talraash Posted February 3, 2017 Share Posted February 3, 2017 ran this command >> $ cpufreq-info got "command not found" Don't type this "$" symbol ) Link to comment Share on other sites More sharing options...
balbes150 Posted February 3, 2017 Author Share Posted February 3, 2017 Program to capture video "kazam" (under multimedia). 1 Link to comment Share on other sites More sharing options...
balbes150 Posted February 3, 2017 Author Share Posted February 3, 2017 Two test image (20170203) with different DE - XFCE and MATE. Link to comment Share on other sites More sharing options...
clarkss12 Posted February 3, 2017 Share Posted February 3, 2017 Two test image (20170203) with different DE - XFCE and MATE. I am downloading now, what will be the password to use with putty??? thanks. Edit: Sorry, thought it was a new firmware, but I had already installed this one. Unfortunately, I could not get any password to work from putty on this version. Edit 2: Sorry, did not look into the "test" folder, downloading it now........ thanks again Link to comment Share on other sites More sharing options...
Shimon Posted February 3, 2017 Share Posted February 3, 2017 Test new image 20170202 CPU_OVERCKLOCK scaling work good out of box, but i don't see any performance(and temperature, of course we know it few months from odroid forum) difference between cpufreq_max = 2GHz, 1.75 and 1.53. OK then, no surprises here - thanks for trying Link to comment Share on other sites More sharing options...
pulpoff Posted February 4, 2017 Share Posted February 4, 2017 Try to use the dtb file from the image LE (the LE with which you work). I tried that already, took it from /Firmware on the booted image, no boot with it neither Link to comment Share on other sites More sharing options...
balbes150 Posted February 4, 2017 Author Share Posted February 4, 2017 I tried that already, took it from /Firmware on the booted image, no boot with it neither Start LE, connect to the TV box via SSH, run the command "fw_printenv", copy the result here. Link to comment Share on other sites More sharing options...
balbes150 Posted February 4, 2017 Author Share Posted February 4, 2017 The difference in temperature decrease is noticeable only with a good cooling system. The problem with all TV boxes - very bad cooling system when shipped from the factory. Closed plastic case, very small heatsink, bad thermal pad / tape. All of this gives a very large thermal inertia (heat dissipation processor has long since reduced, but the overall temperature is reduced very slowly, the heat no where to go). I ran some tests. 1. Staffing the state TV of the box (no changes in the hull and the cooling system). 2. Without housing, but the cooling system is normal (did not change the heatsink and thermal pads). 3. Without housing, replace the thermal pads on kachestvenno thermal grease. 4. Without housing, high-quality thermal grease, replacement of standard radiator is increased. 5. Without housing, thermal grease, increased radiator + fan. And now can definitely say the potential of all platforms (S905 S905X S912), is severely limited by the poor heat dissipation system. 5 are very well visible link to reduce the frequency and temperature decrease from maximum load to minimum. The difference is 10-20 Degrees for a long period of time. The worse the heat dissipation , the less noticeable the difference between the minimum and maximum temperature. https://yadi.sk/i/AXsVyyk-3CnRGN 1 Link to comment Share on other sites More sharing options...
lvmc Posted February 4, 2017 Share Posted February 4, 2017 The difference in temperature decrease is noticeable only with a good cooling system. The problem with all TV boxes - very bad cooling system when shipped from the factory. Closed plastic case, very small heatsink, bad thermal pad / tape. All of this gives a very large thermal inertia (heat dissipation processor has long since reduced, but the overall temperature is reduced very slowly, the heat no where to go). I ran some tests. 1. Staffing the state TV of the box (no changes in the hull and the cooling system). 2. Without housing, but the cooling system is normal (did not change the heatsink and thermal pads). 3. Without housing, replace the thermal pads on kachestvenno thermal grease. 4. Without housing, high-quality thermal grease, replacement of standard radiator is increased. 5. Without housing, thermal grease, increased radiator + fan. And now can definitely say the potential of all platforms (S905 S905X S912), is severely limited by the poor heat dissipation system. 5 are very well visible link to reduce the frequency and temperature decrease from maximum load to minimum. The difference is 10-20 Degrees for a long period of time. The worse the heat dissipation , the less noticeable the difference between the minimum and maximum temperature. https://yadi.sk/i/AXsVyyk-3CnRGN I don't have as many Amlogic boards as shown on your picture to test. A good test would be to run cpuburn on the 5 cooling cases you mentioned. I think it is very important to all of us know the average temperature on any scenario. https://github.com/ssvb/cpuburn-arm Here, on my side, by running GT1 with original enclosure and cpuburn running for 5 days I'm stuck at 70~74ºC with environment temperature between 20 and 28ºC. Link to comment Share on other sites More sharing options...
balbes150 Posted February 4, 2017 Author Share Posted February 4, 2017 Just an hour ago, I got Khadas VIM. A photo of the size comparison circuit boards and the cooling system, I replaced a new one. Now not large explanations to the photo. Top row, left to right. 1. Spot i7 (s905 1\8) radiator replaced (taken from the Vega models S95 Telos) 2. Spot Pro i7 (s905x 2\16) is the standard radiator (I replaced only the thermal paste thermostats) 3. Vega S96 (s912 2\16) cooling system default, but I'll have to redo it (after testing the native system). 4. Vega S95 (s905 2\16) the radiator was replaced by the model from the graphics card (not visible in the photo, but it is above the regular radiator). Second row (left to right). 5. Spot i5 (s805 1\8) in the delivery state there is no radiator (to be installed in the future). 6. Transpeed (s805 2\8 stated in the sale 2 GB of RAM, but in fact I haven't been able to verify this and there are big doubts about this) the cooling system will be reworked in the future. 7. Tronsmart MIII Plus (s812 2\16) radiator staff (I will probably add a fan, while this is not necessary). Right edge from top to bottom (starting from the second from the top) 8. RPi3 (next two radiator from the kit), the model has not yet been tested, but the cooling system is clearly not sufficient. 9. Odroid C2 (s905 2\SD 8-64) standard radiator, I plan to add a fan. 10. Orange Pi PC2 (H5 1\8mb) standard cooling system, there will be definitely added on a heatsink and fan. 11 Khadas VIM (s905x 2\16) the cooling system I'd have to add a radiator with fan. In addition to the boards in the photo set of various fan and radiator to be used for tests. By the way, there is a proposal to make a topic discussion of cooling systems in a separate topic (if the moderators don't mind). Link to comment Share on other sites More sharing options...
clarkss12 Posted February 4, 2017 Share Posted February 4, 2017 Thanks Balbes150 for the valuable information on the cooling. I will be watching closely to see how you modify the cooling, and more importantly, the performance increase. The only tangible effects that I am looking for, is how my servers perform. In other words, I am using my boxes (Amlogic S905X and Pine64) as Plex and Emby servers. Right now, they cannot transcode subtitles on the fly, it the cooling enhancements and therefore performance can cause my devices to transcode on the fly, it will be a real game changer. Just my 2 cents. Link to comment Share on other sites More sharing options...
balbes150 Posted February 5, 2017 Author Share Posted February 5, 2017 Update images. (20170205) TEST Changes. 1. Added a lot of kernel modules for peripheral devices (DVB DTV Net Touchscreen etc) 2. Added script dd_backup_x to create a compressed copy of the internal memory (by xXx details about the script on the forum armbian in the subject s905\s905x) 3. Added a script to evaluate the performance of the CPU aml_cpu.sh in the /root directory 4. In the image MATE added a number of packages (screensaver, screenshot, multimedia, utility etc) 1 Link to comment Share on other sites More sharing options...
Nofan Tasi Posted February 6, 2017 Share Posted February 6, 2017 Update images. (20170205) TEST Changes. 1. Added a lot of kernel modules for peripheral devices (DVB DTV Net Touchscreen etc) 2. Added script dd_backup_x to create a compressed copy of the internal memory (by xXx details about the script on the forum armbian in the subject s905\s905x) 3. Added a script to evaluate the performance of the CPU aml_cpu.sh in the /root directory 4. In the image MATE added a number of packages (screensaver, screenshot, multimedia, utility etc) Thanks for new .config ! - DVB-T stick recognized - webcam recognized (psychedelic colors though :-)) minimx-g ~ # lsmod Module Size Used by bluetooth 243731 0 6lowpan_iphc 5767 1 bluetooth nbd 9769 1 snd_usb_audio 118514 0 snd_hwdep 6845 1 snd_usb_audio snd_usbmidi_lib 20367 1 snd_usb_audio snd_rawmidi 18862 1 snd_usbmidi_lib uvcvideo 70360 0 videobuf2_vmalloc 3059 1 uvcvideo dvb_usb_dtt200u 24406 1 dvb_usb 17207 1 dvb_usb_dtt200u mali 195629 0 hid_apple 5538 0 Link to comment Share on other sites More sharing options...
newc Posted February 8, 2017 Share Posted February 8, 2017 just tested latest armbian image Armbian_5.24_Amlogic-s905x_Debian_jessie_3.14.29_20161223.img.xz on my x96 tv box (s905x) 1) first boot, loging under root and creatig new user account is ok 2) After reboot the screen resolution is strange, i can see two columns of text next to each other. Any idea on how to fix screen resolution change after second boot? Can i change it to mode which is being used in first boot? SSH works well so i can change some configs remotely if that would solve the problem.... @jan.pal ,hello I'm a newbie and probably asking silly questions. I have the same x96 tv box as You and I can not boot ubuntu image.Can You please explain what do I need to do to boot linux on this board? Link to comment Share on other sites More sharing options...
Tommy21 Posted February 8, 2017 Share Posted February 8, 2017 Hi to you all! I want to backup all of the apps i have installed, so i can restore it if i use another distribution, without going one by one and searching through synaptic or software center. I have found Aptik, but it gives me errors, saying i have unmet dependencies, i can't install it. Maybe even some automated script that would mark all of the software i want with its dependencies in synaptic would help, but all with software of my selection, without DE specific apps. Is there any arm working software that can backup installed apps on a flash drive, external hdd, or maybe even cloud backup? Link to comment Share on other sites More sharing options...
balbes150 Posted February 8, 2017 Author Share Posted February 8, 2017 I do not see in network repositories the package "aptik". Are you trying to install a third-party package ? Link to comment Share on other sites More sharing options...
Tommy21 Posted February 8, 2017 Share Posted February 8, 2017 Yes, it's not in repositories, i added it but with no luck, is there any similar software for arm? Link to comment Share on other sites More sharing options...
balbes150 Posted February 8, 2017 Author Share Posted February 8, 2017 A little test of the effectiveness of active cooling and the potential use as a media center with KODI. Install network of rap KODI (15.2). Prescribed in the file .xinitrc to run KODI (straight run only KODI, without DM). Started the system from USB stick on i7Pro (PCB without housing, standard radiator + USB fan with separate power supply). Mode 720. Playback test clips (from the image Armbian) occurs in fullscreen mode. The smoothness of the video is not the best, but I was interested in temperature. Connection via UART console , run "armbian -m". Monitoring shows the average temperature when playing video 49-55 Degrees, a frequency of about 2000. The temperature in the idle drops to 35-38 degrees (at a frequency of 250). Thus it is possible to consider this option - a very early alpha for Libreelec on the basis of the usual Ubuntu, with advantages in a standard package management system and the ability to run as required graphical desktop (XFCE MATE DM etc) with all the advantages of standard office systems. I think if we solve the problem of not properly start the graphical environment for the authorization of entrance and selection of used DM (xdm lightdm lxdm etc), then you can create an easy to use universal system. If you need media center - chose KODI (or other similar systems), you need the desktop version - chose a convenient DM (XFCE MATE KDE, LXQT LXDM etc). 2 Link to comment Share on other sites More sharing options...
Shimon Posted February 8, 2017 Share Posted February 8, 2017 a frequency of about 2000 That's 1536 actually, never mind what the evil blob says. http://forum.odroid.com/viewtopic.php?p=157441#p157441 Link to comment Share on other sites More sharing options...
Tommy21 Posted February 8, 2017 Share Posted February 8, 2017 I have connected Amd cpu fan with usb cable, it's 12V fan that now runs at 5V, it stands above cpu, i have made a hole on the upper side of Khadas Vim case. Although the fan doesn't ran at full speed, it makes a big difference when running Linux, i can finally have more apps or tabs opened in it. For now, only thing i have noticed that it's hard to play yt videos, temperatures do rise up and Vim is struggling to play videos, but this is hw acceleration problem. They didn't rise as quickly as before, but eventually the cpu will get much hot when using yt, i have exited when it reached 60°C. Most of the time the cpu was between 35-50°C, and that's ok, i'll live with it before official fan becomes available. And Balbes, you don't know about any backup app, i know i am boring, but i want to be sure! Link to comment Share on other sites More sharing options...
balbes150 Posted February 9, 2017 Author Share Posted February 9, 2017 1. In case you need to add space for air flow. For this, you can cut the middle strap, stacked housing, leaving only the corners for fixing the height. The flow direction of the fan should be pulling air out of the case. Soon I hope to post a photo of how I altered the case and installed a fan. 2. I don't know the programs for this selective backup and restore system. The only option is to selectively replace existing system files that have changed in the new version. Link to comment Share on other sites More sharing options...
Shimon Posted February 9, 2017 Share Posted February 9, 2017 Forgot to mention, iotop stopped working (IIRC): Could not run iotop as some of the requirements are not met: - Linux >= 2.6.20 with - I/O accounting support (CONFIG_TASKSTATS, CONFIG_TASK_DELAY_ACCT, CONFIG_TASK_IO_ACCOUNTING) Link to comment Share on other sites More sharing options...
pulpoff Posted February 10, 2017 Share Posted February 10, 2017 Start LE, connect to the TV box via SSH, run the command "fw_printenv", copy the result here. LibreELEC:~ # fw_printenv EnableSelinux=enforcing aml_dt=gxl_p212_1g baudrate=115200 bootcmd=run start_autoscript;run storeboot; bootdelay=1 bootfromnand=0 bootfromrecovery=0 cmdline_keys=if keyman init 0x1234; then if keyman read usid ${loadaddr} str; then setenv bootargs ${bootargs} androidboot.serialno=${usid};fi;if keyman read mac ${loadaddr} str; then setenv bootargs ${bootargs} mac=${mac} androidboot.mac=${mac};fi;if keyman read deviceid ${loadaddr} str; then setenv bootargs ${bootargs} androidboot.deviceid=${deviceid};fi;fi; cvbs_drv=0 cvbsmode=576cvbs display_bpp=16 display_color_bg=0 display_color_fg=0xffff display_color_index=16 display_height=1080 display_layer=osd1 display_width=1920 dtb_mem_addr=0x1000000 ethaddr=00:15:18:01:81:31 factory_reset_poweroff_protect=echo wipe_data=${wipe_data}; echo wipe_cache=${wipe_cache};if test ${wipe_data} = failed; then run init_display; run storeargs;if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash;fi; if test ${wipe_cache} = failed; then run init_display; run storeargs;if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash;fi; fb_addr=0x3d800000 fb_height=1080 fb_width=1920 fdt_high=0x20000000 firstboot=0 gatewayip=10.18.9.1 hdmimode=1080p60hz hostname=arm_gxbb init_display=osd open;osd clear;imgread pic logo bootup $loadaddr;bmp display $bootup_offset;bmp scale initargs=rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 ipaddr=10.18.9.97 jtag=apao loadaddr=1080000 netmask=255.255.255.0 outputmode=1080p60hz preboot=run factory_reset_poweroff_protect;run upgrade_check;run init_display;run storeargs;run upgrade_key;run switch_bootmode; recovery_from_flash=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if imgread kernel ${recovery_part} ${loadaddr} ${recovery_offset}; then wipeisb; bootm ${loadaddr}; fi recovery_from_sdcard=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if fatload mmc 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;if fatload mmc 0 ${loadaddr} recovery.img; then if fatload mmc 0 ${dtb_mem_addr} dtb.img; then echo sd dtb.img loaded; fi;wipeisb; bootm ${loadaddr};fi; recovery_from_udisk=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if fatload usb 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;if fatload usb 0 ${loadaddr} recovery.img; then if fatload usb 0 ${dtb_mem_addr} dtb.img; then echo udisk dtb.img loaded; fi;wipeisb; bootm ${loadaddr};fi; recovery_offset=0 recovery_part=recovery sdc_burning=sdc_burn ${sdcburncfg} sdcburncfg=aml_sdc_burn.ini serverip=10.18.9.113 start_autoscript=if usb start ; then run start_usb_autoscript;fi;if mmcinfo; then run start_mmc_autoscript;fi; start_mmc_autoscript=if fatload mmc 0 1020000 s905_autoscript; then autoscr 1020000; fi start_usb_autoscript=if fatload usb 0 1020000 s905_autoscript; then autoscr 1020000; fi storeargs=setenv bootargs ${initargs} androidboot.selinux=${EnableSelinux} logo=${display_layer},loaded,${fb_addr},${outputmode} maxcpus=${maxcpus} vout=${outputmode},enable hdmimode=${hdmimode} cvbsmode=${cvbsmode} hdmitx=${cecconfig} cvbsdrv=${cvbs_drv} androidboot.firstboot=${firstboot} jtag=${jtag}; setenv bootargs ${bootargs} androidboot.hardware=amlogic;run cmdline_keys; storeboot=if imgread kernel boot ${loadaddr}; then bootm ${loadaddr}; fi;run update; switch_bootmode=get_rebootmode;if test ${reboot_mode} = factory_reset; then run recovery_from_flash;else if test ${reboot_mode} = update; then run update;else if test ${reboot_mode} = cold_boot; then run try_auto_burn; fi;fi;fi; try_auto_burn=update 700 750; update=run usb_burning; run sdc_burning; if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash; upgrade_check=echo upgrade_step=${upgrade_step}; if itest ${upgrade_step} == 3; then run init_display; run storeargs; run update;else fi; upgrade_key=if gpio input GPIOAO_2; then echo detect upgrade key; sleep 3;if gpio input GPIOAO_2; then run update; fi;fi; upgrade_step=2 usb_burning=update 1000 wipe_cache=successful wipe_data=successful LibreELEC:~ # just noticed that the remote is not working with libreelec, only usb mouse/keyb.. Link to comment Share on other sites More sharing options...
balbes150 Posted February 10, 2017 Author Share Posted February 10, 2017 @pulpoff What version of the images You tried to run ? Have you tried to start the system without manually copying the dtb (without the file "dtb.img") ? You have tried to use as a USB flash drive ? Link to comment Share on other sites More sharing options...
Shimon Posted February 12, 2017 Share Posted February 12, 2017 @balbes Are the VESA modes from vegas95_init.sh meant to be used in s905_autoscript.cmd or is that some generic armbian stuff? I ended up with green screen and no visible console trying to set 1280x1024p60Hz Link to comment Share on other sites More sharing options...
balbes150 Posted February 13, 2017 Author Share Posted February 13, 2017 Kernel 3.14.29 - only supports screen resolution 720 and 1080. Kernel - 3.14.79 - supports many different screen resolutions (list of resolutions can be viewed in the file /boot/vegas95_init.sh). To enable other screen resolutions need to regenerate the startup script s905_autoscript. The details are in this thread , post #461. Link to comment Share on other sites More sharing options...
Shimon Posted February 13, 2017 Share Posted February 13, 2017 Kernel 3.14.29 - only supports screen resolution 720 and 1080. Kernel - 3.14.79 - supports many different screen resolutions (list of resolutions can be viewed in the file /boot/vegas95_init.sh). To enable other screen resolutions need to regenerate the startup script s905_autoscript. The details are in this thread , post #461. Are you sure it's supposed to work? I was using the Armbian_5.24_Vegas95_Ubuntu_xenial_3.14.79_20160125 image for this test and it ends up with no console, as described. Moreover, you didn't include the dtb file for Mini MX III which was present in the github repo last year. I had to use a local copy. Link to comment Share on other sites More sharing options...
balbes150 Posted February 13, 2017 Author Share Posted February 13, 2017 It works for me. Link to comment Share on other sites More sharing options...
Nofan Tasi Posted February 13, 2017 Share Posted February 13, 2017 Are you sure it's supposed to work? I was using the Armbian_5.24_Vegas95_Ubuntu_xenial_3.14.79_20160125 image for this test and it ends up with no console, as described. Moreover, you didn't include the dtb file for Mini MX III which was present in the github repo last year. I had to use a local copy. I remember adding following to /boot/vegas95_init.sh before common_display_setup for 3.14.79 # 1920 1080 32 60 shows green echo 1 > /sys/class/amhdmitx/amhdmitx0/output_rgb note that this was specific to my 1920 1080 32 60 setup The screen would now turn from green to black. And, in my case, I also eventually reach console. Today I mostly run 3.14.29 again. Link to comment Share on other sites More sharing options...
Shimon Posted February 13, 2017 Share Posted February 13, 2017 OK, I've found the culprit. VESA modes do work fine, indeed. For some reason, adding additional commands to my rc.local after the /boot/vegas95_init.sh invocation, interfered with setting the resolution somehow. Link to comment Share on other sites More sharing options...
