Does "orangepi3" also support Orange Pi 3 LTS?
Go to solution Solved by Ukhellfire,
Does "orangepi3" also support Orange Pi 3 LTS?  The board looks different from the Orange Pi 3 on the download page and has a different number of USB ports.
Yes and no. Other RK based boards have been re-released as well with Motorola PHY due to chip shortage. So this driver needs to be implemented in various families.
1 hour ago, Fatih said:
is it working fine? I'm thinking of buying one for it.
If I am interpreting above correctly, it sounds like there have been some hardware changes and those will need to be implemented.  So until that gets done some things might not work.
@Igor question for you if you don't mind answering or pointing me in the direction of I fo with the answer?
When building armbian, the patches. All the patches in the patch folder, do they all get applied? Or are the patches called by the specific board in a config somewhere?
the link you posted above for the r1+. He adds patches for certain things, but nothing calls them. Is it just a case of adding a patch if something never before seen in armbian is needed?
hello guys. I want to use glodroid on orangepi3lts. is it possible to use the image in my orangepi? from the official website. they only release the android image version 9.0. can i use glodroid inside my orangepi3lts?
No idea what you are talking about. You are aware that this is Armbian forums that handles topics around Armbian, right?
