11 hours ago, Tommy21 said:
will this work with official khadas vim fan?
The script works with the fan connector to the VIM2 (s912), it is a scheme for power control of the fan and you can install several levels (off, low speed, middle speed, high speed). In VIM (s905x) there is no such scheme fan. By the way, VIM (S905X) I have installed the radiator and connected the fan to the pins of 3.3 V. the Fan turns on with the system startup and turns off when you stop the system. His work does not depend on the type of OS (Linux, Android, LE). It runs nearly silent and provides cooling under all load conditions.
https://ru.aliexpress.com/item/2-Pieces-lot-Computer-PC-Case-DC-Cooling-Fan-5-Volt-35mm-Dupont-Connector/32545826051.html?spm=a2g0s.9042311.0.0.5gJjn3
5 hours ago, TonyMac32 said:
, it's a Mini M8S_II
Such ?
https://mysku.ru/blog/china-stores/43736.html
Is there any other way to flash bootloader variables to boot from external media ? On my t95x with custom rom, i don't have the update&backup app to flash aml_autoscript.zip
edit:
nevermind, fixed it. Just extracted the apk from the original rom.
On 16.10.2017 at 5:41 PM, ennoente said:
Looking for an installation manual?
What would the module, it is necessary to collect from source with the kernel that you are using.
Yes, i looking for an installation manual.   The tuner is contain in LE Version kszaq.
FYI : avl6862 in kszaq LE comes from a separate media_build driver repository (i.e. not the linux kernel repository itself).
Hi all, I'm using Armbian 5.32 with Debian Jessie server dated 20170907, is there some simple way to correctly update at latest version?
Does the bluetooth work for someone? I load at boot the module hci_uart and I also automatically execute the command:
su -c 'hciattach /dev/ttyS1 any'
but I'm not able to connect via bluetooth any device, I tried with hcitool and bluetoothctl.
Does the hardware acceleration work? And is it possible to install kodi on the server version?
I have also found and tried these deb packages:
https://yadi.sk/d/pHxaRAs-tZiei/deb
(where can I find a description of the these packages? Should I to install them?)
I tried to install mali-aml_5.27_arm64.deb and kodi-aml_5.27_arm64.deb but doesn't seems to me that the hardware acceleration works and kodi has missing dependencies.
Instead thanks to the package amremote_5.27_arm64.deb I have been able to use the remote control.
First of all, thank you for your help on making armbian possible on those SoC.
Now, I have a KhadasVIM box and I used a USB drive to burn Armbian_5.34_S9xxx_Debian_jessie_3.14.29_server_20171020.img and boot from it.
I must say, graphics are really laggy. I can't even watch a youtube video on firefox or chromium. Kodi doesn't even play a frame.
I made a mistake and changed the sources.list to sid from jessie, but that's not the case. It was laggy before this change, too.
So, what should I do to fix this? Or it's not implemented yet?
Thanks
Update 3.14.29_20171027.
Changes.
1. Fixed the launch KODI.
2. Fixed installation mode of the OS in eMMC.
3. Update packages to current versions.
On 20.10.2017 at 11:10 PM, hojnikb said:
is video acceleration  working on these builds ?
Fullscreen video is KODI
also, any chance for more ram to be available to the system ?
What is the issue ?
The answer is on the last pages of this topic.
The work depends on the specific iron TV box and the correct dtb file.
Works in KODI.
Possible. Install required packages and to perform before configuring the system. If you don't know how to do it, for you will be the best solution, to use a finished version of the image of the desktop, where everything is installed and configured.
This issue has already been discussed a million times. For video playback there is a special version of image Mate, where everything is already set up for full-screen video playback through KODI.
p.s.
I don't understand why the people themselves create problems. Why do people take the server version and try to make him Destkop, if you do not know how to do yourself ?
Hi All!
@balbes150: I saw you have added a Debian testing (buster/sid currently) repository when building jessie or stretch flavor of Armbian -> lib/general.sh#L142
So when building myself, the jessie (or stretch) image is not anymore a true Debian Jessie. Could you please explain your reasoning for adding this testing repository? Tks.
On the side note also, my build images are not booting if I commented out this repository when buiding...
Works in KODI.
p.s.
In my case I don't need the desktop version, I don't need the server X, I'd like to use my device as an headless server.
If the hardware acceleration is working I can use it in the video surveillance software with my h264 cameras. I know that the amlogic s905 has native hardware encoding/decoding for h264 and h265.
About kodi, mine has been only a simple question because I haven't understood if it can been used without a server X. If it needs the X server then I'll use the readymedia versions with transcoding support. I simply need to stream videos via dlna.
About the bluetooth, I'm using an S95 Telos with gxbb_p200_2G.dtb, the wifi is working but the bluetooth doesn't work.
Is there some way to use the hardware acceleration with other softwares? And about bluetooth is there something to do?
On 10/27/2017 at 3:05 PM, balbes150 said:
What is the issue ?
"Issue" is that there is a lot of ram dedicated to the GPU and there is only ~820MB left for the system. On such a small amount of ram every MB counts. Allwinner devices usually have over 1000MB available to the system and i'm guessing additional ram gets allocated to GPU via CMA.
So my question is; does S905X have any sort of CMA or is gpu ram allocation just fixed to a certain amount and thats it ?
This repository is added to the operation of the audio and video playback in mpd.
HW is implemented for the fbdev. For use in other programs (except KODI) , you need to collect these programs using the library libMali. What kind of BT devices ?
20 hours ago, ennoente said:
support update internal tuner avl6862?
No
Yes, for the GPU to play the part of the memory. To disable it you need to rebuild dtb and remove the memory reservation.
Thanks for your answer concerning the testing repository.
Maybe you might have a clue about the issue when commenting out this repository?
I'm trying ti build a jessie image with the next kernel (it is the 4.14.0-rc5 as of this writing) for a Khadas VIM Pro board (S905X board)
So to pinpoint the issue, I have build 2 images, one with the testing repository and one without. With logging the boot sequence, it seems the "true" jessie image hangs after printing the message "[drm] Cannot find any crtc or sizes" :
[    3.076125]  mmcblk0: p1 p2
[    3.081542] leds_pwm pwmleds: unable to request PWM for vim:red:power: -517
omain-0 init dvfs: 4
[    3.105941] systemd-udevd[1237]: starting version 215
[    3.596017] mmc1: new HS200 MMC card at address 0001
[    3.596479] mmcblk1: mmc1:0001 AWPD3R 14.6 GiB
[    3.600079] mmcblk1boot0: mmc1:0001 AWPD3R partition 1 4.00 MiB
[    3.605844] mmcblk1boot1: mmc1:0001 AWPD3R partition 2 4.00 MiB
[    3.611774] mmcblk1rpmb: mmc1:0001 AWPD3R partition 3 4.00 MiB, chardev (242:0)
[    3.624449] leds_pwm pwmleds: unable to request PWM for vim:red:power: -517
[    3.677968] [drm] Cannot find any crtc or sizes
With the "buster upgraded" jessie image, it doesn't hang and the login prompt is displayed :
[    3.096645]  mmcblk0: p1 p2
[    3.101569] leds_pwm pwmleds: unable to request PWM for vim:red:power: -517
[    3.303982] mmc1: new HS200 MMC card at address 0001
[    3.304459] mmcblk1: mmc1:0001 AWPD3R 14.6 GiB
[    3.308099] mmcblk1boot0: mmc1:0001 AWPD3R partition 1 4.00 MiB
[    3.317859] mmcblk1boot1: mmc1:0001 AWPD3R partition 2 4.00 MiB
[    3.319723] mmcblk1rpmb: mmc1:0001 AWPD3R partition 3 4.00 MiB, chardev (242:0)
[    3.333393] leds_pwm pwmleds: unable to request PWM for vim:red:power: -517
[    3.677882] [drm] Cannot find any crtc or sizes
[    3.946149] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
[    4.515283] systemd[1]: System time before build time, advancing clock.
[    4.547073] NET: Registered protocol family 10
[    4.547969] Segment Routing with IPv6
[    4.557808] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.572838] systemd[1]: systemd 235 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN default-hierarchy=hybrid)
[    4.588257] systemd[1]: Detected architecture arm64.
[    4.594745] systemd[1]: Set hostname to <amlogic>.
[    4.751436] systemd[1]: File /lib/systemd/system/systemd-journald.service:33 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    4.762857] systemd[1]: Proceeding WITHOUT firewalling in effect!
[    4.775827] systemd[1]: File /lib/systemd/system/systemd-udevd.service:32 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    4.786943] systemd[1]: Proceeding WITHOUT firewalling in effect!
[    4.847590] systemd[1]: File /lib/systemd/system/systemd-logind.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    4.858856] systemd[1]: Proceeding WITHOUT firewalling in effect!
[    4.948859] systemd[1]: Created slice User and Session Slice.
[    5.111335] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
Debian GNU/Linux buster/sid amlogic ttyAML0
amlogic login:
The "EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback" is displayed after when booting the "buster upgraded" jessie image,  I think it might be the rootfs that is not mounted so the boot sequence cannot continue on the "true" jessie image...
I have tried to connect several smartphones android and a bluetooth headset.
I'm not able to see the Telos from any smartphone and vice-versa. Same thing with the bt headset, the Telos isn't able to see it.
Guys does kodi in this armbian distro run as good as kodi on LibreELEC ? I mean can it make use of the hardware acceleration just like LibreELEC ? LibreELEC is too limited for my needs, I need to install a few CLI based programs, I'm thinking of installing the server version of armbian
Well after 2 days of testing, I don't have a clue why a true Jessie or Stretch image made for my Khadas VIM pro doesn't boot as it doesn't mount the rootfs. A true Buster boot like a charm, so I will continue my current project with such an image since I not really care which Debian flavor I use for it. I was first thinking it might be the initramsfs package version, but no : The Stretch and Buster versions are the same. After maybe the mounting with label identification : Nope, mounting with a device name or with UUID are also a no go. Puzzling, puzzling :huh: If someone has the slightest clue to put me on track, he/she will be in my dept :wub:
BTW, debootstraping/updating packages on a Buster and newer qemu chroot, as of the 3rd of November, will not work anymore: it will froze with "qemu: Unsupported syscall: 277" since the apt 1.6~alpha3 version was migrated to testing/Buster at this date and seccomp is used on the 1.6 branch of apt, which is not implemented in the current version of qemu, so the Unsupported syscall message. The workaround I found out is to use snapshot.debian.org/archive/debian/20171101T160520Z as package repository, in place of httpredir.debian.org to build my Buster image.
CU :D
The I check. In network repositories version Debian 8 jessie broken packages, which are responsible for mounting partitions by their labels. Have to use direct instructions to the device (/dev/mmcblkXpX and /dev/sdX). For this you need to change the scripts S905_autoscript and fstab. If you are using the latest version of the Assembly environment BUILD (I plan to update it in GIT soon), version Debian 9 Stretch is going correctly and running mount on labels. By the way, it fixed the audio and MPV correctly plays the test video. I uploaded the two images of Debian (server and XFCE). Perhaps in the future will correct the error in the packages, responsible for mounting in Debian 8.
To all
update image Debian 9 (Stretch) 20171104
@balbes150
Any reason why my box is freezing ? I have T95X 1GB and i'm using the latest version (4.11.2017) armbian mate image. I tried compiling retroarch-setup script overnight but the thing froze like two times after an hour or so.
I'm using "gxl_p212_1g.dtb" as my dtb image.
To all
Tks balbes150! I will check when you have updated Github.
It's a typo that you are using "Armbian Mate 20171104" ? What media is running the system ? With the temperature and free space on the media all right ? A link to a description of what you are trying to compile, I'll try to run VIM (S905X) for verification.
Update Git.
Update image kernel 3.14.29 Debian and Ubuntu 20171104.
Yes, i'm using this image. I'm using Samsung 32GB EVO+ card as a boot drive and has 27GB left on it. Temps are around 50-60C when compiling according to armbianmonitor.
I've tried 3rd time now and looking at the armbianmonitor logs, it seem to be freezing at a 30 minute mark but shows values after that with few minutes of delay. So i'm guessing system is not totally frozen, just very very busy doing something.
This is what i'm trying to compile https://github.com/RetroPie/RetroPie-Setup
I'm using odroid-c2 as a target platform, as it's the closest to S905X. If anyone knows for a ready made retro distro, i'd like to know about it :)
I'm using the ubuntu mate image in this thread but I can't get past the login screen since I don't have a USB keyboard to be attached to my tv box. How do I auto login to the main screen ? I've tried adding this option to /etc/lightdm/lightdm.conf but still doesn't work:
[Seat:*]
autologin-user=tanix
autologin-user-timeout=0
user-session=ubuntu
keyboard=onboard
# Uncomment the following, if running Unity
#greeter-session=unity-greeter
tanix is the username I created during the first boot
