lucab Posted June 9, 2022 Posted June 9, 2022 Hi All, On an Odroid N2+ board, I have tried to install ZFS following different suggestions I found on the web. None of them worked so far. I tried: https://forum.armbian.com/topic/19952-cant-install-kernel-headers-via-armbian-config/ https://forum.armbian.com/topic/18790-odroidhc4-with-5139-meson64-missing-zfs-modules/ https://forum.armbian.com/topic/17337-zfs-just-works-now-on-armbian-2-step-instructions-if-you-are-thick-like-me/ I installed both Armbian 22.05 Bullseye 5.10.110-meson64 first, and then Jammy 5.17. Could someone please help me? Thanks 🙂
lucab Posted July 11, 2022 Author Posted July 11, 2022 Update: still not working. Fresh installation of Armbian_22.05.4_Odroidn2_bullseye_current_5.10.123.img sudo apt-get update sudo apt-get dist-upgrade sudo reboot sudo armbian-config -> software -> Headers_install sudo armbian-config -> software -> Source_install sudo apt install zfs-dkms zfsutils-linux Get error: Setting up zfsutils-linux (2.0.3-9) ... modprobe: FATAL: Module zfs not found in directory /lib/modules/5.10.123-meson64 zfs-import-scan.service is a disabled or a static unit, not starting it. Job for zfs-load-module.service failed.
Igor Posted July 15, 2022 Posted July 15, 2022 On 7/11/2022 at 11:26 PM, lucab said: Fresh installation of Armbian_22.05.4_Odroidn2_bullseye_current_5.10.123.img It was only tested with Jammy: https://forum.armbian.com/ytopic/19336-armbian-ubuntu-2204-jammy-with-zfs-211-for-odroid-hc4/ Debian package base might need some additional fixing.
lucab Posted July 19, 2022 Author Posted July 19, 2022 I see. Hopefully soon it will be available for odroid N2+. Thanks @Igor for answering and for the great work and support. Luca
Igor Posted July 19, 2022 Posted July 19, 2022 4 hours ago, lucab said: Hopefully soon it will be available for odroid N2+. For Odroid N2+ this works exactly the same, but you need to use EDGE kernel. https://www.armbian.com/odroid-n2/ ... as the bug is elsewhere.
Greek64 Posted July 27, 2022 Posted July 27, 2022 On 7/11/2022 at 11:26 PM, lucab said: Setting up zfsutils-linux (2.0.3-9) ... modprobe: FATAL: Module zfs not found in directory /lib/modules/5.10.123-meson64 zfs-import-scan.service is a disabled or a static unit, not starting it. Job for zfs-load-module.service failed. There should be another error before this for the failed `zfs-dkms` installation. Probably something along the lines of "configure: error: Unable to build an empty module." That happens because the kernel header package "linux-headers-current-meson64" is missing a file needed to build out-of-tree modules (dkms). Check if "module.lds" exists under "/usr/src/linux-headers-5.10.123-meson64/scripts/". If not, you have found the root of your problem. The fix is somewhat simple. You can just construct your own "module.lds" and place it in the above directory. The file contents consists of following: The contents of the official "module.lds.S" file of the 5.10 kernel source (can be found here) without the last "#include" line The contents of the architecture specific "module.lds.h" header file. Odroid N2+ should be arm64, so the contents of "/usr/src/linux-headers-5.10.123-meson64/arch/arm64/include/asm/module.lds.h" For my Odroid HC4 the module.lds looks as follows: /* * Common module linker script, always used when linking a module. * Archs are free to supply their own linker scripts. ld will * combine them automatically. */ SECTIONS { /DISCARD/ : { *(.discard) *(.discard.*) } __ksymtab 0 : { *(SORT(___ksymtab+*)) } __ksymtab_gpl 0 : { *(SORT(___ksymtab_gpl+*)) } __ksymtab_unused 0 : { *(SORT(___ksymtab_unused+*)) } __ksymtab_unused_gpl 0 : { *(SORT(___ksymtab_unused_gpl+*)) } __ksymtab_gpl_future 0 : { *(SORT(___ksymtab_gpl_future+*)) } __kcrctab 0 : { *(SORT(___kcrctab+*)) } __kcrctab_gpl 0 : { *(SORT(___kcrctab_gpl+*)) } __kcrctab_unused 0 : { *(SORT(___kcrctab_unused+*)) } __kcrctab_unused_gpl 0 : { *(SORT(___kcrctab_unused_gpl+*)) } __kcrctab_gpl_future 0 : { *(SORT(___kcrctab_gpl_future+*)) } .init_array 0 : ALIGN(8) { *(SORT(.init_array.*)) *(.init_array) } __jump_table 0 : ALIGN(8) { KEEP(*(__jump_table)) } } SECTIONS { .plt 0 : { BYTE(0) } .init.plt 0 : { BYTE(0) } .text.ftrace_trampoline 0 : { BYTE(0) } } Since you have the same kernel and also the same architecture the file contents should work as is also for you. As for why this file is missing, the reason is some upstream kernel module compiling changes, which affected armbian build scripts because the Makefiles were removing the "module.lds" file on "make clean". This SHOULD have been fixed with AR-608 / #2545. Maybe @Igor could shed some light on which kernel version will have the "module.lds" files included in the header package (If I understood it correctly, the header packages for 5.15.y kernels do not have this problem).
lucab Posted August 3, 2022 Author Posted August 3, 2022 Thanks all for your suggestions and help. I think I will wait for a stable release as I don't want to risk to do this procedure all the time a new kernel update is available. Thanks, Luca
lucab Posted September 9, 2022 Author Posted September 9, 2022 Hi All. I have just installed Armbian v22.08 (2022-08-30). It says it has zfs support, so I have tried running sudo apt-get install zfsutils-linux zfs-dkms. It returns an error. So I tried to follow @Greek64 suggestion, but the path /usr/src/ is empty. I used armbian-config to install software -> header_install. The progress bar appears but it exits immediately, like nothing happened. Any suggestions? Thanks, Luca
