Ilya Zonov Posted November 1, 2016 Posted November 1, 2016 Hello! I have faced with following issue on CubieBoard. After upgrade from 5.11 to 5.23 I can't mount cifs remote drive (Apple Time Capsule). There is only one log in syslog during mount attempt. sun4i-ss 1c15000.crypto-engine: ERROR: Empty IV Is it known issue?
Igor Posted November 1, 2016 Posted November 1, 2016 Unknown issue. Try upgrade kernel to the one from daily (4.8.6) or development build (4.9.x).
gTs2 Posted November 1, 2016 Posted November 1, 2016 or try putting blacklist sun4i_ss into /etc/modprobe.d/sun4i.conf
Ilya Zonov Posted November 1, 2016 Author Posted November 1, 2016 Hello! I have tested @gTS2 solution. Cifs mount works fine with sun4i_ss in blacklist. What I miss with this option? @Igor, I will test daily and dev kernels later.
Ilya Zonov Posted November 1, 2016 Author Posted November 1, 2016 Hi, Igor! I have tested 4.9.0 kernel on my Cubieboard (A10, Debian jessie). The same issue: root@cubieboard:~# mount.cifs //10.0.1.1/Data /mnt/cifs -o sec=ntlm Password for root@//10.0.1.1/Data: ******** mount error(22): Invalid argument Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) root@cubieboard:~# uname -a Linux cubieboard 4.9.0-sunxi #6 SMP Sun Oct 23 16:00:06 CEST 2016 armv7l GNU/Linux root@cubieboard:~# tail /var/log/messages Nov 1 21:50:32 localhost kernel: [ 47.234972] vdd-cpu: ramp_delay not set Nov 1 21:50:32 localhost kernel: [ 47.485529] vdd-cpu: ramp_delay not set Nov 1 21:50:32 localhost kernel: [ 47.785429] vdd-cpu: ramp_delay not set Nov 1 21:50:42 localhost kernel: [ 57.796352] vdd-cpu: ramp_delay not set Nov 1 21:50:43 localhost kernel: [ 58.355434] vdd-cpu: ramp_delay not set Nov 1 21:50:49 localhost kernel: [ 64.115095] vdd-cpu: ramp_delay not set Nov 1 21:50:49 localhost kernel: [ 64.595420] vdd-cpu: ramp_delay not set Nov 1 21:50:55 localhost kernel: [ 71.020496] Key type cifs.idmap registered Nov 1 21:50:55 localhost kernel: [ 71.026614] vdd-cpu: ramp_delay not set Nov 1 21:50:56 localhost kernel: [ 71.785428] vdd-cpu: ramp_delay not set root@cubieboard:~# tail /var/log/syslog Nov 1 21:50:32 localhost kernel: [ 47.485529] vdd-cpu: ramp_delay not set Nov 1 21:50:32 localhost kernel: [ 47.785429] vdd-cpu: ramp_delay not set Nov 1 21:50:42 localhost kernel: [ 57.796352] vdd-cpu: ramp_delay not set Nov 1 21:50:43 localhost kernel: [ 58.355434] vdd-cpu: ramp_delay not set Nov 1 21:50:49 localhost kernel: [ 64.115095] vdd-cpu: ramp_delay not set Nov 1 21:50:49 localhost kernel: [ 64.595420] vdd-cpu: ramp_delay not set Nov 1 21:50:55 localhost kernel: [ 71.020496] Key type cifs.idmap registered Nov 1 21:50:55 localhost kernel: [ 71.026614] vdd-cpu: ramp_delay not set Nov 1 21:50:55 localhost kernel: [ 71.030719] sun4i-ss 1c15000.crypto-engine: ERROR: Empty IV Nov 1 21:50:56 localhost kernel: [ 71.785428] vdd-cpu: ramp_delay not set Also I have tried to downgrade to 3.4 kernel. But I received unbootable image. Board just switch off after "Starting kernel". The same issue after clean install 5.20 with legacy 3.4 kernel. It seems module blacklist is the only option now.
sooperior Posted November 13, 2016 Posted November 13, 2016 I think as a new bug on the allwinner security system sun4i-ss kernel module (maybe new version in armbian) or something changed on the armbian kernel that conflicts with this module. I have come to the same problem with ecryptfs, which internally uses ss. sun4i-ss 1c15000.crypto-engine: ERROR: Empty IV I have tested the same solution (blacklisting module) and it works. You just lose hardware acceleration (=slower)
Ilya Zonov Posted November 14, 2016 Author Posted November 14, 2016 sooperior, thanks for info. Where can we report this issue?
Igor Posted November 14, 2016 Posted November 14, 2016 sooperior, thanks for info. Where can we report this issue? Corentin Labbe <clabbe.montjoie@gmail.com> http://sunxi.montjoie.ovh/
Honor Posted February 4, 2017 Posted February 4, 2017 hello i have a same problem, mount.cifs //192.168.1.10/Elements /media/elements/ Password for root@//192.168.1.10/Elements: mount error(22): Invalid argument Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) uname -a Linux bananapi 4.8.4-sunxi #6 SMP Sun Oct 23 15:55:47 CEST 2016 armv7l armv7l armv7l GNU/Linux how can fix problem?? thx
martinayotte Posted February 4, 2017 Posted February 4, 2017 You need to provide option to specify username, look at the man page. Also you can avoid calling mount.cifs directly and use traditional mount : mount -t cifs //server/share /mnt --verbose -o user=username
eternalWalker Posted February 4, 2017 Posted February 4, 2017 (?) apt-get install cifs-utils great eW
