January 5, 20233 yr @Igor I tested the XFCE, CLI and Minimal Bullseye images from https://armbian.com/bananapi-m5 (2022-11-30). I tried to build myself one from master (current and edge - bullseye/desktop/xfce), same outcome: it shows the Splashscreen and then stops here: I don't have a USB-to-TTL adapter, so I can't provide more debug informations. The only images that still boot (reliably!) from the SD card are the ones archived here https://imola.armbian.com/archive/bananapim5/archive/ that still used the Kernel 5.19.16. The switch to 6.0.x occurred two weeks ago: https://github.com/armbian/build/commit/ce61bd7827d42c63bc1f763dad5c7e4717e1f75b I tried to checkout the previous commit (20d388b) and to build an image from it, but it failed: So I can't confirm, but I'm under the impression that all the images since the switch to Kernel 6.0.x don't boot anymore from the SD card.
January 5, 20233 yr 3 minutes ago, atone said: I tried to checkout the previous commit (20d388b) and to build an image from it, but it failed: It is difficult to go back but staying on the same kernel branch. Which patches might not work properly. I could point you what to fix, but its pointless going that way. Lets try to stabilise M5 on K6.1 / latest (best working) u-boot. Which is the cause of this: 5 minutes ago, atone said: it shows the Splashscreen and then stops here: SD card / eMMC initialisation is failing. This problem we are fighting with Amlogic for years.
January 5, 20233 yr 38 minutes ago, atone said: Would a USB-to-TTL adapter be useful? I could buy one. They are inexpensive and a necessary tool to have around if you work with sbc's. I would recommend you own one.
January 8, 20233 yr I confirm archive version boot on sdcard without problem, @igor using the same technique I described here There is simply a regression on armbian latest image 30nov imho as pointed by @atone
January 8, 20233 yr The big question is how to flush /boot/ kernel and u-boot updates made by debian after apt upgrade on the U-BOOT partition (BPI declares aarch64 whereas debian packages arm64) ? root@bananapim5:/usr/src# ls /boot/ armbianEnv.txt Image armbian_first_run.txt.template initrd.img-5.19.16-meson64 boot.bmp System.map-5.19.16-meson64 boot.cmd uImage boot.scr uInitrd config-5.19.16-meson64 uInitrd-5.19.16-meson64 dtb vmlinuz-5.19.16-meson64 dtb-5.19.16-meson64 root@bananapim5:/usr/src# uname -a Linux bananapim5 4.9.312-BPI-M5 #1 SMP PREEMPT Tue Sep 6 13:22:04 HKT 2022 aarch64 GNU/Linux Edited January 8, 20233 yr by SoSie
January 9, 20233 yr Solution 23 hours ago, SoSie said: There is simply a regression on armbian latest image Some people had troubles, indeed. Images were replaced today and they have been tested. Try. (download might be slow / not synced to all servers yet / use torrent or retry if you are going to try within next couple of hours)
January 10, 20233 yr YES, I have tested the archive version on the sdcard directly the xfce image , it rocks, I wished to have found this working image earlier that uses kernel 5.19.16-meson64 that brings two huge differences: 1) screen autodetection is perfect (device name is correct and freq is not 0!) 2) enough lighweight to be able to run kodi debian which is a)very reactive b)saturates no processors , when playing mp4 -1024p, 25fps, H264, 128kbit AAC),,load is 200% and well balanced on the 4 cores (I have tested with ubuntu 22.10, raspian,... processor were busy at 70-90% EVEN DOING NOTHING!) SO WELL DONE @Igor and the whole Armbian team !!! for the upgrade of the U-BOOT partition, this is no more required unless we want multiboot...what about a bananaPINN with auto-install to sdcard, whith armbian chooser, installer direct in flash (let's dream for 2023)? Edited January 10, 20233 yr by SoSie
January 11, 20233 yr What @atone obtained , i got it too from Armbian_22.08.7_Bananapim5_bullseye_edge_5.19.16_minimal.img and after upgrading 5.19.16 (22.08.6) to 6.0.10 (22.11.30) with sudo apt upgrade linux-dtb-edge-meson64 sudo apt upgrade linux-image-edge-meson64 sudo apt upgrade linux-u-boot-bananapim5-edge as it removes 5.19.6 boot without asking your opinion, there is no way to go back except manually and externaly. the linux-* packages seems to be virtual, there is nothing in /var/cache/apt/archives FAILSAFE MODE: ============= What I did to come back in case some are stuck is to mount the partition armbi_root within the image decompacted losetup --partscan loop25 Armbian_22.08.7_Bananapim5_bullseye_edge_5.19.16_minimal.img At this point loop25p1 should be available to be mounted somewhere, ideally in /media/$USER/armbi_root. Now do (USER matches the current user USER=`whoami`) cp -a /media/$USER/armbi_root/boot/* <usb_card_root>/boot IMPORTANT: check the UUID in <usb_card_root>/boot/ArmbianEnv.txt matches the UUID declared in <usb_card_root>/etc/fstab, if not fix modify <usb_card_root>/boot/ArmbianEnv.txt ! don't forget to copy the modules.. cp -a /media/$USER/armbi_root/usr/lib/modules/* <usb_card_root>/usr/lib/modules umount <usb_card_root> Now let go back to the past in apt world too.. apt install linux-image-edge-meson64=22.08.6 linux-dtb-edge-meson64=22.08.6 linux-u-boot-bananapim5-edge=22.08.6 PUT & PRAY!!!! CONCLUSION: -The nice Armbian logo went away, even after apt going back (sorry i don't know how to restore it) but it boots back with the 5.19.16 kernel -REALLY HAVING NO FAILSAFE KERNEL IS A MESS! So..Yes multiboot would imho not be an option. Edited January 11, 20233 yr by SoSie
January 11, 20233 yr Author On 1/9/2023 at 10:28 PM, Igor said: Images were replaced today and they have been tested. @SoSie, as @Igor has said, new images are available on https://www.armbian.com/bananapi-m5/ since 2023-01-09. They work flawlessly.
January 11, 20233 yr @atone, @igor and the armbian team thanks for all yours efforts and answers, will check the new release. UPDATE with 6.1.14: -boot works 😃 -looses video signal on my 7'' screen after armbian logo -> console* -> back graphical *with error failed to start Access point and authentication for wifi and Ethernet : this is normal I don't have the wifi module) SO DOES NOT PASS THE TESTS, é_è so I stay with version 22.08.6 Edited January 11, 20233 yr by SoSie
January 12, 20233 yr @atone, I have just tested Bullseye XFCE desktop with the Kernel 6.1.14, Release date: Jan 9, 2023. Maybe it is just an Xorg issue as it boots correctly and display correct on my 23'' but not on 7' (no signal) so for now I freeezed the packages with apt-mark hold to prevent upgrades Edited January 12, 20233 yr by SoSie
January 12, 20233 yr Author 1 hour ago, SoSie said: it boots correctly and display correct on my 23'' but not on 7' @SoSie can you please tell the native resolution of each monitors? thx
January 13, 20233 yr Well @atone the 7" is 1024x600 59.8Hz the 23" is 1920x1080 60Hz the 7" can play 1k videos with not problem so ie h264 mp4 1920x1080 ones ONLY reduced to 1024x600. I tried with lower mp4 it does not work. I thinks it is a limitation of video decoder, I don't have this with my RPI3B. Edited January 13, 20233 yr by SoSie
October 22, 20233 yr SD card images don’t work flawlessly. Actually none of them boot at all. I cleared off my emmc my Banana Pi M5 needs to have a real bootable SD image. At the moment only the Ubuntu images provided by BPI work.
December 23, 20232 yr Have the same problem! One of my 2 M5 only boots the half-official ArchLinux image. Nothing else boots, and I tried all images I could find (Debian, Ubuntu, Armbian, OpenBSD - nothing). Absolutely no idea whats wrong with my M5. Connecting a serial works and I see, that no boot image was found. But it exists, really. B.
