  On 9/1/2022 at 1:52 PM, blondu said:
2.I have a Wi-Fi 6E 2x2 MT7921K M.2 module renamed AMD RZ608 from GMKtec NucBox 5 does it work in M.2?
Expand
I haven't checked, but maybe for it to work, you need to first change the DTB and switch to NVMe\PCIe mode. But it is better to check with the manufacturer.
Posted (edited)
I also did the test, look at the results:http://ix.io/49rV
PS
I installed Station OS which according to the instructions was supposed to have multiboot but it doesn't on M3 so I lost the first test 2 days ago without ssd m2 sata.
Edited by blondu
Ok, I'm also waiting for a 128Gb Samsung module.
The boot mode is more strange for me for the ssd, it reads the boot from the MMCe if I don't have a boot directory in the eMMC with the correct partition id, it doesn't boot. is it possible to boot directly from the SSD?
Expand
This is as it should be, this is the right launch option. For direct launch from SATA\NVMe, support for these devices in u-boot is needed, at the moment there is no such thing.
Posted (edited)
I opted for a smaller capacity SSD and because I don't know what consumption it supports on the M2 slot
Does the fan support RPM management in Armbian?
Edited by blondu
I tried to compile drivers for 0572:c688 Conexant Systems (Rockwell), Inc. Geniatech T230 DVB-T2 TV Stick, I installed a generic header and received an error at:
Preparing to compile for kernel version 5.10.66
File not found: /lib/modules/5.10.66-station-m3/build/.config at ./scripts/make_kconfig.pl line 33, <IN> line 4.
make[1]: *** [Makefile:376: alliesconfig] Error 2
I mention that I have the rk35**s linux sdk can it be solved?
Expand
Which header package have you installed, from a shared network repository? This package will not work with the core for M3. You can build your kernel (change the configuration) directly on the M3 in the Armbian system, clone my GIT and run the generally accepted kernel assembly procedure in it (with the choice of kernel configuration). But be prepared that the necessary driver may not be in the source code or it will require a fix for proper assembly.
It surpasses me on the hardware side, I'm much more advanced...
I have attached the necessary drivers.
If I have some steps to follow, I'm willing to try, On odroid N2 I managed to compile drivers and 2 devices work perfectly: T230 DVB-T2 and tbs5520se with compiled oscam.
my_configFetching info...
Posted (edited)
With SSD M.2 PCIe2.0 interface the writing and reading speeds are much lower.
I tested here:http://ix.io/49Y3 cu ssd SAMSUNG MZALQ128HBHQ-000L2 and with gnome-disk-utility.
ady@station-m3:~$ sudo hdparm -Tt /dev/nvme0n1p1
/dev/nvme0n1p1:
 Timing cached reads:   3388 MB in  2.00 seconds = 1694.54 MB/sec
 Timing buffered disk reads: 1104 MB in  3.00 seconds = 367.64 MB/sec
Edited by blondu
I did a little test comparison of SATA and NVMe on M3. Yes, the speed of NVMe is lower than SATA. I think this is due to the fact that the rk3588s chip has "stripped down" functionality for PCIe\NVMe, so the speed is lower and therefore it is preferable to use SATA mode by default. SATA features are quite enough for fast work, it is significantly better than all Amlogic. For example, the complete assembly and packaging in the XZ format of the Armbian image on M3 takes only 20-30 minutes, which is faster than the intel shit i5-i7, which cost 2-3 times more expensive.
Excellent!
What OS can be added and how is it selected?
I couldn't boot from the SSD.
I saw some selections in Armbian config but I didn't succeed...
Thanks.
Posted (edited)
  On 9/8/2022 at 4:51 PM, blondu said:
367.64 MB/sec
Expand
Really low numbers.
1) hdparm uses 128K block size to test which was a lot last century when whoever hardcoded this in hdparm but today it's just a joke. Use iozone or fio with larger block sizes
2) Armbian doesn't care since years about low-level optimizations. Better search for 'io_is_busy' and 'dmc/governor' to get full speed (both storage and CPU performance or at least a 2000 higher 7-zip score): https://github.com/ThomasKaiser/Knowledge/blob/master/articles/Quick_Preview_of_ROCK_5B.md
3) check 'cat /sys/devices/system/cpu/cpufreq/policy?/ondemand/io_is_busy' – if I/O is processed by cpu6 or cpu7 it might be a lot slower compared even to the little cores
4) A PCIe Gen2 lane allows for 5 GT/s, SATA 6Gbps has 120% the data rate and both use 8b10b coding. As such SATA should be faster with sequential transfer speeds
5) Sequential transfer speeds are BS if it's about an OS drive since here random I/O matters. And due to SATA relying on AHCI made for spinning rust last century NVMe should outperform SATA even in a single Gen2 lane config and even if silly 'benchmarks' like hdparm draw a different picture.
6) What is 'cat /sys/module/pcie_aspm/parameters/policy' telling?
Edited by tkaiser
Expand
While there is no support for HDMI output, the choice of OS\other kernel is possible in extlinux.conf and in EFI\GRUB, but only through the UART console. To add another kernel or OS, you can manually edit extlinux.conf, for EFI, the addition can be done as standard, as on a regular PC, add the necessary kernel files and run the GRUB update procedure, os_probe will find and add the necessary menu options. Important, I haven't managed to add support for installation on eMMC\NVMe in EFI mode yet, so when starting the installation, extlinux.conf mode will be used.
Expand
I checked the installation on SATA and everything works for me without any problems (now I have Armbian installed on SATA and I'm starting to build images for M3 on it (it works very fast). When starting the installation, select the bootloader placement mode on eMMC \ system on SATA\NVMe. Please note, the installation works only in extlinux.conf mode.
Due to the peculiarities of working with new media, when starting the installation on SATA\NVMe, the disk must be prepared in advance, run gparted and create an MBR (dos) partition table and it is desirable to create a partition with ext4. After that, you can run the armbian-config utility and perform the installation.
This can be fixed, but I still feel sorry to waste time on it, with what, in the near future I plan to rework the installation process for EFI mode.
Expand
How did you perform this comparison? Looking only at sequential transfer speeds? Or checking random I/O (which matters way more on an OS drive or when building software)? What does /sys/module/pcie_aspm/parameters/policy look like? powersave, right?
And for a quick comparison of schedutil, performance, ondemand and ondemand with io_is_busy see the comments below https://github.com/radxa/kernel/commit/55f540ce97a3d19330abea8a0afc0052ab2644ef
Expand
I made a simple dumb comparison of running these combinations on two SATA and NVMe modules (both modules have an exact clone of the same system, the difference is only in DTB).
fio --name=write --ioengine=libaio --iodepth=4 --rw=write --bs=1M --direct=1 --size=2G --numjobs=30 --runtime=60 --group_reporting --filename=/mnt/tmp/test
fio --name=read --ioengine=libaio --iodepth=4 --rw=read --bs=1M --direct=1 --size=2G --numjobs=30 --runtime=60 --group_reporting --filename=/mnt/tmp/test
fio --name=randwrite --ioengine=libaio --iodepth=4 --rw=randwrite --bs=4K --direct=1 --size=2G --numjobs=30 --runtime=60 --group_reporting --filename=/mnt/tmp/test
fio --name=randread --ioengine=libaio --iodepth=4 --rw=randread --bs=4K --direct=1 --size=2G --numjobs=30 --runtime=60 --group_reporting --filename=/mnt/tmp/test
Expand
But your image or lets better say the kernel you're using is made for Android and lacks optimisations.
As for NVMe what about
echo default >/sys/module/pcie_aspm/parameters/policy
or removing CONFIG_PCIEASPM_POWERSAVE=y from kernel config?
And for I/O performance in general this would be needed since with my code fragments from half a decade ago that are still part of Armbian the 3rd CPU cluster isn't adjusted properly:
prefix="/sys/devices/system/cpu"
CPUFreqPolicies=($(ls -d ${prefix}/cpufreq/policy? | sed 's/freq\/policy//'))
if [ ${#CPUFreqPolicies[@]} -eq 1 -a -d "${prefix}/cpufreq" ]; then
	# if there's just a single cpufreq policy ondemand sysfs entries differ
	CPUFreqPolicies=${prefix}
fi
for i in ${CPUFreqPolicies[@]}; do
	affected_cpu=$(tr -d -c '[:digit:]' <<< ${i})
	echo ondemand >${prefix}/cpu${affected_cpu:-0}/cpufreq/scaling_governor
	echo 1 >${i}/cpufreq/ondemand/io_is_busy
	echo 25 >${i}/cpufreq/ondemand/up_threshold
	echo 10 >${i}/cpufreq/ondemand/sampling_down_factor
	echo 200000 >${i}/cpufreq/ondemand/sampling_rate
done
And based on sbc-bench results shared here the dmc/dfi nodes are enabled in device-tree (defaulting to dmc_ondemand) and as such this would restore 'full performance':
echo performance >/sys/class/devfreq/dmc/governor
Expand
So far, this is the only option that can be used for full-fledged work. The main core still has minimal support, it is not enough even for minimal work.
Expand
I do not have access to the device yet (it is involved in a large amount of work). After the release, I will check these options.
Expand
Sorry, I didn't understand what needs to be done? Is this code to include in scripts ?
Posted (edited)
Expand
It's not about mainline kernel vs. BSP kernel but the latter having settings that might fit for Android (use cases like watching video, playing games) but not for Linux.
You seem to be using these defaults without questioning them. Rockchip's BSP kernel defaults to powersave for ASPM (Active State Power Management) which of course negatively affects NVMe performance. As such you need to either eliminate CONFIG_PCIEASPM_POWERSAVE=y from kernel config or need to execute somewhere after booting:
Also the BSP kernel when the dmc/dfi device-tree nodes are enabled (seems to be the case with your RK3588 kernel fork since the 7-zip scores you and @blondu are sharing are below 14800 while they could be around 16500) defaults to dmc_ondemand governor which can be changed by doing this:
(similar way as I've done this for RK3399 years ago: https://github.com/armbian/build/blob/fdf73a025ba56124523baefaf705792b74170fb8/packages/bsp/common/usr/lib/armbian/armbian-hardware-optimization#L241-L244 )
And this here:
fi
done
is the exact replacement for lines 81-89 in armbian-hardware-optimization: https://github.com/armbian/build/blob/fdf73a025ba56124523baefaf705792b74170fb8/packages/bsp/common/usr/lib/armbian/armbian-hardware-optimization#L81-L89
Without this I/O performance with Armbian sucks on a variety of boards for example ODROID N2/N2+, VIM3 or now the RK3588/RK3588S based boards. Unfortunately @lanefu seems to be way too biased or limited in his thinking to understand this when he creates bizarre tickets that are rotting around somewhere: https://armbian.atlassian.net/browse/AR-1262
I really don't care whether these fixes will be incorporated into Armbian. But if you benchmark stuff the settings should be adjusted accordingly. And we (we as a broader community – not this place here) already know how ASPM settings negatively affect performance of PCIe devices (like for example NVMe SSDs): https://forum.radxa.com/t/rock-5b-debug-party-invitation/10483/86?u=tkaiser, we know which role io_is_busy has and what the benefits and drawbacks of the chosen dmc governor are.
A quality NVMe SSD even when just connected with a single Gen2 lane should always outperform any SATA SSD if it's about what really matters: random I/O. If the SSD is cheap garbage or the settings are garbage it might look differently.
Edited by tkaiser
