jumbo125 Posted April 8, 2023 Posted April 8, 2023 (edited) Hello I tried to retasrt my system, but it doesn't work. Before i post my question i found this thread: i can't find a solution in the thread. Does anybody knows, how he fixed it? I need to restart the system. Can i disable the user login to the beginn? i need to start without a login choice. Thank you Edited April 9, 2023 by jumbo125 0 Quote
Igor Posted April 12, 2023 Posted April 12, 2023 On 4/8/2023 at 9:16 AM, jumbo125 said: Can i disable the user login to the beginn? i need to start without a login choice. Expand You mean this? https://www.google.com/search?q=debian+auto+login+cli 0 Quote
jumbo125 Posted April 17, 2023 Author Posted April 17, 2023 yes, but my problem is, that the restart not work. do you have a answer for it? thank you 0 Quote
dev001 Posted April 18, 2023 Posted April 18, 2023 (edited) I have a similar continuous reboot issue and have narrowed it down... I have an odroid-c2 with eMMC module flashed with Armbian_23.02.1_Odroidc2_jammy_current_6.1.14_xfce_desktop I have the following connected to the USB ports. 1) USB to audio headphone/microphone jacks 2) Wifi keyboard dongle Odroid-c2 starts up ok and presents me with the XFCE desktop. The issue is if I have both the eMMC module and a SDHC card on the system and power up the system, it continuously reboots. Note that the SDHC card is not bootable. Just formatted with ext4 Note that I could boot the odroid-c2 with either eMMC module or SDHC card flashed with Armbian. Edited April 18, 2023 by dev001 more info 0 Quote
jumbo125 Posted May 2, 2023 Author Posted May 2, 2023 (edited) Is there any solution to fix the problem or detect the fail? Edited May 2, 2023 by jumbo125 0 Quote
jumbo125 Posted August 8, 2023 Author Posted August 8, 2023 @dev001 i use a 64GB Micro Micro SD Card MicroSDXC. reboot not work. can you give me a tip? 0 Quote
dev001 Posted August 9, 2023 Posted August 9, 2023 My observation is that you should have either an eMMC or SDHC card installed but not both. Installing both would cause a boot issue. 0 Quote
jumbo125 Posted August 9, 2023 Author Posted August 9, 2023 i have only a SDHC card. No eMMC card. Why you believe that i use a eMMC card? 0 Quote
dev001 Posted August 10, 2023 Posted August 10, 2023 I was stating my observation about my odroidc2. If you only have SDHC installed then have you verified that your SDHC is specified as UHS-I? Read this https://forum.odroid.com/viewtopic.php?t=37363 0 Quote
jumbo125 Posted August 13, 2023 Author Posted August 13, 2023 (edited) On 4/18/2023 at 11:25 AM, dev001 said: The issue is if I have both the eMMC module and a SDHC card on the system and power up the system, it continuously reboots. Note that the SDHC card is not bootable. Just formatted with ext4 Expand okay, i check it. My card is ext4 formated 😞 can i change it? which format do i need to maket the sdhc bootable? should it fix the problem, when i convert it? Edited August 13, 2023 by jumbo125 0 Quote
dev001 Posted August 13, 2023 Posted August 13, 2023 As mentioned previously, make sure your SDHC card is specified as UHS-I You do not need to format your SDHC card. You need to flash the card with the Armbian image for the odroidc2. 0 Quote
jumbo125 Posted August 13, 2023 Author Posted August 13, 2023 (edited) On 8/13/2023 at 10:07 AM, dev001 said: You do not need to format your SDHC card. You need to flash the card with the Armbian image for the odroidc2. Expand Okay, i had flashed it with the armbian image for the odroid c2. So my last chance is to check, if it is specified as uhs-i i will try to find it out thank you EDIT: yes it is u1. i have this: https://www.amazon.de/gp/product/B08JYDZ75X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Edited August 13, 2023 by jumbo125 0 Quote
