial (September 2017):
The default hardware.conf that comes with Armbian is broken. It's assigning the 'remote' and 'transmitter' to the same device, this breaks everything. Ensure the TRANSMITTER_MODULES="" and TRANSMITTER_DEVICE = ""
# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="None"
REMOTE_MODULES="sunxi_cir"
REMOTE_DRIVER="default"
REMOTE_DEVICE="/dev/lirc0"
REMOTE_SOCKET="" # FYI - /run/lirc/lircd   will probably be the socket that the system uses
REMOTE_LIRCD_CONF=""
REMOTE_LIRCD_ARGS=""
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE="/dev/null"
TRANSMITTER_SOCKET=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Disable kernel support.
#Typically, lirc will disable in-kernel support for ir devices in order to
#handle them internally.  Set to false to prevent lirc from disabling this
#in-kernel support.
#DISABLE_KERNEL_SUPPORT="true"
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
START_LIRCMD=""
For Debian Jessie (~year 2016):
By default Armbian doesn't have the suxi-cir module enabled at boot-up, but it is available, so you will need to edit hardware.conf to enable this, as well as correct the DRIVER= line and the DEVICE= line, as the defaults in there are WRONG.
Also I suggest commenting out Igor's code in the top five lines. A hardware.conf that works:
# Cubietruck automatic lirc device detection by Igor Pecovnik
#str=$(cat /proc/bus/input/devices | grep "H: Handlers=sysrq rfkill kbd event" | awk '{print $(NF)}')
#sed -i 's/DEVICE="\/dev\/input.*/DEVICE="\/dev\/input\/'$str'"/g' /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS=""
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
# 'devinput' driver on Orange PI PC causes NO EVENTS TO OCCUR
# via irw for some reason.
DRIVER="default"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/lirc0"
MODULES="sunxi-cir"
LIRCD_CONF=""
LIRCMD_CONF=""
Step 2) Restart lircd service
As lirc is actually already running and installed in Armbian, do the following:
root@orangepipc:/etc# /etc/init.d/lirc stop
root@orangepipc:/etc# /etc/init.d/lirc start
To reboot the service.
Then perform an 'lsmod' to see if it loaded the sunxi_cir module (because otherwise nothing will work):
user@orangepipc:~$ lsmod
Module                  Size  Used by
mali_drm                2732  1
drm                   178255  2 mali_drm
mali                  123208  0
ump                    29379  3 mali
sunxi_cir               1601  0
8189es               1076034  0
Step 3) Find out what '/dev/input/eventX' device is your IR receiver
If you do a:
ls /dev/input/event*
You will most likely get a bunch of possible event devices to choose from, for example:
anonymouspi@orangepipc:~$ ls /dev/input/event*
/dev/input/event0  /dev/input/event2  /dev/input/event4
/dev/input/event1  /dev/input/event3  /dev/input/event5
For my installation, /dev/input/event3 is the IR receiver, but if you have other devices installed (i.e. USB cameras, keyboards etc.) then the number could be different. For example, executing 'evtest /dev/input/event3' reveals:
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
Input device name: "sunxi-ir"
A device name of 'sunxi-ir' means that we are using the right device for the purposes of evtest
Step 4) Do a quick test with with 'evtest' (OrangePI PC armbian seems to use /dev/input/event3 for IR input )
Armbian has the 'evtest' program installed, point the IR remote (in my case a  LED colour remote) at your Orange PI PC and as root 'evtest /dev/input/event3'.
root@orangepipc:/etc# evtest /dev/input/event3
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 152 (KEY_SCREENLOCK)
  Event type 4 (EV_MSC)
    Event code 4 (MSC_SCAN)
Key repeat handling:
  Repeat type 20 (EV_REP)
    Repeat code 0 (REP_DELAY)
      Value    500
    Repeat code 1 (REP_PERIOD)
      Value    125
Properties:
Testing ... (interrupt to exit)
Pressing the remote reveals events like:
Event: time 1472917554.113967, type 4 (EV_MSC), code 4 (MSC_SCAN), value 58
Event: time 1472917554.113981, -------------- EV_SYN ------------
Event: time 1472917554.464390, type 4 (EV_MSC), code 4 (MSC_SCAN), value 59
Event: time 1472917554.464398, -------------- EV_SYN ------------
Event: time 1472917554.842832, type 4 (EV_MSC), code 4 (MSC_SCAN), value 45
Event: time 1472917554.842839, -------------- EV_SYN ------------
Event: time 1472917555.345584, type 4 (EV_MSC), code 4 (MSC_SCAN), value 58
That was the red, green, blue and white buttons being pressed. This is a good news.
Step 5) Configure lirc to map IR input to key presses or events.
Again, Armbian has irrecord installed (great work Igor), but given I'm re-using this remote to configure the output of a LED strip I have, I'll need to map the IR data sent, to something more meaningful. In other use-cases this isn't generally required as lircs provides a database of media remotes which is pre-mapped to Linux commands/keyboard keys.
There's plenty of information on how to use irrecord, command I used was:
...to first stop the service, then:
irrecord -H default -d /dev/lirc0 /etc/lirc/lircd.conf
... to record my remote and bind to 'keys'.
Step 6) Test with irw
Now that I recorded my configuration file with irrecord:
.. to start lird service again
then type 'irw' and check that the key mapping works when I point the remote at the Orange PI PC and press a button:
root@orangepipc:/etc# irw
0000000000ff1ae5 00 KEY_R /etc/lirc/lircd.conf
0000000000ff1ae5 01 KEY_R /etc/lirc/lircd.conf
0000000000ff9a65 00 KEY_G /etc/lirc/lircd.conf
0000000000ff9a65 01 KEY_G /etc/lirc/lircd.conf
0000000000ffa25d 00 KEY_B /etc/lirc/lircd.conf
0000000000ffa25d 01 KEY_B /etc/lirc/lircd.conf
0000000000ff22dd 00 KEY_W /etc/lirc/lircd.conf
0000000000ff22dd 01 KEY_W /etc/lirc/lircd.conf
Hoo Ray!
Step 7) Create a /etc/lirc/lircrc file to run commands
sudo vi /etc/lirc/lircrc
I'd actually call mpv here and call the player:
# http://www.lirc.org/html/configure.html
begin
   button = KEY_R
   prog = irexec
   config = mpv  /home/root/Rick\\ Astley\\ -\\ Never\\ Gonna\\ Give\\ You\\ Up.m4a & echo "COMMENT RICK ROLLING" &
end
begin
   button = KEY_W
   prog = irexec
   config = killall mpv & echo "SADFACE!" &
end
begin
   button = KEY_B
   prog = irexec
   config = mpv http://sj256.hnux.com &
end
You could also create a file for each user of the system if you want, eg: /root/.lircrc, /home/userXXX/.lircrc
However if you do this, you will need to start the irexec service manually. If you have a /etc/lirc/lircrc file, the irexec service will start automatically at boot - this service is what actually converts the key press to the command.
So there you go, Rickrolling with a simple press of the red (KEY_R) button :-)
Additional References:
[Guide] Android + InfraRed (IR) + Kodi
How to setup Remote Control for Linux
Is it possible to bind this lirc to some python script or something? Or how someone could intercept these button press events and then pipe them somewhere else where they could be used to trigger stuff?
I wanted to configure my Orange PI PC to do something ridiculous like play Rick Ashley 'Never going to give you up' upon pressing the 'red button' on some generic crap Chinese IR remote for an LED light strip I have in my living room.
I like your style kid.  :lol:
Hi all,
According to:
I have a completely different contents of this file,
where I make a mistake? :)
the contents of my file /etc/lirc/hardware.conf  below :
count 1
range '0 - 7'
control.2 {
iface MIXER
name 'MIC2_G boost stage output mixer control'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.3 {
iface MIXER
name 'LINEIN_G boost stage output mixer control'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.4 {
iface MIXER
name 'MIC1 boost AMP gain control'
value 4
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.5 {
iface MIXER
name 'MIC2 boost AMP gain control'
value 4
comment {
access 'read write'
type INTEGER
count 1
range state.audiocodec {
control.1 {
iface MIXER
name 'MIC1_G boost stage output mixer control'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.2 {
iface MIXER
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.3 {
iface MIXER
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.4 {
iface MIXER
value 4
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.5 {
iface MIXER
value 4
comment {
access 'read write'
type INTEGER
count 1
range
btw. I changed the contents of this file and everything works, :)
 but why after the Armbian installation this file  was so different  from the target?
Certainty is never, but this file seemed ok, only content was strange.
I did not created this file.
Armbian was compiled from sources some four months ago, is working fine
(webmin, apache,ssl,mqtt server and many other things working 24/7)
now IR remote control (Samsung) also work  :)
Maybe an error at compile time? file system error is not indicated
Thaks for this  :)
Btw.
Did Yoy try play stream from playlist ? (works for me:  mpv --playlist = playlist.pls) but..
Do You know how to easy change to next stream from play list using IR ?
(just kill and restart with new stream only metod?)
Last news:    :)  :)
I am fine now,
I solved the problem and I use mpd, mpc for bacground playing music from playlist
eg.
begin
  prog = irexec
  button = KEY_CHANNELDOWN
  config = mpc prev & echo "prev music" >/dev/ttyS0
end
Hi All,
I recently bought an Orange PI PC and the best thing I ever did was install Armbian straight away (and donate). Now that I have a bit of spare time, I wanted to configure my Orange PI PC to do something ridiculous like play Rick Ashley 'Never going to give you up' upon pressing the 'red button' on some generic crap Chinese IR remote for an LED light strip I have in my living room.
Step 5) Create a /root/.lircrc file to run commands
begin
   button = KEY_R
   prog = irexec
end
begin
   button = KEY_W
   prog = irexec
end
begin
   button = KEY_B
   prog = irexec
end
Hi, I'm having problems with the evtest. Everything works just fine until I reach that point. The evtest shows nothing.
I tried using the command "sudo mode2 -d /dev/lirc0" and it works, so my IR receiver is functioning, but the evtest doesn't detec anything.
I also tried with both the default and the Igor's hardware.conf file. Same result.
I don't know if it is usefull, but the command "irw" also doesn't work for me, it says "connection refused".
I'm using Armbian on an Orange PI PC Plus.
Thanks !
for me, this tutorial was very helpful.
However, the configuration file created :
but the remote control to work properly.
Already done ...
It is difficult for proper entries: .....and shows that are very important!
  name        mceusb
  bits                 16
  flags  RC6|CONST_LENGTH
  eps                  30
  aeps                100
  header       2667   889
  one           444   444
  zero          444   444
  pre_data_bits        21
  pre_data        0x37FF0
  gap              105000
  toggle_bit           22
  rc6_mask    0x100000000
after the change of all is OK ...I use the remote control OrigenAE RC153 which uses standard codes RC6 (mce)
original config (lircd.conf) under the remote control mce ..... and created:
mce https://dl.dropboxusercontent.com/u/68191728/LINUX/lircd-mce.conf
OrigenAE https://dl.dropboxusercontent.com/u/68191728/LINUX/lircd-OrigenAE.conf
a list of possible names in the irrecord : https://dl.dropboxusercontent.com/u/68191728/LINUX/key
Useful links (internet radio) http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&tid=1389
another sensor and remote control : https://forum.armbian.com/index.php/topic/3288-orangepi-lite-armbian-remote-x10/
Regards !
Thanks for the write up AnonymousPi!
I am running an OrangePi PC as well with Armbian on top of an Ubuntu Kernel. The default LIRC config, however, is different. I tried making changes, but whatever I do sunxi_cir just does not show with lsmod. Is anyone else having issues?
I have Orange Pi lite / ARMBIAN 5.25 stable Ubuntu 16.04.2 LTS 3.4.113-sun8i
And after the lsmod command:
mali_drm                2732  1
pcf8591                 3363  0
bmp085                  3487  0
mali                  123146  0
ump                    29379  3 mali
ir_lirc_codec           3650  3
lirc_dev                7834  1 ir_lirc_codec
ir_mce_kbd_decoder      2885  0
snd_usb_audio          80352  2
ir_sanyo_decoder        1480  0
snd_hwdep               5562  1 snd_usb_audio
ir_sony_decoder         1422  0
snd_usbmidi_lib        17545  1 snd_usb_audio
snd_seq_midi            4215  0
snd_seq_midi_event      5340  1 snd_seq_midi
ir_jvc_decoder          1452  0
ir_rc6_decoder          1941  0
snd_rawmidi            17134  2 snd_usbmidi_lib,snd_seq_midi
ir_rc5_decoder          1412  0
ir_nec_decoder          1556  0
g_serial               27617  2
sunxi_cir               1601  0
  • Igor unpinned this topic
We would appreciate help fixing this upstream. It has been some time since I was playing with LIRC ... And there are some other changes in Debian Stretch which are completely broken in some other way. Haven't check how it is done there yet.
This is the code which should fix this - configuration for Allwinner H3:
https://github.com/armbian/build/blob/master/config/sources/sun8i.conf#L31-L52
Hi Igor. More than happy to help out, but I am confused as to the purpose of that sun8i.conf config file. What really needs to change is the contents within the distribution '/etc/lirc/hardware.conf' so similar to how lircd.conf is contained here.
Any insight in to how to do this appreciated. I am happy to test for stretch.
Today I reinstalled my OPi R1 with stable/legacy for testing IR/lirc with the IR-Port of the NAS-Expansionboard.
I installed the IR-Support via armbian-config (network-section) and it automatically loads the module sunxi_cir
Modules are loaded and I get a  /dev/input/event2 - but evtest  /dev/input/event2 did only produce this output and doesnt recognize the IR-remote:
root@opi-zero-r1:~# evtest /dev/input/event2
Supported events:
      Value    500
      Value    125
Properties:
My OrangePi Zero does load all modules if I modprobe sunxi_cir and does respond to the IR-remote:
root@orangepizero:/etc/lirc# evtest /dev/input/event2
Supported events:
      Value    500
      Value    125
Properties:
Event: time 1511898396.197217, type 4 (EV_MSC), code 4 (MSC_SCAN), value 116
Event: time 1511898396.197227, -------------- SYN_REPORT ------------
Event: time 1511898397.768212, type 4 (EV_MSC), code 4 (MSC_SCAN), value 11a
Event: time 1511898397.768236, -------------- SYN_REPORT ------------
I did take a look at the fex-edit in armbian-config for the 2 boards and the section for IR seems to be the same.
Can I take a look in anything other?
on the OPi Zero R1 the follwing lirc-components are installed:
root@opi-zero-r1:~# dpkg -l|grep lirc
ii  inputlirc                        23-2                                       armhf        Zeroconf LIRC daemon using input event devices
ii  liblircclient0:armhf             0.9.0-0ubuntu6                             armhf        infra-red remote control support - client library
ii  lirc                             0.9.0-0ubuntu6                             armhf        infra-red remote control support
ii  lirc-x                           0.9.0-0ubuntu6                             armhf        infra-red remote control support - X utilities
and on the normal OPi Zero this lirc-components are installed:
root@orangepizero:/etc/lirc#  dpkg -l|grep lirc
seems to be the same :(
I assume you use identical kernel / armbian version on both?
Yes - because I had before the R1 on 4.x Kernel I reinstalled another uSD with 3.4.x legacy kernel:
OPi Zero R1:
ARMBIAN 5.35 user-built Ubuntu 16.04.3 LTS 3.4.113-sun8i
Linux opi-zero-r1 3.4.113-sun8i #4 SMP PREEMPT Wed Nov 22 13:45:28 CET 2017 armv7l armv7l armv7l GNU/Linux
OPi Zero (normal-version):
Linux orangepizero 3.4.113-sun8i #4 SMP PREEMPT Wed Nov 22 13:45:28 CET 2017 armv7l armv7l armv7l GNU/Linux
