Hi everyone,
So I am a real beginner with networking so I though I would buy this board for learning and messing about. But I cant get the switched 6 port Ethernet to work. It shows up with ip link:
root@armada:~#ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: bond0: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether 0a:b2:e1:6c:82:2e brd ff:ff:ff:ff:ff:ff
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 532
    link/ether 00:50:43:25:fb:84 brd ff:ff:ff:ff:ff:ff
4: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 532
    link/ether 00:50:43:84:25:2f brd ff:ff:ff:ff:ff:ff
5: eth2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 532
    link/ether 00:50:43:0d:19:18 brd ff:ff:ff:ff:ff:ff
6: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default qlen 1
    link/ipip 0.0.0.0 brd 0.0.0.0
7: lan1@eth1: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
8: lan2@eth1: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
9: lan3@eth1: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
10: lan4@eth1: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
11: lan5@eth1: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
12: lan6@eth1: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
I also can a assign an IP to eth1 and ping it, but i cant ping any thing connected with eth1.
I am running the latest vanilla version of armbian for the Clearfog Pro.
Help would be much appreciated.
There are some problems with ports and I am not sure all this is fixed by now but we are releasing an update later today. There will be one new kernel (4.4.20, when released: apt-get install linux-image-dev-marvell linux-dtb-dev-marvell ) which is supported by a SolidRun and needs to be tested if it's any better. Based on my tests all three kernels needs extra fixing and I thought to include more fixes into this release but their lead developer is having vacations at this moment and I could not retrieve any valuable data. After this update, it comes another and another ... :)
Please just confirm which kernels have you try: 3.10., 4.7 and 4.4.20 (yesterday build?) There are no other kernels, official / any other builds are only older that this.
I tried it on:
root@armada:~# ping 192.168.177.2
PING 192.168.177.2 (192.168.177.2) 56(84) bytes of data.
From 192.168.177.1 icmp_seq=1 Destination Host Unreachable
From 192.168.177.1 icmp_seq=2 Destination Host Unreachable
From 192.168.177.1 icmp_seq=3 Destination Host Unreachable
^C
--- 192.168.177.2 ping statistics ---
5 packets transmitted, 0 received, +3 errors, 100% packet loss, time 4002ms
pipe 3
root@armada:~# uname -a
Linux armada 4.7.3-marvell #25 SMP Wed Sep 14 19:24:33 CEST 2016 armv7l armv7l armv7l GNU/Linux
And on 4.4.20. But at this point I am worrying that I'm doing something wrong so i would like to go over the configurations I made.
this is a list of thing I change.
  1. apt-get update && apt-get upgrade
  2. enable ip forwarding in /etc/sysctl.conf
  3. adding this config  to /etc/network/interfaces
auto eth1 iface
eth1 inet static
address 192.168.177.1
netmask 255.255.255.0
  1. perform a reboot
  2. on the computer connected to the clearfog I create a static IP like this
auto eth0
iface eth0 inet static
address 192.168.177.2
gateway 192.168.177.1
  1. and perform a reboot
  2.   and then on the clearfog I try pinging 192.168.177.2 but it always gets lost.
I was wondering if these are the right settings
Thats a switched device, which means: you give your bridged device an ip, and the ports use it.
Make sure you are really using the switch, and not the SFP !
I used archlinux and it worked without problems setting the br0 up myself, give it an ip adress, register the lan1-lan6 ports to it
also: iptables -L
ethtool eth0 eth1 eth2
unfortunately only 4.4.x from clearfog supports sfp, thats how to see that it is the sfp device. if you have further problems, i can check this evening in detail. the sfp cage is (iirc) defined in the .dtb in /boot
Yes, its the pro i use. It does not matter which image you use. If you use armbian, the lan* ports should be already there for usage. If not, create (as mentioned in the PM) the bridge device via systemd with the lan* devices. It should work out of the box.
I would recommend using mii-tool, ethtool and ifconfig to check whats going on.
yeah I think I found the problem. I couldn't load the mv88e6xxx_drv module in /etc/modules. I also tried the modules in this link: http://cateee.net/lkddb/web-lkddb/NET_DSA_MV88E6XXX.html but with the same result. I send an email to SolidRun and waiting for there response ( hopefully I get something useful but i highly doubt that).
I am using latest vanilla jessie server from armbian for the clearfog pro.
EDIT 1:
after updating to the dev branch the module became available.
EDIT 2:
okay I have setup a bridge with lan1-lan6 as bridge ports and gave the bridge an IP address. But now I'm completely lost. I thought that the device behind lan1 would show up on my router but that appears not to be the case. Am I doing something wrong or is my understanding of bridges flawed? How do I communicate to the device behind lan1?
