Nanopi R4S freezes at random point after boot and gets really hot.
Caught that on serial the same moment:
 Unable to handle kernel paging request at virtual address ffffcd4b1d7116a8
[  100.412511] Mem abort info:
[  100.412756]   ESR = 0x86000006
[  100.413025]   EC = 0x21: IABT (current EL), IL = 32 bits
[  100.413489]   SET = 0, FnV = 0
[  100.413758]   EA = 0, S1PTW = 0
[  100.414034]   FSC = 0x06: level 2 translation fault
[  100.414460] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000003840000
[  100.415045] [ffffcd4b1d7116a8] pgd=10000000f7fff003, p4d=10000000f7fff003, pud=1000000006808003, pmd=0000000000000000
[  100.415977] Internal error: Oops: 86000006 [#1] PREEMPT SMP
[  100.416465] Modules linked in: rfkill lz4hc lz4 snd_soc_simple_card snd_soc_rockchip_i2s rockchip_vdec(C) snd_soc_rt5651 snd_soc_rockchip_spdif snd_soc_rl6231 snd_soc_simple_card_utils snd_soc_hdmi_codec snd_soc_rockchip_pcm rockchip_iep v4l2_h264 rockchip_rga videobuf2_dma_contig snd_soc_core v4l2_mem2mem videobuf2_dma_sg snd_pcm_dmaengine snd_pcm videobuf2_memops videobuf2_v4l2 snd_timer videobuf2_common videodev snd mc soundcore cpufreq_dt zram sunrpc ip_tables x_tables autofs4 dwmac_rk dw_hdmi_i2s_audio dw_hdmi_cec stmmac_platform stmmac r8169 realtek pcs_xpcs
[  100.420862] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G         C        5.15.79-rockchip64 #22.11.1
[  100.421637] Hardware name: FriendlyElec NanoPi R4S (DT)
[  100.422093] pstate: 800000c5 (Nzcv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[  100.422701] pc : 0xffffcd4b1d7116a8
[  100.423012] lr : 0xffffcd4b1d7116a8
[  100.423318] sp : ffff80000[  100.423609] x29: ffff800008023f90 x28: ffff546ac078ac40 x27: [  100.424235] x26: ffff8000081e3c80 x25: 000000000000001e x24: [  100.424862] x23: 0000000000000000 x22: 0000000000000000 x21: [  100.425487] x20: ffffcd4b5ea276c0 x19: ffffcd4b5ed3d6b0 x18:
                                             [  100.426113] x17: ffff872058a58000 x16: ffff800008024000 x15:
[  100.426738] x14: 0000000000000000 x13: 00000000000000a5 x12
[  100.427362] x11: 0000000000000000 x10: 0000000000000004 x9 5
[  100.427988] x8 : 0000000000000000 x7 : 7fffffffffffffff x6ad
[  100.428613] x5 : 00ffffffffffffff x4 : 003afbfdb9026790 x001
[  100.429238] x2 : 0000000000001fff x1 : 000000000000001e 2a08
[  100.429864] Call trace:
[  100.430080]  0xffffcd4b1d71 100.430358]  gic_handle_irq+0xb8/0x134
[  100.430693]  call_onk+0x28/0x54
[  100.431041]  do_interrupt_handler+0x58/0x68
[  431409]  el1_interrupt+0x30/0x78
[  100.431725]  el1h_64_irq_ha[  100.432085]  el1h_64_irq+0x74/0x78
[  100.432385]  arch_cpu_[  100.432699]  default_idle_call+0x40/0x184
[  100.433053]  do/0x270
[  100.433339]  cpu_startup_entry+0x24/0x68
[  100.4336ry_start_kernel+0x154/0x168
[  100.434084]  __secondary_switche4
[  100.434455] Code: bad PC value
[  100.434726] ---[ end tr8800cc203 ]---
[  100.435130] Kernel panic - not syncing: Oops:tion in interrupt
[  100.435728] SMP: stopping secondary CPUs
436076] Kernel Offset: 0x4d4b55600000 from 0xffff800008000000
[ PHYS_OFFSET: 0xffffab9540000000
[  100.436972] CPU features: 00846
[  100.437354] Memory Limit: none
[  100.437625] ---[ endanic - not syncing: Oops: Fatal exception in interrupt ]---
Tested with Armbian_22.11.1_Nanopi-r4s_bullseye_current_5.15.79.img.xz
Damn Rockchip.
I have no issues (except PCI timeouts) with this:
Armbian_22.11.1_Rockpi-4b_jammy_current_5.15.79_gnome_desktop.img.xz
https://paste.armbian.com/sahalaxuru
ClearfogPro and Helios4 images are working ok. ClearfogBase I expect to do the same (not explicitly tested).
@TheLinuxBug one improvement for the testing form would be a checkbox for "does not apply" on the feature section. My boards don't have wireless but no options really matches :)
I agree, this would be good.
26.11.2022 в 19:45, Igor сказал:
New RC images are out. 22.11.1
Armbian_22.11.1_Station-m3_jammy_legacy_5.10.66_xfce_desktop.img.xz
Station m3 - work
by the way, on the page of the testing form, there is no Station M3 model in the list.
I will check into this and get it updated.  Once updated I will let you know so you can submit the form.
Cheers!
Cheers!
@balbes150Okay, station-m3 has now been added to the form.  Please fill it out when you have a chance.
Thanks!
I will take this into consideration when we next review the form :)
Thanks!
12 часов назад, TheLinuxBug сказал:
Done
Alternatively, a suggestion for the testing process. It is preferable to use the version with DE (XFCE - as officially recommended) for tests by maintainers. If the DE version works, then the Cli version will also work. I ran into a problem on Station M1 - last time I checked the Cli version and fixed the problems that were there, and did not immediately notice that there was a problem with DE (there is no startup due to the use of packages from the ppa). It looks like this is a common problem with the legacy kernel - DE does not work (does not start) due to the use of the 3D group as part of the image).  Disabling the repository and updating the system (with reinstalling the xorg component) restores the DE startup.
I'm not sure. it's either a bug or it's planned that way. But after changing the ROOT password at the first step of the settings wizard (at the first start it asks for a new password, and confirmation, everything goes without errors), the primary password 1234 remains in the system. Is that how it 's meant to be ?
I guess not.
Maybe related:
Removing packages from this PPA shit, restores DE startup. This repository is more trouble than it's worth. I propose to exclude him from all official images. For those who want to use it, let them install it themselves manually and take full responsibility.
This seems to fix it.
fixed with https://github.com/armbian/build/commit/e8f441a7e38a8ecd931c47f27e25890711f64d61
Thanks!
Okay, I have added a "Does Not Apply' checkbox to the form for all questions so you can choose this if it isn't applicable to the board being tested.
Cheers!
Check if something important is missing from the docs - if you have added pull requests to the Github without a Jira ticket, then its missing from the list. Please add now!
# Release notes - Armbian - 22.11
## Story
### [AR-1278](https://armbian.atlassian.net/browse/AR-1278) Implement plymouth for kernel > 5.19.y
### [AR-1319](https://armbian.atlassian.net/browse/AR-1319) Upgrade Allwinner boot loader to 2022.08
### [AR-1335](https://armbian.atlassian.net/browse/AR-1335) Add gpiod library to armhf and arm64 server \+ desktop images
### [AR-1346](https://armbian.atlassian.net/browse/AR-1346) Grub optimisations
### [AR-1355](https://armbian.atlassian.net/browse/AR-1355) Add support for UEFI install to the nand-sata-install
### [AR-1362](https://armbian.atlassian.net/browse/AR-1362) Add Bananapi M5 to the build system
### [AR-1389](https://armbian.atlassian.net/browse/AR-1389) Refactor u-boot patches
### [AR-1390](https://armbian.atlassian.net/browse/AR-1390) Add Riscv64 support
### [AR-1399](https://armbian.atlassian.net/browse/AR-1399) Enable BASH linter at PR on changed files
### [AR-1402](https://armbian.atlassian.net/browse/AR-1402) Enable ES8316 audio properly on Radxa Rock Pi 4
## Task
### [AR-668](https://armbian.atlassian.net/browse/AR-668) Using extlinux.conf instead of the legacy set of boot.scr \+ text files.
### [AR-949](https://armbian.atlassian.net/browse/AR-949) Initial board setup
### [AR-977](https://armbian.atlassian.net/browse/AR-977) Add package version number to the rootfs cache
### [AR-1034](https://armbian.atlassian.net/browse/AR-1034) Add missing Docker dependencies
### [AR-1112](https://armbian.atlassian.net/browse/AR-1112) Add ZFS repository
### [AR-1301](https://armbian.atlassian.net/browse/AR-1301) Add Rockpi 4C plus
### [AR-1312](https://armbian.atlassian.net/browse/AR-1312) Clean bootlogo patches
### [AR-1317](https://armbian.atlassian.net/browse/AR-1317) Remove nfs-kernel-server from default install
### [AR-1325](https://armbian.atlassian.net/browse/AR-1325) Deploy Chromium repo and keys to CLI images too
### [AR-1326](https://armbian.atlassian.net/browse/AR-1326) Add SKEL distribution to all existing users to the postinst script
### [AR-1336](https://armbian.atlassian.net/browse/AR-1336) Fix wallpaper not showing correct in virtual desktop
### [AR-1337](https://armbian.atlassian.net/browse/AR-1337) Re-enable Thunderbird email client for Debian Sid
### [AR-1338](https://armbian.atlassian.net/browse/AR-1338) Add Codium to Debian builds
### [AR-1342](https://armbian.atlassian.net/browse/AR-1342) Switch Codium with Code on x86
### [AR-1343](https://armbian.atlassian.net/browse/AR-1343) Update UEFI configs with latest Ubuntu desktop 22.04
### [AR-1349](https://armbian.atlassian.net/browse/AR-1349) Add Intel sound firmware to the desktops
### [AR-1350](https://armbian.atlassian.net/browse/AR-1350) Deprecating Buster and Focal
### [AR-1351](https://armbian.atlassian.net/browse/AR-1351) Adjust desktop support status
### [AR-1352](https://armbian.atlassian.net/browse/AR-1352) Add initial configuration for Terminator
### [AR-1353](https://armbian.atlassian.net/browse/AR-1353) Define panel shortcuts for Gnome x64 per appgroup
### [AR-1373](https://armbian.atlassian.net/browse/AR-1373) Port legacy kernel Rockchip Hardware Random Number Generator forward into Edge
### [AR-1376](https://armbian.atlassian.net/browse/AR-1376) Replace Ubuntu PRO advertisement
### [AR-1377](https://armbian.atlassian.net/browse/AR-1377) Add plymouth package to base images except minimal
### [AR-1388](https://armbian.atlassian.net/browse/AR-1388) Change purge releases action
### [AR-1404](https://armbian.atlassian.net/browse/AR-1404) Updated box86 and box64
## Bug
### [AR-577](https://armbian.atlassian.net/browse/AR-577) Fix USB port on Rockpi S
### [AR-1060](https://armbian.atlassian.net/browse/AR-1060) Freshly build image doesn't have BRANCH info in /etc/armbian-release
### [AR-1186](https://armbian.atlassian.net/browse/AR-1186) Screen power savings does not work
### [AR-1265](https://armbian.atlassian.net/browse/AR-1265) Rock PI-S images will not boot from internal EMMC \(SDNAND\)
### [AR-1268](https://armbian.atlassian.net/browse/AR-1268) RockPI-S WiFi throughput only 300K bytes/second
### [AR-1269](https://armbian.atlassian.net/browse/AR-1269) RockPI WiFi assigned different MAC address on each boot
### [AR-1305](https://armbian.atlassian.net/browse/AR-1305) CI build wrong images in cron
### [AR-1309](https://armbian.atlassian.net/browse/AR-1309) Some images doesn't want to be built, some are corrupted
### [AR-1310](https://armbian.atlassian.net/browse/AR-1310) Update JetHub D1 \(j100\) u-boot patchset
### [AR-1318](https://armbian.atlassian.net/browse/AR-1318) Replace expired GPG key for Github CLI
### [AR-1330](https://armbian.atlassian.net/browse/AR-1330) CLI images can ran out of space
### [AR-1332](https://armbian.atlassian.net/browse/AR-1332) Missing dependency in Docker images
### [AR-1334](https://armbian.atlassian.net/browse/AR-1334) Nanopi Neo3 does not have DT file in  EDGE
### [AR-1340](https://armbian.atlassian.net/browse/AR-1340) Disable event debugging on UEFI builds
### [AR-1341](https://armbian.atlassian.net/browse/AR-1341) Missing wallpaper in XFCE login screen Armbian Sid
### [AR-1344](https://armbian.atlassian.net/browse/AR-1344) Wrong location of package uninstall
### [AR-1345](https://armbian.atlassian.net/browse/AR-1345) Thunderbird 32b is no more, refactoring - provide it only for 64b
### [AR-1348](https://armbian.atlassian.net/browse/AR-1348) Pine64H b and NPI R1 does not build u-boot
### [AR-1363](https://armbian.atlassian.net/browse/AR-1363) Kernel freezing in armbian-kernel might not work correctly
### [AR-1374](https://armbian.atlassian.net/browse/AR-1374) Hostapd needs to be workarounded
### [AR-1381](https://armbian.atlassian.net/browse/AR-1381) XU4: On a fresh install, after moving root to f2fs eMMC, it fails to boot
### [AR-1384](https://armbian.atlassian.net/browse/AR-1384) Fix RTL8822CS driver. Update build config
### [AR-1385](https://armbian.atlassian.net/browse/AR-1385) Ambian's password rules are annoying
### [AR-1391](https://armbian.atlassian.net/browse/AR-1391) MOTD is not displaying messages correctly
### [AR-1392](https://armbian.atlassian.net/browse/AR-1392) Error triggered when changing BSP package
### [AR-1393](https://armbian.atlassian.net/browse/AR-1393) Converting to u-boot fails on riscv
### [AR-1394](https://armbian.atlassian.net/browse/AR-1394) Update kernel meson mmc driver to set phase clock from dts
### [AR-1395](https://armbian.atlassian.net/browse/AR-1395) Don't add PPA's to the CLI images
### [AR-1398](https://armbian.atlassian.net/browse/AR-1398) nand-sata-install must fail with a proper error message if the chosen mkfs.xyz is not installed
### [AR-1400](https://armbian.atlassian.net/browse/AR-1400) Raspberry Pi is unbootable
### [AR-1403](https://armbian.atlassian.net/browse/AR-1403) Wrong post install handling on install
### [AR-1405](https://armbian.atlassian.net/browse/AR-1405) When using PPA sources we need to run install\_ppa\_prerequisites
Made a release build & images are uploading and syncing. This will take at least a day ... we continue to test. Repository update can wait a bit.
  • Igor unpinned this topic
