Orangepi Zero2 bullseye image can't use
Go to solution Solved by Igor,
I just download the image for Oranegpi Zero2 :
Armbian 21.08 Bullseye
Kernel 4.9.y, Size: 337Mb, Updated: Jan 24, 2022
And I use "usbimage" write the image to my SD card .
And,  nothing happen, Red LED and Green LED not lighting. Serial Port has no any message.
I have 3 SD card, 2 Orangepi Zero2. All of it I test still failure.
I have a older image for Orangepi Zero2 name "Armbian_21.08.1_Orangepizero2_buster_legacy_4.9.280.img.xz". This one is useful. BUT, can not "apt upgrade". If you do so , you cannot boot up next time.
So I just confuse now......
18 hours ago, Igor said:
Holy sh!t , Igor just reply me !!!
I will try the new image later...I will try...
No,I do it right now.
(10 minutes later)......
OK, it's WORK!
The version "Kernel 4.9.y, Size: 340Mb, Updated: Mar 7, 2022" is WORK!
Congratulations!
Thanks for all. I'm going to enjoy my new Pi right now.
