@balbes150
different question :
did you test the latest 4.10 kernel with amlogic support (s905 and others) ?
only for a server image i imagine as there's no mali driver yet.
@sukanime
First of all, thanks for your answer.
MiniM8S with balbes150 ubuntu mate images runs very stable. I'm using it for my everyday work, and never had a problem for about 3 months now.
Video playback is not very pleasant, but for my needs are OK. I don't watch many videos, and when i do, i can live mpv's somewhat poor performance.
A 3.5 WATT desktop is what i wanted, and for this, i can forgive some performance issues.
Now about the pin shorting method you will need:
1) The original ANDROID firmware for the box
2) A USB MALE to USB MALE cable of good quality.
3) A thick needle or some other metallic object.
4) USB image writer tool from manufacturer.
5) You need to open the box to gain access to AmLogic chip's pins.
This method is not easy, and is dangerous too. You need this method only if you have really bricked the device.
If the device can still boot from USB or SDCARD there is NO NEED for this method.
Some info can be found here and a video here
For many people the pin shorting is not needed, if windows sees the box when you connect it via the USB cable.
Then you only need AmLogic USB Burning tool, firmware, and a Windows machine.
Unfortunatelly for me, that never was the case. I always have to short pin 18 and 19 ( if i remember correctly )
for windows to idendify the tvbox when connected to USB, and play the "magic" sound.
@mdel
I tried 4.10 (own built from default config) but it would not show anything on HDMI screen. In gentoo arm64 forum someone says mainline kernel support for normal usage may come with 4.12 ... Not sure what other people experiences are.
54 minutes ago, xXx said:
@sukanime
I use Ubuntu Odroid C2 based from Koxx , i just recompile kernel to add Sound and Wifi support, i have run it for around 3 month too... it's very stable except when using Kodi.
Low Power to save electricity bill is my first consent, because i use it for downloading youtube with app called youtube-dl so its run 24 hour,  its make realy nice to have this Mini M8S.
some times i do Picture Editing with Gimp and Inkscape... but just small picture... because it use alot of RAM.
i hope in the future there will be a cheaps Android TV (as cheaps MiniM8S) thats can run Ubuntu and have 4GB RAM, so i can use it for editing Bigger Picture with Gimp and Inkscape .
OMG, thats tutorial..... its not for me, i dont want to open the Box and i dont have Windows Os, i dont have the money to buy it, and i already fall in love with Gnu/Linux.
You right, but thanks i will bookmark it.
Perhaps there will be the time i need it.
The method i use is this tutorial http://www.stane1983.com/index.php/2014/02/22/how-to-create-amlogic-recovery-sd-card-from-linux/
Thanks a lot... ^_^
1 hour ago, Nofan Tasi said:
@mdel
okay thx,
have you shared that kernel build online ?
having watched baylibre's conference on amlogic mainline support, i believe he did mention that hdmi support had not been submitted yet :
https://www.youtube.com/watch?v=FYvTatdgS_0&index=83&list=PLbzoR-pLrL6pSlkQDW7RpnNLuxPq6WVUR
and also confirmed in this blog post : http://baylibre.com/elc-2017-3d-mainline/
During the ELC Showcase event, BayLibre showed, among other demos, Quake III Arena running fully accelerated on an Odroid-C2 powered by the Amlogic S905 SoC
This particular demo was running the lastest Linux 4.10 release with some in-development patches for HDMI Support, Audio and Mali acceleration that will certainly go into the next Linux releases.
After booting armbian on myamilogic s905  mini m8s tv box the image is stripped, it looks like some lines are not synchronized and I have 2 screens side by side with half of the lines. It does not matter if its graphical or text mode. I tried it on a 4k tv and hdmi to vga converter.
When I boot original android or libreelec there's no problems so it must be some software problem. dbt file I use is gxbb_p200_2g. I tried also with the original one extracted from android but it won't boot
That probably means you're using the universal 3.14.29 kernel whereas the original dtb's are supposed to work with 3.14.79 Vega kernel for S905 devices. But yeah, definitely a bug as both types of images work fine on my S905 based boxes.
info
I connect 60Gb 2.5" IDE HDD via Jmicon USB-PATA-SATA bridge with ext power supply
image S9xxx_4G_ICEWM_MATE_XFCE_LXDE_LXQT_20170129.img
The system is booted up and running
Also using gparted I ran a swap of 4GB  partition sda3
Using QEMU successfully launched winxpsp3 , 512 Mb RAM , with networking :)
Sandra 2005 determined the Pentium2-333 processor, the speed is about 70-200 MIPS
SoC S905X / TVBox MiniM8II / SZTomatoto vim v1.2
1 hour ago, Batmah said:
info
What about the performance of the gnu/linux os?
Is this much faster and smooth if booted from HDD Ext or just the same when booted from SDCard?
I want to try using HDD Ext, but i'am afraid it's not as good as with SDCard.
@xXx or @balbes150
can you tell me if the current images "s9xxx" are safe to flash on the emmc (always on my a95x s905 1G/8G) ?
i see it causes problems on some boxes but i can't quite figure out if there's a way to determine if your box is safe or not.
i made a backup with xxx script juste in case.
thx
On 12.03.2017 at 11:53 AM, mmss said:
With both
What screen resolution are You using ? Ubuntu test files at 720 shows quite smoothly.
On 12.03.2017 at 0:26 PM, xXx said:
Do i need to have the original android firmware in my MiniM8S box for the installation to EMMC to be successful?
I tried 7 times yesterday with your latest ubuntu mate image, and although everything went well ( no errors ) the system
Most likely You have a TV box is using an outdated version of NAND flash memory. To support it you need to manually rebuild initrd (which is included with the linux.img in the /boot directory). You need to get the system to load the module for NAND right at the start of the initrd. I was told that I was sent a few samples of a TV with a similar type of memory. When they arrive, I can test and debug the installation process of this kind of memory.
On 12.03.2017 at 3:05 PM, etona said:
I know that apt-get work ok, i just dont know find this - on my tronsmart airmouse.
Other keyboard have old jack, no usb...
You can connect via ssh with a regular PC and perform any settings on the TV box over the network.
Yes, I hope that in the future will be full support for KODI on Linux on the s9xxx (we're working on it, but I don't have enough free time).
On 12.03.2017 at 3:55 PM, mdel said:
So i'd like to know if you could do it for me and which files you'd need (i think i have the boot block from android, the extracted dtb and decompiled dts, from previous experiments)
If You have a dts file - it will be good. I can include it in the kernel source.
I have a test kernel 4, but I still could not achieve correct operation.
In 4.12 there is a notable progress, but it is too early to talk about the complete work.
What version image are You using ? Try to replace the fbset file in the one that is on the site in the Test directory.
Забавно, Windows из под Linux. :)
Если не секрет, для чего такой хитрый запуск ?
Show me the dmesg output. There should be seen what type of memory do You use and is there a possibility now automatically install Linux to the internal memory.
32 minutes ago, balbes150 said:
On 12/3/2017 at 9:53 AM, mmss said:
With both
Default at 720, also with full screen?
1 hour ago, balbes150 said:
yes
:o
So the problem is my box, Im using the image dated 20170303
What screen resolution are You using ? Ubuntu test files at 720 shows quite smoothly..
For me is intersting, all videos from you tube are same smootly!!
Firefox, no sound, I am not finded pakage in synaptic for audio.Ill try again.
Yesterday i am try, 4k, fhd, 720p-hd, 360p? ld...
All videos are same.
Just a little smootly, "20% beter, will be - a perfect!
On a full screen, same, just stop a half second, when I touch airmouse.
This is on 720p on my monitor, 1080p i dont know sett.
In display options i have only 720p.
Anybody know link with this problem and how to set 1080p?
Balbes, tnx for your answers.
A new version of the backup script ( and hopefully the final version, if no bugs found ).
There are many improvements in this version, and is well tested ( by me, and in my box only ).
The script is reimagined and redesigned from top to bottom.
The most notable changes are:
  • backup and restore is now separated ( if you just want to restore it won't stop you in low space scenario )
  • forcing compressed mode backup in low space scenarios ( at your own risk afted some warnings )
  • the script now accepts an argument for backup/restore to/from another mounted drive.
  • cleaner code as the script have become very complex
  • color changes for better compatibility with white background terminals ( mate default scheme ).
the list goes on and on, but all the changes are in the script's comments.
Some info can be seen here and here
The script can be downloaded from here
The code can be seen below
#!/bin/bash
# Author: xXx
# Purpose: Automate the process of backing up internal storage.
# Date: 4 Jan 2017 20:22:00 EET
# Update: 5 Jan 2017 19:48:00 EET                                             #
# Reason: Added support for when the user have started his machine            #
# from USB. Now the right source and destination should be selected.          #
# Added support for uncompressed images.                                      #
# Added detection if the user runs already from emmc.                         #
# Update: 6 Jan 2017 21:43:00 EET                                             #
# Reason: Added functionality to restore images that this program creates.    #
# Update: 8 Mar 2017 18:30:00 EET                                             #
# Reason: Changed yellow color to cyan for white backround terminals.         #
# Update: 8 Mar 2017 18:52:00 EET                                             #
# Reason: Changed backup/restore dir to /ddbr as installer excludes this dir. #
# Update: 12 Mar 2017 10:47:00 EET                                            #
# Reason: Added the ability for the user to continue with compressed backup   #
# only, and at his/her own risk, in case of lesser free space on the drive.   #
# Tried to annoy the user with questions, in order to discourage him/her.     #
# Update: 12 Mar 2017 13:02:00 EET                                            #
# Reason: Separated backup and restore dialogs for better handling of the     #
# various situations for the program itself. Now the program ask first if a   #
# backup or restore is wanted, and skips/adds some checks accordingly.        #
# There should be no stops now, if a restore only wanted, and the free space  #
# was too low, as this is irrelevant to the requested function.               #
# Update: 12 Mar 2017 16:08:00 EET                                            #
# Reason: The program can now accept an argument for PowerUsers.              #
# This argument can only be a directory, and must exists before calling the   #
# program. This mode is dangerous, and most users will not need this mode, as #
# great damages can be done to your system if you use it incorrectly.         #
# The argument is really the backup/restore directory that now can be forced  #
# by the user, to bypass the programs checks, always at his/her own risk.     #
# Update: 12 Mar 2017 16:32:00 EET                                            #
# Reason: Code cleaning. As the program have become very complex already, a   #
# cleaner code was mandatory, in order to keep it safe and maintainable. If i #
# am to kill any bugs below these lines, i should be able to spot them first. #
# Update: 13 Mar 2017 11:52:00 EET                                            #
# Reason: Squashed some small bugs when running on normal Linux desktops that #
# have no EMMC or SDCARDS installed. And some more code cleaning.             #
# Update: 13 Mar 2017 12:40:00 EET                                            #
# Reason: Changed the messages to darker colors for better compatibility with #
# white background terminals. Only the red color is now bright for emphasis.  #
_r=$(tput bold && tput setaf 1)
_g=$(tput setaf 2)
_b=$(tput setaf 4)
_c=$(tput setaf 6)
_x=$(tput sgr0)
[ $(whoami) != root ] && echo "$_r Please run this program as root""$_x" && exit 1
OUTDIR=$1
if [ "$OUTDIR" = "" ]
then
    OUTDIR="/ddbr"
    [ ! -d /ddbr ] && mkdir -p /ddbr
else
    OUTDIR=$(echo "$OUTDIR" | sed "s,/\+$,,")
    echo "$_b ARGUMENT MODE DETECTED. YOU HAVE BEEN WARNED!!!       $_x"
    echo "$_b NO IN/OUT SIZE CHECKS WILL BE PERFORMED IN THIS MODE. $_x"
    echo "$_b YOU ARE USING THIS MODE AT YOUR OWN RISK!!! $_x"
        if [ ! -d "$OUTDIR" ]
        then
            echo "$_r IN ARGUMENT MODE THE OUT/IN DIRECTORY MUST PRE-EXIST $_x"
            echo "$_r AND IT IS BETTER TO BE ON AN MOUNTED EXTERNAL DRIVE. $_x"
            echo "$_r PROGRAM EXITED DUE TO ERROR: NO DIR $OUTDIR          $_x"
            exit 1
        fi
fi
dobackup(){
    echo $_c" DO YOU WANT COMPRESSION ? "$_x
        while true
        read -p " "$_b"YES=("$_c"y"$_b") NO=("$_c"n"$_b")"$_x" " yn
        do
            case $yn in
                y)
                COMPRESS=TRUE
                break;;
                n)
                COMPRESS=FALSE
                break;;
            esac
        done
    if [ "$COMPRESS" = "TRUE" ]
    then
        echo "$_b SAVING AND COMPRESSING "$_g"$emmc"$_b" TO "$_g"$OUTDIR/$image.gz"$_x"..."
        dd if=/dev/$emmc | pv -s $intsize"K" | gzip > $OUTDIR/$image.gz
        finish
    else
        echo "$_b SAVING "$_g"$emmc"$_b" TO "$_g"$OUTDIR/$image"$_x"..."
        dd if=/dev/$emmc | pv -s $intsize"K" | dd of=$OUTDIR/$image
        finish
    fi
dorestore(){
    echo $_c" DID YOU USED COMPRESSION WHEN YOU TOOK THE BACKUP ? "$_x
    while true
    do
        case $yn in
            y)
            COMPRESS=TRUE
            break;;
            n)
            COMPRESS=FALSE
            break;;
        esac
    done
    then
        [ ! -f $OUTDIR/$image.gz ] && echo "$_r NO IMAGE FOUND. MAKE SURE YOU HAVE MADE A BACKUP FIRST."$_x"" && exit 1
        echo "$_c YOU ARE ABOUT TO MAKE SERIOUS CHANGES TO YOUR SYSTEM!!!"
        echo " FILE "$_g"$OUTDIR/$image.gz"$_c" IS GOING TO BE WRITEN TO "$_g"$emmc"$_c" "
        echo " MAKE SURE EVERYTHING LOOKS OK AND:"
        read -p " PRESS ENTER TO CONTINUE OR CTRL+C TO CANCEL $_x" blah
        echo $_b" RESTORING $OUTDIR/$image.gz TO /dev/$emmc | PLEASE WAIT..."$_x
        gunzip -c $OUTDIR/$image.gz | pv -s $intsize"K" | dd of=/dev/$emmc
        finish
    else
        [ ! -f $OUTDIR/$image ] && echo "$_r NO IMAGE FOUND. MAKE SURE YOU HAVE MADE A BACKUP FIRST."$_x"" && exit 1
        echo " FILE "$_g"$OUTDIR/$image"$_c" IS GOING TO BE WRITEN TO "$_g"$emmc"$_c" "
        echo $_b" RESTORING $OUTDIR/$image TO /dev/$emmc | PLEASE WAIT..."$_x
        dd if=$OUTDIR/$image | pv -s $intsize"K" | dd of=/dev/$emmc
        finish
    fi
compress(){
    echo "$_c YOU ARE IN FORCED COMPRESSION MODE!!! $_x"
    echo " THIS MODE CAN BE FROM DANGEROUS TO DESTRUCTIVE FOR YOUR $runfrom DRIVE"
    echo " IF THE COMPRESSED BACKUP GROW BIGGER THAN THE FREE SPACE ON THE DRIVE"
    echo " BAD THINGS MAY HAPPEN TO YOUR CURRENTLY RUNNING DRIVE $runfrom"
    echo " IT IS BETTER TO USE A DRIVE WITH PLENTY OF SPACE FOR BACKING UP EMMC"
    echo " BY PRESSING ENTER YOU ARE CONTINUING AT YOUR OWN RISK!!!"
    read -p " CTRL+C to QUIT | ENTER TO CONTINUE " null
    while true
    read -p " "$_b"ARE YOU SURE? YES=("$_c"Y"$_b") NO=("$_c"N"$_b")"$_x" " YN
    do
        case $YN in
            Y)
            break;;
            N)
            exit 1
            break;;
        esac
    done
    finish
finish(){
    echo "$_g JOB FINISHED!"$_x""
    exit 0
echo "$_c DO YOU WANT TO BACKUP OR RESTORE ? "$_x""
while true
read -p " "$_b"BACKUP=("$_c"b"$_b") RESTORE=("$_c"r"$_b")"$_x" " br
do
    case $br in
       B)
        wantsbackup=true
        break;;
        r)
        wantsbackup=false
        break;;
    esac
done
### COMMON CHECKS / VARIABLES CREATION / INFO GATHERING
hasdrives=$(lsblk | grep -oE '(mmcblk[0-9])' | sort | uniq)
if [ "$hasdrives" = "" ]
then
    echo "$_r UNABLE TO FIND ANY EMMC OR SD DRIVES ON THIS SYSTEM!!! $_x"
    exit 1
fi
avail=$(lsblk | grep -oE '(mmcblk[0-9]|sda[0-9])' | sort | uniq)
if [ "$avail" = "" ]
then
    echo "$_r UNABLE TO FIND ANY DRIVES ON THIS SYSTEM!!! $_x"
    exit 1
fi
runfrom=$(lsblk | grep /$ | grep -oE '(mmcblk[0-9]|sda[0-9])')
if [ "$runfrom" = "" ]
then
    echo "$_r UNABLE TO FIND ROOT OF THE RUNNING SYSTEM!!! $_x"
    exit 1
fi
emmc=$(echo $avail | sed "s/$runfrom//" | sed "s/sd[a-z][0-9]//g" | sed "s/ //g")
if [ "$emmc" = "" ]
then
    echo "$_r UNABLE TO FIND YOUR EMMC DRIVE "$_c"OR"$_r" YOU ALREADY RUN FROM EMMC!!! $_x"
    exit 1
fi
if [ "$runfrom" = "$avail" ]
then
    echo "$_r YOU ARE RUNNING ALREADY FROM EMMC!!! $_x"
    exit 1
fi
if [ $runfrom = $emmc ]
then
    exit 1
fi
if [ "$(echo $emmc | grep mmcblk)" = "" ]
then
    echo "$_r YOU DO NOT APPEAR TO HAVE AN EMMC DRIVE!!! $_x"
    exit 1
fi
intsize=$(fdisk -s /dev/$emmc)
image=$(echo $(cat /proc/cpuinfo | egrep '(Hardware|Revision)' | awk '{print $3}') | sed "s/ /-/g")-emmc.img
### BACKUP ONLY CHECKS
if [ "$wantsbackup" = true ]
then
    rootfree=$(df | grep /$ | awk '{print $4}')
    [ $rootfree -le $intsize ] && echo -e "$_r NOT ENOUGH FREE SPACE! \n FORCING COMPRESSION MODE $_x" && compress=true
else
    echo "$_b AVAILABLE DEVICES: "$_g"$(echo $avail)""$_x"
    echo "$_b YOU ARE RUNNING "$_g"$(lsb_release -c | awk '{print $2}')"$_b" FROM "$_g"$runfrom""$_x"
    dorestore
fi
if [ $(echo $intsize | sed "s/ //g" | wc -c) -le 7 ]
then
    echo -e "$_b INTERNAL EMMC IS: "$_g"$emmc"$_b" SIZE:\t"$_g"$intsize""$_x"
else
fi
if [ $(echo $rootfree | sed "s/ //g" | wc -c) -le 7 ]
then
    echo -e "$_b ROOT ($runfrom) FREE SPACE IS:\t\t\t"$_g"$rootfree""$_x"
else
    echo -e "$_b ROOT ($runfrom) FREE SPACE IS:\t\t"$_g"$rootfree""$_x"
fi
[ "$compress" = "true" ] && compress || dobackup
Yes ,  this is much faster and smooth if booted from HDD
i have attached the dmesg and dts files for my nexbox a95x s905 version.
let me know if i can "safely" flash to internal emmc, i should be able to unbrick if necessary so don't worry too much about that.
dmesg.txt.gz
nexbox_a95x_s905.dts.gz
http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905x/598320-a95x-s905x-emmc-boot-for-ubuntu?p=635318#post635318
To change the screen resolution, you need to edit the file "amlogics905x_init.sh". To move comments from 1080 to 720 and restart the system..
Downloaded. Will check at home.
Judging by the output, the installation should work. Pay attention to matching the size of the partitions and installed system. That would be enough space to install.
dts will look at it later.
Firefox sound fixed.
Screen resolution , i dont know how.
I am try, and i cant.
Im finded this file in "boot" folder, and give me 4 option.
2x terminal, do nothing, 1x exit,do exit, and 1x display, this option I can open, but cant edit...
Can write # near 1080, and delete near 720, but cant save this.
Next time when open is same, again.
Some program for setting this, in synaptic not egsist?
sudo nano /boot/thefileinquestion.sh
edit the file and remove the "#" in front of 1080 line, put it in from of the 720 line.
CTRL+O to save
CTRL+X to exit
sudo reboot.
You are done.
