Odroid-C2 does not start (no boot) after "reboot" command (RE-OPEN), start without login
jumbo125
Hello
I tried to retasrt my system, but it doesn't work.
Before i post my question i found this thread:
i can't find a solution in the thread. Does anybody knows, how he fixed it?
I need to restart the system.
Can i disable the user login to the beginn? i need to start without a login choice.
Thank you
Edited by jumbo125
Link to comment
Share on other sites
  • jumbo125 changed the title to Odroid-C2 does not start (no boot) after "reboot" command (RE-OPEN), start without login
I have a similar continuous reboot issue and have narrowed it down...
I have an odroid-c2 with eMMC module flashed with Armbian_23.02.1_Odroidc2_jammy_current_6.1.14_xfce_desktop
I have the following connected to the USB ports.  1) USB to audio headphone/microphone jacks 2) Wifi keyboard dongle
Odroid-c2 starts up ok and presents me with the XFCE desktop.
The issue is if I have both the eMMC module and a SDHC card on the system and power up the system, it continuously reboots. Note that the SDHC card is not bootable. Just formatted with ext4
Note that I could boot the odroid-c2 with either eMMC module or SDHC card flashed with Armbian.
Edited by dev001
more info
Link to comment
Am 18.4.2023 um 13:25 schrieb dev001:
okay, i check it.
My card is ext4 formated 😞
can i change it? which format do i need to maket the sdhc bootable?
should it fix the problem, when i convert it?
Edited by jumbo125
Link to comment
vor 8 Stunden schrieb dev001:
You do not need to format your SDHC card. You need to flash the card with the Armbian image for the odroidc2.
Okay, i had flashed it with the armbian image for the odroid c2. So my last chance is to check, if it is specified as uhs-i
i will try to find it out
thank you
EDIT: yes it is u1.
i have this:
https://www.amazon.de/gp/product/B08JYDZ75X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Edited by jumbo125
Link to comment
