SBC OPI5 freezes after fresh install : cpu frequency
Go to solution Solved by SteeMan,
While I was waiting for my OPI5 to arrive, I searched for which OS to install, in this search I found Armbian.
Armbian 23.02 Jammy "CLI"
https://redirect.armbian.com/orangepi5/Jammy_legacy
Size: 499M, Release date: Feb 27, 2023
Armbian Bullseye "CLI"
https://redirect.armbian.com/region/EU/orangepi5/Bullseye_legacy
Size: 427M, Release date: Feb 27, 2023
I downloaded and installed both versions and the result was the same "freezes" within minutes of booting up.
Hardware:  OPI5 v1.2 / 8GB RAM
How to solve the problem?
Thank !!!
Observation: if I install the "Orangepi5_1.1.2_debian_bullseye_server_linux5.10.110.7z" version the problem does not occur, but I want to use armbian :)
Edited by JamesCL
add more infomation (detail hardware)
  On 3/10/2023 at 10:15 PM, JamesCL said:
Armbian_23.02.2_Uefi-arm64_bullseye_current_5.15.94.img.xz
Expand
That is UEFI generic image which will not work on OPi5 due to lack of UEFI presence.
As you can see above I use the same vendor bsp kernel 5.10.110. Userspace (Bullseye or Jammy to say) make usually no difference since both flavours  are always shipped with the very same kernel package.
The only difference for me is that I disabled debugfs in kernel config to get rid of some dmesg annoyance but thats it.
Again, read and check here: https://forum.armbian.com/forum/31-sd-card-and-psu-issues/
Thank for your reply
I bought an nvme and installed the distro "https://armbian.tnahosting.net/dl/orangepi5/archive/Armbian_23.02.2_Orangepi5_bullseye_legacy_5.10.110.img.xz"
How can I upgrade from 23.02.2 to 23.05.0-trunk?
Thank.
  • Solution
Expand
Either use armbian-config to switch to nightly (unstable) builds, or build images yourself via the build framework.  But either way in doing so you would be switching from a stable build to unstable/under development builds.
Also at this moment do to significant changes in build framework introduced after the release of 23.02, no nightly builds are being produced as issues are being sorted out.
