ReneHegewald Posted April 14, 2023 Share Posted April 14, 2023 Hello, i like to activate / use more RS232 UARTS. What is the best way to do this ? Thanks a lot, René 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 14, 2023 Share Posted April 14, 2023 Check armbian-config for DTB overlays. 0 Quote Link to comment Share on other sites More sharing options...
ReneHegewald Posted April 14, 2023 Author Share Posted April 14, 2023 i had .. but i don't understand what todo to activate ... 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 14, 2023 Share Posted April 14, 2023 Once chosen and restarted check dmesg for activated serial consoles. They probably pop up as devices like /dev/ttyS1 and so on. 0 Quote Link to comment Share on other sites More sharing options...
ReneHegewald Posted April 14, 2023 Author Share Posted April 14, 2023 i can only edit the DTB File .. there is no point for DTB overlays 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 14, 2023 Share Posted April 14, 2023 armbian-config, go to system, go to hardware then you see a menu like this: Check for uart options. 0 Quote Link to comment Share on other sites More sharing options...
ReneHegewald Posted April 19, 2023 Author Share Posted April 19, 2023 Hi Werner, i tried, but it does not work. i see the Overlay Settings in the armbianEnv.txt After Linux was bootet, i don't see the new Serial UARTS in "dmesg" o neither in /dev/ttyS* 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 19, 2023 Share Posted April 19, 2023 I dont have this hw. Need somebody with the board to confirm if either it works or not. 0 Quote Link to comment Share on other sites More sharing options...
ReneHegewald Posted May 8, 2023 Author Share Posted May 8, 2023 @linhz0hz can you please test and verify ? 🙂 0 Quote Link to comment Share on other sites More sharing options...
ReneHegewald Posted May 23, 2023 Author Share Posted May 23, 2023 @tkaiser have you a change to verify this ? 🙂 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 23, 2023 Share Posted May 23, 2023 If its not in the menu, it means overlays weren't developed. Our capacity for development is limited as with this its not possible to hire many people that will serve you. We will probably do this once, but we have many many other issues to fight. If you are asking Armbian volunteer maintainers to sponsor development (for your business or fun), you ask once, then perhaps go and hire professional to do the coding for you and then you share with others. This is how you can make someone else happy. No offence, but project owes you nothing, contrary. If this is something critical for you, then it won't be a problem supporting people that helps you? If you want to get a quote for developing this, you need to be at least gold partner. This is how we try to cover the loss of providing software for free. For you and open source pirates that are not contributing to open source while providing Armbian under different name(s). Please do not @call people if they aren't your friends. 0 Quote Link to comment Share on other sites More sharing options...
ReneHegewald Posted May 23, 2023 Author Share Posted May 23, 2023 Hi Igor, it is for fun 🙂 and learn ... the Overlay is in the Menu, but does not work .... and i don't know how to debug this. Best regards, René 0 Quote Link to comment Share on other sites More sharing options...
Marco Schirrmeister Posted May 24, 2023 Share Posted May 24, 2023 (edited) Rene, with an installation of the official image like Bullseye with the 5.10 kernel, it should work. Maybe you did some modifications? If so, try it with a fresh installation. Without any changes I can see "ttyS6". After enabling all uart in armbian-config, I can see more after a reboot. root@rock-5b ~# ls -la /dev/ttyS* crw--w---- 1 root tty 4, 66 May 24 08:55 /dev/ttyS2 crw-rw---- 1 root dialout 4, 67 May 24 08:55 /dev/ttyS3 crw-rw---- 1 root dialout 4, 68 May 24 08:55 /dev/ttyS4 crw-rw---- 1 root dialout 4, 70 May 24 08:55 /dev/ttyS6 crw-rw---- 1 root dialout 4, 71 May 24 08:55 /dev/ttyS7 In the images from balbes150, with some 6.x kernel, I think you can see more ttyS by default. Edited May 24, 2023 by Marco Schirrmeister 0 Quote Link to comment Share on other sites More sharing options...
