xXx Posted June 4, 2017 Share Posted June 4, 2017 Tried "https://yadi.sk/d/pHxaRAs-tZiei/Test/META-MESON/S905.dtb" Wifi worked after a few retries: Spoiler [Sun Jun 4 14:06:29 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:06:30 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:06:51 2017] meson8b-dwmac c9410000.ethernet eth0: Link is Down [Sun Jun 4 14:07:22 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:07:23 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:07:37 2017] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [Sun Jun 4 14:07:37 2017] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [Sun Jun 4 14:07:37 2017] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [Sun Jun 4 14:07:37 2017] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=-1) [Sun Jun 4 14:07:37 2017] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW [Sun Jun 4 14:07:37 2017] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [Sun Jun 4 14:07:37 2017] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [Sun Jun 4 14:07:37 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:07:39 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:07:39 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:07:41 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:08:03 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:08:04 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:08:36 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:08:37 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:09:19 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:09:20 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:09:42 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:09:44 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:09:49 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:09:51 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:09:56 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:09:57 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:10:03 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:10:04 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:10:08 2017] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [Sun Jun 4 14:10:08 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:10:09 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:10:11 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:10:12 2017] RTL8723BS: nolinked power save enter [Sun Jun 4 14:10:24 2017] RTL8723BS: nolinked power save leave [Sun Jun 4 14:10:25 2017] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008 [Sun Jun 4 14:10:25 2017] RTL8723BS: start auth [Sun Jun 4 14:10:25 2017] RTL8723BS: auth success, start assoc [Sun Jun 4 14:10:25 2017] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !! [Sun Jun 4 14:10:25 2017] RTL8723BS: assoc success [Sun Jun 4 14:10:25 2017] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [Sun Jun 4 14:10:26 2017] RTL8723BS: send eapol packet [Sun Jun 4 14:10:26 2017] RTL8723BS: send eapol packet [Sun Jun 4 14:10:26 2017] RTL8723BS: set pairwise key camid:4, addr:xx:xx:xx:xx:xx:xx kid:0, type:AES [Sun Jun 4 14:10:26 2017] RTL8723BS: send eapol packet [Sun Jun 4 14:10:26 2017] RTL8723BS: set group key camid:5, addr:xx:xx:xx:xx:xx:xx, kid:1, type:TKIP dmesg says about my board: [Sun Jun 4 14:06:11 2017] Hardware name: Amlogic Meson GXBB P200 Development Board (DT) mpv still dies with error: Spoiler user@amlogic-s905x:~/Desktop$ mpv Test.mp4 Playing: Test.mp4 (+) Video --vid=1 (*) (h264) (+) Audio --aid=1 --alang=und (*) (aac) libEGL warning: DRI2: failed to authenticate [vo/opengl] Suspected software renderer or indirect context. [vo/opengl] Suspected software renderer or indirect context. Failed to open VDPAU backend libvdpau_sunxi.so: cannot open shared object file: No such file or directory [vo/vdpau] Error when calling vdp_device_create_x11: 1 [vo/xv] No Xvideo support found. [vo/sdl] Using opengl AO: [pulse] 44100Hz stereo 2ch float VO: [sdl] 480x266 yuv420p Segmentation fault Link to comment Share on other sites More sharing options...
balbes150 Posted June 5, 2017 Author Share Posted June 5, 2017 22 hours ago, xXx said: dmesg says about my board: What type of RAM you have eMMC or NAND ? Link to comment Share on other sites More sharing options...
balbes150 Posted June 5, 2017 Author Share Posted June 5, 2017 To ALL In the last images I removed from startup all the modules of Wi-Fi. They prevent launch on some models of TV boxes (which require other modules for WiFi). So you need to manually (via terminal) to verify which model is suitable for your TV model and enter it in the file /etc/modules (for later auto run at startup). 1 Link to comment Share on other sites More sharing options...
Stress Posted June 5, 2017 Share Posted June 5, 2017 What commands do I use to identify my wifi card? thank you Link to comment Share on other sites More sharing options...
balbes150 Posted June 6, 2017 Author Share Posted June 6, 2017 Run terminal sudo modprobe wifi_dummy or sudo modprobe dhd 1 Link to comment Share on other sites More sharing options...
Stress Posted June 6, 2017 Share Posted June 6, 2017 Thanks a lot as soon as I go out of school I try. smack Link to comment Share on other sites More sharing options...
xXx Posted June 6, 2017 Share Posted June 6, 2017 23 hours ago, balbes150 said: What type of RAM you have eMMC or NAND ? I have no idea, but... Spoiler 2 pictures = 2000 words :-D Link to comment Share on other sites More sharing options...
balbes150 Posted June 6, 2017 Author Share Posted June 6, 2017 (edited) The memory type it is easy to determine with the command "fdisk-l". If this team will see internal storage as a regular disk (mmcblkXpX), then it's eMMC. And for such memory the desired option gxbb_p200. By the way, you can accurately determine, through run your script ddbr, if he can start back up - then it's eMMC. Edited June 6, 2017 by balbes150 Link to comment Share on other sites More sharing options...
xXx Posted June 6, 2017 Share Posted June 6, 2017 @balbes150 Then it's eMMC as the carton box says: Model: Mini M8S TV BOX CPU: Amlogic S905 Quad-core 64-bit ARM Cortex-A53 up to 2GHz GPU: Penta-core ARM Mali-450 Ethernet: 100Mbps/LAN RAM: DDR3 2GB ROM: eMMC 8GB WIFI: IEEE 802.11b/g/n,2.4G BT: 4.0 Adapter: 5VDC 2A Operation System: Android 5.1 Link to comment Share on other sites More sharing options...
xXx Posted June 6, 2017 Share Posted June 6, 2017 @balbes150 The files in /boot/dtb and /boot/dtb-4.12.0-next-20170516+ are identical (checked with md5sum) There is no gxbb_p200 : all dtb's are prefixed with "meson-" So meson-gxbb-p200.dtb is the file i am looking for, of is there some other file i have to find? If yes, i will use this in the next boot. And a recommendation: For a pleasant Desktop experience, this image Armbian_5.27_S905_Ubuntu_xenial_4.12.0-next-20170516+_mate.img.xz needs some packages: ubuntu-mate-themes ( for correctly picking GTK theme that is in memory but not exists ) adwaita-icon-theme-full ( for correctly picking the mouse pointer that again is in memory but not exists ) Also there are some useless packages that left there from xfce ( thunar* for example as there exists caja already ). Spoiler 1 Link to comment Share on other sites More sharing options...
balbes150 Posted June 6, 2017 Author Share Posted June 6, 2017 1. Directories with the same dtb. Multiple directories with the same files - the result of the installation kernel, the installation script makes an advance copy with the version name in case of error. 2. You need the files where the name has the specified value, prefixed with "meson" all the same. You can check all files to find the one with which the system will work better. 3. In the last images have already appeared of the topic. 4. A list of extra files I will check, but it can be tied to the build scripts and dependencies. Thank you for the test and information, it helps to improve the system. Link to comment Share on other sites More sharing options...
xXx Posted June 6, 2017 Share Posted June 6, 2017 Started fresh with a usb stick 3.0 32GB with the latest testing image as i mentioned in previous posts. USB not always picking up the boot process and some times system starts to LibreELEC that i have in eMMC. WiFi was not working ( it was able to see networks but was not connecting ) but after 3 reboot it picked up my nwtwork. Since then it is always working as expected. ( i run "rfkill unblock wifi" between those reboots, as my wifi was Soft Blocked, but i dont know if that helped any ). Bluetooth is not working ( no adapter at all ). Video playback with mpv still segfaults. Video playback with vlc segfaults too Audio is not working. Youtube in windows looks ok, in fullscreen looks acceptable but i have no audio to compare if video/audio was in sync. The first dtb tried was meson-gxbb-p200.dtd as /boot/dtb.img That's all the info i have for now. Tomorrow i will try another dtb ( if God wants so ). 1 Link to comment Share on other sites More sharing options...
Stress Posted June 6, 2017 Share Posted June 6, 2017 I can not understand ?? Please help me to determine the type of wifi hardware of my x96. thank you Link to comment Share on other sites More sharing options...
xXx Posted June 6, 2017 Share Posted June 6, 2017 @Stress Try the command lsmod if wifi is working ( as i can see in your picture ), it should tell you the names of the active modules in your system. Link to comment Share on other sites More sharing options...
Stress Posted June 7, 2017 Share Posted June 7, 2017 This is the result, wifi what? Link to comment Share on other sites More sharing options...
balbes150 Posted June 7, 2017 Author Share Posted June 7, 2017 10 hours ago, Stress said: I can not understand ?? 1. After the first command, you need to wait 1-2 minutes and check the network connections Manager the advent of Wi-Fi. If your desired network appears, you need to open the file /etc/modules and add on a new line the name of the module wifi_dummy. After that, reboot the system, if you did everything correctly, you should automatically see the wifi network at startup. 2. If the first module (wifi_dummy) network did not work. You need to run the second command "sudo modprobe dhd" . Notice all the letters exactly as written. Capitalization is important in LINUX. dhd is not equal DHD. Other actions with the dhd module are the same as in the first point. Link to comment Share on other sites More sharing options...
Stress Posted June 7, 2017 Share Posted June 7, 2017 I want to understand wifi hardware is there, rtl81 ?? Link to comment Share on other sites More sharing options...
jakogut Posted June 9, 2017 Share Posted June 9, 2017 Hi Balbes150, I've been following this topic, and others related to your Linux development efforts on Amlogic platforms for a few weeks now. I'm curious about the function of the Fn button inside the headphone jack. When that button is held, does the device change its boot order, and use the u-boot installed on the SD card, or does it simply change the stock u-boot's environment? Is it possible to create an SD card with a custom u-boot that's bootable in an unmodified (no multiboot) TV box like the Mini M8S II simply by holding the recovery/Fn button? Link to comment Share on other sites More sharing options...
balbes150 Posted June 10, 2017 Author Share Posted June 10, 2017 10 hours ago, jakogut said: I've been following this topic, and others related to your Linux development efforts on Amlogic platforms for a few weeks now. I'm curious about the function of the Fn button inside the headphone jack. When that button is held, does the device change its boot order, and use the u-boot installed on the SD card, or does it simply change the stock u-boot's environment? Is it possible to create an SD card with a custom u-boot that's bootable in an unmodified (no multiboot) TV box like the Mini M8S II simply by holding the recovery/Fn button? 1. Button makes the built-in bootloader (u-boot) in the first place to look for on an external storage medium a file (aml_autoscript). If it is, go to it aml_autoscript. If there is no such file, the loader starts the built-in recovery mode. In theory, you could write your own version aml_autoscript that will load from external media new u-boot and will give him control. But it requires a good knowledge of the structure of u-boot (source code for your specific model) and the availability of special commands for the complete transfer of control the new u-boot on an external drive. 2. If you need to boot from external media (without making any changes multi-boot) you can rename the script s905_autoscript in aml_autoscript and pressing the button will immediately run the script to start the system from external media. In this embodiment, for system start up from external media will need to click when you enable this button. 3 Link to comment Share on other sites More sharing options...
Joseph22 Posted June 11, 2017 Share Posted June 11, 2017 (edited) On 6/5/2017 at 1:23 PM, balbes150 said: To ALL In the last images I removed from startup all the modules of Wi-Fi. They prevent launch on some models of TV boxes (which require other modules for WiFi). So you need to manually (via terminal) to verify which model is suitable for your TV model and enter it in the file /etc/modules (for later auto run at startup). First of all thank you very much for your hard work. You have made my nexbox usable and fun. The only part i dont undesrtand is wifi. After running the wifi dummy command it finds my network and I succesfuly connect but I dont understand how to add it to modules . I am not an experienced linux user and I dont know what line do I write (i open the file with sudo nano command). My wifi driver is rtl8723bs . How do I add it to modules config file? Thank you in advance for your answer Edited June 11, 2017 by Joseph22 Link to comment Share on other sites More sharing options...
balbes150 Posted June 12, 2017 Author Share Posted June 12, 2017 16 hours ago, Joseph22 said: First of all thank you very much for your hard work. You have made my nexbox usable and fun. The only part i dont undesrtand is wifi. After running the wifi dummy command it finds my network and I succesfuly connect but I dont understand how to add it to modules . I am not an experienced linux user and I dont know what line do I write (i open the file with sudo nano command). My wifi driver is rtl8723bs . How do I add it to modules config file? Thank you in advance for your answer What command do you give to load the WiFi module ? Link to comment Share on other sites More sharing options...
jakogut Posted June 13, 2017 Share Posted June 13, 2017 Balbes150, I've got Linux 4.12.0-rc5 running on an Amlogic S905X based P212 device with your Arch image. Next is the Mali kernel driver. 1 Link to comment Share on other sites More sharing options...
oczkers Posted June 14, 2017 Share Posted June 14, 2017 I've got 3.14.29 kernel with xorg installed manually but cannot launch kodi (twm/xterm is working fine), looks like xrandr is not detecting refresh rate and kodi denies to launch. Anyone got it working? localhost kodi # DISPLAY=:0 startx ... 12:35:48.630 T:547496951824 DEBUG: Selected UDev as storage provider 12:35:48.655 T:547496951824 INFO: Available videomodes (xrandr): 12:35:48.655 T:547496951824 INFO: Output 'default' has 1 modes 12:35:48.656 T:547496951824 INFO: ID:0x53 Name:1920x1080 Refresh:0.000000 Width:1920 Height:1080 12:35:48.656 T:547496951824 INFO: Pixel Ratio: 1.000000 12:35:48.656 T:547496951824 NOTICE: Checking resolution 16 12:35:48.657 T:547496951824 ERROR: Failed to find matching visual 12:35:48.658 T:547496951824 INFO: GL: Maximum texture width: 32768 localhost kodi # DISPLAY=:0 xrandr xrandr: Failed to get size of gamma for output default Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080 default connected 1920x1080+0+0 0mm x 0mm 1920x1080 0.00* PS. is there any way to get rid of bootimage (android on internal) and see whole kernel logs on tv without soldering uart? Link to comment Share on other sites More sharing options...
Joseph22 Posted June 14, 2017 Share Posted June 14, 2017 On 6/12/2017 at 7:23 AM, balbes150 said: What command do you give to load the WiFi module ? sudo modprobe wifi_dummy Link to comment Share on other sites More sharing options...
krzystke Posted June 14, 2017 Share Posted June 14, 2017 Hello, I recently bought Odroid C2. Legacy Ubuntu Server image works great, but Ubuntu Server Next (mainline kernel) doesn't boot. SSH shows network error: connection timed out, screen is black. Is it something wrong with current image or my hardware? (Other OSes are working fine like legacy dekstop, DietPi). Power supply is official barrel DC jack 5V/2A Link to comment Share on other sites More sharing options...
xXx Posted June 14, 2017 Share Posted June 14, 2017 Continuing from my last post: This is Armbian_5.27_S905_Ubuntu_xenial_4.12.0-next-20170516+_mate.img Tried meson-gxbb-p200.dtb ( see previous post ) meson-gxbb-nexbox-a95x.dtb ( boot to cli, no keyboard, power led blinking ) meson-gxbb-p201.dtb ( same as p200 if not worse ) meson-gxbb-vega-s95-meta.dtb ( no boot at all ) meson-gxbb-vega-s95-pro.dtb ( no boot at all ) meson-gxbb-odroidc2.dtb ( no boot + power led blinking ) meson-gxbb-vega-s95-telos.dtb ( next to try when i have the time... ) Link to comment Share on other sites More sharing options...
magan Posted June 15, 2017 Share Posted June 15, 2017 Hi everyone, It seems Mali EGL X11 support is broken, here are the steps to reproduce the defect: sudo apt-get install mesa-utils cmake xorg-dev git clone --depth 1 https://github.com/ptitseb/gl4es cd gl4es cmake . -DODROID=1; make GL -j4 export LD_LIBRARY_PATH=./lib glxgears Exporting `LIBGL_FB=1` (2, 3) doesn't help either. The same allegedly works on Odroid C2 so there's no reason it shouldn't be made to work on S905 boxes as well. Any suggestions where the `eglInitialize` failure is coming from? Link to comment Share on other sites More sharing options...
balbes150 Posted June 15, 2017 Author Share Posted June 15, 2017 On 13.06.2017 at 9:00 AM, jakogut said: I've got Linux 4.12.0-rc5 running on an Amlogic S905X based P212 device with your Arch image. I updated the image with ArchLinux. Also added to the website test versions of packages with kernel 3.14 and 4.12 (for installation via pacman). On 14.06.2017 at 1:42 PM, oczkers said: I've got 3.14.29 kernel with xorg installed manually but cannot launch kodi (twm/xterm is working fine), looks like xrandr is not detecting refresh rate and kodi denies to launch. Anyone got it working? What version of KODI are you trying to run ? On 14.06.2017 at 1:42 PM, oczkers said: PS. is there any way to get rid of bootimage (android on internal) and see whole kernel logs on tv without soldering uart? You want to install Armbian (Linux) on the internal memory ? On 14.06.2017 at 6:38 PM, Joseph22 said: sudo modprobe wifi_dummy Add the file /etc/modules a new line with the name of the module (wifi_dummy). 21 hours ago, xXx said: Continuing from my last post: Soon to be updated to the image-4.12\13 Link to comment Share on other sites More sharing options...
balbes150 Posted June 15, 2017 Author Share Posted June 15, 2017 4 hours ago, magan said: It seems Mali EGL X11 support is broken, here are the steps to reproduce the defect: image Armbian Ubuntu Mate 20170601 root@amlogic:/home/user/gl4es# export LD_LIBRARY_PATH=./lib root@amlogic:/home/user/gl4es# glxgears LIBGL: Initialising gl4es LIBGL: v0.9.7 built on Jun 15 2017 19:13:38 LIBGL:loaded: libGLESv1_CM.so LIBGL:loaded: libEGL.so LIBGL: Extension glBlendColor found and used LIBGL: Extension GL_OES_point_sprite detected and used LIBGL: Extension GL_OES_point_size_array detected LIBGL: Extension GL_OES_framebuffer_object detected and used LIBGL: Extension GL_OES_packed_depth_stencil detected and used LIBGL: Extension GL_OES_depth24 detected and used LIBGL: Extension GL_OES_rgb8_rgba8 detected and used LIBGL: Extension GL_EXT_texture_format_BGRA8888 detected and used LIBGL: Extension GL_OES_depth_texture detected and used LIBGL: Extension GL_OES_texture_cube_map detected and used LIBGL: Extension GL_OES_draw_texture detected and used LIBGL: Max texture size: 4096 LIBGL: Texture Units: 8, Max lights: 8, Max planes: 1 LIBGL: Implementation Read is GL_RGB/GL_UNSIGNED_SHORT_5_6_5 LIBGL: Current folder is:/home/user/gl4es Error: couldn't open display (null) 1 Link to comment Share on other sites More sharing options...
oczkers Posted June 15, 2017 Share Posted June 15, 2017 Quote What version of KODI are you trying to run ? 17.3 kodi-standalone and kodi on top of twm using fbdev but no luck so i'll wait for 4.12+ and full gles support via xf86-video-armsoc Quote You want to install Armbian (Linux) on the internal memory ? It would be perfect to just remove splashscreen and show full boot process without installing to internal - i'm just not familiar with android boot process. Link to comment Share on other sites More sharing options...
