haajee Posted March 9, 2022 Posted March 9, 2022 (edited) Armbianmonitor: https://pastebin.com/8PqTV4eh Hi everyone, After the last armbian update with a new kernel does the internal networkcard not work anymore! Luckely does a USB NIC work and can i run everything but on only 100Mbps iwonstead of 1Gb of the internal NIC. What i remember did this problem also a few years ago happen. I have pasted all the required info to pastebin because armbianmonitor -u does not work. I got an error that network is not availble. Thank you all for you support! Edited April 18, 2022 by haajee 0 Quote
haajee Posted March 9, 2022 Author Posted March 9, 2022 By plugging in the USB NIC i could ssh to the Orange Pi 4 again but did not a working internet connection. Probaply because the DNS server was not correct or something. Anyway i made the following change to got it working. I did go to the dir /etc/NetworkManager/SystemConnections/ I renamed the file 'default' to '_old_default'. There where also 2 files for the builtin NIC i think and my external NIC. So i renamed the internal NIC file to 'default' In the file edited the interfacename eth0 to the USB NIC enx000ec6c13633 After a reboot it works for now with the external NIC. Maybe is the Internal NIC broken because there is a new Orange Pi 4 LTS with another ethernet chip? I see also now that wifi and bluetooth doesn't work anymore after the update... 0 Quote
firedgje Posted March 13, 2022 Posted March 13, 2022 I have the same issue since the update of kernel version 5.15. I have no network and no HDMI during the boot... I'm using the first version of Orange PI 4 B. Is it a way to solve by replacing only the kernel (or other file) on SD ? 0 Quote
laurentppol Posted March 13, 2022 Posted March 13, 2022 I have "plain" OPi4 (not B, nor LTS), after todays update to 5.15.25 #22.02.1 Armbian Buster, network works fine. Didn't tested BT / WiFi / HDMI (during boot) as I don't use then on this box. May test later if someone needs. 0 Quote
haajee Posted March 20, 2022 Author Posted March 20, 2022 On 3/13/2022 at 1:23 PM, firedgje said: I have the same issue since the update of kernel version 5.15. I have no network and no HDMI during the boot... I'm using the first version of Orange PI 4 B. Is it a way to solve by replacing only the kernel (or other file) on SD ? Expand I hope it would. But didn't get any anwser. So i did al full reinstall from zero. Sadly today again a update what brokes the whole thing down...! On 3/13/2022 at 8:54 PM, laurentppol said: I have "plain" OPi4 (not B, nor LTS), after todays update to 5.15.25 #22.02.1 Armbian Buster, network works fine. Didn't tested BT / WiFi / HDMI (during boot) as I don't use then on this box. May test later if someone needs. Expand \ Got exactly the same but with Focal. Today this update broke the whole system again after reboot: Bezig met uitpakken van armbian-config (22.02.2) over (22.02.0-trunk.0004) ... Uitpakken van .../armbian-firmware-full_22.02.2_all.deb wordt voorbereid... Bezig met uitpakken van armbian-firmware-full (22.02.2) over (21.08.6) ... Uitpakken van .../armbian-zsh_22.02.2_all.deb wordt voorbereid... Bezig met uitpakken van armbian-zsh (22.02.2) over (22.02.1) ... So i should install from scratch again... This time buster and hopefully the next updates would not broke the system again and again and again I think that it maybe has to do something that my OS is on the USB drive... Edit: ok, i know a lot more. Also if i enable I2C on armbian-config the system NIC stops working. Also on Focal and Bullseye and it doesn't make sense if i use a usb disk or not. 0 Quote
firedgje Posted March 27, 2022 Posted March 27, 2022 On 3/20/2022 at 2:38 AM, haajee said: I hope it would. But didn't get any anwser. So i did al full reinstall from zero. Sadly today again a update what brokes the whole thing down...! Expand OK, thanks for the info. I will wait for a fix. If someone has a solution to manually fix the issue directly on SD card (as Ethernet is broken), I'm interested in order to recover my previous installation and configuration... Thanks in advance for your help ! 0 Quote
haajee Posted April 18, 2022 Author Posted April 18, 2022 Did you have any update? I have now freezed all updates for shure and now runs ok. 0 Quote
lmdc45 Posted April 20, 2022 Posted April 20, 2022 On orangepi 4 LTS wifi is not working on available debian cli img file Noting wifi is working fine on orange pi 4 lts orangepi debian image (Linux 5.10.43 #3.0.0 aarch64 GNU/Linux) Could not find any way to make it work, device not showing at all Would be interested in any updates on this as well 0 Quote
Werner Posted April 20, 2022 Posted April 20, 2022 On 4/20/2022 at 4:59 AM, lmdc45 said: On orangepi 4 LTS wifi is not working on available debian cli img file Noting wifi is working fine on orange pi 4 lts orangepi debian image (Linux 5.10.43 #3.0.0 aarch64 GNU/Linux) Could not find any way to make it work, device not showing at all Would be interested in any updates on this as well Expand This topic is about Orangepi4, not LTS. Those are different boards. OPi4LTS is not supported as this time. 0 Quote
haajee Posted April 30, 2022 Author Posted April 30, 2022 On 4/20/2022 at 5:05 AM, Werner said: This topic is about Orangepi4, not LTS. Those are different boards. OPi4LTS is not supported as this time. Expand Hi Werner, do you know if this problem is fixed? I have now freezed all Armbian updates because the whole system broke after a kernel update. But what i know this is a problem of all RK3399 boards? Thank you for your answer 0 Quote
Werner Posted April 30, 2022 Posted April 30, 2022 No idea. Maybe @Igor can or cannot confirm a fix since he is maintainer for OPi4. 1 Quote
cristobalgh Posted May 16, 2022 Posted May 16, 2022 Hi! Any updates? I'm using Armbian_22.02.1_Orangepi4_focal_current_5.15.25_xfce_desktop and wifi not working... Thanks! 0 Quote
cristobalgh Posted May 17, 2022 Posted May 17, 2022 On 5/16/2022 at 9:25 PM, Cristobal Galleguillos Hart said: Hi! Any updates? I'm using Armbian_22.02.1_Orangepi4_focal_current_5.15.25_xfce_desktop and wifi not working... Thanks! Expand ok, I have the LTS board, just read that its not supported.... thanks 0 Quote
haajee Posted June 1, 2022 Author Posted June 1, 2022 Can someone confirm if the Armbian update today not broke down the running system? Is it safe to upgrade?? 0 Quote
haajee Posted June 22, 2022 Author Posted June 22, 2022 To anwser my own question: yes it's safe to upgrade! Everything works perfect after upgrade to 22.05.1 Focal and 22.05.3 Focal on the OrangePi 4! 0 Quote
firedgje Posted June 25, 2022 Posted June 25, 2022 You have some chance because I tried new install and also by update (from 5.10) without success on my op4 (orginal one/non LTS)... With new kernel 5.15 I have no Ethernet so I cannot see what is the issue... 0 Quote
firedgje Posted June 26, 2022 Posted June 26, 2022 So I finally tested the default jammy install ans it works but I have no HDMI sound. 0 Quote
haajee Posted June 27, 2022 Author Posted June 27, 2022 On 6/26/2022 at 2:39 PM, firedgje said: So I finally tested the default jammy install ans it works but I have no HDMI sound. Expand Hmm, i don't use HDMI sound. But i got a new update today and not yet rebooted but got a trunk version??? Preparing to unpack .../0-curl_7.68.0-1ubuntu2.12_arm64.deb ... Unpacking curl (7.68.0-1ubuntu2.12) over (7.68.0-1ubuntu2.11) ... Preparing to unpack .../1-libcurl4_7.68.0-1ubuntu2.12_arm64.deb ... Unpacking libcurl4:arm64 (7.68.0-1ubuntu2.12) over (7.68.0-1ubuntu2.11) ... Preparing to unpack .../2-armbian-config_22.08.0-trunk.0038_all.deb ... Unpacking armbian-config (22.08.0-trunk.0038) over (22.05.3) ... Preparing to unpack .../3-armbian-firmware_22.08.0-trunk.0038_all.deb ... Unpacking armbian-firmware (22.08.0-trunk.0038) over (22.05.3) ... Preparing to unpack .../4-armbian-zsh_22.08.0-trunk.0038_all.deb ... Unpacking armbian-zsh (22.08.0-trunk.0038) over (22.05.3) ... Don't know if this is a good sign.... 0 Quote
Werner Posted June 28, 2022 Posted June 28, 2022 On 6/27/2022 at 6:22 PM, haajee said: Don't know if this is a good sign.... Expand Me neither Usually there should not be mixups between stable and nightly, no idea what happened. Did you change firmware to nightly via armbian-config or something? Regardless from what I see here is that the bumps probably do not cause harm. You just get a slightly newer version of firmware package and unrelated stuff. 0 Quote
firedgje Posted June 28, 2022 Posted June 28, 2022 @haajee: I think I also seen this update. I have some issues sometime the board never starts, but I cannot see any logs as I have no Ethernet. @Werner: In update configuration tool in Ubuntu, I cannot manage the apt repositories, I have just the default for Ubuntu and it was not the case before. I can maybe directly modify the sources in config file (/etc/apt/sources.list) but that is stange... 0 Quote
firedgje Posted July 15, 2022 Posted July 15, 2022 I tested again last jammy version with the update. I still have an issue with u-boot because sometimes it boot correctly and somtimes not... But the OS seems to work. 0 Quote
