I've spent the entire morning trying to boot armbian on a vim 3 basic.
It won't boot from sdcard.
I erased the emmc with krescue, no change except now it doesn't boot anything, except the krescue sdcard.
I put the armbian image on a USB stick and tried to flash it to emmc
With krescue but krescue says it's an invalid vim 3 image.
I verified the Sha and I also tried using the extracted dot img file. Which isn't recognized by krescue.
How do I boot an sdcard or flash the emmc
When none of these things work?
The only thing that boots now is the krescue sdcard.
What am I doing incorrectly?  What else can I try?
So I've tried booting both jammy
Currents from SD card. Neither work.
I tried installing them to emmc with krescue and it says they are unsuitable for this board.
I booted and installed manjaro from/on sdcard with no problems.
I checked the Sha of both jammy images and both match up.
I don't know what is going on. But manjaro boots and armbian doesn't.
Yes those are the exact images I used.
I erased the emmc with krescue to get rid of Android.
I did a zcat | dd to write the images to sdcard, the same way I did manjaro.  I let them sit for a very long time.
Manjaro and krescue come right up.
I also copied them to a usb stick as is for krescue to try to install them.
Krescue says the images are unsuitable. I don't know why.
I didn't try that with manjaro yet.
The board is a vim 3 basic with 4g. Nothing special. Just plugged it in.
Not even in a case yet.
I was able to recreate the problem when having Android on the eMMC.
The new way Igor used didn't work for me. Used krescue to format eMMC and SPI. But then it didn't boot at all with the latest Armbian image.
The boot loop.
I then used OOWOW to install Ubuntu to the eMMC. And with Ubuntu on eMMC you can boot the latest Armbian image from SD and install to eMMC.
Igor asked me to help you with the launch of Armbian. Show the UART startup log in two states - Armbian start from SD card and kreskue start from SD card. IMHo kreskue is a bad tool and I would not advise using it, everything can be done without it.
@balbes150 What configuration you want the output from? Non-working Armbian with Android on eMMC or working with Ubuntu on eMMC
Output of Armbian on SD with Ubuntu on eMMC, so working Armbian.
OPTIONS: I18n
Port /dev/ttyUSB0, 20:31:52
Press CTRL-A Z for help on special keys
G12B:BL:6e7c85:2a3b91;FEAT:E0F83180:402000;POC:F;RCY:0;EMMC:0;READ:0;0.
        bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0000 - pwm id 0x01
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 81350
BL2 Built : 19:23:21, Sep 18 2020. g12b g9fde858 - gongwei.chen@droid11-sz
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 00018653
eMMC boot @ 0
sw8 s
board id: 6
Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
Get wrong ddr fw magic! Error!!
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
ddr saved addr:00016000
Load ddr parameter from eMMC, src: 0x02c00000, des: 0xfffd0000, size: 0x00001000, part: 0
00000000
emmc switch 0 ok
fastboot data verify
result: 255
Cfg max: 12, cur: 1. Board id: 255. Force loop cfg
LPDDR4 probe
LPDDR4_PHY_V_0_1_22-Built : 14:57:26, Sep  1 2020. g12b g3c95fed - gongwei.chen@droid11-sz
ddr clk to 1608MHz
dmc_version 0001
Check phy result
INFO : ERROR : Training has failed!
Check phy result
Check phy result
INFO : End of initialization
1D training failed
Cfg max: 12, cur: 2. Board id: 255. Force loop cfg
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
INFO : End of CA training
INFO : Training has run successfully!
Check phy result
INFO : End of read enable training
INFO : End of fine write leveling
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of Write leveling coarse delay
INFO : End of read delay center optimization
Check phy result
INFO : End of write delay center optimization
INFO : End of max read latency training
1D training succeed
Check phy result
INFO : End of 2D read delay Voltage center optimization
INFO : End of 2D write delay Voltage center optimization
soc_vref_reg_value 0x 00000021 0000001f 00000020 00000022 00000020 00000021 00000020 0000001f 00000021 00000
 dram_vref_reg_value 0x 00000048
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002cDDR size: 2048MB
cs0 DataBus test pass
cs0 AddrBus test pass
non-sec scramble use zero key
ddr scramble enabled
100bdlr_step_size ps== 409
result report
boot times 0Enable ddr reg access
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000a8400, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
[Image: g12b_v1.1.3390-6ac5299 2019-09-26 14:10:05 luan.yuan@droid15-sz]
OPS=0x10
ring efuse init
3 USB Device(s) found
Setting bus to 0
Hit SPACE in 2 seconds to stop autoboot
Device 0: unknown device
Card did not respond to voltage select! : -110
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.cmd
8075 bytes read in 3 ms (2.6 MiB/s)
## Script run a:08000000 l:8075 c:0
U-boot default fdtfile: amlogic/meson-g12b-a311d-khadas-vim3.dtb
Current variant:
224 bytes read in 2 ms (109.4 KiB/s)
Current fdtfile after armbianEnv: amlogic/meson-g12b-a311d-khadas-vim3.dtb
Mainline bootargs: root=UUID=bf2b5748-1fdf-468e-8f90-9eb3f62d8337 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart=ec3a7ada-01
23250284 bytes read in 1050 ms (21.1 MiB/s)
27034112 bytes read in 1216 ms (21.2 MiB/s)
78594 bytes read in 6 ms (12.5 MiB/s)
232 bytes read in 3 ms (75.2 KiB/s)
Applying kernel provided DT fixup script (meson-fixup.scr)
## Executing script at 32000000
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   uInitrd
   Data Size:    23250220 Bytes = 22.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 04080000
   Booting using the fdt blob at 0x4080000
   Loading Ramdisk to 7a8eb000, end 7bf1752c ... OK
   Loading Device Tree to 000000007a86f000, end 000000007a8eafff ... OK
Starting kernel ...
[    8.155454] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4359-sdio for chip BCM4359/9
[   10.592229] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[   10.604339] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4359/9 wl0: Mar  6 2017 10:16:06 version 9.87.51.7 (r686312) FWID 01-4dcc75d9
[   13.240235] ieee80211 phy0: brcmf_dongle_roam: WLC_SET_ROAM_TRIGGER error (-52)
Armbian 23.5.1 Jammy ttyAML0
khadas-vim3 login: [   20.973208]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   20.974538]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   20.982599]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   20.989201]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   20.996978]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.003710]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.011660]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.018458]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.026356]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.032872]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.041177]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.047466]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.055237]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.062032]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.069779]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.076591]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.084494]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.091184]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.099058]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.105797]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.114210]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.120332]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.128210]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.135111]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.142882]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.149507]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.157460]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.164066]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.172149]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.178644]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.187210]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.193217]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.201088]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.207796]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.215640]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.222378]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.230319]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.236930]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.244892]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.251513]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.261383]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.266110]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.273873]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.280664]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.288433]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.295261]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.303189]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.309815]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.317688]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.324395]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.332745]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.338986]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.346759]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.353554]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.361313]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.368128]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.376019]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.382704]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.390609]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.397276]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.405715]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.411871]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.419695]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.426428]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.434244]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.441008]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.448962]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.455608]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.463556]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.470163]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.478811]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.484767]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.492603]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.499318]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.507186]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.513897]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.521859]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.528465]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   21.536427]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   21.543048]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.051227]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.052571]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.060355]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.067156]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.074911]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.081726]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.089614]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.096295]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.104209]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.110984]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.119315]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.125462]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.133205]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.140030]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.147782]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.154603]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.162484]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.169177]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.177051]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.183758]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.192268]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.198332]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.206180]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.212908]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.220753]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.227516]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.235424]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.242069]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.249979]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.256679]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.265163]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.271239]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.279064]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.285803]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.293636]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.300365]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.308378]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.314946]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.322916]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.329518]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.338839]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.344109]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.351860]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.358674]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.366424]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.373244]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.381110]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.387825]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.395690]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.402402]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.410672]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.416989]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.424755]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.431567]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.439312]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.446128]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.453994]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.460702]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.468557]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.475283]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.483687]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.489863]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.497691]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.504437]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.512259]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.519017]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.526944]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.533601]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.541526]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.548177]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.556666]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.562747]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.570602]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.577315]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.585149]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.591896]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.599837]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.606477]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.614411]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.621045]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.643731]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.645069]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.652867]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.659659]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.667411]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.674228]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.674447]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.688791]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.696698]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.703394]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.711781]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.718042]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.725733]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.732533]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.740289]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.747109]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.754969]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.761695]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.769546]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.776252]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.784758]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.790847]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.798679]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.805409]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.813229]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.819986]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.827948]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.834571]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.842505]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.849148]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.857612]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.863728]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.871564]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.878293]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.886134]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.892871]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.900819]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.907453]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.915392]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.922024]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.931339]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.936606]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.944351]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.951174]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.958920]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.965747]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.973609]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.980326]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   22.988208]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   22.994903]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.003174]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.009496]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.017240]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.024057]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.031800]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.038632]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.046498]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.053206]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.061055]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.067786]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.076208]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.082375]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.090211]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.096953]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.104772]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.111528]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.119444]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.126099]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.134067]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.140671]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.149219]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.155255]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.163119]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.169821]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.177659]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.184395]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.192361]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.198971]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.206938]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.213560]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.234847]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.236192]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.243961]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.250773]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.258546]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.265335]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.273237]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.279936]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.287826]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.294500]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.302756]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.309070]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.316823]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.323650]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.331394]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.338222]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.346091]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.352792]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.360654]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.367372]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.375796]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.381970]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.389780]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.396541]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.404417]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.411118]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.419047]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.425687]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.433612]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.440252]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.448866]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.454835]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.462697]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.469416]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.477250]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.483990]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.491930]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.498565]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.506517]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.513142]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.522330]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.527726]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.535487]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.542290]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.550040]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.556861]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.564751]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.571446]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.579303]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.586024]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.594276]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.600602]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.608345]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.615173]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.622934]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.629752]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.637612]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.644315]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.652220]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.658905]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.667324]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.673485]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.681312]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.688055]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.695875]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.702641]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.710582]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.717202]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.725146]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.731783]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.740311]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.746364]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.754217]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.760932]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.768806]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.775526]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.783637]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.790114]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.798714]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.804812]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.845154]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.846502]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.854451]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.861114]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.868892]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.875744]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.883599]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.890262]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.898172]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.904837]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.914914]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.919427]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.927303]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.933985]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.941814]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.948580]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.956520]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.963142]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.971082]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.977726]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   23.986284]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   23.992303]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.000156]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.006858]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.014699]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.021446]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.029425]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.036028]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.043999]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.050592]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.059126]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.065187]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.073059]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.079769]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.087706]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.094346]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.102327]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.108996]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.117120]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.123486]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.134405]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.138044]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.145805]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.152629]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.160436]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.167227]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.175103]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.181762]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.189633]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.196400]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.205021]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.210959]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.218752]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.225487]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.233285]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.240064]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.248177]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.254651]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.262559]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.269271]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.277653]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.283824]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.291613]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.298399]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.306175]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.312954]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.320854]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.327533]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.335421]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.342104]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.351386]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.356682]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.364587]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.371259]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.379137]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.385834]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.393871]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.400409]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.408370]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.414988]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.437539]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.438862]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.446778]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.453449]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.461489]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.468027]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.476033]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.482622]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.490491]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.497229]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.505514]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.511795]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.519507]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.526378]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.534118]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.540941]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.548805]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.555527]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.563666]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.570090]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.578722]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.584643]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.592538]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.599223]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.607044]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.613880]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.621725]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.628416]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.636293]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.642947]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.651414]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.657584]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.665397]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.672114]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.680018]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.686685]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.694811]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.701245]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.709340]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.715830]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.726142]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.730415]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.738159]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.745019]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.752733]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.759597]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.767436]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.774143]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.782031]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.788713]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.797534]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.803312]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.811097]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.817873]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.825635]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.832442]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.840336]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.847022]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.854871]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.861634]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.869966]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.876228]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.883985]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.890733]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.898518]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.905308]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.913258]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.919889]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.927752]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.934471]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.942884]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.949044]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.956844]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.963614]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.971399]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.978198]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   24.986068]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   24.992767]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
[   25.000653]  fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0
[   25.007341]  fe.dai-link-0: ASoC: error at dpcm_fe_dai_prepare on fe.dai-link-0: -22
Here boot with krescue on sd with Ubuntu on eMMC : Edit : it was OOWOW and not krescue, had both sd-cards and saw the files for oowow with rescue...
OPTIONS: I18n
Port /dev/ttyUSB0, 20:43:37
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 81038
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 0001851b
eMMC boot @ 0
sw8 s
board id: 6
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 0 ok
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000022 0000001f 00000020 00000023 00000020 00000021 00000020 0000001f 00000021 00000020 00000020 00000021 00000022 00000022 00000021 00000021 00000022 00000022 00000022 00000020 00000021 00000020 00000021
2D training succeed
DDR cs1 size: 0MB
100bdlr_step_size ps== 403
result report
00000000
emmc switch 3 ok
00000000
emmc switch 0 ok
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
29 0b 10 00 01 0c 0c 00 00 03 37 30 4e 42 4e 50
[0.018961 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):4fc40b1
NOTICE:  BL31: Built : 15:58:17, May 22 2019
NOTICE:  BL31: G12A normal boot!
NOTICE:  BL31: BL33 decompress pass
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2021.04 (Dec 29 2022 - 05:09:22 +0000) khadas-vim3
Model: Khadas VIM3
SoC:   Amlogic Meson G12B (A311D) Revision 29:b (10:2)
DRAM:  2 GiB
MMC:   sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
In:    serial
Out:   serial
Err:   serial
fusb302_init: Device ID: 0x91
CC connected in 1 as UFP
fusb302 detect chip.port_num = 0
Net:   eth0: ethernet@ff3f0000
Failed to load 'splash.bmp'
Can't set block device
1080138 bytes read in 27 ms (38.2 MiB/s)
DISPLAY: setup failsave FullHD mode
starting USB...
Bus usb@ff500000: Register 3000140 NbrPorts 3
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 3 USB Device(s) found
Setting bus to 0
Scanning mmc 1:1...
Found U-Boot script /boot.ini
9921 bytes read in 2 ms (4.7 MiB/s)
## Script run a:08000000 l:9893 c:0
saradc: 0x0, hw_ver: 0x32 (VIM3.V12)
[i] rescue loading via fatload mmc 1 ...
[w] maxcpus not defined
t# amlogic/meson-g12b-a311d-khadas-vim3.dtb amlogic/
t# amlogic/meson-g12b-a311d-khadas-vim3.dtb ""/
** OOWOW load... by fatload mmc 1 FROM // emmc+ post:  // VIM3.V12 // VIM3.V12 **
load env
fatload mmc 1 0x32000000 /rescue/80_user_env.txt
580 bytes read in 2 ms (283.2 KiB/s)
env import -t 0x32000000 244
mainline uboot detected
addrs:  UIMAGE_ADDR ::  UINITRD_ADDR ::  DTB_ADDR
addrs: 0x08080000 :: 0x13000000 :: 0x08008000
setenv kernel_addr_r 0x08080000; setenv ramdisk_addr_r 0x13000000; setenv fdt_addr_r 0x08008000;
load dtb
fatload mmc 1 0x08008000 /rescue/fdt.kresq/amlogic/meson-g12b-a311d-khadas-vim3.dtb
76986 bytes read in 6 ms (12.2 MiB/s)
fdt addr 0x08008000
libfdt fdt_path_offset() returned FDT_ERR_BADPATH
port mode is usb3.0
** port mode is 0 **
load packed initrd
fatload mmc 1 0x13000000 /rescue/uInitrd
9565248 bytes read in 414 ms (22 MiB/s)
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
[i] bootargs: rw panic=10 net.ifnames=0 loglevel=4 fbcon=font:TER16x32 video=HDMI-A-1:1920x1080@60e kresq_type=sd config_test=sd booted=emmc hwver=VIM3.V12 no_console_suspend consoleblank=0 dtb=/rescue/fdt.kresq/amlogic/meson-g122
[i] bootcmd:  run distro_bootcmd
load packed kernel
bootm 0x08080000 0x13000000 0x08008000
fatload mmc 1 0x08080000 /rescue/uImage
6549213 bytes read in 286 ms (21.8 MiB/s)
## Booting kernel from Legacy Image at 08080000 ...
   Image Name:   kernel
   Image Type:   AArch64 Linux Kernel Image (gzip compressed)
   Data Size:    6549149 Bytes = 6.2 MiB
   Load Address: 0d080000
   Entry Point:  0d080000
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (uncompressed)
   Data Size:    9565184 Bytes = 9.1 MiB
## Flattened Device Tree blob at 08008000
   Booting using the fdt blob at 0x8008000
   Uncompressing Kernel Image
   Loading Ramdisk to 7b5f8000, end 7bf17400 ... OK
   Loading Device Tree to 000000007b5e2000, end 000000007b5f7cb9 ... OK
Starting kernel ...
Wed Mar  8 00:00:00 UTC 2023
[i] INITRD INIT :: UPTIME: 1.91 9.70 Linux (none) 5.14.0-rc5 #1 SMP PREEMPT Mon Mar 6 11:05:15 CST 2023 aarch64 GNU/Linux
#MANUAL
    link/ether c8:63:14:70:41:c2 brd ff:ff:ff:ff:ff:ff
[    2.039785] rc_core: IR keymap rc-khadas not found
Failed to connect to ubus
BusyBox v1.30.1 () built-in shell (ash)
OOWOW system ## hyphop ## khadas
build 230308.000 from Wed Mar  8 00:00:00 2023
[i] Device: VIM3 Amlogic:G12B ver:0x0001 6 cores 2GB ram 16GB eMMC
[w] root password undefined
[i] just type > system < to start gui menu
root@vim3-c0c01:/#
If you want non-working Armbian with Android or with cleared eMMC + SPI, let me know.
There's also no HDMI-audio but a dummy output. I'd like to see that fixed too if possible. Cheers.
So that wasn't krescue but oowow.
Here is krescue with Ubuntu on eMMC
OPTIONS: I18n
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 80718
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 000183da
eMMC boot @ 0
sw8 s
board id: 6
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 0 ok
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000021 0000001f 00000020 00000022 00000020 00000021 00000020 0000001f 00000021 0000001f 00000020 00000020 00000021 00000021 00000021 00000020 00000022 00000023 00000022 00000020 00000021 00000020 00000021
2D training succeed
DDR cs1 size: 0MB
result report
00000000
emmc switch 3 ok
00000000
emmc switch 0 ok
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[0.018960 Inits done]
secure task start!
high task start!
low task start!
run into bl31
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
7660 bytes read in 2 ms (3.7 MiB/s)
starting USB...
USB XHCI 1.10
Setting bus to 0
Scanning mmc 1:1...
9502 bytes read in 2 ms (4.5 MiB/s)
## Script run a:08000000 l:9474 c:0
** KRESCUE START hwver: VIM3.V12 hostname: meson-g12b-a311d-khadas-vim3 maxcpus:  fdt: amlogic/meson-g12b-a311d-khadas-vim3.dtb source: emmc: target: mmc1**
**KRESCUE LOAD by fatload mmc 1 FROM // emmc+ post:  // VIM3.V12 // VIM3.V12**
load env
1898 bytes read in 2 ms (926.8 KiB/s)
env import -t 0x32000000 76a
KRESCUE_TIME: 1641796810
KRESCUE_DATE: Mon Jan 10 06:40:10 2022
KRESCUE_VER : 220110_266
load dtb
port mode is usb3.0
load packed initrd
9155280 bytes read in 396 ms (22 MiB/s)
[i] bootargs: rw panic=10 net.ifnames=0 loglevel=4 fbcon=font:TER16x32 video=HDMI-A-1:1920x1080@60e config_firewall=private kresq_type=sd config_test=sd booted=emmc hwver=VIM3.V12 no_console_suspend consoleblank=0 dtb=/rescue/fdt2
load packed kernel
6547474 bytes read in 286 ms (21.8 MiB/s)
   Image Name:   kernel
   Data Size:    6547410 Bytes = 6.2 MiB
   Image Name:   uInitrd
   Data Size:    9155216 Bytes = 8.7 MiB
   Loading Ramdisk to 7b65c000, end 7bf17290 ... OK
   Loading Device Tree to 000000007b646000, end 000000007b65bcb9 ... OK
Starting kernel ...
[i] INITRD INIT :: UPTIME: 1.84 9.14 Linux (none) 5.14.0-rc5 #1 SMP PREEMPT Wed Dec 15 10:08:36 CST 2021 aarch64 GNU/Linux
[i] init display
failed to find a module named meson_ee_pwrc
failed to find a module named meson_dw_hdmi
#MANUAL
# Krescue
     __ _____  Khadas ## hyphop ##
    / //_/ _ \___ ___ ______ _____
   / ,< / , _/ -_|_-</ __/ // / -_)
  /_/|_/_/|_|\__/___/\__/\_,_/\__/
 extreme tiny and fast rescue system
BUILD: 220110_266 from: Mon Jan 10 06:40:10 2022
[i] POST_CONFIG: kresq_type=sd + booted=emmc + || start: /dev/mmcblk0
[i] Device: VIM3 Amlogic:G12B ver:0x0001 6 cores 2G ram 14.5 G eMMC
[i] just type > krescue < to start gui
root@Krescue:/#
CTRL-A Z for help
12 часов назад, NicoD сказал:
If possible, I am interested in the Armbian startup log from the SD card with the VIM3 in its normal state, as it arrives to users upon purchase (i.e. the default factory state of SPI\eMMC).
@balbes150So I installed Android on eMMC. I think that's how it's shipped. But I'm having a very hard time to read out uart because it goes way too fast and forgets the top because too much info. I can show you the top of it and the last, but there's a whole part missing.
The top, so Armbian SD non-working with Android on eMMC. Boots into Android...
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 12:28:00
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 237255
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 0003e7ab
eMMC boot @ 0
sw8 s
board id: 6
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 0 ok
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
2D training succeed
DDR cs1 size: 0MB
100bdlr_step_size ps== 431
result report
00000000
emmc switch 3 ok
00000000
emmc switch 0 ok
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000e1400, part: 0
[Image: g12b_v1.1.3396-c893a7153 2020-11-11 13:54:36 gongwei.chen@droid11-sz]
OPS=0x10
ring efuse init
chipver efuse init
[0.016082 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):5c909a099
NOTICE:  BL31: Built : 17:18:21, Nov 20 2020
U-Boot 2015.01-g659d7a71e9-dirty (Jan 30 2023 - 14:15:46)
DRAM:  2 GiB
Relocation Offset is: 76e23000
mmu cfg end: 0x80000000
spi_post_bind(spicc): req_seq = 0
spi_post_bind(spifc): req_seq = 1
register usb cfg[0][1] = 0000000077f31960
aml_i2c_init_port init regs for 0
MCU version: 0x00 0x01
MCU version is to low! Doesn't support froce boot from SD card.
NAND:  MMC:   aml_priv->desc_buf = 0x0000000073e13b10
aml_priv->desc_buf = 0x0000000073e15e50
SDIO Port B: 0, SDIO Port C: 1
co-phase 0x3, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x3ff2800
emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x3ff2800
co-phase 0x1, tx-dly 0, clock 40000000
[set_emmc_calc_fixed_adj][875]find fixed adj_delay=20
init_part() 297: PART_TYPE_AML
[mmc_init] mmc init success
start dts,buffer=0000000073e186c0,dt_addr=0000000073e186c0
get_partition_from_dts() 92: ret 0
parts: 17
00:      logo   0000000000800000 1
01:  recovery   0000000001800000 1
02:      misc   0000000000800000 1
03:      dtbo   0000000000800000 1
04:  cri_data   0000000000800000 2
05:     param   0000000001000000 2
06:      boot   0000000001000000 1
set has_boot_slot = 0
07:       rsv   0000000001000000 1
08:  metadata   0000000001000000 1
09:    vbmeta   0000000000200000 1
10:       tee   0000000002000000 1
11:    vendor   000000001f000000 1
12:       odm   0000000008000000 1
13:    system   0000000078800000 1
14:   product   0000000008000000 1
15:     cache   0000000046000000 2
16:      data   ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!!
crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!!
crc32_s:0x79f50f07 == storage crc_pattern:0x79f50f07!!!
mmc env offset: 0x4d400000
In:    serial
Out:   serial
Err:   serial
aml log : internal sys error!
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-3354: calc c731f02c, store 0
update_dtb_info()-3462: cpy 1 is not valid
update_dtb_info()-3462: cpy 0 is not valid
dtb_read()-3569: total valid 0
emmc - EMMC sub system
Usage:
emmc dtb_read addr size
emmc dtb_write addr size
emmc erase dtb
emmc erase key
emmc fastboot_read addr size
emmc fastboot_write addr size
amlkey_init() enter!
[EFUSE_MSG]keynum is 1
vpu: driver version: v20190313
vpu: detect chip type: 9
vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz)
vpu: clk_level in dts: 7
vpu: vpu_power_on
vpu: set_vpu_clk
vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100)
vpu: set_vpu_clk finish
vpu: vpu_module_init_config
vpp: vpp_init
vpp: vpp osd2 matrix rgb2yuv..............
hdr_func 4, hdr_process_select 0x1
LCD_RESET PIN: 0
lcd: lcd_debug_print flag: 0
lcd: detect mode: tablet, key_valid: 0
lcd: detect lcd_clk_path: 1
lcd: failed to get lcd_cpu_gpio_names
lcd: load config from dts
lcd: pinctrl_version: 2
lcd: use panel_type=lcd_1
lcd: bl: pinctrl_version: 2
lcd: bl: name: backlight_pwm, method: 1
lcd: error: gpio: wrong name invalid
lcd: bl: pwm_reg=0x00800002
lcd: bl: aml_bl_power_ctrl: 0
Net:   use internal ethernet
--------ext_ethernet=0
+++++++++ext_ethernet=0
dwmac.ff3f0000 Waiting for PHY auto negotiation to complete...
And the last part...
3.214974@4] PPMGRDRV: info: ppmgr_dev major:507
[    3.220049@4] ionvideo-000: V4L2 device registered as video13
[    3.225441@4] ionvideo-001: V4L2 device registered as video14
[    3.231158@4] ionvideo-002: V4L2 device registered as video15
[    3.236888@4] ionvideo-003: V4L2 device registered as video16
[    3.242597@4] ionvideo-004: V4L2 device registered as video17
[    3.248316@4] ionvideo-005: V4L2 device registered as video18
[    3.254050@4] ionvideo-006: V4L2 device registered as video19
[    3.259759@4] ionvideo-007: V4L2 device registered as video20
[    3.265477@4] ionvideo-008: V4L2 device registered as video21
[    3.271132@4] ionvid: info: Video Technology Magazine Ion Video
[    3.277026@4] ionvid: info: Capture Board ver 1.0 successfully loaded
[    3.283567@4] picdec: picdec_driver_probe called.
[    3.288259@4] picdec: probe of picdec failed with error -22
[    3.293781@4] videosync_create_instance dev_s ffffffc00c4c3000,dev_s->dev ffffffc00c56cd00
[    3.301899@4] videosync_create_instance reg videosync.0
[    3.307152@4] aml_vecm_init:module init
[    3.307153@5] videosync_thread started
[    3.314787@4] VECM probe start
[    3.317867@4] vlock_status_init vlock_en:1
[    3.321749@4] pixel_probe: vpp probe func error!
[    3.326350@4] request amvecm_vsync2_irq successful
[    3.331112@4] aml_vecm_probe: ok
[    3.334348@4] amdolby_vision_init:module init
[    3.338827@4]
[    3.338827@4]  amdolby_vision probe start
[    3.339015@0] hdmitx: hdmitx_set_drm_pkt: tf=1, cf=1, colormetry=0
[    3.350431@4] [amdolby_vision.] : amdolby_vision error.
[    3.355664@4] prime_sl module init
[    3.359220@4] reg base = ffffff80084cb000
[    3.363006@4] gdc_platform_probe: reserve_mem is not used
[    3.368483@4] gdc_platform_probe: gdc core clk is 799 MHZ
[    3.373802@4] gdc_platform_probe: gdc axi clk is 799 MHZ
[    3.379059@4] gdc_wq_init: init gdc device
[    3.383120@4] gdc_wq_init: gdc start monitor
[    3.387400@5] gdc_monitor_thread: gdc workqueue monitor start
[    3.387595@4] vm_init .
[    3.388246@4] meson-mmc: mmc driver version: 3.02, 2017-05-15: New Emmc Host Controller
[    3.393348@4] meson-mmc: >>>>>>>>hostbase ffffff80084d3000, dmode
[    3.393528@4] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[    3.393540@4] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[    3.436215@4] meson-mmc: meson_mmc_probe() : success!
[    3.446699@4] meson-mmc: >>>>>>>>hostbase ffffff80084dc000, dmode
[    3.447247@4] meson-mmc: gpio_cd = 1ca
[    3.488233@0] meson-mmc: meson_mmc_probe() : success!
[    3.490350@0] meson-mmc: >>>>>>>>hostbase ffffff80084e5000, dmode
[    3.495286@0] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[    3.500645@0] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[    3.507338@4] meson-mmc: set rate clkin2>>>>>>>>clk:799999987
[    3.507381@4] meson-aml-mmc ffe07000.emmc: divider requested rate 200000000 != actual rate 199999997: ret=0
[    3.507384@4] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[    3.507395@4] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000204
[    3.508405@4] meson-mmc: aml_sd_emmc_clktest [1549] clktest : 25054, delay_cell: 51, count: 97
[    3.508414@4] meson-mmc: [aml_emmc_hs200_tl1][2001] clk config:0x10100004
[    3.553395@4] meson-mmc: cmd->u64eyet:0x1c06000000000000
[    3.568846@4] meson-mmc: [aml_emmc_hs200_tl1][2067] clk config:0x10000204
[    3.570107@4] meson-mmc: set rate clkin2>>>>>>>>clk:799999987
[    3.575724@4] meson-aml-mmc ffe07000.emmc: divider requested rate 200000000 != actual rate 199999997: ret=0
[    3.585420@4] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[    3.591495@4] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000204
[    3.591504@5] meson-mmc: meson_mmc_probe() : success!
[    3.591955@5] aml_vrtc rtc: rtc core: registered aml_vrtc as rtc1
[    3.592060@5] input: aml_vkeypad as /devices/platform/rtc/input/input3
[    3.592714@3] cectx ff80023c.aocec: cec driver date:2020/03/16:reduece no msg in sleep time
[    3.592714@3]
[    3.592831@5] cectx ff80023c.aocec: compatible:amlogic, aocec-g12a
[    3.592834@5] cectx ff80023c.aocec: cecb_ver:0x1
[    3.592836@5] cectx ff80023c.aocec: line_reg:0x1
[    3.592837@5] cectx ff80023c.aocec: line_bit:0x3
[    3.592839@5] cectx ff80023c.aocec: ee_to_ao:0x1
[    3.592919@5] input: cec_input as /devices/virtual/input/input4
[    3.592994@3] cectx ff80023c.aocec: not find 'port_num'
[    3.592997@3] cectx ff80023c.aocec: using cec:1
[    3.593013@3] cectx ff80023c.aocec: no hdmirx regs
[    3.593015@3] cectx ff80023c.aocec: no hhi regs
[    3.593021@3] cectx ff80023c.aocec: not find 'output'
[    3.594284@3] irq cnt:2, a:39, b38
[    3.594463@3] cectx ff80023c.aocec: wakeup_reason:0x0
[    3.594531@3] cectx ff80023c.aocec: cev val1: 0x0;val2: 0x0
[    3.594540@3] cectx ff80023c.aocec: aml_cec_probe success end
[    3.594955@3] unifykey: no efuse-version set, use default value: -1
[    3.595151@5] unifykey: aml_unifykeys_init done!
[    3.595199@5] meson ts init
[    3.595227@5] tsensor id: 0
[    3.595314@5] r1p1_tsensor_read  valid cnt is 0
[    3.595325@5] tsensor trim info: 0xfa008058!
[    3.595327@5] tsensor hireboot: 0xc0ff2aa0
[    3.595369@5] meson ts init
[    3.595383@5] tsensor id: 1
[    3.595441@5] r1p1_tsensor_read  valid cnt is 0
[    3.595448@5] tsensor trim info: 0xfa00805c!
[    3.595449@5] tsensor hireboot: 0xc0ff2aa0
[    3.595560@5] audio_dsp: [dsp]register dsp to char divece(257)
[    3.595658@3] amaudio: amaudio: driver amaudio init!
[    3.595891@3] amaudio: amaudio_init - amaudio: driver amaudio succuess!
[    3.596263@2] amlkaraoke init success!
[    3.596390@2] sysled: module init
[    3.596570@2] meson_wdt ffd0f0d0.watchdog: start watchdog
[    3.596573@2] meson_wdt ffd0f0d0.watchdog: creat work queue for watch dog
[    3.596717@2] meson_wdt ffd0f0d0.watchdog: AML Watchdog Timer probed done
[    3.597051@5] amlogic rfkill init
[    3.597142@5] enter bt_probe of_node
[    3.597157@5] not get gpio_en
[    3.597163@5] not get gpio_btwakeup
[    3.597167@5] power on valid level is high
[    3.597167@5] bt: power_on_pin_OD = 0;
[    3.597168@5] bt: power_off_flag = 1;
[    3.597170@5] dis power down = 0;
[    3.628260@5] request_irq error ret=-22
[    3.628285@5] dev_pm_set_wake_irq failed: -22
[    3.628719@5] meson-saradc ff809000.saradc: set delay per tick to <1ms> by default.
[    3.628722@5] meson-saradc ff809000.saradc: set ticks per period to <1> by default.
[    3.629374@5] dmc_monitor_probe
[    3.629478@5] page_trace_module_init, create sysfs failed
[    3.630084@5] atv_demod: aml_atvdemod_init: OK, atv demod version: V2.15.
[    3.630194@5] defendkey ff630218.defendkey: Reserved memory is not enough!
[    3.630201@5] defendkey: probe of ff630218.defendkey failed with error -22
[    3.630526@3] usbcore: registered new interface driver snd-usb-audio
[    3.631251@3] aml_codec_T9015 ff632000.t9015: aml_T9015_audio_codec_probe
[    3.631263@3] T9015 acodec used by auge, tdmout:1
[    3.631808@3] es8316 spk_ctl_gpio 0
[    3.631811@3] es8316 spk_mute_gpio 1
[    3.631815@3] es8316 4-0010: Can not read property hp_det_gpio
[    3.631817@3] es8316_i2c_probe 1329
[    3.631821@3] es8316_i2c_probe 1333
[    3.633254@3] asoc debug: aml_audio_controller_probe-129
[    3.633651@3] aml_tdm_platform_probe, tdm ID = 0, lane_cnt = 4
[    3.633673@3] snd_tdm ff642000.audiobus:tdma: lane_mask_out = 1, lane_oe_mask_out = 1
[    3.633717@3] snd_tdm ff642000.audiobus:tdma: neither mclk_pad nor mclk2pad set
[    3.633802@3] aml_tdm_platform_probe(), share en = 1
[    3.633802@3] No channel mask node Channel_Mask
[    3.633984@3] aml_tdm_platform_probe, tdm ID = 1, lane_cnt = 4
[    3.634052@3] TDM id 1 samesource_sel:3
[    3.634058@3] snd_tdm ff642000.audiobus:tdmb: lane_mask_out = 1, lane_oe_mask_out = 0
[    3.634259@3] aml_tdm_platform_probe(), share en = 1
[    3.634260@3] No channel mask node Channel_Mask
[    3.634395@3] aml_tdm_platform_probe, tdm ID = 2, lane_cnt = 4
[    3.634414@3] snd_tdm ff642000.audiobus:tdmc: lane_mask_out = 1, lane_oe_mask_out = 0
[    3.634551@3] periphs-banks:471 is using the pin GPIOA_11 as gpio
[    3.634554@3] meson-g12a-pinctrl pinctrl@ff634480: request() failed for pin 61
[    3.634557@3] meson-g12a-pinctrl pinctrl@ff634480: pin-61 (ff642000.audiobus:tdmc) status -22
[    3.634560@3] meson-g12a-pinctrl pinctrl@ff634480: could not request pin 61 (GPIOA_11) from group mclk1_a  on n
[    3.634562@3] snd_tdm ff642000.audiobus:tdmc: Error applying setting, reverse things back
[    3.634567@3] snd_tdm ff642000.audiobus:tdmc: aml_tdm_get_pins error!
[    3.634575@3] aml_tdm_platform_probe(), share en = 1
[    3.634575@3] No channel mask node Channel_Mask
[    3.635286@3] aml_spdif_platform_probe, register soc platform
[    3.635704@3] audio-ddr-manager ff642000.audiobus:ddr_manager: 0, irqs toddr 26, frddr 29
[    3.635723@3] audio-ddr-manager ff642000.audiobus:ddr_manager: 1, irqs toddr 27, frddr 30
[    3.635741@3] audio-ddr-manager ff642000.audiobus:ddr_manager: 2, irqs toddr 28, frddr 31
[    3.635950@3] loopback ff642000.audiobus:loopback@0: check whether to update loopback chipinfo
[    3.635982@3]        datain_src:4, datain_chnum:4, datain_chumask:f
[    3.635984@3]        datalb_src:1, datalb_chnum:2, datalb_chmask:3
[    3.635985@3]        datain_lane_mask:0x5, datalb_lane_mask:0x1
[    3.635986@3] datalb_format: 1, chmask for lanes: 0x3
[    3.636312@3] loopback_platform_probe, p_loopback->id:0 register soc platform
[    3.636555@3] audiolocker_platform_probe
[    3.637577@5] Register vad
[    3.639564@5] es8316_probe 1088
[    3.639567@5] es8316_probe 1097
[    3.639571@5] es8316_probe 1099
[    3.645372@5] es8316_probe 1103
[    3.696343@0] meson-mmc: card IN
[    3.757703@5] es8316_probe 1110
[    3.759471@5] es8316_probe 1130
[    3.762485@5] asoc-aml-card auge_sound: control 2:0:0:I2SIn CLK:0 is already present
[    3.762488@5] snd_tdm ff642000.audiobus:tdmb: ASoC: Failed to add I2SIn CLK: -16
[    3.762498@5] aml_dai_tdm_probe, failed add snd tdm controls
[    3.762502@5] asoc-aml-card auge_sound: control 2:0:0:I2SIn CLK:0 is already present
[    3.762505@5] snd_tdm ff642000.audiobus:tdmc: ASoC: Failed to add I2SIn CLK: -16
[    3.762511@5] aml_dai_tdm_probe, failed add snd tdm controls
[    3.762518@5] aml_dai_spdif_probe
[    3.762543@5] pin(1) should be selected for only one usage
[    3.762558@5] master_mode(1), binv(1), finv(0) out_skew(2), in_skew(3)
[    3.762943@5] asoc-aml-card auge_sound: multicodec <-> TDM-A mapping ok
[    3.763804@5] master_mode(1), binv(1), finv(1) out_skew(2), in_skew(3)
[    3.764094@5] asoc-aml-card auge_sound: multicodec <-> TDM-B mapping ok
[    3.764115@5] master_mode(1), binv(1), finv(1) out_skew(2), in_skew(3)
[    3.764401@5] asoc-aml-card auge_sound: multicodec <-> TDM-C mapping ok
[    3.764707@5] asoc-aml-card auge_sound: dummy <-> SPDIF mapping ok
[    3.764715@5]
[    3.764715@5] loopback_dai_set_sysclk, 0, 12288000, 0
[    3.764717@5] asoc loopback_dai_set_fmt, 0x4010, ffffffc04466e718
[    3.764970@5] asoc-aml-card auge_sound: dummy <-> ff642000.audiobus:loopback@0 mapping ok
[    3.766139@5] es8316 4-0010: ASoC: Failed to create Left Hp mixer debugfs file
[    3.766144@5] es8316 4-0010: ASoC: Failed to create Right Hp mixer debugfs file
[    3.766299@5] es8316 4-0010: ASoC: Failed to create HPCP L debugfs file
[    3.766438@5] es8316 4-0010: ASoC: Failed to create HPCP R debugfs file
[    3.766585@5] es8316 4-0010: ASoC: Failed to create HPVOL L debugfs file
[    3.766724@5] es8316 4-0010: ASoC: Failed to create HPVOL R debugfs file
[    3.768124@3] snd_card_add_kcontrols card:ffffffc00c5e4018
[    3.768131@3] effect_v2 is not init
[    3.768134@3] Failed to add VAD controls
[    3.768147@3] eq/drc v1 function enable
[    3.800349@3] u32 classifier
[    3.800350@3]     Actions configured
[    3.800354@3] Netfilter messages via NETLINK v0.30.
[    3.800501@3] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.800597@0] meson-mmc: normal card in
[    3.800637@3] ctnetlink v0.93: registering with nfnetlink.
[    3.800869@5] xt_time: kernel timezone is -0000
[    3.800917@5] IPv4 over IPsec tunneling driver
[    3.811634@5] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.811760@5] arp_tables: arp_tables: (C) 2002 David S. Miller
[    3.815262@5] Initializing XFRM netlink socket
[    3.815547@5] NET: Registered protocol family 10
[    3.816173@3] mip6: Mobile IPv6
[    3.816204@3] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.822975@3] NET: Registered protocol family 17
[    3.822987@3] NET: Registered protocol family 15
[    3.824291@3] Registered swp emulation handler
[    3.826694@3] Registered cp15_barrier emulation handler
[    3.826700@3] Registered setend emulation handler
[    3.827050@3] registered taskstats version 1
[    3.832997@5] dwc3 ff500000.dwc3: Configuration mismatch. dr_mode forced to host
[    3.835661@5] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.835671@5] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.835891@5] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x20010010
[    3.835924@5] xhci-hcd xhci-hcd.0.auto: irq 15, io mem 0xff500000
[    3.836324@3] hub 1-0:1.0: USB hub found
[    3.836339@3] hub 1-0:1.0: 2 ports detected
[    3.836535@3] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.836541@3] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.836573@3] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.836868@5] hub 2-0:1.0: USB hub found
[    3.836882@5] hub 2-0:1.0: 1 port detected
[    3.837304@5] i2c i2c-4: sensor_probe: kxtj3,ffffffc04429c000
[    3.837788@5] sensors 4-000e: sensor_probe:kxtj3:devid=0x35,ops=0xffffff800a552910
[    3.839274@5] input: gsensor as /devices/platform/soc/ff800000.aobus/ff805000.i2c/i2c-4/4-000e/input/input5
[    3.840129@3] sensors 4-000e: sensor_probe:use polling,delay=30 ms
[    3.840217@5] sensors 4-000e: sensor_probe:miscdevice: gsensor
[    3.840222@5] sensors 4-000e: sensor_probe:initialized ok,sensor name:kxtj3,type:2,id=0
[    3.840222@5]
[    3.841952@2] khadas-rtc 4-0051: setting system clock to 2011-01-01 12:00:02 UTC (1293883202)
[    3.842219@2] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: ffe09000, ctrl: 0
[    3.928308@0] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[    3.928326@0] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[    3.942366@5] dwc_otg: Core Release: 3.30a
[    3.942372@5] dwc_otg: Setting default values for core params
[    3.942380@5] dwc_otg: curmode: 0, host_only: 0
[    3.954556@5] dwc_otg: Using Buffer DMA mode
[    3.954559@5] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1
[    3.954561@5] dwc_otg: Working on port type = SLAVE
[    3.954564@5] dwc_otg: Dedicated Tx FIFOs mode
[    3.955271@5] input: adc_keypad as /devices/platform/adc_keypad/input/input6
[    3.956370@3] meson_cdev probe
[    3.956426@3] meson_cdev index: 0
[    3.956483@3] thermal thermal_zone0: binding zone soc_thermal with cdev thermal-cpufreq-0 failed:-22
[    3.956508@3] meson_cdev index: 1
[    3.956553@3] thermal thermal_zone0: binding zone soc_thermal with cdev thermal-cpufreq-1 failed:-22
[    3.956559@3] thermal: no cluster id, cpucore as one cooldev
[    3.956577@3] meson_cdev index: 2
[    3.956591@3] cpucore_cooling_register, max_cpu_core_num:6
[    3.956598@3] cpucore_cooling_register, clutser[1] core num:4
[    3.956603@3] cpucore_cooling_register, clutser[0] core num:2
[    3.956676@3] meson_cdev index: 3
[    3.956693@3] meson_cdev index: 4
[    3.956724@3] find tzd id: 0
[    3.956829@3] find tzd id: 0
[    3.956912@3] find tzd id: 0
[    3.956942@3] meson_cdev probe done
[    3.957037@3] gxbb_pm: enter meson_pm_probe!
[    3.957047@3] no vddio3v3_en pin
[    3.957047@3] pm-meson aml_pm: Can't get switch_clk81
[    3.957065@3] gxbb_pm: meson_pm_probe done
[    3.957320@3] ALSA device list:
[    3.957322@3]   #0: AML-AUGESOUND
[    4.034498@0] meson-mmc: actual_clock :50000000, HHI_nand: 0x880
[    4.034516@0] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000254
[    4.034601@0] sd: new high speed SDXC card at address aaaa
[    4.035090@0] sd: clock 50000000, 4-bit-bus-width
[    4.035090@0]
[    4.035090@0] mmcblk1: sd:aaaa SN128 119 GiB
[    4.036160@0]  mmcblk1: p1
[    4.036536@0] meson-mmc: Enter aml_emmc_partition_ops
[    4.160201@3] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    4.316691@3] hub 1-1:1.0: USB hub found
[    4.316732@3] hub 1-1:1.0: 4 ports detected
[    4.616197@3!   4.745562@4] meson-mmc: meson_mmc_set_ios_v3 290
[    4.745740@4] meson-aml-mmc ffe07000.emmc: divider requested rate 52000000 != actual rate 50000000: ret=0
[    4.754128@4] meson-mmc: actual_clock :50000000, HHI_nand: 0x80
[    4.760020@4] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000154
[    4.766246@3] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/7
[    4.766547@3] hid-generic 0003:24AE:2010.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless D0
[    4.768564@3] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/8
[    4.809106@4] emmc:use ds type0
[    4.812094@4] emmc: no support driver strength type 1 and 4
[    4.817779@4] meson-aml-mmc ffe07000.emmc: divider requested rate 52000000 != actual rate 50000000: ret=0
[    4.824497@3] hid-generic 0003:24AE:2010.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G W1
[    4.826019@3] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/9
[    4.855867@4] meson-mmc: actual_clock :50000000, HHI_nand: 0x80
[    4.861774@4] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000154
[    4.868353@4] meson-mmc: emmc: try set sd/emmc to HS400 mode
[    4.874074@4] meson-aml-mmc ffe07000.emmc: divider requested rate 200000000 != actual rate 199999997: ret=0
[    4.883687@4] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[    4.888694@3] hid-generic 0003:24AE:2010.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireles2
[    4.903462@4] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10100004
[    4.910036@4] meson-mmc: emmc: try set sd/emmc to HS400 mode
[    4.916672@4] meson-mmc: aml_sd_emmc_clktest [1549] clktest : 12256, delay_cell: 53, count: 47
[    4.924252@4] meson-mmc: [aml_post_hs400_timming], delay1: 0x0, delay2: 0x1a000000
[    4.937329@5] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 115200 to 115200
[    4.962720@5] meson-mmc: ds_sht:19, window:26, intf3:0x4130c8, clock:0x10100002[    4.964209@4] meson-mmc: adj0
[    4.985655@4] meson-mmc: delay1:0x61902d0, delay2:0x1a005145
[    5.017416@4] meson-mmc: ds_sht:24, window:26, intf3:0x4180c8, clock:0x10100002[    5.018897@4] meson-mmc: adj0
[    5.326789@4] meson-mmc: scan time distance: 304417291 ns
[    5.326813@4] meson-mmc: best_start 0x16, best_size 37, cmd_delay is 0x28
[    5.333304@4] meson-mmc: >>>>>>>>>>>>>>scan command window>>>>>>>>>>>>>>>
[    5.340069@4] meson-mmc: >>cmd delay [ 0x0 -- 0x7 ] is ok
[    5.345440@4] meson-mmc: >>cmd delay [ 0x8 -- 0x15 ] is nok
[    5.350988@4] meson-mmc: >>cmd delay [ 0x16 -- 0x3a ] is ok
[    5.356528@4] meson-mmc: >>cmd delay [ 0x3b -- 0x3f ] is nok
[    5.362165@4] meson-mmc: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[    5.368907@4] emmc: new HS400 MMC card at address 0001
[    5.373863@4] emmc: clock 199999997, 8-bit-bus-width
 [    5.379222@4] mmcblk0: emmc:0001 AJTD4R 14.6 GiB
[    5.383688@4] mmcblk0boot0: emmc:0001 AJTD4R partition 1 4.00 MiB
[    5.389752@4] mmcblk0boot1: emmc:0001 AJTD4R partition 2 4.00 MiB
[    5.395815@4] mmcblk0rpmb: emmc:0001 AJTD4R partition 3 4.00 MiB
[    5.402331@4] meson-mmc: Enter aml_emmc_partition_ops
[    5.407189@4] meson-mmc: [aml_emmc_partition_ops] mmc read partition OK!
[    5.413388@4] meson-mmc: add_emmc_partition
[    5.417629@4] meson-mmc: [mmcblk0p01]           bootloader  offset 0x000000000000, size 0x000000400000
[    5.426981@4] meson-mmc: [mmcblk0p02]             reserved  offset 0x000002400000, size 0x000004000000
[    5.436350@4] meson-mmc: [mmcblk0p03]                cache  offset 0x000006c00000, size 0x000046000000
[    5.445698@4] meson-mmc: [mmcblk0p04]                  env  offset 0x00004d400000, size 0x000000800000
[    5.455063@4] meson-mmc: [mmcblk0p05]                 logo  offset 0x00004e400000, size 0x000000800000
[    5.464428@4] meson-mmc: [mmcblk0p06]             recovery  offset 0x00004f400000, size 0x000001800000
[    5.473780@4] meson-mmc: [mmcblk0p07]                 misc  offset 0x000051400000, size 0x000000800000
[    5.483140@4] meson-mmc: [mmcblk0p08]                 dtbo  offset 0x000052400000, size 0x000000800000
[    5.492504@4] meson-mmc: [mmcblk0p09]             cri_data  offset 0x000053400000, size 0x000000800000
[    5.501858@4] meson-mmc: [mmcblk0p10]                param  offset 0x000054400000, size 0x000001000000
[    5.511220@4] meson-mmc: [mmcblk0p11]                 boot  offset 0x000055c00000, size 0x000001000000
[    5.520585@4] meson-mmc: [mmcblk0p12]                  rsv  offset 0x000057400000, size 0x000001000000
[    5.529940@4] meson-mmc: [mmcblk0p13]             metadata  offset 0x000058c00000, size 0x000001000000
[    5.539296@4] meson-mmc: [mmcblk0p14]               vbmeta  offset 0x00005a400000, size 0x000000200000
[    5.548665@4] meson-mmc: [mmcblk0p15]                  tee  offset 0x00005ae00000, size 0x000002000000
[    5.558019@4] meson-mmc: [mmcblk0p16]               vendor  offset 0x00005d600000, size 0x00001f000000
[    5.567377@4] meson-mmc: [mmcblk0p17]                  odm  offset 0x00007ce00000, size 0x000008000000
[    5.576749@4] meson-mmc: [mmcblk0p18]               system  offset 0x000085600000, size 0x000078800000
[    5.586095@4] meson-mmc: [mmcblk0p19]              product  offset 0x0000fe600000, size 0x000008000000
[    5.595458@4] meson-mmc: [mmcblk0p20]                 data  offset 0x000106e00000, size 0x00029d000000
[    5.596207@5] prepare_namespace() wait 74
[    5.608742@4] card key: card_blk_probe.
[    5.612551@4] emmc_key_init:183 emmc key lba_start:0x12020,lba_end:0x12220
[    5.619394@4] emmc key: emmc_key_init:205 ok.
[    5.623725@4] meson-mmc: amlmmc_dtb_init: register dtb chardev[    5.630879@4] meson-mmc: calc c731f02c, store0
[    5.633871@4] meson-mmc: cpy 1 is not valid
[    5.639492@4] meson-mmc: calc c731f02c, store 0
[    5.642532@4] meson-mmc: cpy 0 is not valid
[    5.646690@4] meson-mmc: total valid 0
[    5.650510@4] meson-mmc: amlmmc_dtb_init: register dtb chardev OK[    5.656315@4] meson-mmc: amlmmc_ddr_init: v
meson-mmc: amlmmc_ddr_init: register ddr parameter chardev OK[    5.668299@4] meson-mmc: Exit aml_emmc_partition_.
[    5.674571@5] EXT4-fs (mmcblk0p18): couldn't mount as ext3 due to feature incompatibilities
[    5.682208@5] EXT4-fs (mmcblk0p18): couldn't mount as ext2 due to feature incompatibilities
[    5.692114@2] EXT4-fs (mmcblk0p18): mounted filesystem without journal. Opts: (null)
[    5.697937@2] VFS: Mounted root (ext4 filesystem) readonly on device 179:50.
[    5.705236@2] devtmpfs: mounted
[    5.709869@2] Freeing unused kernel memory: 4672K
[    5.726075@2] init: init first stage started!
[    5.726568@2] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.734163@2] init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
[    5.767578@2] EXT4-fs (mmcblk0p17): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    5.772246@2] init: [libfs_mgr]__mount(source=/dev/block/odm,target=/odm,type=ext4)=0: Success
[    5.781723@2] EXT4-fs (mmcblk0p19): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    5.790540@2] init: [libfs_mgr]__mount(source=/dev/block/product,target=/product,type=ext4)=0: Success
[    5.801179@2] EXT4-fs (mmcblk0p16): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    5.809759@2] init: [libfs_mgr]__mount(source=/dev/block/vendor,target=/vendor,type=ext4)=0: Success
[    5.818951@2] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[    5.825944@2] init: Loading SELinux policy
[    5.909033@2] audit: type=1403 audit(1293883204.564:2): policy loaded auid=4294967295 ses=4294967295
[    5.912654@2] selinux: SELinux: Loaded policy from /odm/etc/selinux/precompiled_sepolicy
[    5.912654@2]
[    5.926175@2] selinux: SELinux: Loaded file_contexts
[    5.926175@2]
[    5.931110@2] init: init second stage started!
[    5.946164@2] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.950813@2] selinux: SELinux: Loaded file_contexts
[    5.950813@2]
[    5.954704@2] init: Running restorecon...
[    5.962565@2] init: waitid failed: No child processes
[    5.965669@2] init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory:y
[    5.977425@2] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[    5.984816@2] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2440
[    5.991755@2] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2441
[    5.998506@2] init: Parsing file /init.rc...
[    6.160495@0] ueventd: ueventd started!
[    6.162165@0] mali_kbase: loading out-of-tree module taints kernel.
[    6.164201@4] lcd vlock_en=1, vlock_mode=0x4
[    6.171434@0] selinux: SELinux: Loaded file_contexts
[    6.171434@0]
[    6.171564@0] ueventd: Parsing file /ueventd.rc...
[    6.180627@5] ueventd: Parsing file /vendor/ueventd.rc...
[    6.186541@5] ueventd: /vendor/ueventd.rc: 115: /sys/ lines must have 5 entries
[    6.191963@2] mali ffe40000.bifrost: Continuing without Mali regulator control
[    6.192029@2] mali ffe40000.bifrost: max pp is 2
[    6.192032@2] mali ffe40000.bifrost: set min pp to default 1
[    6.192034@2] mali ffe40000.bifrost: min pp is 1
[    6.192037@2] mali ffe40000.bifrost: set min clk default to 0
[    6.192038@2] mali ffe40000.bifrost: min clk  is 0
[    6.192051@2] mali ffe40000.bifrost: hiu io source  0xffffff8008cfd000
[    6.192058@2] mali ffe40000.bifrost: hiu io source  0xffffff8008f0a000
[    6.192061@2] mali ffe40000.bifrost: num of pp used most of time 1
[    6.192063@2] mali ffe40000.bifrost: clock dvfs cfg table size is 6
[    6.192086@2] mali ffe40000.bifrost: max clk set 4
[    6.192088@2] mali ffe40000.bifrost: max clk  is 4
[    6.192091@2] mali ffe40000.bifrost: turbo clk set to 5
[    6.192092@2] mali ffe40000.bifrost: turbo clk  is 5
[    6.192094@2] mali ffe40000.bifrost: default clk set to 4
[    6.192096@2] mali ffe40000.bifrost: default clk  is 4
[    6.192100@2] mali ffe40000.bifrost: ====================0====================
[    6.192100@2] clk_freq= 285714285, clk_parent=fclk_div7, voltage=1150, keep_count=5, threshod=<100 190>, clk_s5
[    6.192104@2] mali ffe40000.bifrost: ====================1====================
[    6.192104@2] clk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_count=5, threshod=<152 207>, clk_s0
[    6.192107@2] mali ffe40000.bifrost: ====================2====================
[    6.192107@2] clk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, threshod=<180 220>, clk_s0
[    6.192110@2] mali ffe40000.bifrost: ====================3====================
[    6.192110@2] clk_freq= 666666666, clk_parent=fclk_div3, voltage=1150, keep_count=5, threshod=<210 236>, clk_s6
[    6.192113@2] mali ffe40000.bifrost: ====================4====================
[    6.192113@2] clk_freq= 800000000, clk_parent=fclk_div2p5, voltage=1150, keep_count=5, threshod=<230 255>, clk0
[    6.192115@2] mali ffe40000.bifrost: ====================5====================
[    6.192115@2] clk_freq= 800000000, clk_parent=fclk_div2p5, voltage=1150, keep_count=5, threshod=<230 255>, clk0
[    6.192117@2] mali ffe40000.bifrost: clock dvfs table size is 6
[    6.192219@2] mali_plat=ffffff8001cef598
[    6.192433@2] find tzd id: 0
[    6.192472@2] gpu cooling register okay with err=0
[    6.192596@2] find tzd id: 0
[    6.192608@2] gpu core cooling register okay with err=0
[    6.192628@2] shader_present=3, tiler_present=1, l2_present=1
[    6.192712@2] Mali_pwr_on:gpu_irq : 200
[    6.193010@2] hrtimer: interrupt took 9291 ns
[    6.193184@2] mali ffe40000.bifrost: GPU identified as 0x2 arch 7.2.1 r0p0 status 0
[    6.193680@2] mali ffe40000.bifrost: Using coherency mode 0 set from dtb
[    6.200525@2] mali ffe40000.bifrost: Probed as mali0
[    6.238971@3] PPMGRVPP: info: RegisterTB_Function: gfunc           (null), func: ffffff8001d29028, ver:TB dete]
[    6.472141@5] ueventd: Parsing file /odm/ueventd.rc...
[    6.477150@5] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    6.487094@5] ueventd: Parsing file /ueventd.amlogic.rc...
[    6.492479@5] ueventd: Unable to read config file '/ueventd.amlogic.rc': open() failed: No such file or directy
[    6.761275@3] ueventd: Coldboot took 0.256 seconds
[    6.797115@2] audit: type=1400 audit(1293883205.452:3): avc:  denied  { write } for  pid=2440 comm="init" name1
[    6.829390@0] EXT4-fs (mmcblk0p20): Ignoring removed nomblk_io_submit option
[    6.895374@1] EXT4-fs (mmcblk0p20): recovery complete
[    6.896661@1] EXT4-fs (mmcblk0p20): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_t
[    7.177869@2] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    7.177869@2]
[    7.178652@2] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[    7.178652@2]
[    7.186300@2] e2fsck: Pass 2: Checking directory structure
[    7.186300@2]
[    7.193403@2] e2fsck: Pass 3: Checking directory connectivity
[    7.193403@2]
[    7.200710@2] e2fsck: Pass 4: Checking reference counts
[    7.200710@2]
[    7.207551@2] e2fsck: Pass 5: Checking group summary information
[    7.207551@2]
[    7.215270@2] e2fsck: /dev/block/data: 2219/685440 files (8.4% non-contiguous), 165677/2740224 blocks
[    7.215270@2]
[    7.228279@3] EXT4-fs (mmcblk0p20): Ignoring removed nomblk_io_submit option
[    7.238931@3] EXT4-fs (mmcblk0p20): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submc
[    7.245753@3] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[    7.255789@3] EXT4-fs (mmcblk0p3): recovery complete
[    7.257178@3] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_it
[    7.257937@4] audit: type=1400 audit(1293883205.912:4): avc:  denied  { read } for  pid=3000 comm="imageserver1
[    7.257969@4] audit: type=1400 audit(1293883205.912:5): avc:  denied  { write } for  pid=3000 comm="imageserve1
[    7.257983@4] audit: type=1400 audit(1293883205.912:6): avc:  denied  { open } for  pid=3000 comm="imageserver1
[    7.258057@4] audit: type=1400 audit(1293883205.912:7): avc:  denied  { ioctl } for  pid=3000 comm="imageserve1
[    7.413464@3] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    7.413464@3]
[    7.414202@3] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[    7.414202@3]
[    7.421817@3] e2fsck: Pass 2: Checking directory structure
[    7.421817@3]
[    7.429481@3] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[    7.437099@3] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submic
[    7.448034@3] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    7.456919@3] EXT4-fs (mmcblk0p13): recovery complete
[    7.459469@3] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_t
[    7.512421@3] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    7.515102@3] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submc
[    7.553461@0] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[    7.556859@1] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submc
[    7.598313@0] EXT4-fs (mmcblk0p15): Ignoring removed nomblk_io_submit option
[    7.605378@0] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submc
[    7.611855@0] init: 27 output lines suppressed due to ratelimiting
[    7.625027@4] No find node.
[    7.625053@4] register clk_set_setting cpu[46]
[    7.632607@0] Registered firmware driver success.
[    7.633652@0] Try to load video/h264_enc.bin  ...
[    7.638049@0] load firmware size : 76288, Name : video/h264_enc.bin.
[    7.643273@0] Try to load video/video_ucode.bin  ...
[    7.659428@2] load firmware size : 1459200, Name : video/video_ucode.bin.
[    7.716104@0] Amlogic A/V streaming port init
[    7.722694@2] get gate demux control ok ffffffc0436dddc0
[    7.722735@2] get gate parser_top control ok ffffffc0436ddbc0
[    7.728123@2] get gate vdec control ok ffffffc0436dd9c0
[    7.733305@2] get gate clk_81 control failed           (null)
[    7.739041@2] get gate clk_vdec_mux control ok ffffffc0436dd840
[    7.744946@2] get gate clk_hcodec_mux control ok ffffffc0436dd640
[    7.751017@2] get gate clk_hevc_mux control ok ffffffc0436dd440
[    7.756915@2] get gate clk_hevcb_mux control ok ffffffc0436dd300
[    7.762861@2] get gate ahbarb0 control ok ffffffc0436dd1c0
[    7.768304@2] get gate asyncfifo control failed           (null)
[    7.796111@4] ammvdec_h264 module init
[    7.830466@3] ammvdec_mpeg12 module init
[    7.840156@3] ammvdec_mpeg4_driver_init_module
[    7.874374@4] amvenc_avc_probe -- reserved memory config fail.
[    7.874567@4] amvenc_avc - cma memory pool size: 60 MB
[    7.879729@4] encode_wq_init.
[    7.882658@4] encode start monitor.
[    7.886211@0] encode workqueue monitor start.
[    7.895794@2] vpu_init
[    7.896010@2] vpu_probe
[    7.896024@2] HevcEnc reserved memory config fail.
[    7.899974@2] HevcEnc - cma memory pool size: 64 MB
[    7.904847@2] HevcEnc - wave420l_irq: 50
[    7.908771@2] vpu base address get from platform driver physical base addr=0xff610000, virtual base=0xffffff800
[    7.920242@2] success to probe vpu device with video memory from cma
[    7.945803@5] audit: type=1400 audit(1293883206.600:8): avc:  denied  { setattr } for  pid=1 comm="init" name=1
[    7.994381@4] logd.auditd: start
[    7.994416@4] logd.klogd: 7846226960
[    8.074911@5] type=1400 audit(1293883206.728:9): avc: denied { setattr } for pid=2440 comm="init" name="droido1
[    8.089796@5] type=1400 audit(1293883206.728:9): avc: denied { setattr } for pid=2440 comm="init" name="droido1
[    8.109936@5] type=1400 audit(1293883206.728:10): avc: denied { setattr } for pid=2440 comm="init" name="log" 1
[    8.129875@3] type=1400 audit(1293883206.728:10): avc: denied { setattr } for pid=2440 comm="init" name="log" 1
[    8.148500@3] type=1400 audit(1293883206.784:11): avc: denied { setattr } for pid=2440 comm="init" name="media1
[    8.193161@0] npu_version: 2
[    8.193449@0] Galcore version 6.4.6.2.8.3.2
[    8.201712@1] gckCOMMAND_Construct 1474 physical=43100000
[    8.201757@1] gckCOMMAND_Construct 1474 physical=43101000
[    8.245755@1] probe iq_dev for sensor: os08a10
[    8.245792@1] get_cali_name_id@:97 SUBDEV_IQ(CRIT) :Loading Calibration for OS08A10_IPC
[    8.252573@1]
[    8.322563@0] config sensor os08a10 driver.
[    8.322596@0] sensor bsp init
[    8.324094@0] cannot get g12a_24m clk
[    8.327811@0] set mclk fail
[    8.372124@2] arm_sensor_i2c_probe: start to probe
[    8.372243@2] system_i2c_init:success to add i2c driver
[    8.377699@2] sensor_get_id@:479 GENERIC(CRIT) :sensor_get_id: Failed to read sensor id
[    8.384447@2]
[    8.386087@2] sensor_detect_os08a10:0
[    8.389754@2] arm_sensor_i2c_remove: remove i2c sensor
[    8.534457@2] arm_isp ff140000.isp: assigned reserved memory node linux,isp_cma
[    8.536144@2] AM_SC: am_sc_parse_dt: rs idx info: name: isp_sc
[    8.541973@2] AM_SC: am_sc_parse_dt:rs info: irq: 58
[    8.552071@0] interrupt comes in (irq = 59) without app handler, status: 0x200, pusle mode:0
[    8.559308@0] acamera_fw_init@:106 GENERIC(CRIT) :seamless:0
[    8.560919@3] pwr_enable: get_named_gpio power-enable fail
[    8.566383@3] set power fail
[    8.584058@3] init clock is 24 MHZ
[    8.625925@3] arm_sensor_i2c_probe: start to probe
[    8.625993@3] arm_sensor_i2c_probe: success get link device:phy-csi
[    8.631429@3] AM_MIPI: am_mipi_parse_dt:Success to get link device: isp-adapter
[    8.638664@3] platform ff650000.isp-adapter: assigned reserved memory node linux,adapt_cma
[    8.646846@3] AM_ADAP: adapter alloc 24M memory
[    8.651439@3] system_i2c_init:success to add i2c driver
[    8.658860@3] pwr_enable: get_named_gpio power-enable fail
[    8.672121@3] pwr_enable: get_named_gpio power-enable fail
[    8.683473@3] sensor_get_id@:479 GENERIC(CRIT) :sensor_get_id: Failed to read sensor id
[    8.685853@3]
[    8.835872@0] AM_MIPI: am_mipi_init:Success mipi init
[    8.835903@0] AM_ADAP: inject_data_flag = 0, dump_data_flag = 0
[    8.842337@0] AM_ADAP: frontend : width = 1920, val = 150
[    8.846627@0] sensor_set_mode@:574 GENERIC(CRIT) :Mode 0, Setting num: 2, RES:1920x1080
[    8.854601@0]
[    8.856208@0] get_cali_name_id@:97 SUBDEV_IQ(CRIT) :Loading Calibration for OS08A10_IPC
[    8.864205@0]
[    8.865792@0] iq_ioctl@:260 SUBDEV_IQ(CRIT) :soc_iq get config os08a10 according to sensor drv
[    8.875431@0] general_set_wdr_mode@:490 GENERAL(CRIT) :Setting Linear Binary Sequence
[    8.882173@2]
[    8.884764@2] sbuf_mgr_alloc_sbuf@:175 SBUF(CRIT) :sbuf: len_needed: 238132, len_alloc: 245759, len_used: 2416.
[    8.900474@2] sbuf_calibration_init@:495 SBUF(CRIT) :sbuf_calibration wdr_mode updated: 65535 -> 0.
[    8.913606@2] connection_thread@:105 GENERIC(CRIT) :[    8.913644@2] connection_thread@:105 GENERIC(CRIT) :
[    8.913645@2] isp_fw_process@:123 GENERIC(CRIT) :
[    8.913646@2] isp_fw_process start
[    8.913647@2]
[    8.914874@4] sensor_get_id@:479 GENERIC(CRIT) :
[    8.914876@4] sensor_get_id: Failed to read sensor id
[    8.914876@4]
[    8.940152@3] connection_thread start
[    8.943841@3]
[    8.950200@1] logd.daemon: reinit
[    9.102940@4] android.hardware.health@2.0-impl: wakealarm_init: timerfd_create failed
[    9.221491@2] type=1400 audit(1293883206.784:11): avc: denied { setattr } for pid=2440 comm="init" name="media1
[    9.222806@5] VID: VD1 off
[    9.223508@5] hdmitx: system: set hdcp_pwr 1
[    9.225480@5] unifykey: amlkey_init_gen() enter!
[    9.248106@2] type=1400 audit(1293883207.876:12): avc: denied { read } for pid=3205 comm="systemcontrol" name=1
[    9.346591@0] fb: osd_open, 1514, fb_index=0,fb_rmem_size=26738688
[    9.347282@0] fb: osd_open, 1514, fb_index=1,fb_rmem_size=1048576
[    9.353318@0] fb: osd_open, 1514, fb_index=2,fb_rmem_size=1048576
[    9.359455@0] fb: vpu clkc clock is 199 MHZ
[    9.363560@0] fb: osd_open, 1514, fb_index=3,fb_rmem_size=8388608
[    9.517571@3] emmc_key_read:114, read ok
[    9.517609@3] unifykey: amlkey_init_gen() storagekey_info.buffer=ffffffc005080000, storagekey_info.size = 4000!
[    9.530606@3] vfm_map_store.part.1:rm default
[    9.530821@3] vfm_map_store.part.1:add default decoder ppmgr deinterlace amvideo
[    9.540693@3] file system registered
[    9.541424@3] audit: audit_lost=1 audit_rate_limit=5 audit_backlog_limit=64
[    9.546883@0] hdmitx: system: restore hdcp_pwr 0
[    9.549722@2] hdmitx: system: sname = 1080p60hz
[    9.549724@2] hdmitx: system: char_clk = 148500
[    9.549725@2] hdmitx: system: cd = 6
[    9.549726@2] hdmitx: system: cs = 2
[    9.549728@2] hdmitx: RX tmds clk: 225   Calc clk: 222
[    9.574031@3] audit: rate limit exceeded
[    9.600074@5] assign_ffs_buffer FFS_BUFFER_MAX=100!!!
[    9.601043@3] cpufreq_interactive: cpufreq_hmp_boost_start.part.8()
[    9.605760@3] cpufreq_interactive: hmp boost cpu:0 cluster:1
[    9.611411@3] cpufreq_interactive: hmp boost cpu:1 cluster:1
[    9.613581@0] vout: vout_io_open
[    9.620506@3] cpufreq_interactive: hmp boost cpu:2 cluster:0
[    9.625873@3] cpufreq_interactive: hmp boost cpu:3 cluster:0
[    9.631516@3] cpufreq_interactive: hmp boost cpu:4 cluster:0
[    9.637261@3] cpufreq_interactive: hmp boost cpu:5 cluster:0
[    9.655252@1] [DI] load 0x3e00 pq table len 424 later.
console:/ $ [    9.698922@1] read descriptors
[    9.698963@1] read strings
[    9.985110@0] vout: vout_io_open
[    9.985159@0] vout: vout_ioctl: cmd_dir = 0x2, cmd_nr = 0x0
[    9.988349@0] vout: vout_io_release
[   10.145670@0] isp_v4l2_stream_try_format@:1321 GENERIC(CRIT) :[Stream#0] format 0x00000000 is not supported, s.
[   10.152939@2]
[   10.158550@2] isp_v4l2_stream_try_format@:1321 GENERIC(CRIT) :[Stream#0] format 0x00000000 is not supported, s.
[   10.167415@5]
[   10.341299@3] avc open
[   10.341326@3] amvenc_avc  check CMA pool success, max instance: 3.
[   10.344788@3] allocating phys 0x5a400000, size 20480k, wq:ffffffc02b6af800.
[   10.351155@3] amvenc_avc  memory config success, buff start:0x5a400000, size is 0x1400000, wq:ffffffc02b6af800.
[   10.361400@3] avc release, wq:ffffffc02b6af800
[   10.365716@3] remove  encode_work_queue ffffffc02b6af800 success, _destroy_encode_work_queue line 3786.
[   10.375304@3] [+] vpu_open
[   10.378820@3] allocating phys 0x5a400000, virt addr 0x0, size 65536k
[   10.384213@3] [-] vpu_open, ret: 0
[   10.387388@3] vpu_release
[   10.389987@3] vpu_free_buffers
[   10.393073@3] vpu_free_instances
[   10.394627@5] aml_spdif_open
[   10.395083@5] aml_spdif_close
[   10.395380@4] aml_tdm_open
[   10.404699@3] vpu_release, s_video_memory 0x5a400000
[   10.405391@4] loopback_dai_startup
[   10.409295@5] loopback_dai_shutdown
[   10.410229@5] aml_tdm_open
[   10.411150@5] aml_tdm_open
[   10.452030@2] aml_tdm_open
[   10.452058@2] Not init audio effects
[   10.518273@3] hdmitx: audio: aout notify format CT_PCM
[   10.518302@3] hdmitx: hw: set audio
[   10.521288@3] hdmitx: hw: hdmitx tx_aud_src = 0
[   10.525869@3] hdmitx: fs = 3, cd = 6, tmds_clk = 148352
[   10.530985@3] hdmitx: hw: aud_n_para = 11648
[   10.535296@3] hdmitx: hw: set channel status
[   10.539482@3] hdmitx: hw: [0x10e3] = 0xf
[   10.543385@3] hdmitx: audio: Audio Type: PCM
[   10.547769@3] hdmitx: audio: set audio param
[   10.692239@3] es8316 spk_ctl_gpio 1
[   10.692272@3] es8316 spk_mute_gpio 0
[   10.694265@3] asoc-aml-card auge_sound: tdm playback enable
[   11.204206@4] fb: osd[0] enable: 1 scale:0x10001 (HwBinder:3218_1)
[   11.204743@4] fb: osd[0] enable: 1 scale:0x10001 (HwBinder:3218_1)
[   11.213605@4] fb: free_scale_switch to fb0, mode: 0x10001
[   11.216319@4] fb: set logo loaded
[   11.435391@5] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[   12.208247@2] vout: aml_tvout_mode_work: monitor_timeout
[   12.215196@4] early_suspend_state=0
[   13.012294@5] type=1400 audit(1293883211.580:44): avc: denied { open } for pid=3469 comm="system_server" path=1
[   13.033352@5] type=1400 audit(1293883211.664:45): avc: denied { read } for pid=3469 comm="android.ui" name="st1
[   13.053662@5] type=1400 audit(1293883211.664:45): avc: denied { read } for pid=3469 comm="android.ui" name="st1
[   13.073782@5] type=1400 audit(1293883211.680:46): avc: denied { open } for pid=3469 comm="android.ui" path="/s1
[   13.098029@5] type=1400 audit(1293883211.680:46): avc: denied { open } for pid=3469 comm="android.ui" path="/s1
[   13.121904@5] type=1400 audit(1293883211.680:47): avc: denied { getattr } for pid=3469 comm="android.ui" path=1
[   13.502792@2] acc_open
[   13.502822@2] acc_release
[   13.854958@1] meson6-dwmac ff3f0000.ethernet eth0: fail to init PTP.
[   13.857047@1] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.963499@3] sdcardfs version 2.0
[   13.963526@3] sdcardfs: dev_name -> /data/media
[   13.967045@3] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,g5
[   13.976699@3] sdcardfs: mnt -> ffffffc02a6a11a0
[   13.981456@3] sdcardfs: mounted on top of /data/media type ext4
[   13.987767@3] Remount options were mask=23,gid=9997 for vfsmnt ffffffc014e921e0.
[   13.995151@3] sdcardfs : options - debug:1
[   14.001929@3] sdcardfs : options - gid:9997
[   14.005385@3] sdcardfs : options - mask:23
[   14.011096@3] Remount options were mask=7,gid=9997 for vfsmnt ffffffc014e92e20.
[   14.015995@3] sdcardfs : options - debug:1
[   14.020275@3] sdcardfs : options - gid:9997
[   14.024618@3] sdcardfs : options - mask:7
[   14.335297@5] aml_wifi wifi: [usb_power_control] Set WiFi power down
[   14.336086@5] meson-mmc: [sdio_notify] finish
[   14.545700@2] aml_wifi wifi: [usb_power_control] Set WiFi power on !
[   14.554957@5] audio_dsp: dts_dec_control/0x0
[   14.741110@3] init: Could not find service hosting interface android.hardware.radio@1.0::IRadio/slot1
[   14.746628@3] init: Could not find service hosting interface android.hardware.radio@1.0::IRadio/slot1
[   14.752283@1] meson-mmc: [sdio_notify] finish
[   14.753903@0] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   14.753907@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   14.754979@0] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   14.754985@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   14.760556@0] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   14.760560@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   14.780301@1] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   14.780330@1] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   14.813163@1] sdio: queuing unknown CIS tuple 0x80 (2 bytes)
[   14.815403@5] sensors 4-000e: set sensor poll time to 66ms
[   14.822147@1] sensors 4-000e: sensor on: starting poll sensor data 64ms
[   14.832396@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   14.836141@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   14.843642@1] sdio: queuing unknown CIS tuple 0x80 (7 bytes)
[   14.850216@1] sdio: queuing unknown CIS tuple 0x81 (9 bytes)
[   14.945203@1] meson-aml-mmc ffe03000.sdio: divider requested rate 200000000 != actual rate 199999997: ret=0
[   14.949888@1] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[   14.955496@1] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000245
[   14.962027@1] meson-mmc: Data 1 aligned delay is 0
[   14.966765@1] meson-mmc: sdio: clk 199999997 tuning start
[   14.977744@1] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   14.977781@1] meson-mmc: step:4, delay1:0x4104104, delay2:0x4004104
[   14.988299@1] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   14.988338@1] meson-mmc: step:8, delay1:0x8208208, delay2:0x8008208
[   14.999502@1] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   14.999541@1] meson-mmc: step:12, delay1:0xc30c30c, delay2:0xc00c30c
[   15.010687@1] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   15.010725@1] meson-mmc: step:16, delay1:0x10410410, delay2:0x10010410
[   15.022223@1] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   15.022261@1] meson-mmc: step:20, delay1:0x14514514, delay2:0x14014514
[   15.032781@1] meson-mmc: sdio: adj_win: < 0 2 3 4 >
[   15.033590@1] meson-mmc: left:3, right:0, mid:4, size:4
[   15.038845@1] meson-mmc: step:0, delay1:0x0, delay2:0x0
[   15.044013@1] meson-mmc: sdio: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x32000
[   15.052424@1] meson-mmc: delay1:0x0, delay2:0x0
[   15.060669@1] sdio: new ultra high speed SDR104 SDIO card at address 0001
[   15.063654@1] sdio: clock 199999997, 4-bit-bus-width
 [   15.069914@5] meson-mmc: [sdio_reinit] finish
[   15.073279@5] aml_wifi wifi: [usb_power_control] Set WiFi power on !
[   15.079495@5] aml_wifi wifi: [pci_reinit] pci wifi reinit!
[   15.084971@5] aml_wifi wifi: [wifi_power_ioctl] Set sdio wifi power up!
[   15.091592@5] aml_wifi wifi: [wifi_power_ioctl] wifi interface dev type: sdio, length = 4
[   15.100064@2] type=1400 audit(1293883211.680:47): avc: denied { getattr } for pid=3469 comm="android.ui" path=1
[   15.124122@2] type=1400 audit(1293883213.752:48): avc: denied { write } for pid=3231 comm="wifi@1.0-servic" na1
[   15.145486@2] type=1400 audit(1293883213.752:48): avc: denied { write } for pid=3231 comm="wifi@1.0-servic" na1
[   15.166819@2] type=1400 audit(1293883213.752:49): avc: denied { add_name } for pid=3231 comm="wifi@1.0-servic"1
[   15.298304@0] [dhd] dhd_module_init: in Dongle Host Driver, version 100.10.545.11 (r826445-20200610-1)
[   15.302369@0] [dhd] ======== dhd_wlan_init_plat_data ========
[   15.308176@1] [dhd] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=70, oob_irq_flags=0x418
[   15.315942@3] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1
[   15.321094@3] [dhd] dhd_wifi_platform_load: Enter
[   15.325994@3] [dhd] Power-up adapter 'DHD generic adapter'
[   15.330969@3] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[   15.337054@3] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[   15.343282@3] aml_wifi wifi: [extern_wifi_set_enable] WIFI  Disable! 482
[   15.391056@2] BT_RADIO going: on
[   15.391082@2] AML_BT: going ON
[   15.553763@5] aml_wifi wifi: [extern_wifi_set_enable] WIFI  Enable! 482
[   15.782085@3] Now can use cma, free:11928, wm:11935
[   15.804477@2] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 0 to 9600
[   15.806910@2] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 9600 to 9600
[   15.815206@0] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 9600 to 115200
[   15.828478@0] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 2000000
[   16.060239@3] [dhd] wifi_platform_bus_enumerate device present 1
[   16.060624@3] [dhd] ======== Card detection to detect SDIO card! ========
[   16.067602@3] sdio_reset_comm():
[   16.070817@3] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   16.076921@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   16.108260@3] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   16.108471@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   16.135663@5] sdio: queuing unknown CIS tuple 0x80 (2 bytes)
[   16.138634@5] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   16.144553@4] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   16.152680@3] sdio: queuing unknown CIS tuple 0x80 (7 bytes)
[   16.160641@5] sdio: queuing unknown CIS tuple 0x81 (9 bytes)
[   16.263671@4] meson-aml-mmc ffe03000.sdio: divider requested rate 200000000 != actual rate 199999997: ret=0
[   16.267839@4] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[   16.274177@4] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000245
[   16.280704@4] meson-mmc: Data 1 aligned delay is 0
[   16.285398@4] meson-mmc: sdio: clk 199999997 tuning start
[   16.296784@3] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   16.296815@3] meson-mmc: step:4, delay1:0x4104104, delay2:0x4004104
[   16.297075@5] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 2000000 to 115200
[   16.316710@5] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   16.316741@5] meson-mmc: step:8, delay1:0x8208208, delay2:0x8008208
[   16.329927@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   16.329958@3] meson-mmc: step:12, delay1:0xc30c30c, delay2:0xc00c30c
[   16.344771@2] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   16.344804@2] meson-mmc: step:16, delay1:0x10410410, delay2:0x10010410
[   16.359831@5] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   16.359863@5] meson-mmc: step:20, delay1:0x14514514, delay2:0x14014514
[   16.372174@2] meson-mmc: sdio: adj_win: < 0 2 3 4 >
[   16.372225@2] meson-mmc: left:3, right:0, mid:4, size:4
[   16.376688@2] meson-mmc: step:0, delay1:0x0, delay2:0x0
[   16.381841@2] meson-mmc: sdio: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x32000
[   16.390285@2] meson-mmc: delay1:0x0, delay2:0x0
[   16.394766@2] meson-mmc: [sdio_reinit] finish
[   16.415906@2] [dhd] bcmsdh_register: register client driver
[   16.416115@2] [dhd] bcmsdh_sdmmc_probe: Enter num=1
[   16.420924@2] [dhd] bcmsdh_sdmmc_probe: Enter num=2
[   16.425705@2] [dhd] bus num (host idx)=2, slot num (rca)=1
[   16.431055@2] [dhd] found adapter info 'DHD generic adapter'
[   16.436699@2] Wifi: bcmdhd_mem_prealloc: sectoin 3, size 139264
[   16.442606@2] succeed to alloc static buf
[   16.446539@2] Wifi: bcmdhd_mem_prealloc: sectoin 4, size 0
[   16.452092@2] [dhd] sdioh_attach: set sd_f2_blocksize 256
[   16.457469@2] [dhd] sdioh_attach: sd clock rate = 0
[   16.462714@2] [dhd] dhdsdio_probe : no mutex held. set lock
[   16.467902@2] [dhd] F1 signature read @0x18000000=0x17294359
[   16.478805@4] [dhd] F1 signature OK, socitype:0x1 chip:0x4359 rev:0x9 pkg:0x2
[   16.481296@5] [dhd] DHD: dongle ram size is set to 917504(orig 917504) at 0x160000
[   16.488263@5] Wifi: bcmdhd_mem_prealloc: sectoin 7, size 31624
[   16.493907@5] [dhd] dhd_conf_set_chiprev : chip=0x4359, chiprev=9
[   16.500010@5] Wifi: bcmdhd_mem_prealloc: sectoin 0, size 10320
[   16.504605@0] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 2000000
[   16.514928@5] Wifi: bcmdhd_mem_prealloc: sectoin 5, size 65536
[   16.520659@5] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   16.528656@5] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   16.537058@5] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   16.545481@5] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   16.553887@5] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   16.562266@5] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   16.570722@5] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   16.579232@5] Wifi: bcmdhd_mem_prealloc: sectoin 19, size 65712
[   16.584982@5] Wifi: bcmdhd_mem_prealloc: sectoin 20, size 262144
[   16.591069@5] Wifi: bcmdhd_mem_prealloc: sectoin 22, size 65536
[   16.596876@5] [dhd] dhd_log_dump_init: kernel log buf size = 512KB; logdump_prsrv_tailsize = 80KB; limit prsrvB
[   16.608580@5] [dhd] dhd_log_dump_init : Try to allocate memory total(4194304) special(8192)
[   16.616887@5] Wifi: bcmdhd_mem_prealloc: sectoin 15, size 4194304
[   16.623509@5] Wifi: bcmdhd_mem_prealloc: sectoin 16, size 8192
[   16.629470@5] dhd_attach(): thread:dhd_watchdog_thread:fab started
[   16.634957@5] dhd_attach(): thread:dhd_dpc:fac started
[   16.640425@5] dhd_attach(): thread:dhd_rxf:fad started
[   16.645121@5] [dhd] dhd_deferred_work_init: work queue initialized
[   16.651248@5] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[   16.658629@5] [dhd] get_mem_val_from_file: File [/data/vendor/misc/wifi/.memdump.info] doesn't exist
[   16.667603@5] [dhd] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[   16.673317@5] [dhd] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[   16.703021@2] Wifi: bcmdhd_mem_prealloc: sectoin 1, size 10300
[   16.703261@2] Wifi: bcmdhd_mem_prealloc: sectoin 2, size 65536
[   16.709281@2] [dhd] dhdsdio_probe_init: making DHD_BUS_DOWN
[   16.715264@4] [dhd] Dongle Host Driver, version 100.10.545.11 (r826445-20200610-1)
[   16.722899@4] [dhd] Register interface [wlan0]  MAC: 6c:21:a2:9b:19:78
[   16.722899@4]
[   16.730505@4] [dhd] dhd_dbg_detach_pkt_monitor, 2099
[   16.735250@4] [dhd] dhd_bus_devreset: == Power OFF ==
[   16.740688@4] [dhd] dhd_bus_stop: making DHD_BUS_DOWN
[   16.745382@4] [dhd] bcmsdh_oob_intr_unregister: Enter
[   16.750307@4] [dhd] bcmsdh_oob_intr_unregister: irq is not registered
[   16.756767@4] [dhd] dhd_bus_devreset: making dhdpub up FALSE
[   16.762504@4] [dhd] dhd_txglom_enable: enable 0
[   16.766936@4] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[   16.772234@4] [dhd] dhd_bus_devreset:  WLAN OFF DONE
[   16.777249@4] [dhd] wifi_platform_set_power = 0, delay: 0 msec
[   16.782985@4] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========
[   16.788722@4] [dhd] dhd_ifname: ifidx 16 out of range
[   16.793724@4] [dhd] <if_bad>: set cur_etheraddr failed
[   16.798817@4] [dhd] dhd_ifname: ifidx 16 out of range
[   16.803854@4] [dhd] dhd_register_if: _dhd_set_mac_address() failed
[   16.810614@4] [dhd] Register interface [wlan1]  MAC: 6e:21:a2:9b:19:78
[   16.810614@4]
[   16.818172@4] [dhd] dhdsdio_probe : the lock is released.
[   16.823693@4] [dhd] dhd_module_init: Exit err=0
[   16.912596@1] meson6-dwmac ff3f0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   16.915788@1] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   16.923288@1] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   16.939315@3] [dhd] dhd_open: Enter wlan0
[   16.939344@3] [dhd] dhd_open : no mutex held. set lock
[   16.942985@3] [dhd]
[   16.942985@3] Dongle Host Driver, version 100.10.545.11 (r826445-20200610-1)
[   16.952324@3] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[   16.957829@3] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[   16.963845@3] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[   16.970120@5] aml_wifi wifi: [extern_wifi_set_enable] WIFI  Disable! 482
[   17.141804@2] selinux: avc:  denied  { set } for property=dhclient.ipaddress.eth0 pid=3469 uid=1000 gid=1000 s1
[   17.141804@2]
[   17.176374@5] aml_wifi wifi: [extern_wifi_set_enable] WIFI  Enable! 482
[   17.684222@5] sdio_reset_comm():
[   17.684299@5] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   17.687632@5] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   17.724267@2] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   17.724474@2] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   17.859559@2] meson-aml-mmc ffe03000.sdio: divider requested rate 200000000 != actual rate 199999997: ret=0
[   17.863679@2] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[   17.869785@2] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000245
[   17.876355@2] meson-mmc: Data 1 aligned delay is 0
[   17.881140@2] meson-mmc: sdio: clk 199999997 tuning start
[   17.892744@5] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   17.892773@5] meson-mmc: step:4, delay1:0x4104104, delay2:0x4004104
[   17.905335@2] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   17.905554@2] meson-mmc: step:8, delay1:0x8208208, delay2:0x8008208
[   17.918978@2] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   17.919015@2] meson-mmc: step:12, delay1:0xc30c30c, delay2:0xc00c30c
[   17.933432@2] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   17.933469@2] meson-mmc: step:16, delay1:0x10410410, delay2:0x10010410
[   17.947625@2] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   17.947656@2] meson-mmc: step:20, delay1:0x14514514, delay2:0x14014514
[   17.960138@5] meson-mmc: sdio: adj_win: < 0 2 3 4 >
[   17.960169@5] meson-mmc: left:3, right:0, mid:4, size:4
[   17.964631@5] meson-mmc: step:0, delay1:0x0, delay2:0x0
[   17.969818@5] meson-mmc: sdio: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x32000
[   17.978260@5] meson-mmc: delay1:0x0, delay2:0x0
[   17.982856@2] [dhd] sdioh_start: set sd_f2_blocksize 256
[   17.988745@5] [dhd]
[   17.988745@5]
[   17.988745@5] dhd_bus_devreset: == Power ON ==
[   17.996449@2] [dhd] F1 signature read @0x18000000=0x17294359
[   18.008014@5] [dhd] F1 signature OK, socitype:0x1 chip:0x4359 rev:0x9 pkg:0x2
[   18.010547@2] [dhd] DHD: dongle ram size is set to 917504(orig 917504) at 0x160000
[   18.017266@2] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[   18.022719@3] [dhd] dhdsdio_probe_init: making DHD_BUS_DOWN
[   18.029502@5] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/wifi/4359/config.txt
[   18.036609@5] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/wifi/4359/fw_bcm4359c0_ag.bin
[   18.045916@5] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/wifi/4359/nvram_ap6398s.txt
[   18.054995@5] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/wifi/4359/clm_bcm4359c0_ag.blob
[   18.064543@5] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/wifi/4359/config.txt
[   18.074696@3] [dhd] dhd_os_open_image1: /vendor/etc/wifi/4359/fw_bcm4359c0_ag.bin (662637 bytes) open success
[   18.193885@5] [dhd] dhd_os_open_image1: /vendor/etc/wifi/4359/nvram_ap6398s.txt (6090 bytes) open success
[   18.198138@5] [dhd] NVRAM version: AP6398S_NVRAM_V2.0_20191009A
[   18.205072@3] [dhd] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   18.400840@5] [dhd] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   18.402089@5] [dhd] bcmsdh_oob_intr_register: HW_OOB irq=70 flags=0x8
[   18.408371@5] [dhd] get_mem_val_from_file: File [/data/vendor/misc/wifi/.memdump.info] doesn't exist
[   18.417269@5] [dhd] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[   18.423186@5] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 -> mode 1
[   18.430692@5] [dhd] dhd_apply_default_clm: Ignore clm file /vendor/etc/wifi/4359/clm_bcm4359c0_ag.blob
[   18.440535@5] [dhd] Firmware up: op_mode=0x0405, MAC=6c:21:a2:9b:19:78
[   18.448718@5] [dhd] dhd_preinit_ioctls: event_log_max_sets: 26 ret: -23
[   18.460435@5] [dhd]   Driver: 100.10.545.11 (r826445-20200610-1)
[   18.460435@5]   Firmware: wl0: Feb 22 2022 19:34:20 version 9.87.51.11.82 (g383358a) FWID 01-cd4b2098
[   18.460435@5]   CLM: 9.7.6 (2022-02-22 19:33:51)
[   18.475352@2] [dhd] dhd_preinit_ioctls wlc_ver failed -23
[   18.480479@3] [dhd] dhd_txglom_enable: enable 1
[   18.484555@3] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy
[   18.490630@3] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[   18.498128@3] [dhd] dhd_conf_set_txglom_params : txinrx_thres=128, dhd_txminmax=-1
[   18.505620@3] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[   18.513246@3] [dhd] dhd_conf_get_disable_proptx : fw_proptx=0, disable_proptx=1
[   18.522297@5] [dhd] dhd_pno_init: Support Android Location Service
[   18.552718@3] [dhd] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[   18.555860@3] [dhd] dhd_rtt_init : FTM is not supported
[   18.561823@5] [dhd] dhd_rtt_ftm_config : failed to set config
[   18.569290@3] [dhd] failed to set WNM capabilities
[   18.585133@3] [dhd] dhd_preinit_ioctls: Failed to get preserve log # !
[   18.586342@5] [dhd] dhd_conf_map_country_list : CN/38
[   18.591067@5] [dhd] dhd_conf_set_country : set country CN, revision 38
[   18.600014@3] [dhd] dhd_conf_set_country : Country code: CN (CN/38)
[   18.612418@5] [dhd] CONFIG-ERROR) dhd_conf_set_intiovar : txbf setting failed -23
[   18.614276@5] [dhd-wlan0] wl_android_wifi_on : Success
[   18.663653@3] [dhd] dhd_open : the lock is released.
[   18.663686@3] [dhd] dhd_open: Exit wlan0 ret=0
[   18.667417@3] [dhd] [wlan0] tx queue started
[   18.682355@5] type=1400 audit(1293883215.484:55): avc: denied { open } for pid=3231 comm="wifi@1.0-servic" pat1
[   18.684831@3] audit: audit_lost=23 audit_rate_limit=5 audit_backlog_limit=64
[   18.684833@3] audit: rate limit exceeded
[   18.710677@5] type=1400 audit(1293883217.336:56): avc: denied { getattr } for pid=1 comm="init" path="/system/1
[   18.726077@3] Process ip granted CAP_NET_ADMIN from Android group net_admin.
[   18.726078@3]   Please update the .rc file to explictly set 'capabilities NET_ADMIN'
[   18.726080@3]   Implicit grants are deprecated and will be removed in the future.
[   18.726091@3] Process ip granted CAP_NET_ADMIN from Android group net_admin.
[   18.726092@3]   Please update the .rc file to explictly set 'capabilities NET_ADMIN'
[   18.726093@3]   Implicit grants are deprecated and will be removed in the future.
[   18.726269@3] Process ip granted CAP_NET_ADMIN from Android group net_admin.
[   18.726270@3]   Please update the .rc file to explictly set 'capabilities NET_ADMIN'
[   18.726271@3]   Implicit grants are deprecated and will be removed in the future.
[   18.747019@2] [dhd] P2P interface registered
[   18.747022@2] [dhd] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc009b63600, wdev->net:           (null)
[   18.753920@0] [dhd] WLC_E_IF: NO_IF set, event Ignored
[   18.792739@2] [dhd] Random MAC OUI to be used - da:1:19
[   18.803351@4] [dhd] dhd_dbg_attach_pkt_monitor, 1501
[   18.804779@2] [dhd] net_os_enable_packet_filter: val = 0
[   18.805451@2] [dhd] net_os_rxfilter_add_remove: add_remove = 0, num = 2
[   18.806972@4] [dhd] net_os_enable_packet_filter: val = 1
[   18.807349@4] [dhd] net_os_enable_packet_filter: val = 0
[   18.807697@4] [dhd] net_os_rxfilter_add_remove: add_remove = 0, num = 3
[   18.808972@4] [dhd] net_os_enable_packet_filter: val = 1
[   18.809351@4] [dhd] dhd_set_suspend: Remove extra suspend setting
[   18.809741@2] [dhd] dhd_enable_packet_filter: enter, value = 0
[   18.872576@5] type=1400 audit(1293883217.336:56): avc: denied { getattr } for pid=1 comm="init" path="/system/1
[   18.893089@5] type=1400 audit(1293883217.336:57): avc: denied { execute } for pid=4029 comm="init" name="dhcli1
[   18.912708@5] type=1400 audit(1293883217.336:57): avc: denied { execute } for pid=4029 comm="init" name="dhcli1
[   18.932338@5] type=1400 audit(1293883217.336:58): avc: denied { read open } for pid=4029 comm="init" path="/sy1
[   18.953428@5] type=1400 audit(1293883217.336:58): avc: denied { read open } for pid=4029 comm="init" path="/sy1
[   18.974095@5] type=1400 audit(1293883217.336:59): avc: denied { transition } for pid=4029 comm="init" path="/s1
[   18.995404@5] type=1400 audit(1293883217.336:59): avc: denied { transition } for pid=4029 comm="init" path="/s1
[   19.016555@5] type=1400 audit(1293883217.336:60): avc: denied { entrypoint } for pid=4029 comm="init" path="/s1
[   20.911776@2] zram0: detected capacity change from 0 to 268435456
[   20.948267@0] mkswap: Swapspace size: 262140k, UUID=aa1a1f41-d0b7-4dbc-9da3-66f28e1c34b7
[   20.951544@0] Adding 262140k swap on /dev/block/zram0.  Priority:-1 extents:1 across:262140k SS
[   20.985098@0] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 0, bssidx: 0
[   21.041042@3] selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)
[   21.041042@3]
[   21.101078@0] selinux: SELinux: Skipping restorecon_recursive(/data/misc_ce/0)
[   21.101078@0]
[   21.476545@2] audit: audit_lost=127 audit_rate_limit=5 audit_backlog_limit=64
[   21.478238@2] audit: rate limit exceeded
[   22.212826@4] adc_keypad adc_keypad: del older key => home:102:2:108:40
[   22.213815@4] adc_keypad adc_keypad: add newer key => home:3:2:108:40
[   24.072548@0] type=1400 audit(1293883220.772:185): avc: denied { write } for pid=4029 comm="dhclient" lport=541
[   24.088858@0] type=1400 audit(1687516528.358:190): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   24.553394@0] type=1400 audit(1687516528.358:190): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   24.564666@0] type=1400 audit(1687516528.842:191): avc: denied { search } for pid=3469 comm="CpuTracker" name=1
[   24.587122@0] type=1400 audit(1687516528.842:191): avc: denied { search } for pid=3469 comm="CpuTracker" name=1
[   24.606273@1] type=1400 audit(1687516528.842:192): avc: denied { read } for pid=3469 comm="CpuTracker" name="s1
[   24.624739@3] type=1400 audit(1687516528.842:192): avc: denied { read } for pid=3469 comm="CpuTracker" name="s1
[   24.644848@3] type=1400 audit(1687516528.842:193): avc: denied { open } for pid=3469 comm="CpuTracker" path="/1
[   26.262623@2] type=1400 audit(1687516528.842:193): avc: denied { open } for pid=3469 comm="CpuTracker" path="/1
[   26.278400@2] type=1400 audit(1687516530.550:194): avc: denied { write } for pid=4029 comm="dhclient" path="so1
[   29.079848@0] type=1400 audit(1687516530.554:199): avc: denied { read } for pid=4029 comm="dhclient" lport=5461
[   29.096038@0] type=1400 audit(1687516533.366:200): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   34.469966@0] type=1400 audit(1687516533.366:200): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   34.485835@0] type=1400 audit(1687516538.758:201): avc: denied { create } for pid=4029 comm="dhclient" scontex1
[   34.499536@0] type=1400 audit(1687516538.758:201): avc: denied { create } for pid=4029 comm="dhclient" scontex1
[   34.520024@0] type=1400 audit(1687516538.758:202): avc: denied { ioctl } for pid=4029 comm="dhclient" path="so1
[   34.541471@2] type=1400 audit(1687516538.758:202): avc: denied { ioctl } for pid=4029 comm="dhclient" path="so1
[   34.564855@2] type=1400 audit(1687516538.758:203): avc: denied { write } for pid=4029 comm="dhclient" lport=541
[   34.583681@3] asoc-aml-card auge_sound: tdm playback stop
[   34.589175@2] type=1400 audit(1687516538.758:203): avc: denied { write } for pid=4029 comm="dhclient" lport=541
[   34.608201@2] type=1400 audit(1687516538.770:204): avc: denied { read } for pid=4029 comm="dhclient" lport=5461
[   34.720214@3] es8316 spk_ctl_gpio 1
[   34.720242@3] es8316 spk_mute_gpio 0
[   34.722300@3] asoc-aml-card auge_sound: tdm playback enable
[   40.986849@0] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 1, bssidx: 0
[   41.794880@0] type=1400 audit(1687516538.770:204): avc: denied { read } for pid=4029 comm="dhclient" lport=5461
[   41.808594@4] type=1400 audit(1687516546.082:205): avc: denied { search } for pid=3469 comm="CpuTracker" name=1
[   41.828971@4] type=1400 audit(1687516546.082:205): avc: denied { search } for pid=3469 comm="CpuTracker" name=1
[   41.849084@4] type=1400 audit(1687516546.082:206): avc: denied { read } for pid=3469 comm="CpuTracker" name="s1
[   41.869033@4] type=1400 audit(1687516546.082:206): avc: denied { read } for pid=3469 comm="CpuTracker" name="s1
[   41.889038@4] type=1400 audit(1687516546.082:207): avc: denied { open } for pid=3469 comm="CpuTracker" path="/1
[   42.062820@3] audit: audit_lost=133 audit_rate_limit=5 audit_backlog_limit=64
[   42.062960@0] type=1400 audit(1687516546.082:207): avc: denied { open } for pid=3469 comm="CpuTracker" path="/1
[   42.062998@0] type=1400 audit(1687516546.350:208): avc: denied { search } for pid=3221 comm="memtrack@1.0-se" 1
[   42.063702@0] type=1400 audit(1687516546.350:208): avc: denied { search } for pid=3221 comm="memtrack@1.0-se" 1
[   42.063731@0] type=1400 audit(1687516546.350:209): avc: denied { read } for pid=3221 comm="memtrack@1.0-se" na1
[   42.149522@3] audit: rate limit exceeded
[   48.915213@0] type=1400 audit(1687516548.394:240): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   48.930485@0] type=1400 audit(1687516553.202:241): avc: denied { getpgid } for pid=1 comm="init" scontext=u:r:1
[   48.942913@0] type=1400 audit(1687516553.202:241): avc: denied { getpgid } for pid=1 comm="init" scontext=u:r:1
[   48.958706@0] type=1400 audit(1687516553.202:242): avc: denied { sigkill } for pid=1 comm="init" scontext=u:r:1
[   62.576273@2] fb: mem_free_work, free memory: addr:800000
[   80.995214@0] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 2, bssidx: 0
[   85.024654@2] init: Could not find service hosting interface android.hardware.radio@1.0::IRadio/slot1
[   85.028567@2] init: Could not find service hosting interface android.hardware.radio@1.0::IRadio/slot1
[   86.464386@5] type=1400 audit(1687516553.202:242): avc: denied { sigkill } for pid=1 comm="init" scontext=u:r:1
[   86.479172@5] type=1400 audit(1687516590.750:243): avc: denied { read write } for pid=4871 comm=4173796E6354611
[   86.497530@5] type=1400 audit(1687516590.750:243): avc: denied { read write } for pid=4871 comm=4173796E6354611
[   86.518020@5] type=1400 audit(1687516590.750:244): avc: denied { open } for pid=4871 comm=4173796E635461736B201
[   86.546947@5] type=1400 audit(1687516590.750:244): avc: denied { open } for pid=4871 comm=4173796E635461736B201
[   86.572273@5] type=1400 audit(1687516590.750:245): avc: denied { getattr } for pid=4871 comm=4173796E6354617361
[   89.244486@2] type=1400 audit(1687516590.750:245): avc: denied { getattr } for pid=4871 comm=4173796E6354617361
[   89.267215@2] type=1400 audit(1687516593.534:246): avc: denied { open } for pid=4947 comm="IntentService[D" pa1
[   89.287846@2] type=1400 audit(1687516593.534:246): avc: denied { open } for pid=4947 comm="IntentService[D" pa1
[   89.571515@5] audit: audit_lost=163 audit_rate_limit=5 audit_backlog_limit=64
[   89.573093@5] audit: rate limit exceeded
[   96.469754@3] asoc-aml-card auge_sound: tdm playback stop
[   96.616210@2] es8316 spk_ctl_gpio 1
[   96.616246@2] es8316 spk_mute_gpio 0
[   96.618380@2] asoc-aml-card auge_sound: tdm playback enable
[  161.002186@0] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 3, bssidx: 0
Booting krescue from sd-card with Android on eMMC.
OPTIONS: I18n
Port /dev/ttyUSB0, 12:28:00
Press CTRL-A Z for help on special keys
G12B:BL:6e7c85:2a3b91;FEAT:E0F83180:402000;POC:F;RCY:0;EMMC:0;READ:0;0.
        bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0000 - pwm id 0x01
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 167922
BL2 Built : 19:23:21, Sep 18 2020. g12b g9fde858 - gongwei.chen@droid11-sz
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 0002d8d6
eMMC boot @ 0
sw8 s
board id: 6
Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
Get wrong ddr fw magic! Error!!
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
ddr saved addr:00016000
Load ddr parameter from eMMC, src: 0x02c00000, des: 0xfffd0000, size: 0x00001000, part: 0
00000000
emmc switch 0 ok
fastboot data verify
result: 255
Cfg max: 12, cur: 1. Board id: 255. Force loop cfg
LPDDR4 probe
LPDDR4_PHY_V_0_1_22-Built : 14:57:26, Sep  1 2020. g12b g3c95fed - gongwei.chen@droid11-sz
ddr clk to 1608MHz
dmc_version 0001
Check phy result
INFO : ERROR : Training has failed!
Check phy result
Check phy result
INFO : End of initialization
1D training failed
Cfg max: 12, cur: 2. Board id: 255. Force loop cfg
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
INFO : End of CA training
INFO : Training has run successfully!
Check phy result
INFO : End of read enable training
INFO : End of fine write leveling
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of Write leveling coarse delay
INFO : End of read delay center optimization
Check phy result
INFO : End of write delay center optimization
INFO : End of max read latency training
1D training succeed
Check phy result
INFO : End of 2D read delay Voltage center optimization
INFO : End of 2D write delay Voltage center optimization
soc_vref_reg_value 0x 00000021 0000001f 00000020 00000023 00000020 00000021 00000020 0000001f 00000021 00000020 0
 dram_vref_reg_value 0x 00000048
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002cDDR size: 2048MB
cs0 DataBus test pass
cs0 AddrBus test pass
non-sec scramble use zero key
ddr scramble enabled
100bdlr_step_size ps== 431
result report
boot times 0Enable ddr reg access
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000e1400, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
[Image: g12b_v1.1.3396-c893a7153 2020-11-11 13:54:36 gongwei.chen@droid11-sz]
OPS=0x10
ring efuse init
chipver efuse init
29 0b 10 00 01 0c 0c 00 00 03 37 30 4e 42 4e 50
[0.016082 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):5c909a099
NOTICE:  BL31: Built : 17:18:21, Nov 20 2020
NOTICE:  BL31: G12A normal boot!
NOTICE:  BL31: BL33 decompress pass
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01-g659d7a71e9-dirty (Jan 30 2023 - 14:15:46)
DRAM:  2 GiB
Relocation Offset is: 76e23000
mmu cfg end: 0x80000000
spi_post_bind(spicc): req_seq = 0
spi_post_bind(spifc): req_seq = 1
register usb cfg[0][1] = 0000000077f31960
aml_i2c_init_port init regs for 0
MCU version: 0x00 0x01
MCU version is to low! Doesn't support froce boot from SD card.
NAND:  MMC:   aml_priv->desc_buf = 0x0000000073e13b10
aml_priv->desc_buf = 0x0000000073e15e50
SDIO Port B: 0, SDIO Port C: 1
co-phase 0x3, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x3ff2800
emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x3ff2800
co-phase 0x1, tx-dly 0, clock 40000000
[set_emmc_calc_fixed_adj][875]find fixed adj_delay=20
init_part() 297: PART_TYPE_AML
[mmc_init] mmc init success
start dts,buffer=0000000073e186c0,dt_addr=0000000073e186c0
get_partition_from_dts() 92: ret 0
parts: 17
00:      logo   0000000000800000 1
01:  recovery   0000000001800000 1
02:      misc   0000000000800000 1
03:      dtbo   0000000000800000 1
04:  cri_data   0000000000800000 2
05:     param   0000000001000000 2
06:      boot   0000000001000000 1
set has_boot_slot = 0
07:       rsv   0000000001000000 1
08:  metadata   0000000001000000 1
09:    vbmeta   0000000000200000 1
10:       tee   0000000002000000 1
11:    vendor   000000001f000000 1
12:       odm   0000000008000000 1
13:    system   0000000078800000 1
14:   product   0000000008000000 1
15:     cache   0000000046000000 2
16:      data   ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!!
crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!!
crc32_s:0x79f50f07 == storage crc_pattern:0x79f50f07!!!
mmc env offset: 0x4d400000
In:    serial
Out:   serial
Err:   serial
aml log : internal sys error!
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-3354: calc c731f02c, store 0
update_dtb_info()-3462: cpy 1 is not valid
update_dtb_info()-3462: cpy 0 is not valid
dtb_read()-3569: total valid 0
emmc - EMMC sub system
Usage:
emmc dtb_read addr size
emmc dtb_write addr size
emmc erase dtb
emmc erase key
emmc fastboot_read addr size
emmc fastboot_write addr size
fusb302_init: Device ID: 0x91
CC connected in 1 as UFP
fusb302 detect chip.port_num = 0
amlkey_init() enter!
[EFUSE_MSG]keynum is 1
vpu: driver version: v20190313
vpu: detect chip type: 9
vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz)
vpu: clk_level in dts: 7
vpu: vpu_power_on
vpu: set_vpu_clk
vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100)
vpu: set_vpu_clk finish
vpu: vpu_module_init_config
vpp: vpp_init
vpp: vpp osd2 matrix rgb2yuv..............
hdr_func 4, hdr_process_select 0x1
LCD_RESET PIN: 0
lcd: lcd_debug_print flag: 0
lcd: detect mode: tablet, key_valid: 0
lcd: detect lcd_clk_path: 1
lcd: failed to get lcd_cpu_gpio_names
lcd: load config from dts
lcd: pinctrl_version: 2
lcd: use panel_type=lcd_1
lcd: bl: pinctrl_version: 2
lcd: bl: name: backlight_pwm, method: 1
lcd: error: gpio: wrong name invalid
lcd: bl: pwm_reg=0x00800002
lcd: bl: aml_bl_power_ctrl: 0
Net:   use internal ethernet
--------ext_ethernet=0
+++++++++ext_ethernet=0
dwmac.ff3f0000 Waiting for PHY auto negotiation to complete.... done
The Best Window is index 40
[KM]Msg:isEncrypt=
[KM]Msg:keyAttr is 0x00000000
dwmac.ff3f0000amlkey_init() enter!
amlkey_init() 71: already init!
ramdump_init, add:0, size:0
CONFIG_AVB2: null
Start read misc partition datas!
info->magic =
info->version_major = 1
info->version_minor = 0
info->slots[0].priority = 15
info->slots[0].tries_remaining = 7
info->slots[0].successful_boot = 0
info->slots[1].priority = 14
info->slots[1].tries_remaining = 7
info->slots[1].successful_boot = 0
info->crc32 = -1075449479
active slot = 0
wipe_data=successful
wipe_cache=successful
upgrade_step=0
reboot_mode:::: cold_boot
lcd: error: outputmode[1080p60hz] is not support
hpd_state=1
do_hpd_detect: hdmimode=1080p60hz
do_hpd_detect: colorattribute=444,12bit
Edid_MonitorCapable861: ycbcr444=1, ycbcr422=1
HDMI_EDID_BLOCK_TYPE_VENDER: pRXCap->ColorDeepSupport=0x38
sink preferred_mode is 1080p60hz[16]
hdmi screen is not single resolution
hdr mode is 0
dv  mode is ver:0  len: 0
hdr10+ mode is 0
read hdmichecksum 0x00000000, colorattribute 444,12bit
read hdmimode 1080p60hz, colorspace <NULL>, colordepth <NULL>
do_get_parse_edid: autoMode = false, manualMode=16
isYuv4kSink: false, maxTMDSRate=225
do_get_parse_edid: non-yuv4k sink: inColorSpace: HDMI_COLOR_FORMAT_RGB
do_get_parse_edid: default inColorDepth: HDMI_COLOR_DEPTH_24B
TV has changed, initial mode is: 1080p60hz  attr: 444,12bit crc is :0xb53e0000
Unknown command 'dovi' - try 'help'
[OSD]load fb addr from dts:/meson-fb
[OSD]set initrd_high: 0x7f800000
[OSD]fb_addr for logo: 0x7f800000
[OSD]VPP_OFIFO_SIZE:0xfff01fff
[CANVAS]canvas init
[CANVAS]addr=0x7f800000 width=3840, height=2160
[OSD]osd_hw.free_dst_data: 0,1919,0,1079
[OSD]osd1_update_disp_freescale_enable
vpp: vpp_matrix_update: 2
set hdmitx VIC = 16
aml_audio_init
config HPLL = 4455000 frac_rate = 1
HPLL: 0x3b0004b9
HPLL: 0x1b0004b9
HPLL: 0xdb0004b9
config HPLL done
j = 6  vid_clk_div = 1
hdmitx: set enc for VIC: 16
hdmitx phy setting done
rx version is 2.0  div=10
hdmtix: set audio
hdmi_tx_set: save mode: 1080p60hz, attr: 444,12bit, hdmichecksum: 0xb53e0000
hdr_packet
vpp: hdr_policy = 1
vpp: Rx hdr_info.hdr_sup_eotf_smpte_st_2084 = 0
s_version: U-Boot 2015.01-g659d7a71e9-dirty
normal power on
boot wol: disable
[reg_31] 0xd8a
[reg_16] 0x0
[reg_17] 0x7fff
[reg_19] 0x0
[reg_31] 0x0
[reg_31] 0xd40
[reg_22] 0x0
[reg_31] 0x0
saradc: 0x1ff, hw_ver: 0x31 (VIM3.V11)
gpio: pin GPIOAO_7 (gpio 7) value is 1
port mode is usb3.0
Command: bcb uboot-command
BCB hasn't any datas,exit!
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
cfgload: start ...
cfgload: reading /boot.ini from mmc 0:1 ...
card in
co-phase 0x2, tx-dly 0, clock 400000
co-phase 0x2, tx-dly 0, clock 40000000
init_part() 282: PART_TYPE_DOS
reading /boot.ini
9502 bytes read in 3 ms (3 MiB/s)
cfgload: applying boot.ini...
[#] Script a:73e1e180 l:9472 c:0 s:0 - run
** KRESCUE START hwver: VIM3.V11 hostname: arm_gxbb maxcpus: 6 fdt:  source: : target: **
[i] scan rescue device usb 0
** Bad device usb 0 **
[i] scan rescue device usb 1
** Bad device usb 1 **
[i] scan rescue device usb 2
** Bad device usb 2 **
[i] scan rescue device usb 1:5
[i] scan rescue device mmc 0
reading /rescue/80_user_env.txt
1898 bytes read in 5 ms (370.1 KiB/s)
[i] rescue loading via fatload mmc 0 ...
[w] detect by maxcpus -6-
**KRESCUE LOAD by fatload mmc 0 FROM // + post:  // VIM3.V11 // VIM3.V11**
load env
fatload mmc 0 0x32000000 /rescue/80_user_env.txt
env import -t 0x32000000 76a
load logo
fatload mmc 0 0x30000000 /splash.bmp
reading /splash.bmp
7660 bytes read in 4 ms (1.8 MiB/s)
There is no valid bmp file at the given address
BMP KO
fatload mmc 0 0x30000000 /rescue/splash.bmp.2.gz
reading /rescue/splash.bmp.2.gz
** Unable to read file /rescue/splash.bmp.2.gz **
unzip 0x30000000 0x7f800000
Uncompressed size: 518454 = 0x7E936
KRESCUE_TIME: 1641796810
KRESCUE_DATE: Mon Jan 10 06:40:10 2022
KRESCUE_VER : 220110_266
addrs:  UIMAGE_ADDR ::  UINITRD_ADDR ::  DTB_ADDR
addrs: 0x1080000 :: 0x8000000 :: 0x1000000
setenv kernel_addr_r ; setenv ramdisk_addr_r ; setenv fdt_addr_r ;
load dtb
fatload mmc 0 0x1000000 /rescue/fdt.kresq/amlogic/meson-g12b-a311d-khadas-vim3.dtb
reading /rescue/fdt.kresq/amlogic/meson-g12b-a311d-khadas-vim3.dtb
76986 bytes read in 13 ms (5.6 MiB/s)
libfdt fdt_path_offset() returned FDT_ERR_BADPATH
port mode is usb3.0
** port mode is 0 **
load packed initrd
fatload mmc 0 0x8000000 /rescue/uInitrd
reading /rescue/uInitrd
9155280 bytes read in 510 ms (17.1 MiB/s)
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
[i] bootargs: rw panic=10 net.ifnames=0 loglevel=4 fbcon=font:TER16x32 video=HDMI-A-1:1920x1080@60e config_firewa
[i] bootcmd:  run storeboot
load packed kernel
bootm 0x1080000 0x8000000 0x1000000
fatload mmc 0 0x1080000 /rescue/uImage
reading /rescue/uImage
6547474 bytes read in 359 ms (17.4 MiB/s)
avb2: 0
ee_gate_off ...
avb2: 0
## Booting kernel from Legacy Image at 01080000 ...
   Image Name:   kernel
   Image Type:   AArch64 Linux Kernel Image (gzip compressed)
   Data Size:    6547410 Bytes = 6.2 MiB
   Load Address: 0d080000
   Entry Point:  0d080000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 08000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (uncompressed)
   Data Size:    9155216 Bytes = 8.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
[store]Is good fdt check header, no need decrypt!
active_slot is normal
load dtb from 0x1000000 ......
## Flattened Device Tree blob at 01000000
   Booting using the fdt blob at 0x1000000
find 1 dtbos
No androidboot.dtbo_idx configured
And no dtbos will be applied
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x0d080000, end = 0x0e09ba00
[rsvmem] fdt get prop fail.
   Loading Ramdisk to 73555000, end 73e10290 ... OK
   Loading Device Tree to 000000001ffea000, end 000000001ffffd6f ... OK
fdt_fixup_memory_banks, reg:000000001fff6378
DTS already have 'reg' property
Starting kernel ...
uboot time: 6858755 us
[i] INITRD INIT :: UPTIME: 1.88 9.55 Linux (none) 5.14.0-rc5 #1 SMP PREEMPT Wed Dec 15 10:08:36 CST 2021 aarch64 x
[i] init display
failed to find a module named meson_ee_pwrc
failed to find a module named meson_dw_hdmi
#MANUAL
    link/ether 00:15:18:01:81:31 brd ff:ff:ff:ff:ff:ff
BusyBox v1.30.1 () built-in shell (ash)
# Krescue
     __ _____  Khadas ## hyphop ##
    / //_/ _ \___ ___ ______ _____
   / ,< / , _/ -_|_-</ __/ // / -_)
  /_/|_/_/|_|\__/___/\__/\_,_/\__/
 extreme tiny and fast rescue system
BUILD: 220110_266 from: Mon Jan 10 06:40:10 2022
[i] POST_CONFIG: kresq_type=sd + booted= + || start: /dev/mmcblk0
[i] Device: VIM3 Amlogic:G12B ver:0x0001 6 cores 2G ram 14.5 G eMMC
[w] root password undefined
[i] just type > krescue < to start gui
root@Krescue:/#
If I find out how to get the whole output then I'll update it. I really hate uart...
28 минут назад, NicoD сказал:
So I installed Android on eMMC. I think that's how it's shipped. But I'm having a very hard time to read out uart because it goes way too fast and forgets the top because too much info. I can show you the top of it and the last, but there's a whole part missing
I only need the output of the u-boot operation, before the kernel starts running Android. You can easily "limit" the desired output - when the kernel startup lines start (line "Start kernel ..."), just turn off the power. :) I also need the same log to run Armbian from an Sd card.
@balbes150 I've got the full output of Armbian on SD and Android on eMMC and it runs Android. I hope that's all you need.
OPTIONS: I18n
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 163086
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 0002c5f1
eMMC boot @ 0
sw8 s
board id: 6
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 0 ok
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
 dram_vref_reg_value 0x 00000047
2D training succeed
DDR cs1 size: 0MB
result report
00000000
emmc switch 3 ok
00000000
emmc switch 0 ok
OPS=0x10
ring efuse init
chipver efuse init
[0.016073 Inits done]
secure task start!
high task start!
low task start!
run into bl31
DRAM:  2 GiB
parts: 17
In:    serial
Out:   serial
Err:   serial
Usage:
emmc erase dtb
emmc erase key
vpu: vpu_power_on
vpu: set_vpu_clk
vpp: vpp_init
LCD_RESET PIN: 0
[KM]Msg:isEncrypt=
CONFIG_AVB2: null
info->magic =
active slot = 0
upgrade_step=0
hpd_state=1
hdr mode is 0
hdr10+ mode is 0
[CANVAS]canvas init
set hdmitx VIC = 16
aml_audio_init
HPLL: 0x3b0004b9
HPLL: 0x1b0004b9
HPLL: 0xdb0004b9
config HPLL done
hdmtix: set audio
hdr_packet
vpp: hdr_policy = 1
normal power on
boot wol: disable
[reg_31] 0xd8a
[reg_16] 0x0
[reg_17] 0x7fff
[reg_19] 0x0
[reg_31] 0x0
[reg_31] 0xd40
[reg_22] 0x0
[reg_31] 0x0
port mode is usb3.0
cfgload: start ...
card in
** File not found /boot.ini **
cfgload: no /boot.ini or empty file on mmc 0:1
cfgload: reading /boot.ini from mmc 1:1 ...
Failed to mount ext2 filesystem...
cfgload: no /boot.ini or empty file on mmc 1:1
cfgload: reading /boot/boot.ini from mmc 1:5 ...
cfgload: no /boot/boot.ini or empty file on mmc 1:5
cfgload: failed to read boot.ini on all partitions!
CONFIG_SYSTEM_AS_ROOT: systemroot
system_mode: 1
active_slot: normal
avb2: 0
ee_gate_off ...
avb2: 0
## Booting Android Image at 0x03080000 ...
Kernel command line: androidboot.dtbo_idx=0 --cmdline root=/dev/mmcblk0p18 buildvariant=userdebug
find 1 dtbos
dtbos to be applied: 0
Apply dtbo 0
   kernel loaded at 0x01080000, end = 0x0265f808
   Loading Device Tree to 000000001ffe5000, end 000000001ffff1fd ... OK
fdt_fixup_memory_banks, reg:0000000000000000
Starting kernel ...
uboot time: 6100182 us
[    0.000000@0] Booting Linux on physical CPU 0x0
[    0.000000@0] Linux version 4.9.113-g3a46c54c29bc-dirty (xiong@server) (gcc version 6.3.1 20170109 (Linaro GCC3
[    0.000000@0] Boot CPU: AArch64 Processor [410fd034]
[    0.000000@0] earlycon: aml-uart0 at MMIO 0x00000000ff803000 (options '')
[    0.000000@0] bootconsole [aml-uart0] enabled
[    0.000000@0]        07400000 - 07500000,     1024 KB, ramoops@0x07400000
[    0.000000@0] fdt_init_reserved_mem, start:0x0000000005000000, end:0x0000000005400000, len:4 MiB
[    0.000000@0]        05000000 - 05400000,     4096 KB, linux,secmon
[    0.000000@0] fdt_init_reserved_mem, start:0x000000007f800000, end:0x0000000080000000, len:8 MiB
[    0.000000@0] failed to allocate memory for node linux,meson-fb, size:8 MB
[    0.000000@0]        70000000 - 78000000,   131072 KB, linux,ion-dev
[    0.000000@0]        6d800000 - 70000000,    40960 KB, linux,di_cma
[    0.000000@0] Reserved memory: created DMA memory pool at 0x000000006d800000, size 0 MiB
[    0.000000@0]        6d800000 - 6d800000,        0 KB, linux,ppmgr
[    0.000000@0]        5a400000 - 6d800000,   315392 KB, linux,codec_mm_cma
[    0.000000@0]        5a400000 - 5a400000,        0 KB, linux,codec_mm_reserved
[    0.000000@0]        56400000 - 5a400000,    65536 KB, linux,vdin0_cma
[    0.000000@0]        52400000 - 56400000,    65536 KB, linux,vdin1_cma
[    0.000000@0]        51400000 - 52400000,    16384 KB, linux,galcore
[    0.000000@0]        49400000 - 51400000,   131072 KB, linux,isp_cma
[    0.000000@0]        47c00000 - 49400000,    24576 KB, linux,adapt_cma
[    0.000000@0] cma: Reserved 8 MiB at 0x0000000047400000
[    0.000000@0] psci: probing for conduit method from DT.
[    0.000000@0] psci: PSCIv1.0 detected in firmware.
[    0.000000@0] psci: Using standard PSCI v0.2 function IDs
[    0.000000@0] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000@0] psci: SMC Calling Convention v1.1
[    0.000000@0] percpu: Embedded 26 pages/cpu @ffffffc0472e8000 s68952 r8192 d29352 u106496
[    0.000000@0] Detected VIPT I-cache on CPU0
[    0.000000@0] CPU features: enabling workaround for ARM erratum 845719
[    0.000000@0] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 483840
[    0.000000@0] Kernel command line: init=/init console=ttyS0,115200 no_console_suspend earlycon=aml-uart,0xff80f
[    0.000000@0] am_vecm: boot hdr_policy: 1
[    0.000000@0] fb: osd0
[    0.000000@0] fb: loaded
[    0.000000@0] fb: 0x3d800000
[    0.000000@0] fb: logo_info.fb_width=1920
[    0.000000@0] fb: logo_info.fb_height=1080
[    0.000000@0] vout: error: get_vout2_init_mode:
[    0.000000@0] vout: vout2: enable: 1
[    0.000000@0] vout: 1080p60hz
[    0.000000@0] vout: enable: 1
[    0.000000@0] lcd: panel_type: lcd_1
[    0.000000@0] lcd: lcd_ctrl: 0x00000083
[    0.000000@0] vout: get hdmimode: 1080p60hz
[    0.000000@0] jason hdmichecksum: 0xb53e0000
[    0.000000@0] vout: get hdmi checksum: 0xb53e0000
[    0.000000@0] vout: get cvbsmode: 576cvbs
[    0.000000@0] vpp_axis_reverse: bootargs is 0
[    0.000000@0] DI: di_read_canvas_reverse: bootargs is 0.
[    0.000000@0] vdin_get_video_reverse: bootargs is 0.
[    0.000000@0] phlock_phase_config: bootargs is 0.
[    0.000000@0] init_wol_state, wol_enable=0
[    0.000000@0] jason lcd_exist: 0
[    0.000000@0] ext_board_exist: 0
[    0.000000@0] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000@0] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000@0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000@0] Memory: 1103288K/1966080K available (12350K kernel code, 1726K rwdata, 3576K rodata, 4672K init,)
[    0.000000@0] Virtual kernel memory layout:
[    0.000000@0]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000@0]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000@0]       .text : 0xffffff8009080000 - 0xffffff8009c90000   ( 12352 KB)
[    0.000000@0]     .rodata : 0xffffff8009c90000 - 0xffffff800a020000   (  3648 KB)
[    0.000000@0]       .init : 0xffffff800a020000 - 0xffffff800a4b0000   (  4672 KB)
[    0.000000@0]       .data : 0xffffff800a4b0000 - 0xffffff800a65f808   (  1727 KB)
[    0.000000@0]        .bss : 0xffffff800a65f808 - 0xffffff800a7d6814   (  1501 KB)
[    0.000000@0]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000@0]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000@0]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000@0]               0xffffffbf00000000 - 0xffffffbf01e00000   (    30 MB actual)
[    0.000000@0]     memory  : 0xffffffc000000000 - 0xffffffc078000000   (  1920 MB)
[    0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000@0] Preemptible hierarchical RCU implementation.
[    0.000000@0]        Build-time adjustment of leaf fanout to 64.
[    0.000000@0]        RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000@0] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000@0] NR_IRQS:64 nr_irqs:64 0
[    0.000000@0] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
[    0.000000@0] g12a_aoclkc_init: register ao clk ok!
[    0.000000@0] Meson chip version = RevB (29:B - 10:0)
[    0.000000@0] meson_g12a_sdemmc_init: register amlogic sdemmc clk
[    0.000000@0] meson_g12a_gpu_init: register meson gpu clk
[    0.000000@0] meson_g12a_media_init: register meson media clk
[    0.000000@0] meson_g12a_misc_init: register amlogic g12a misc clks
[    0.000000@0] meson_g12a_misc_init: done.
[    0.000000@0] g12a_clkc_init initialization complete
[    0.000000@0] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000@0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 4407s
[    0.000003@0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008257@0] meson_bc_timer: mclk->mux_reg =ffffff800800c190,mclk->reg =ffffff800800e194
[    0.017171@0] Console: colour dummy device 80x25
[    0.021097@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=9)
[    0.031586@0] pid_max: default: 32768 minimum: 301
[    0.036448@0] thread_stack_cache_init, vmap:ffffffc044c7a0c0, bitmap:ffffffc044c74000, cache page:44c80
[    0.045872@0] thread_stack_cache_init, allocation vm area:ffffffc044c39800, addr:ffffff8020000000, size:2000100
[    0.056095@0] cpu 0, vmap_stack:[ffffffc0472f2a20-ffffffc0472f6a10]
[    0.062394@0] cpu 0, irq_stack: [ffffffc0472e8060-ffffffc0472ec050]
[    0.068693@0] cpu 1, vmap_stack:[ffffffc04730ca20-ffffffc047310a10]
[    0.074993@0] cpu 1, irq_stack: [ffffffc047302060-ffffffc047306050]
[    0.081293@0] cpu 2, vmap_stack:[ffffffc047326a20-ffffffc04732aa10]
[    0.087593@0] cpu 2, irq_stack: [ffffffc04731c060-ffffffc047320050]
[    0.093893@0] cpu 3, vmap_stack:[ffffffc047340a20-ffffffc047344a10]
[    0.100193@0] cpu 3, irq_stack: [ffffffc047336060-ffffffc04733a050]
[    0.106493@0] cpu 4, vmap_stack:[ffffffc04735aa20-ffffffc04735ea10]
[    0.112793@0] cpu 4, irq_stack: [ffffffc047350060-ffffffc047354050]
[    0.119093@0] cpu 5, vmap_stack:[ffffffc047374a20-ffffffc047378a10]
[    0.125393@0] cpu 5, irq_stack: [ffffffc04736a060-ffffffc04736e050]
[    0.131750@0] Security Framework initialized
[    0.135985@0] SELinux:  Initializing.
[    0.139709@0] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.146574@0] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.154494@0] ftrace: allocating 40600 entries in 159 pages
[    0.234623@0] sched-energy: Sched-energy-costs installed from DT
[    0.234992@0] CPU0: update cpu_capacity 631
[    0.239229@0] ASID allocator initialised with 65536 entries
[    0.299919@0] secmon: clear_range:5100000 200000
[    0.345581@1] Detected VIPT I-cache on CPU1
[    0.345632@1] CPU1: update cpu_capacity 631
[    0.345634@1] CPU1: Booted secondary processor [410fd034]
[    0.378129@2] Detected VIPT I-cache on CPU2
[    0.378175@2] CPU2: update cpu_capacity 1192
[    0.378177@2] CPU2: Booted secondary processor [410fd092]
[    0.409686@3] Detected VIPT I-cache on CPU3
[    0.409709@3] CPU3: update cpu_capacity 1192
[    0.409711@3] CPU3: Booted secondary processor [410fd092]
[    0.441769@4] Detected VIPT I-cache on CPU4
[    0.441792@4] CPU4: update cpu_capacity 1192
[    0.441794@4] CPU4: Booted secondary processor [410fd092]
[    0.473864@5] Detected VIPT I-cache on CPU5
[    0.473887@5] CPU5: update cpu_capacity 1192
[    0.473889@5] CPU5: Booted secondary processor [410fd092]
[    0.473983@0] Brought up 6 CPUs
[    0.540943@0] SMP: Total of 6 processors activated.
[    0.545856@0] CPU features: detected feature: 32-bit EL0 Support
[    0.552016@0] CPU: All CPU(s) started at EL2
[    0.556213@0] alternatives: patching kernel code
[    0.562257@5] addr:ffffff80200c3e10 is in kernel, size fix 4096->10, data:mode=0755
[    0.568637@4] devtmpfs: initialized
[    0.589522@4] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.593848@4] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.600471@4] pinctrl core: initialized pinctrl subsystem
[    0.606530@4] NET: Registered protocol family 16
[    0.612668@4] schedtune: init normalization constants...
[    0.615718@4] schedtune: CLUSTER[0-1]      min_pwr:     0 max_pwr:    42
[    0.622448@4] schedtune: CPU[0]            min_pwr:     0 max_pwr:   279
[    0.629184@4] schedtune: CPU[1]            min_pwr:     0 max_pwr:   279
[    0.635921@4] schedtune: CLUSTER[2-5]      min_pwr:     0 max_pwr:   110
[    0.642658@4] schedtune: CPU[2]            min_pwr:     0 max_pwr:  1048
[    0.649395@4] schedtune: CPU[3]            min_pwr:     0 max_pwr:  1048
[    0.656132@4] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1048
[    0.662873@4] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1048
[    0.669616@4] schedtune: SYSTEM            min_pwr:     0 max_pwr:  4902
[    0.676347@4] schedtune: using normalization constants mul: 2882587190 sh1: 1 sh2: 12
[    0.684225@4] schedtune: verify normalization constants...
[    0.689739@4] schedtune: max_pwr/2^0: 4902 => norm_pwr:  1024
[    0.695513@4] schedtune: max_pwr/2^1: 2451 => norm_pwr:   512
[    0.701283@4] schedtune: max_pwr/2^2: 1225 => norm_pwr:   255
[    0.707062@4] schedtune: max_pwr/2^3:  612 => norm_pwr:   127
[    0.712832@4] schedtune: max_pwr/2^4:  306 => norm_pwr:    63
[    0.718612@4] schedtune: max_pwr/2^5:  153 => norm_pwr:    31
[    0.724383@4] schedtune: configured to support 5 boost groups
[    0.746206@4] cpuidle: using governor menu
[    0.746295@4] register canvas platform driver
[    0.749040@4] register rdma platform driver
[    0.755493@4] vdso: 2 pages (1 code @ ffffff8009c97000, 1 data @ ffffff800a4b5000)
[    0.760853@4] hw-breakpoint: found 6 breakpoint and 2 watchpoint registers.
[    0.768403@4] DMA: preallocated 256 KiB pool for atomic allocations
[    0.774239@4] clkmsr: clkmsr: driver init
[    0.778168@4] codec_mm_module_init
[    0.781600@4] media_configs_system_init
[    0.785651@4] aml_watch_point_probe, in, wp:2
[    0.790137@4] pstore: using zlib compression
[    0.794773@4] console [pstore-1] enabled
[    0.798037@4] pstore: Registered ramoops as persistent store backend
[    0.804424@4] ramoops: attached 0x100000@0x7400000, ecc: 0/0
[    0.810103@4] ramoops: ramoops_io_en:0 1 old:0x0 ftrace_size:0x40000[    0.818276@4] aml_iomap: amlogic iomap e
[    0.821479@4] vpu: driver version: v20190329(8-g12b)
[    0.826038@4] vpu: load vpu_clk: 666666667Hz(7)
[    0.830797@4] vpu: clktree_init
[    0.833771@4] vpu: vpu_probe OK
[    0.840729@4] clkmsr: msr_clk_reg0=ffffff80081b7004,msr_clk_reg2=ffffff80081b900c
[    0.844417@4] clkmsr ffd18004.meson_clk_msr: failed to get msr ring reg0
[    0.853621@4] audio_clocks: audio_clocks_probe done
[    0.858986@4] aml_vdac_config_probe: cpu_id:4, name:meson-g12ab-vdac
[    0.862593@4] aml_vdac_probe: ok
[    0.865787@4] canvas_probe reg=00000000ff638000,size=2000
[    0.871104@4] canvas maped reg_base =ffffff80081be000
[    0.881805@4] rdma_probe,cpu_type:0, ver:0, len:8
[    0.882036@4] rdma_register, rdma_table_addr ffffff80081e1000 rdma_table_addr_phy 47440000 reg_buf ffffffc04450
[    0.891406@4] rdma_register success, handle 1 table_size 32768
[    0.897259@4] set_rdma_handle video rdma handle = 1.
[    0.902262@4] classs created ok
[    0.905386@4] classs file created ok
[    0.909964@4] aml_snd_reg_map[0], reg:ff640000, size:2000
[    0.914423@4] aml_snd_reg_map[1], reg:ff642000, size:2000
[    0.919838@4] aml_snd_reg_map[2], reg:ff64a000, size:2000
[    0.925268@4] aml_snd_reg_map[3], reg:ff656000, size:1800
[    0.930689@4] aml_snd_reg_map[4], reg:ffd01000, size:1000
[    0.936105@4] amlogic auge_snd_iomap probe done
[    0.943109@4] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[    0.948254@4] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[    0.955704@4] codec_mm_probe ok
[    1.137164@4] khadas_hwver_probe
[    1.137461@4] SCSI subsystem initialized
[    1.138892@4] usbcore: registered new interface driver usbfs
[    1.144430@4] usbcore: registered new interface driver hub
[    1.149962@4] usbcore: registered new device driver usb
[    1.155202@4] Linux video capture interface: v2.00
[    1.159997@4] pps_core: LinuxPPS API ver. 1 registered
[    1.165112@4] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.174484@4] PTP clock support registered
[    1.178980@4] secmon: reserve_mem_size:0x300000
[    1.183217@4] secmon secmon: assigned reserved memory node linux,secmon
[    1.190201@4] secmon: get page:ffffffbf00140000, 5000
[    1.194861@4] secmon: share in base: 0xffffffc0050fe000, share out base: 0xffffffc0050ff000
[    1.203262@4] secmon: phy_in_base: 0x50fe000, phy_out_base: 0x50ff000
[    1.211478@4] fb: osd_init_module
[    1.213381@4] fb: viu vsync irq: 43
[    1.216584@4] fb: viu2 vsync irq: 52
[    1.220205@4] 0x000000c0:Y=c0,U=0,V=0
[    1.223822@4] 0x000000c1:Y=c1,U=0,V=0
[    1.227485@4] 0x000000c2:Y=c2,U=0,V=0
[    1.231175@4] 0x000000c3:Y=c3,U=0,V=0
[    1.234835@4] 0x000000c4:Y=c4,U=0,V=0
[    1.238518@4] 0x000000c5:Y=c5,U=0,V=0
[    1.242353@4] fb: osd_rdma_enable: rdma_table p=0x47448000,op=0x47448000 , v=0xffffff80081fd000
[    1.250981@4] rdma_register, rdma_table_addr ffffff80082d1000 rdma_table_addr_phy 47449000 reg_buf ffffffc04460
[    1.261450@4] rdma_register success, handle 2 table_size 4096
[    1.267234@4] fb: osd_rdma_enable:osd rdma handle = 2.
[    1.272390@4] fb: mem_size: 0x800000
[    1.275960@4] fb: mem_size: 0x1980000
[    1.279647@4] fb: mem_size: 0x100000
[    1.283223@4] fb: mem_size: 0x100000
[    1.286818@4] fb: mem_size: 0x800000
[    1.290434@4] fb: failed to init reserved memory
[    1.295090@4] vout: error: invalid vinfo1. current vmode is not supported
[    1.301907@4] nativeui_propname:disable
[    1.305798@4]  fb_var_set_process
[    1.309219@4] not recovery mode set
[    1.312797@4] fb_def_var_set
[    1.315779@4] fb: init fbdev bpp is:32
[    1.320553@4] fb: set osd0 reverse as NONE
[    1.323655@4] vout: error: invalid vinfo1. current vmode is not supported
[    1.337220@4] fb: osd probe OK
[    1.337833@4] hdmitx: system: Ver: 20190815
[    1.338920@4] hdmitx: system: hpd irq = 36
[    1.343449@4] hdmitx: hdmitx20: Mapped PHY: 0xffd00000
[    1.348110@4] hdmitx: hdmitx20: Mapped PHY: 0xff634400
[    1.353273@4] hdmitx: hdmitx20: Mapped PHY: 0xff900000
[    1.358437@4] hdmitx: hdmitx20: Mapped PHY: 0xff800000
[    1.363590@4] hdmitx: hdmitx20: Mapped PHY: 0xff63c000
[    1.368747@4] hdmitx: hdmitx20: Mapped PHY: 0xffd00000
[    1.373911@4] hdmitx: hdmitx20: Mapped PHY: 0xff608000
[    1.379071@4] hdmitx: hdmitx20: Mapped PHY: 0xff600000
[    1.384238@4] hdmitx: hdmitx20: Mapped PHY: 0xffe01000
[    1.389400@4] hdmitx: hw: alread display in uboot 0x10
[    1.394583@4] hdmitx: hw: avmute set to 1
[    1.398585@4] vout: vout1: register server: hdmitx_vout_server
[    1.404444@4] vout: vout2: register server: hdmitx_vout2_server
[    1.410881@4] hdmitx: system: fmt_attr 444,12bit
[    1.415757@4] vout: create vout attribute OK
[    1.419465@4] vout: aml_vout_probe OK
[    1.422987@4] vout: vout1: register server: nulldisp_vout_server
[    1.429115@4] vout: tvout monitor interval:500(ms), timeout cnt:20
[    1.435274@4] hdmitx: hdmitx_set_current_vmode[4728]
[    1.440234@4] hdmitx: system: recalc before 1080p60hz 60 1
[    1.445750@4] hdmitx: system: recalc after 1080p60hz 2997 50
[    1.451432@4] hdmitx: alread display in uboot
[    1.455811@4] vout: init mode 1080p60hz set ok
[    1.460275@4] vout: aml_vout_probe
[    1.463684@4] vout: aml_vout_probe OK
[    1.467966@4] chip type:0x29
[    1.470515@4] MEMORY:[0+78000000]
[    1.473584@4] ramdump_probe, storage device:data
[    1.478213@4] NO valid ramdump args:0 0
[    1.482061@4] ramdump_probe, set sticky to 8780
[    1.490195@3] Advanced Linux Sound Architecture Driver Initialized.
[    1.493404@3] Bluetooth: Core ver 2.22
[    1.496762@3] NET: Registered protocol family 31
[    1.501321@3] Bluetooth: HCI device and connection manager initialized
[    1.507890@3] Bluetooth: HCI socket layer initialized
[    1.512965@3] Bluetooth: L2CAP socket layer initialized
[    1.518247@3] Bluetooth: SCO socket layer initialized
[    1.532185@2] clocksource: Switched to clocksource arch_sys_counter
[    1.543364@5] hdmitx: edid: EDID Parser:
[    1.543414@5] [RX]-up_phy_addr = 1
[    1.545083@5] hdmitx: edid: get dtd0 vic: 16
[    1.549356@5] hdmitx: hdmitx: get PMT vic: 16
[    1.553739@5] hdmitx: edid: find IEEEOUT
[    1.557699@5] hdmitx: edid: blk0 raw data
[    1.561722@5] hdmitx: edid:
[    1.561722@5] 00ffffffffffff005db86015deed0000081b0103801e1a78ea1ec5ae4f34b126
[    1.561722@5] 0e50542308008180a940d1c0b3000101010101010101023a801871382d40582c
[    1.561722@5] 450008402100001e662156b051001b304070330000000000001e000000fd0038
[    1.561722@5] 3f1e5111000a202020202020000000fc00594d3135364648440a2020202001b5
[    1.561722@5]
[    1.561722@5]
[    1.583082@2] VFS: Disk quotas dquot_6.6.0
[    1.583142@2] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.591739@3] dtv_dmd:[amldtvdemod..]aml_dtvdemod_init.
[    1.591827@3] NET: Registered protocol family 2
[    1.592298@3] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.592390@3] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.592506@3] TCP: Hash tables configured (established 16384 bind 16384)
[    1.592582@3] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.592603@3] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.592735@3] NET: Registered protocol family 1
[    1.594479@3] wifi: power_on_pin_OD = 0;
[    1.594502@3] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[    1.594609@3] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[    1.594628@3] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[    1.594637@3] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup
[    1.594648@3] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem(): 100.10.545.3
[    1.595034@3] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem prealloc ok
[    1.595043@3] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=483
[    1.595051@3] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[    1.595058@3] aml_wifi wifi: [wifi_dev_probe] power_on_pin=482
[    1.595065@3] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[    1.595260@3] aml_wifi wifi: [wifi_dev_probe] wifi_setup_dt
[    1.595334@3] aml_wifi wifi: [wifi_dev_probe] irq num is:(70)
[    1.595342@3] aml_wifi wifi: [wifi_dev_probe] interrupt_pin(483)
[    1.595358@3] aml_wifi wifi: [wifi_dev_probe] power_on_pin(482)
[    1.599944@3] hw perfevents: clusterb_enabled = 1
[    1.599949@3] hw perfevents: cpumasks 0x3, 0x3c
[    1.599979@3] hw perfevents: cluster A irq = 10
[    1.600015@3] hw perfevents: cluster B irq = 11
[    1.601078@3] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.603712@3] audit: initializing netlink subsys (disabled)
[    1.603766@3] audit: type=2000 audit(1.456:1): initialized
[    1.604655@2] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.612571@2] exFAT: Version 1.2.9
[    1.612679@2] Registering sdcardfs 0.1
[    1.612994@2] ntfs: driver 2.1.32 [Flags: R/O].
[    1.613232@2] fuse init (API version 7.26)
[    1.676852@2] NET: Registered protocol family 38
[    1.677072@2] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    1.677076@2] io scheduler noop registered (default)
[    1.677210@2] io scheduler cfq registered
[    1.686031@2] random: fast init done
[    1.686064@2] random: crng init done
[    1.686384@3] Unable to detect cache hierarchy for CPU 0
[    1.691662@3] loop: module loaded
[    1.692232@2] zram: Added device: zram0
[    1.692310@2] mcu_probe
[    1.692315@2] mcu_parse_dt hwver:49
[    1.693280@2] mcu version is 1
[    1.694555@2] mcu_probe
[    1.694655@2] mcu_probe,wol enable=0
[    1.696937@2] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.697702@2] libphy: Fixed MDIO Bus: probed
[    1.697851@2] tun: Universal TUN/TAP device driver, 1.6
[    1.697853@2] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.698458@2]  REG0:Addr = ffffff8008417540
[    1.698468@2]  ee eth reset:Addr = ffffff8008419008
[    1.698480@2] auto_cali_idx 40
[    1.698872@2] meson6-dwmac ff3f0000.ethernet: no reset control found
[    1.698876@2] stmmac - user ID: 0x11, Synopsys ID: 0x37
[    1.698879@2]  Ring mode enabled
[    1.698883@2]  DMA HW capability register supported
[    1.698884@2]  Normal descriptors
[    1.698886@2]  RX Checksum Offload Engine supported
[    1.698887@2]        COE Type 2
[    1.698889@2]  TX Checksum insertion supported
[    1.698891@2]  Wake-Up On Lan supported
[    1.698928@2]  Enable RX Mitigation via HW Watchdog Timer
[    1.702012@2] libphy: stmmac: probed
[    1.702017@2] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    1.702020@2] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[    1.703658@2] PPP generic driver version 2.4.2
[    1.704014@2] PPP BSD Compression module registered
[    1.704019@2] PPP Deflate Compression module registered
[    1.704050@2] PPP MPPE Compression module registered
[    1.704055@2] NET: Registered protocol family 24
[    1.704272@2] usbcore: registered new interface driver rtl8150
[    1.704354@2] usbcore: registered new interface driver r8152
[    1.704446@2] usbcore: registered new interface driver lan78xx
[    1.704510@2] usbcore: registered new interface driver asix
[    1.704587@2] usbcore: registered new interface driver ax88179_178a
[    1.704646@2] usbcore: registered new interface driver cdc_ether
[    1.704694@2] usbcore: registered new interface driver dm9601
[    1.704737@2] usbcore: registered new interface driver sr9700
[    1.704805@2] usbcore: registered new interface driver CoreChips
[    1.704869@2] usbcore: registered new interface driver smsc75xx
[    1.704923@2] usbcore: registered new interface driver smsc95xx
[    1.704987@2] usbcore: registered new interface driver net1080
[    1.705050@2] usbcore: registered new interface driver cdc_subset
[    1.705101@2] usbcore: registered new interface driver zaurus
[    1.705186@2] usbcore: registered new interface driver cdc_ncm
[    1.705215@2] GobiNet: Quectel_Linux&Android_GobiNet_Driver_V1.6.1
[    1.705268@2] usbcore: registered new interface driver GobiNet
[    1.707095@2] usbcore: registered new interface driver cdc_acm
[    1.707098@2] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.707193@2] usbcore: registered new interface driver usb-storage
[    1.707372@2] usbcore: registered new interface driver usbserial
[    1.707438@2] usbcore: registered new interface driver option
[    1.707475@2] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.708081@3] mousedev: PS/2 mouse device common for all mice
[    1.708276@3] usbcore: registered new interface driver xpad
[    1.708375@3] edt_ft5x06 3-0038: probing for EDT FT5x06 I2C
[    1.710316@4] clear:40c00000, free:40c00000, tick:215969 us
[    2.029143@3] edt_ft5x06 3-0038: touchscreen probe failed
[    2.029256@3] sensor_register_slave:kxtj3,id=0
[    2.039585@3] khadas-rtc 4-0051: rtc core: registered khadas-rtc as rtc0
[    2.039635@3] i2c /dev entries driver
[    2.039976@2] usbcore: registered new interface driver uvcvideo
[    2.039978@2] USB Video Class driver (1.1.1)
[    2.040387@3] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.040496@3] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[    2.042010@3] hidraw: raw HID events driver (C) Jiri Kosina
[    2.042522@4] usbcore: registered new interface driver usbhid
[    2.042524@4] usbhid: USB HID core driver
[    2.042645@2] ashmem: initialized
[    2.043525@2] meson_cpufreq_init: ignor dsu clk!
[    2.043537@2] meson_cpufreq_init: ignor dsu pre parent clk!
[    2.043583@2] value of voltage_tolerance 0
[    2.043594@2] meson_cpufreq_init:don't find the node <dynamic_gp1_clk>
[    2.043596@2] value of gp1_clk_target 0
[    2.044293@2] cpu cpu0: meson_cpufreq_init: CPU 0 initialized
[    2.046456@2] meson_cpufreq_init: ignor dsu clk!
[    2.046467@2] meson_cpufreq_init: ignor dsu pre parent clk!
[    2.046538@2] value of voltage_tolerance 0
[    2.046549@2] meson_cpufreq_init:don't find the node <dynamic_gp1_clk>
[    2.046551@2] value of gp1_clk_target 0
[    2.047258@2] cpu cpu2: meson_cpufreq_init: CPU 2 initialized
[    2.049151@2] ff803000.serial: clock gate not found
[    2.049176@2] meson_uart ff803000.serial: ==uart0 reg addr = ffffff800841d000
[    2.049205@2] ff803000.serial: ttyS0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
[    2.294753@5] hdmitx: edid: blk1 raw data
[    2.298792@5] hdmitx: edid:
[    2.298792@5] 020329f15090050403020716011f121314201511062309070767030c00100038
[    2.298792@5] 2d83010000e3050301023a801871382d40582c450006442100001e011d801871
[    2.298792@5] 1c1620582c250006442100009e011d007251d01e206e28550006442100001e8c
[    2.298792@5] 0ad08a20e02d10103e960006442100001800000000000000000000000000003e
[    2.298792@5]
[    2.298792@5]
[    2.334042@5] hdmitx: system: update rx hdr info 0
[    2.339028@5] hdmitx: hdmitx: get vic 16 cscd 444,12bit
[    2.344109@5] hdmitx: hdmitx: mode name 1920x1080p60hz
[    2.349273@5] hdmitx: hdmitx: tmds clock 148
[    2.353553@5] hdmitx: hdmitx: act clock: 222
[    2.357871@0] hdmitx: system: irq 80000002 0
[    2.367724@2] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 0 to 115200
[    2.370365@2] console [ttyS0] enabled
[    2.377634@2] bootconsole [aml-uart0] disabled
[    2.386788@2] meson_uart ffd24000.serial: ==uart1 reg addr = ffffff8008431000
[    2.393602@2] ffd24000.serial: ttyS1 at MMIO 0xffd24000 (irq = 35, base_baud = 1500000) is a meson_uart
[    2.403713@2] amlogic-new-usb2-v2 ffe09000.usb2phy: USB2 phy probe:phy_mem:0xffe09000, iomap phy_base:0xffffff0
[    2.413975@2] amlogic-new-usb3-v2 ffe09080.usb3phy: USB3 phy probe:phy_mem:0xffe09080, iomap phy_base:0xffffff0
[    2.425948@2] aml_dma ff63e000.aml_dma: Aml dma
[    2.429910@2] aml_aes_dma ff63e000.aml_dma:aml_aes: Aml AES_dma
[    2.435257@2] aml_tdes_dma ff63e000.aml_dma:aml_tdes: Aml TDES_dma
[    2.441540@2] aml_sha_dma ff63e000.aml_dma:aml_sha: Aml SHA1/SHA224/SHA256 dma
[    2.448614@2] gpio-keypad gpio_keypad: power key(116) registed.
[    2.454333@2] input: gpio_keypad as /devices/platform/gpio_keypad/input/input1
[    2.461582@2] meson-remote: Driver init
[    2.465365@2] meson-remote: remote_probe
[    2.469160@2] meson-remote ff808040.rc: protocol = 0x1
[    2.474268@2] meson-remote ff808040.rc: don't find the node <led_blink>
[    2.480854@2] meson-remote ff808040.rc: led_blink = 0
[    2.485883@2] meson-remote ff808040.rc: don't find the node <led_blink_frq>
[    2.492813@2] meson-remote ff808040.rc: led_blink_frq  = 100
[    2.498464@2] meson-remote ff808040.rc: platform_data irq =34
[    2.504198@2] meson-remote ff808040.rc: custom_number = 1
[    2.509556@2] meson-remote ff808040.rc: ptable->map_size = 13
[    2.515261@2] meson-remote ff808040.rc: ptable->custom_name = khadas-ir
[    2.521846@2] meson-remote ff808040.rc: ptable->custom_code = 0xff00
[    2.528174@2] meson-remote ff808040.rc: ptable->release_delay = 80
[    2.534330@2] meson-remote ff808040.rc: default protocol = 0x1 and id = 0
[    2.541088@2] meson-remote ff808040.rc: reg=0x0, val=0x1f40190
[    2.546893@2] meson-remote ff808040.rc: reg=0x4, val=0x12c00c8
[    2.552702@2] meson-remote ff808040.rc: reg=0x8, val=0x960050
[    2.558420@2] meson-remote ff808040.rc: reg=0xc, val=0x480028
[    2.564139@2] meson-remote ff808040.rc: reg=0x10, val=0x70fa0013
[    2.570119@2] meson-remote ff808040.rc: reg=0x18, val=0x8616800
[    2.576012@2] meson-remote ff808040.rc: reg=0x1c, val=0x9f00
[    2.581646@2] meson-remote ff808040.rc: reg=0x20, val=0x0
[    2.587019@2] meson-remote ff808040.rc: reg=0x24, val=0x0
[    2.592394@2] meson-remote ff808040.rc: reg=0x28, val=0x0
[    2.598028@2] input: aml_keypad as /devices/platform/ff808040.rc/input/input2
[    2.605114@2] meson-remote: IR XMP protocol handler initialized
[    2.611933@2] ion_dev soc:ion_dev: assigned reserved memory node linux,ion-dev
[    2.618241@2] ge2d: ge2d_init_module
[    2.621885@2] ge2d: ge2d clock is 499 MHZ
[    2.625517@2] ge2d: reserved mem is not used
[    2.629775@2] ge2d: ge2d start monitor
[    2.633737@2] [tsync_pcr_init]init success.
[    2.637752@2] amvideom vsync irq: 43
[    2.641208@2] create_ge2d_work_queue video task ok
[    2.646317@2] hdmitx: hdcp: hdmitx_hdcp_init
[    2.650520@2] vout: vout2: create vout2 attribute OK
[    2.655223@2] vout: vout2: aml_vout2_probe OK
[    2.659585@2] vout: vout2: clktree_init
[    2.663288@2] vout: vout2: register server: nulldisp_vout2_server
[    2.669411@2] vout: vout2: init mode null set ok
[    2.673954@2] vout: vout2: aml_vout2_probe OK
[    2.678354@2] DI: di_module_init ok.
[    2.681942@2] DI: di_probe:
[    2.684611@2] DI: di_probe: major 511
[    2.688362@2] deinterlace deinterlace: assigned reserved memory node linux,di_cma
[    2.695705@2] di:flag_cma=1
[    2.698473@2] DI: CMA size 0x2800000.
[    2.702127@2] pre_irq:67
[    2.704633@2] post_irq:68
[    2.707223@2] DI: di_probe allocate rdma channel 0.
[    2.712085@2] di_probe: get clk vpu error.
[    2.716154@2] DI: vpu clkb <334000000, 667000000>
[    2.720855@2] get clkb rate:333333328
[    2.724482@2] DI:enable vpu clkb.
[    2.727769@2] 0x000000c9:Y=c9,U=0,V=0
[    2.731407@2] 0x000000ca:Y=ca,U=0,V=0
[    2.735048@2] 0x000000cb:Y=cb,U=0,V=0
[    2.738686@2] 0x000000cc:Y=cc,U=0,V=0
[    2.742327@2] 0x000000cd:Y=cd,U=0,V=0
[    2.745965@2] 0x000000ce:Y=ce,U=0,V=0
[    2.749605@2] 0x000000cf:Y=cf,U=0,V=0
[    2.753244@2] 0x000000d0:Y=d0,U=0,V=0
[    2.756885@2] 0x000000d1:Y=d1,U=0,V=0
[    2.760524@2] 0x000000d2:Y=d2,U=0,V=0
[    2.764164@2] 0x000000d3:Y=d3,U=0,V=0
[    2.767805@2] 0x000000d4:Y=d4,U=0,V=0
[    2.771444@2] 0x000000d5:Y=d5,U=0,V=0
[    2.775085@2] 0x000000d6:Y=d6,U=0,V=0
[    2.778724@2] 0x000000d7:Y=d7,U=0,V=0
[    2.782364@2] 0x000000d8:Y=d8,U=0,V=0
[    2.786008@2] 0x000000d9:Y=d9,U=0,V=0
[    2.789644@2] 0x000000da:Y=da,U=0,V=0
[    2.793286@2] 0x000000db:Y=db,U=0,V=0
[    2.796926@2] 0x000000dc:Y=dc,U=0,V=0
[    2.800564@2] 0x000000dd:Y=dd,U=0,V=0
[    2.804204@2] 0x000000de:Y=de,U=0,V=0
[    2.807842@2] 0x000000df:Y=df,U=0,V=0
[    2.811487@2] 0x000000e0:Y=e0,U=0,V=0
[    2.815125@2] 0x000000e1:Y=e1,U=0,V=0
[    2.818764@2] DI: support multi decoding 223~224~225.
[    2.823904@2] DI: di_probe:Di use HRTIMER
[    2.827865@2] DI: di_probe:ok
[    2.830774@2] dim:dim_module_init
[    2.834191@2] dim:dim_module_init finish
[    2.837925@2] dil:dil_init.
[    2.840810@2] dil:dil_init ok.
[    2.843740@2] vdin_drv_init: major 510
[    2.847750@2] rdma_register, rdma_table_addr ffffff80084c7000 rdma_table_addr_phy 4744a000 reg_buf ffffffc00610
[    2.857864@2] rdma_register success, handle 3 table_size 512
[    2.863493@2] vdin_drv_probe:vdin.0 rdma hanld 3.
[    2.868299@2] vdin vdin0: assigned reserved memory node linux,vdin0_cma
[    2.874761@2]
[    2.874761@2]  vdin memory resource done.
[    2.880391@2] vdin0 cma_mem_size = 64 MB
[    2.884291@2] vdin0 irq: 40 rdma irq: 2
[    2.888095@2] set_canvas_manual = 0
[    2.891582@2] get fclk_div5 err
[    2.894720@2] vdin_drv_probe: vdin cannot get msr clk !!!
[    2.900077@2] hdmitx: system: plugin
[    2.903639@2] vdin_drv_probe: driver initialized ok
[    2.912251@3] rdma_register, rdma_table_addr ffffff80084c9000 rdma_table_addr_phy 4744b000 reg_buf ffffffc04450
[    2.918877@3] rdma_register success, handle 4 table_size 512
[    2.924506@3] vdin_drv_probe:vdin.1 rdma hanld 4.
[    2.929288@3] vdin vdin1: assigned reserved memory node linux,vdin1_cma
[    2.935769@3]
[    2.935769@3]  vdin memory resource done.
[    2.941404@3] vdin1 cma_mem_size = 64 MB
[    2.945301@3] vdin1 irq: 41 rdma irq: 4
[    2.949115@3] set_canvas_manual = 0
[    2.952591@3] get fclk_div5 err
[    2.955700@3] vdin_drv_probe: vdin cannot get msr clk !!!
[    2.961094@3] vdin_debugfs_init only support debug vdin0 1
[    2.966538@3] vdin_drv_probe: driver initialized ok
[    2.971464@3] vdin_drv_init: vdin driver init done
[    2.976158@3] [viuin..]viuin_init_module viuin module init
[    2.981798@3] [viuin..]viuin_probe probe ok.
[    2.986184@3] [RX]-hdmirx: hdmirx_init.
[    2.989675@3] ESM HLD: Initializing...
[    2.993874@5] amvdec_csi module: init.
[    2.997140@5] amvdec_csi_init_module:major 508
[    3.001667@5] amvdec_csi module: init. ok
[    3.005535@5] amlvid:info: amlvideo_init called[    3.009869@5] amlvid:info: amlvideo_create_instance called
[    3.015327@5] amlvid:info: v4l2_dev.name=:amlvideo-000
[    3.020525@3] amlvideo-000: V4L2 device registered as video10
[    3.026163@3] amlvid:info: amlvideo_create_instance called
[    3.031624@3] amlvid:info: v4l2_dev.name=:amlvideo-001
[    3.036701@2] hdmitx: edid: EDID Parser:
[    3.036710@2] [RX]-up_phy_addr = 1
[    3.036718@2] hdmitx: edid: get dtd0 vic: 16
[    3.036720@2] hdmitx: hdmitx: get PMT vic: 16
[    3.036722@2] hdmitx: edid: find IEEEOUT
[    3.036742@2] hdmitx: edid: blk0 raw data
[    3.036758@2] hdmitx: edid:
[    3.036758@2] 00ffffffffffff005db86015deed0000081b0103801e1a78ea1ec5ae4f34b126
[    3.036758@2] 0e50542308008180a940d1c0b3000101010101010101023a801871382d40582c
[    3.036758@2] 450008402100001e662156b051001b304070330000000000001e000000fd0038
[    3.036758@2] 3f1e5111000a202020202020000000fc00594d3135364648440a2020202001b5
[    3.036758@2]
[    3.036758@2]
[    3.036760@2] hdmitx: edid: blk1 raw data
[    3.036776@2] hdmitx: edid:
[    3.036776@2] 020329f15090050403020716011f121314201511062309070767030c00100038
[    3.036776@2] 2d83010000e3050301023a801871382d40582c450006442100001e011d801871
[    3.036776@2] 1c1620582c250006442100009e011d007251d01e206e28550006442100001e8c
[    3.036776@2] 0ad08a20e02d10103e960006442100001800000000000000000000000000003e
[    3.036776@2]
[    3.036776@2]
[    3.036779@2] hdmitx: system: update physcial size: 300 260
[    3.036782@2] hdmitx: hw: set audio
[    3.036785@2] hdmitx: hw: hdmitx tx_aud_src = 0
[    3.036797@2] hdmitx: fs = 0, cd = 6, tmds_clk = 148352
[    3.036798@2] hdmitx: hw: aud_n_para = 11648
[    3.036805@2] hdmitx: hw: set channel status
[    3.036817@2] hdmitx: hw: [0x10e3] = 0xf
[    3.165507@3] amlvideo-001: V4L2 device registered as video23
[    3.171254@3] amlvideo2 probe called
[    3.174709@3] amlvideo2_create_node[    3.178094@3] amlvideo2: V4L2 device registered as video11
[    3.183479@3] amlvideo2 probe called
[    3.187014@3] amlvideo2_create_node[    3.190393@3] amlvideo2: V4L2 device registered as video12
[    3.195801@3] PPMGRDRV: warn: ppmgr module init func called
[    3.201408@3] PPMGRDRV: info: ppmgr_driver_probe called
[    3.206565@3] Reserved memory: failed to init DMA memory pool at 0x000000006d800000, size 0 MiB
[    3.215183@3] PPMGRDRV: info: ppmgr_dev major:507
[    3.220278@3] ionvideo-000: V4L2 device registered as video13
[    3.225646@3] ionvideo-001: V4L2 device registered as video14
[    3.231366@3] ionvideo-002: V4L2 device registered as video15
[    3.237089@3] ionvideo-003: V4L2 device registered as video16
[    3.242806@3] ionvideo-004: V4L2 device registered as video17
[    3.248528@3] ionvideo-005: V4L2 device registered as video18
[    3.254247@3] ionvideo-006: V4L2 device registered as video19
[    3.259970@3] ionvideo-007: V4L2 device registered as video20
[    3.265685@3] ionvideo-008: V4L2 device registered as video21
[    3.271342@3] ionvid: info: Video Technology Magazine Ion Video
[    3.277236@3] ionvid: info: Capture Board ver 1.0 successfully loaded
[    3.283779@3] picdec: picdec_driver_probe called.
[    3.288474@3] picdec: probe of picdec failed with error -22
[    3.293992@3] videosync_create_instance dev_s ffffffc00613ec00,dev_s->dev ffffffc04473c880
[    3.302114@3] videosync_create_instance reg videosync.0
[    3.307358@3] aml_vecm_init:module init
[    3.307359@4] videosync_thread started
[    3.314999@3] VECM probe start
[    3.318073@3] vlock_status_init vlock_en:1
[    3.321956@3] pixel_probe: vpp probe func error!
[    3.326563@3] request amvecm_vsync2_irq successful
[    3.331318@3] aml_vecm_probe: ok
[    3.334559@3] amdolby_vision_init:module init
[    3.339034@3]
[    3.339034@3]  amdolby_vision probe start
[    3.339224@0] hdmitx: hdmitx_set_drm_pkt: tf=1, cf=1, colormetry=0
[    3.350640@3] [amdolby_vision.] : amdolby_vision error.
[    3.355877@3] prime_sl module init
[    3.359436@3] reg base = ffffff80084cb000
[    3.363216@3] gdc_platform_probe: reserve_mem is not used
[    3.368692@3] gdc_platform_probe: gdc core clk is 799 MHZ
[    3.374013@3] gdc_platform_probe: gdc axi clk is 799 MHZ
[    3.379268@3] gdc_wq_init: init gdc device
[    3.383329@3] gdc_wq_init: gdc start monitor
[    3.387608@4] gdc_monitor_thread: gdc workqueue monitor start
[    3.387801@3] vm_init .
[    3.388445@3] meson-mmc: mmc driver version: 3.02, 2017-05-15: New Emmc Host Controller
[    3.393556@3] meson-mmc: >>>>>>>>hostbase ffffff80084d3000, dmode
[    3.393717@3] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[    3.393728@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[    3.432194@3] meson-mmc: meson_mmc_probe() : success!
[    3.441369@2] meson-mmc: >>>>>>>>hostbase ffffff80084dc000, dmode
[    3.441920@2] meson-mmc: gpio_cd = 1ca
[    3.483624@3] meson-mmc: set rate clkin2>>>>>>>>clk:799999987
[    3.483759@3] meson-aml-mmc ffe07000.emmc: divider requested rate 200000000 != actual rate 199999997: ret=0
[    3.484252@0] meson-mmc: meson_mmc_probe() : success!
[    3.486273@0] meson-mmc: >>>>>>>>hostbase ffffff80084e5000, dmode
[    3.486513@0] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[    3.486529@0] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[    3.517006@3] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[    3.523089@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000204
[    3.524206@2] meson-mmc: meson_mmc_probe() : success!
[    3.524647@5] aml_vrtc rtc: rtc core: registered aml_vrtc as rtc1
[    3.524752@5] input: aml_vkeypad as /devices/platform/rtc/input/input3
[    3.525376@2] cectx ff80023c.aocec: cec driver date:2020/03/16:reduece no msg in sleep time
[    3.525376@2]
[    3.525493@4] cectx ff80023c.aocec: compatible:amlogic, aocec-g12a
[    3.525495@4] cectx ff80023c.aocec: cecb_ver:0x1
[    3.525497@4] cectx ff80023c.aocec: line_reg:0x1
[    3.525499@4] cectx ff80023c.aocec: line_bit:0x3
[    3.525500@4] cectx ff80023c.aocec: ee_to_ao:0x1
[    3.525579@4] input: cec_input as /devices/virtual/input/input4
[    3.525652@5] cectx ff80023c.aocec: not find 'port_num'
[    3.525655@5] cectx ff80023c.aocec: using cec:1
[    3.525672@5] cectx ff80023c.aocec: no hdmirx regs
[    3.525674@5] cectx ff80023c.aocec: no hhi regs
[    3.525679@5] cectx ff80023c.aocec: not find 'output'
[    3.526943@5] irq cnt:2, a:39, b38
[    3.527121@4] cectx ff80023c.aocec: wakeup_reason:0x0
[    3.527188@4] cectx ff80023c.aocec: cev val1: 0x0;val2: 0x0
[    3.527197@4] cectx ff80023c.aocec: aml_cec_probe success end
[    3.527603@4] unifykey: no efuse-version set, use default value: -1
[    3.527800@5] unifykey: aml_unifykeys_init done!
[    3.527848@5] meson ts init
[    3.527879@5] tsensor id: 0
[    3.527964@5] r1p1_tsensor_read  valid cnt is 0
[    3.527974@5] tsensor trim info: 0xfa008058!
[    3.527976@5] tsensor hireboot: 0xc0ff2aa0
[    3.528018@5] meson ts init
[    3.528031@5] tsensor id: 1
[    3.528091@5] r1p1_tsensor_read  valid cnt is 0
[    3.528097@5] tsensor trim info: 0xfa00805c!
[    3.528099@5] tsensor hireboot: 0xc0ff2aa0
[    3.528226@5] audio_dsp: [dsp]register dsp to char divece(257)
[    3.528328@4] amaudio: amaudio: driver amaudio init!
[    3.528555@5] amaudio: amaudio_init - amaudio: driver amaudio succuess!
[    3.528905@4] amlkaraoke init success!
[    3.529019@4] sysled: module init
[    3.529193@4] meson_wdt ffd0f0d0.watchdog: start watchdog
[    3.529195@4] meson_wdt ffd0f0d0.watchdog: creat work queue for watch dog
[    3.529341@4] meson_wdt ffd0f0d0.watchdog: AML Watchdog Timer probed done
[    3.529679@2] amlogic rfkill init
[    3.529773@2] enter bt_probe of_node
[    3.529787@2] not get gpio_en
[    3.529793@2] not get gpio_btwakeup
[    3.529796@2] power on valid level is high
[    3.529797@2] bt: power_on_pin_OD = 0;
[    3.529798@2] bt: power_off_flag = 1;
[    3.529799@2] dis power down = 0;
[    3.556239@2] request_irq error ret=-22
[    3.556261@2] dev_pm_set_wake_irq failed: -22
[    3.556694@2] meson-saradc ff809000.saradc: set delay per tick to <1ms> by default.
[    3.556697@2] meson-saradc ff809000.saradc: set ticks per period to <1> by default.
[    3.557342@4] dmc_monitor_probe
[    3.557446@4] page_trace_module_init, create sysfs failed
[    3.558079@5] atv_demod: aml_atvdemod_init: OK, atv demod version: V2.15.
[    3.558187@5] defendkey ff630218.defendkey: Reserved memory is not enough!
[    3.558194@5] defendkey: probe of ff630218.defendkey failed with error -22
[    3.558522@2] usbcore: registered new interface driver snd-usb-audio
[    3.559241@2] aml_codec_T9015 ff632000.t9015: aml_T9015_audio_codec_probe
[    3.559254@2] T9015 acodec used by auge, tdmout:1
[    3.559806@2] es8316 spk_ctl_gpio 0
[    3.559809@2] es8316 spk_mute_gpio 1
[    3.559813@2] es8316 4-0010: Can not read property hp_det_gpio
[    3.559814@2] es8316_i2c_probe 1329
[    3.559822@2] es8316_i2c_probe 1333
[    3.561272@2] asoc debug: aml_audio_controller_probe-129
[    3.561656@2] aml_tdm_platform_probe, tdm ID = 0, lane_cnt = 4
[    3.561678@2] snd_tdm ff642000.audiobus:tdma: lane_mask_out = 1, lane_oe_mask_out = 1
[    3.561722@2] snd_tdm ff642000.audiobus:tdma: neither mclk_pad nor mclk2pad set
[    3.561807@2] aml_tdm_platform_probe(), share en = 1
[    3.561807@2] No channel mask node Channel_Mask
[    3.561985@2] aml_tdm_platform_probe, tdm ID = 1, lane_cnt = 4
[    3.562054@2] TDM id 1 samesource_sel:3
[    3.562060@2] snd_tdm ff642000.audiobus:tdmb: lane_mask_out = 1, lane_oe_mask_out = 0
[    3.562259@2] aml_tdm_platform_probe(), share en = 1
[    3.562260@2] No channel mask node Channel_Mask
[    3.562394@2] aml_tdm_platform_probe, tdm ID = 2, lane_cnt = 4
[    3.562413@2] snd_tdm ff642000.audiobus:tdmc: lane_mask_out = 1, lane_oe_mask_out = 0
[    3.562549@2] periphs-banks:471 is using the pin GPIOA_11 as gpio
[    3.562552@2] meson-g12a-pinctrl pinctrl@ff634480: request() failed for pin 61
[    3.562555@2] meson-g12a-pinctrl pinctrl@ff634480: pin-61 (ff642000.audiobus:tdmc) status -22
[    3.562558@2] meson-g12a-pinctrl pinctrl@ff634480: could not request pin 61 (GPIOA_11) from group mclk1_a  on n
[    3.562561@2] snd_tdm ff642000.audiobus:tdmc: Error applying setting, reverse things back
[    3.562565@2] snd_tdm ff642000.audiobus:tdmc: aml_tdm_get_pins error!
[    3.562573@2] aml_tdm_platform_probe(), share en = 1
[    3.562573@2] No channel mask node Channel_Mask
[    3.563287@2] aml_spdif_platform_probe, register soc platform
[    3.563710@2] audio-ddr-manager ff642000.audiobus:ddr_manager: 0, irqs toddr 26, frddr 29
[    3.563729@2] audio-ddr-manager ff642000.audiobus:ddr_manager: 1, irqs toddr 27, frddr 30
[    3.563747@2] audio-ddr-manager ff642000.audiobus:ddr_manager: 2, irqs toddr 28, frddr 31
[    3.563972@2] loopback ff642000.audiobus:loopback@0: check whether to update loopback chipinfo
[    3.564005@2]        datain_src:4, datain_chnum:4, datain_chumask:f
[    3.564007@2]        datalb_src:1, datalb_chnum:2, datalb_chmask:3
[    3.564008@2]        datain_lane_mask:0x5, datalb_lane_mask:0x1
[    3.564010@2] datalb_format: 1, chmask for lanes: 0x3
[    3.564328@2] loopback_platform_probe, p_loopback->id:0 register soc platform
[    3.564571@2] audiolocker_platform_probe
[    3.565580@4] Register vad
[    3.567572@4] es8316_probe 1088
[    3.567576@4] es8316_probe 1097
[    3.567580@4] es8316_probe 1099
[    3.573381@4] es8316_probe 1103
[    3.681688@4] es8316_probe 1110
[    3.683466@4] es8316_probe 1130
[    3.686491@4] asoc-aml-card auge_sound: control 2:0:0:I2SIn CLK:0 is already present
[    3.686495@4] snd_tdm ff642000.audiobus:tdmb: ASoC: Failed to add I2SIn CLK: -16
[    3.686503@4] aml_dai_tdm_probe, failed add snd tdm controls
[    3.686509@4] asoc-aml-card auge_sound: control 2:0:0:I2SIn CLK:0 is already present
[    3.686511@4] snd_tdm ff642000.audiobus:tdmc: ASoC: Failed to add I2SIn CLK: -16
[    3.686517@4] aml_dai_tdm_probe, failed add snd tdm controls
[    3.686524@4] aml_dai_spdif_probe
[    3.686548@4] pin(1) should be selected for only one usage
[    3.686563@4] master_mode(1), binv(1), finv(0) out_skew(2), in_skew(3)
[    3.686954@4] asoc-aml-card auge_sound: multicodec <-> TDM-A mapping ok
[    3.687820@4] master_mode(1), binv(1), finv(1) out_skew(2), in_skew(3)
[    3.688095@4] asoc-aml-card auge_sound: multicodec <-> TDM-B mapping ok
[    3.688115@4] master_mode(1), binv(1), finv(1) out_skew(2), in_skew(3)
[    3.688314@0] meson-mmc: card IN
[    3.688462@4] asoc-aml-card auge_sound: multicodec <-> TDM-C mapping ok
[    3.688768@4] asoc-aml-card auge_sound: dummy <-> SPDIF mapping ok
[    3.688777@4]
[    3.688777@4] loopback_dai_set_sysclk, 0, 12288000, 0
[    3.688779@4] asoc loopback_dai_set_fmt, 0x4010, ffffffc0444b6418
[    3.689030@4] asoc-aml-card auge_sound: dummy <-> ff642000.audiobus:loopback@0 mapping ok
[    3.690202@4] es8316 4-0010: ASoC: Failed to create Left Hp mixer debugfs file
[    3.690206@4] es8316 4-0010: ASoC: Failed to create Right Hp mixer debugfs file
[    3.690354@4] es8316 4-0010: ASoC: Failed to create HPCP L debugfs file
[    3.690494@4] es8316 4-0010: ASoC: Failed to create HPCP R debugfs file
[    3.690641@4] es8316 4-0010: ASoC: Failed to create HPVOL L debugfs file
[    3.690781@4] es8316 4-0010: ASoC: Failed to create HPVOL R debugfs file
[    3.692156@5] snd_card_add_kcontrols card:ffffffc044112018
[    3.692163@5] effect_v2 is not init
[    3.692165@5] Failed to add VAD controls
[    3.692197@5] eq/drc v1 function enable
[    3.724328@5] u32 classifier
[    3.724329@5]     Actions configured
[    3.724333@5] Netfilter messages via NETLINK v0.30.
[    3.724480@5] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.724617@5] ctnetlink v0.93: registering with nfnetlink.
[    3.724848@2] xt_time: kernel timezone is -0000
[    3.724896@2] IPv4 over IPsec tunneling driver
[    3.725469@2] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.725603@2] arp_tables: arp_tables: (C) 2002 David S. Miller
[    3.731936@2] Initializing XFRM netlink socket
[    3.732230@2] NET: Registered protocol family 10
[    3.732815@2] mip6: Mobile IPv6
[    3.732825@2] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.740075@2] NET: Registered protocol family 17
[    3.740086@2] NET: Registered protocol family 15
[    3.741390@2] Registered swp emulation handler
[    3.743201@2] Registered cp15_barrier emulation handler
[    3.743207@2] Registered setend emulation handler
[    3.743557@2] registered taskstats version 1
[    3.749519@5] dwc3 ff500000.dwc3: Configuration mismatch. dr_mode forced to host
[    3.752196@5] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.752206@5] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.752428@5] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x20010010
[    3.752457@5] xhci-hcd xhci-hcd.0.auto: irq 15, io mem 0xff500000
[    3.752859@2] hub 1-0:1.0: USB hub found
[    3.752874@2] hub 1-0:1.0: 2 ports detected
[    3.753070@2] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.753076@2] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.753107@2] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.753401@4] hub 2-0:1.0: USB hub found
[    3.753414@4] hub 2-0:1.0: 1 port detected
[    3.753849@4] i2c i2c-4: sensor_probe: kxtj3,ffffffc04471c000
[    3.754332@2] sensors 4-000e: sensor_probe:kxtj3:devid=0x35,ops=0xffffff800a552910
[    3.755815@2] input: gsensor as /devices/platform/soc/ff800000.aobus/ff805000.i2c/i2c-4/4-000e/input/input5
[    3.756671@5] sensors 4-000e: sensor_probe:use polling,delay=30 ms
[    3.756752@2] sensors 4-000e: sensor_probe:miscdevice: gsensor
[    3.756758@2] sensors 4-000e: sensor_probe:initialized ok,sensor name:kxtj3,type:2,id=0
[    3.756758@2]
[    3.758294@2] khadas-rtc 4-0051: setting system clock to 2011-01-01 12:00:02 UTC (1293883202)
[    3.758562@2] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: ffe09000, ctrl: 0
[    3.792629@0] meson-mmc: normal card in
[    3.858729@5] dwc_otg: Core Release: 3.30a
[    3.858732@5] dwc_otg: Setting default values for core params
[    3.858740@5] dwc_otg: curmode: 0, host_only: 0
[    3.870914@5] dwc_otg: Using Buffer DMA mode
[    3.870917@5] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1
[    3.870918@5] dwc_otg: Working on port type = SLAVE
[    3.870921@5] dwc_otg: Dedicated Tx FIFOs mode
[    3.871629@5] input: adc_keypad as /devices/platform/adc_keypad/input/input6
[    3.872571@2] meson_cdev probe
[    3.872622@2] meson_cdev index: 0
[    3.872676@2] thermal thermal_zone0: binding zone soc_thermal with cdev thermal-cpufreq-0 failed:-22
[    3.872697@2] meson_cdev index: 1
[    3.872742@2] thermal thermal_zone0: binding zone soc_thermal with cdev thermal-cpufreq-1 failed:-22
[    3.872747@2] thermal: no cluster id, cpucore as one cooldev
[    3.872763@2] meson_cdev index: 2
[    3.872777@2] cpucore_cooling_register, max_cpu_core_num:6
[    3.872784@2] cpucore_cooling_register, clutser[1] core num:4
[    3.872789@2] cpucore_cooling_register, clutser[0] core num:2
[    3.872863@2] meson_cdev index: 3
[    3.872879@2] meson_cdev index: 4
[    3.872911@2] find tzd id: 0
[    3.873014@2] find tzd id: 0
[    3.873097@2] find tzd id: 0
[    3.873127@2] meson_cdev probe done
[    3.873225@2] gxbb_pm: enter meson_pm_probe!
[    3.873235@2] no vddio3v3_en pin
[    3.873236@2] pm-meson aml_pm: Can't get switch_clk81
[    3.873253@2] gxbb_pm: meson_pm_probe done
[    3.873510@2] ALSA device list:
[    3.873512@2]   #0: AML-AUGESOUND
[    3.916288@0] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[    3.916306@0] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[    4.022474@0] meson-mmc: actual_clock :50000000, HHI_nand: 0x880
[    4.022492@0] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000254
[    4.022575@0] sd: new high speed SDXC card at address aaaa
[    4.023057@0] sd: clock 50000000, 4-bit-bus-width
[    4.023057@0]
[    4.023057@0] mmcblk1: sd:aaaa SN128 119 GiB
[    4.024204@0]  mmcblk1: p1
[    4.024558@0] meson-mmc: Enter aml_emmc_partition_ops
[    4.080186@2] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    4.233226@2] hub 1-1:1.0: USB hub found
[    4.233267@2] hub 1-1:1.0: 4 ports detected
[    4.552181@2]    4.677225@4] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 115200 to 115200
[    4.678148@3] meson-mmc: aml_sd_emmc_clktest [1549] clktest : 25062, delay_cell: 51, count: 97
[    4.678158@3] meson-mmc: [aml_emmc_hs200_tl1][2001] clk config:0x10100004
[    4.681359@3] meson-mmc: cmd->u64eyet:0x0e06000000000000
[    4.688922@2] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/7
[    4.689174@2] hid-generic 0003:24AE:2010.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless D0
[    4.691172@2] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/8
[    4.694358@3] meson-mmc: [aml_emmc_hs200_tl1][2067] clk config:0x10000204
[    4.694458@3] meson-mmc: set rate clkin2>>>>>>>>clk:799999987
[    4.694476@3] meson-aml-mmc ffe07000.emmc: divider requested rate 200000000 != actual rate 199999997: ret=0
[    4.694478@3] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[    4.694488@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000204
[    4.694496@3] meson-mmc: meson_mmc_set_ios_v3 290
[    4.694551@3] meson-aml-mmc ffe07000.emmc: divider requested rate 52000000 != actual rate 50000000: ret=0
[    4.694553@3] meson-mmc: actual_clock :50000000, HHI_nand: 0x80
[    4.694559@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000154
[    4.694629@3] emmc:use ds type0
[    4.694630@3] emmc: no support driver strength type 1 and 4
[    4.694686@3] meson-aml-mmc ffe07000.emmc: divider requested rate 52000000 != actual rate 50000000: ret=0
[    4.694688@3] meson-mmc: actual_clock :50000000, HHI_nand: 0x80
[    4.694694@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000154
[    4.694697@3] meson-mmc: emmc: try set sd/emmc to HS400 mode
[    4.694744@3] meson-aml-mmc ffe07000.emmc: divider requested rate 200000000 != actual rate 199999997: ret=0
[    4.694746@3] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[    4.694752@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10100004
[    4.694754@3] meson-mmc: emmc: try set sd/emmc to HS400 mode
[    4.695762@3] meson-mmc: aml_sd_emmc_clktest [1549] clktest : 12276, delay_cell: 53, count: 47
[    4.695770@3] meson-mmc: [aml_post_hs400_timming], delay1: 0x0, delay2: 0x1a000000
[    4.726825@3] meson-mmc: ds_sht:19, window:26, intf3:0x4130c8, clock:0x10100002
[    4.726825@3] meson-mmc: adjust:0x0
[    4.745073@3] meson-mmc: delay1:0x61902d0, delay2:0x1a005145
[    4.748446@2] hid-generic 0003:24AE:2010.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G W1
[    4.750004@2] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/9
[    4.777275@3] meson-mmc: ds_sht:24, window:27, intf3:0x4180c8, clock:0x10100002
[    4.777275@3] meson-mmc: adjust:0x0
[    4.808583@2] hid-generic 0003:24AE:2010.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireles2
[    5.133506@3] meson-mmc: scan time distance: 356227540 ns
[    5.133532@3] meson-mmc: best_start 0x17, best_size 37, cmd_delay is 0x29
[    5.140026@3] meson-mmc: >>>>>>>>>>>>>>scan command window>>>>>>>>>>>>>>>
[    5.146784@3] meson-mmc: >>cmd delay [ 0x0 -- 0x8 ] is ok
[    5.152153@3] meson-mmc: >>cmd delay [ 0x9 -- 0x16 ] is nok
[    5.157705@3] meson-mmc: >>cmd delay [ 0x17 -- 0x3b ] is ok
[    5.163246@3] meson-mmc: >>cmd delay [ 0x3c -- 0x3f ] is nok
[    5.168878@3] meson-mmc: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[    5.175621@3] emmc: new HS400 MMC card at address 0001
[    5.180581@3] emmc: clock 199999997, 8-bit-bus-width
 [    5.185941@3] mmcblk0: emmc:0001 AJTD4R 14.6 GiB
[    5.190421@3] mmcblk0boot0: emmc:0001 AJTD4R partition 1 4.00 MiB
[    5.196469@3] mmcblk0boot1: emmc:0001 AJTD4R partition 2 4.00 MiB
[    5.202532@3] mmcblk0rpmb: emmc:0001 AJTD4R partition 3 4.00 MiB
[    5.209031@3] meson-mmc: Enter aml_emmc_partition_ops
[    5.213907@3] meson-mmc: [aml_emmc_partition_ops] mmc read partition OK!
[    5.220102@3] meson-mmc: add_emmc_partition
[    5.224349@3] meson-mmc: [mmcblk0p01]           bootloader  offset 0x000000000000, size 0x000000400000
[    5.233699@3] meson-mmc: [mmcblk0p02]             reserved  offset 0x000002400000, size 0x000004000000
[    5.243064@3] meson-mmc: [mmcblk0p03]                cache  offset 0x000006c00000, size 0x000046000000
[    5.252428@3] meson-mmc: [mmcblk0p04]                  env  offset 0x00004d400000, size 0x000000800000
[    5.261778@3] meson-mmc: [mmcblk0p05]                 logo  offset 0x00004e400000, size 0x000000800000
[    5.271141@3] meson-mmc: [mmcblk0p06]             recovery  offset 0x00004f400000, size 0x000001800000
[    5.280496@3] meson-mmc: [mmcblk0p07]                 misc  offset 0x000051400000, size 0x000000800000
[    5.289856@3] meson-mmc: [mmcblk0p08]                 dtbo  offset 0x000052400000, size 0x000000800000
[    5.299222@3] meson-mmc: [mmcblk0p09]             cri_data  offset 0x000053400000, size 0x000000800000
[    5.308577@3] meson-mmc: [mmcblk0p10]                param  offset 0x000054400000, size 0x000001000000
[    5.317933@3] meson-mmc: [mmcblk0p11]                 boot  offset 0x000055c00000, size 0x000001000000
[    5.327305@3] meson-mmc: [mmcblk0p12]                  rsv  offset 0x000057400000, size 0x000001000000
[    5.336661@3] meson-mmc: [mmcblk0p13]             metadata  offset 0x000058c00000, size 0x000001000000
[    5.346014@3] meson-mmc: [mmcblk0p14]               vbmeta  offset 0x00005a400000, size 0x000000200000
[    5.355383@3] meson-mmc: [mmcblk0p15]                  tee  offset 0x00005ae00000, size 0x000002000000
[    5.364735@3] meson-mmc: [mmcblk0p16]               vendor  offset 0x00005d600000, size 0x00001f000000
[    5.374092@3] meson-mmc: [mmcblk0p17]                  odm  offset 0x00007ce00000, size 0x000008000000
[    5.383462@3] meson-mmc: [mmcblk0p18]               system  offset 0x000085600000, size 0x000078800000
[    5.388201@4] prepare_namespace() wait 76
[    5.396799@3] meson-mmc: [mmcblk0p19]              product  offset 0x0000fe600000, size 0x000008000000
[    5.406167@3] meson-mmc: [mmcblk0p20]                 data  offset 0x000106e00000, size 0x00029d000000
[    5.415464@3] card key: card_blk_probe.
[    5.419270@3] emmc_key_init:183 emmc key lba_start:0x12020,lba_end:0x12220
[    5.426112@3] emmc key: emmc_key_init:205 ok.
[    5.430446@3] meson-mmc: amlmmc_dtb_init: register dtb chardev[    5.437599@3] meson-mmc: calc c731f02c, store0
[    5.440589@3] meson-mmc: cpy 1 is not valid
[    5.446209@3] meson-mmc: calc c731f02c, store 0
[    5.449248@3] meson-mmc: cpy 0 is not valid
[    5.453406@3] meson-mmc: total valid 0
[    5.457222@3] meson-mmc: amlmmc_dtb_init: register dtb chardev OK[    5.463033@3] meson-mmc: amlmmc_ddr_init: v
meson-mmc: amlmmc_ddr_init: register ddr parameter chardev OK[    5.475014@3] meson-mmc: Exit aml_emmc_partition_.
[    5.481289@4] EXT4-fs (mmcblk0p18): couldn't mount as ext3 due to feature incompatibilities
[    5.488911@4] EXT4-fs (mmcblk0p18): couldn't mount as ext2 due to feature incompatibilities
[    5.503275@0] EXT4-fs (mmcblk0p18): mounted filesystem without journal. Opts: (null)
[    5.505442@2] VFS: Mounted root (ext4 filesystem) readonly on device 179:50.
[    5.512748@2] devtmpfs: mounted
[    5.517373@2] Freeing unused kernel memory: 4672K
[    5.533586@2] init: init first stage started!
[    5.534092@2] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.541714@2] init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
[    5.575444@2] EXT4-fs (mmcblk0p17): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    5.580048@2] init: [libfs_mgr]__mount(source=/dev/block/odm,target=/odm,type=ext4)=0: Success
[    5.589418@2] EXT4-fs (mmcblk0p19): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    5.598488@2] init: [libfs_mgr]__mount(source=/dev/block/product,target=/product,type=ext4)=0: Success
[    5.609231@2] EXT4-fs (mmcblk0p16): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    5.617657@2] init: [libfs_mgr]__mount(source=/dev/block/vendor,target=/vendor,type=ext4)=0: Success
[    5.626874@2] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[    5.633819@2] init: Loading SELinux policy
[    5.721061@2] audit: type=1403 audit(1293883204.460:2): policy loaded auid=4294967295 ses=4294967295
[    5.724704@2] selinux: SELinux: Loaded policy from /odm/etc/selinux/precompiled_sepolicy
[    5.724704@2]
[    5.738166@2] selinux: SELinux: Loaded file_contexts
[    5.738166@2]
[    5.743091@2] init: init second stage started!
[    5.758279@2] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.762954@2] selinux: SELinux: Loaded file_contexts
[    5.762954@2]
[    5.766847@2] init: Running restorecon...
[    5.774630@2] init: waitid failed: No child processes
[    5.777787@2] init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory:y
[    5.789556@2] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[    5.796937@2] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2438
[    5.803886@2] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2439
[    5.810657@2] init: Parsing file /init.rc...
[    5.943708@5] ueventd: ueventd started!
[    5.945667@5] selinux: SELinux: Loaded file_contexts
[    5.945667@5]
[    5.948690@5] ueventd: Parsing file /ueventd.rc...
[    5.955952@4] ueventd: Parsing file /vendor/ueventd.rc...
[    5.958798@0] mali_kbase: loading out-of-tree module taints kernel.
[    5.965247@5] ueventd: /vendor/ueventd.rc: 115: /sys/ lines must have 5 entries
[    5.972293@5] ueventd: Parsing file /odm/ueventd.rc...
[    5.977301@5] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    5.979085@0] mali ffe40000.bifrost: Continuing without Mali regulator control
[    5.979172@0] mali ffe40000.bifrost: max pp is 2
[    5.979176@0] mali ffe40000.bifrost: set min pp to default 1
[    5.979180@0] mali ffe40000.bifrost: min pp is 1
[    5.979183@0] mali ffe40000.bifrost: set min clk default to 0
[    5.979186@0] mali ffe40000.bifrost: min clk  is 0
[    5.979204@0] mali ffe40000.bifrost: hiu io source  0xffffff8008cfd000
[    5.979215@0] mali ffe40000.bifrost: hiu io source  0xffffff8008f0a000
[    5.979218@0] mali ffe40000.bifrost: num of pp used most of time 1
[    5.979222@0] mali ffe40000.bifrost: clock dvfs cfg table size is 6
[    5.979263@0] mali ffe40000.bifrost: max clk set 4
[    5.979266@0] mali ffe40000.bifrost: max clk  is 4
[    5.979269@0] mali ffe40000.bifrost: turbo clk set to 5
[    5.979272@0] mali ffe40000.bifrost: turbo clk  is 5
[    5.979276@0] mali ffe40000.bifrost: default clk set to 4
[    5.979279@0] mali ffe40000.bifrost: default clk  is 4
[    5.979284@0] mali ffe40000.bifrost: ====================0====================
[    5.979284@0] clk_freq= 285714285, clk_parent=fclk_div7, voltage=1150, keep_count=5, threshod=<100 190>, clk_s5
[    5.979289@0] mali ffe40000.bifrost: ====================1====================
[    5.979289@0] clk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_count=5, threshod=<152 207>, clk_s0
[    5.979294@0] mali ffe40000.bifrost: ====================2====================
[    5.979294@0] clk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, threshod=<180 220>, clk_s0
[    5.979299@0] mali ffe40000.bifrost: ====================3====================
[    5.979299@0] clk_freq= 666666666, clk_parent=fclk_div3, voltage=1150, keep_count=5, threshod=<210 236>, clk_s6
[    5.979303@0] mali ffe40000.bifrost: ====================4====================
[    5.979303@0] clk_freq= 800000000, clk_parent=fclk_div2p5, voltage=1150, keep_count=5, threshod=<230 255>, clk0
[    5.979308@0] mali ffe40000.bifrost: ====================5====================
[    5.979308@0] clk_freq= 800000000, clk_parent=fclk_div2p5, voltage=1150, keep_count=5, threshod=<230 255>, clk0
[    5.979311@0] mali ffe40000.bifrost: clock dvfs table size is 6
[    5.979420@0] mali_plat=ffffff8001cef598
[    5.979847@0] find tzd id: 0
[    5.979915@0] gpu cooling register okay with err=0
[    5.980100@0] find tzd id: 0
[    5.980127@0] gpu core cooling register okay with err=0
[    5.980160@0] shader_present=3, tiler_present=1, l2_present=1
[    5.980245@0] Mali_pwr_on:gpu_irq : 200
[    5.984693@2] hrtimer: interrupt took 7125 ns
[    5.984964@2] mali ffe40000.bifrost: GPU identified as 0x2 arch 7.2.1 r0p0 status 0
[    5.985449@2] mali ffe40000.bifrost: Using coherency mode 0 set from dtb
[    5.986805@3] mali ffe40000.bifrost: Probed as mali0
[    6.009451@4] PPMGRVPP: info: RegisterTB_Function: gfunc           (null), func: ffffff8001d29028, ver:TB dete]
[    6.184178@3] lcd vlock_en=1, vlock_mode=0x4
[    6.270338@5] ueventd: Parsing file /ueventd.amlogic.rc...
[    6.275694@5] ueventd: Unable to read config file '/ueventd.amlogic.rc': open() failed: No such file or directy
[    6.545368@5] ueventd: Coldboot took 0.257 seconds
[    6.591300@2] audit: type=1400 audit(1293883205.328:3): avc:  denied  { write } for  pid=2438 comm="init" name1
[    6.621915@1] EXT4-fs (mmcblk0p20): Ignoring removed nomblk_io_submit option
[    6.674364@1] EXT4-fs (mmcblk0p20): recovery complete
[    6.675349@1] EXT4-fs (mmcblk0p20): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_t
[    6.974634@3] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    6.974634@3]
[    6.975370@3] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[    6.975370@3]
[    6.983040@3] e2fsck: Pass 2: Checking directory structure
[    6.983040@3]
[    6.990107@3] e2fsck: Pass 3: Checking directory connectivity
[    6.990107@3]
[    6.997481@3] e2fsck: Pass 4: Checking reference counts
[    6.997481@3]
[    7.004349@3] e2fsck: Pass 5: Checking group summary information
[    7.004349@3]
[    7.011945@3] e2fsck: /dev/block/data: 2221/685440 files (8.3% non-contiguous), 165708/2740224 blocks
[    7.011945@3]
[    7.023755@2] EXT4-fs (mmcblk0p20): Ignoring removed nomblk_io_submit option
[    7.035753@2] EXT4-fs (mmcblk0p20): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submc
[    7.043138@2] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[    7.054182@2] EXT4-fs (mmcblk0p3): recovery complete
[    7.054634@2] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_it
[    7.063835@3] audit: type=1400 audit(1293883205.800:4): avc:  denied  { read } for  pid=2999 comm="imageserver1
[    7.063867@3] audit: type=1400 audit(1293883205.800:5): avc:  denied  { write } for  pid=2999 comm="imageserve1
[    7.063881@3] audit: type=1400 audit(1293883205.800:6): avc:  denied  { open } for  pid=2999 comm="imageserver1
[    7.063960@3] audit: type=1400 audit(1293883205.800:7): avc:  denied  { ioctl } for  pid=2999 comm="imageserve1
[    7.196273@3] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[    7.196273@3]
[    7.197004@3] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[    7.197004@3]
[    7.204618@3] e2fsck: Pass 2: Checking directory structure
[    7.204618@3]
[    7.212264@3] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[    7.219926@3] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submic
[    7.230802@3] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    7.239736@3] EXT4-fs (mmcblk0p13): recovery complete
[    7.242367@3] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_t
[    7.298547@2] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    7.301202@2] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submc
[    7.337342@0] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[    7.340692@1] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submc
[    7.385363@0] EXT4-fs (mmcblk0p15): Ignoring removed nomblk_io_submit option
[    7.392431@0] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submc
[    7.398933@0] init: 27 output lines suppressed due to ratelimiting
[    7.413940@0] No find node.
[    7.413973@0] register clk_set_setting cpu[46]
[    7.424286@0] Registered firmware driver success.
[    7.425297@0] Try to load video/h264_enc.bin  ...
[    7.429824@0] load firmware size : 76288, Name : video/h264_enc.bin.
[    7.435002@0] Try to load video/video_ucode.bin  ...
[    7.451713@0] load firmware size : 1459200, Name : video/video_ucode.bin.
[    7.506094@2] Amlogic A/V streaming port init
[    7.512974@2] get gate demux control ok ffffffc044141380
[    7.513012@2] get gate parser_top control ok ffffffc044141900
[    7.518412@2] get gate vdec control ok ffffffc044141e40
[    7.523567@2] get gate clk_81 control failed           (null)
[    7.529393@2] get gate clk_vdec_mux control ok ffffffc044141600
[    7.535235@2] get gate clk_hcodec_mux control ok ffffffc044141c80
[    7.541340@2] get gate clk_hevc_mux control ok ffffffc043421ec0
[    7.547198@2] get gate clk_hevcb_mux control ok ffffffc043421840
[    7.553142@2] get gate ahbarb0 control ok ffffffc043429840
[    7.558585@2] get gate asyncfifo control failed           (null)
[    7.586278@5] ammvdec_h264 module init
[    7.622647@2] ammvdec_mpeg12 module init
[    7.632337@2] ammvdec_mpeg4_driver_init_module
[    7.666605@5] amvenc_avc_probe -- reserved memory config fail.
[    7.666793@5] amvenc_avc - cma memory pool size: 60 MB
[    7.671995@5] encode_wq_init.
[    7.674895@5] encode start monitor.
[    7.678469@0] encode workqueue monitor start.
[    7.689025@5] vpu_init
[    7.689221@5] vpu_probe
[    7.689235@5] HevcEnc reserved memory config fail.
[    7.692969@5] HevcEnc - cma memory pool size: 64 MB
[    7.697863@5] HevcEnc - wave420l_irq: 50
[    7.701737@5] vpu base address get from platform driver physical base addr=0xff610000, virtual base=0xffffff800
[    7.712598@5] success to probe vpu device with video memory from cma
[    7.738462@4] audit: type=1400 audit(1293883206.476:8): avc:  denied  { setattr } for  pid=1 comm="init" name=1
[    7.784388@2] logd.auditd: start
[    7.784431@2] logd.klogd: 7640252877
[    7.865218@3] type=1400 audit(1293883206.604:9): avc: denied { setattr } for pid=2438 comm="init" name="droido1
[    7.880072@3] type=1400 audit(1293883206.604:9): avc: denied { setattr } for pid=2438 comm="init" name="droido1
[    7.900230@3] type=1400 audit(1293883206.604:10): avc: denied { setattr } for pid=2438 comm="init" name="log" 1
[    7.919538@3] type=1400 audit(1293883206.604:10): avc: denied { setattr } for pid=2438 comm="init" name="log" 1
[    7.925492@2] npu_version: 2
[    7.925678@2] Galcore version 6.4.6.2.8.3.2
[    7.931991@2] gckCOMMAND_Construct 1474 physical=40d00000
[    7.931999@2] gckCOMMAND_Construct 1474 physical=40d01000
[    7.956470@3] type=1400 audit(1293883206.604:11): avc: denied { setattr } for pid=2438 comm="init" name="media1
[    7.965648@2] probe iq_dev for sensor: os08a10
[    7.965655@2] get_cali_name_id@:97 SUBDEV_IQ(CRIT) :Loading Calibration for OS08A10_IPC
[    7.965655@2]
[    8.030040@0] config sensor os08a10 driver.
[    8.030073@0] sensor bsp init
[    8.031535@0] cannot get g12a_24m clk
[    8.035363@0] set mclk fail
[    8.079637@2] arm_sensor_i2c_probe: start to probe
[    8.079728@2] system_i2c_init:success to add i2c driver
[    8.085236@2] sensor_get_id@:479 GENERIC(CRIT) :sensor_get_id: Failed to read sensor id
[    8.091959@2]
[    8.093621@2] sensor_detect_os08a10:0
[    8.097277@2] arm_sensor_i2c_remove: remove i2c sensor
[    8.236269@2] arm_isp ff140000.isp: assigned reserved memory node linux,isp_cma
[    8.237962@2] AM_SC: am_sc_parse_dt: rs idx info: name: isp_sc
[    8.243784@2] AM_SC: am_sc_parse_dt:rs info: irq: 58
[    8.253946@0] interrupt comes in (irq = 59) without app handler, status: 0x200, pusle mode:0
[    8.261287@0] acamera_fw_init@:106 GENERIC(CRIT) :seamless:0
[    8.262734@2] pwr_enable: get_named_gpio power-enable fail
[    8.268238@2] set power fail
[    8.285293@2] init clock is 24 MHZ
[    8.327791@2] arm_sensor_i2c_probe: start to probe
[    8.327859@2] arm_sensor_i2c_probe: success get link device:phy-csi
[    8.333298@2] AM_MIPI: am_mipi_parse_dt:Success to get link device: isp-adapter
[    8.340548@2] platform ff650000.isp-adapter: assigned reserved memory node linux,adapt_cma
[    8.348753@2] AM_ADAP: adapter alloc 24M memory
[    8.353285@2] system_i2c_init:success to add i2c driver
[    8.360685@2] pwr_enable: get_named_gpio power-enable fail
[    8.373915@2] pwr_enable: get_named_gpio power-enable fail
[    8.385278@2] sensor_get_id@:479 GENERIC(CRIT) :sensor_get_id: Failed to read sensor id
[    8.387631@2]
[    8.535678@0] AM_MIPI: am_mipi_init:Success mipi init
[    8.535708@0] AM_ADAP: inject_data_flag = 0, dump_data_flag = 0
[    8.542142@0] AM_ADAP: frontend : width = 1920, val = 150
[    8.546430@0] sensor_set_mode@:574 GENERIC(CRIT) :Mode 0, Setting num: 2, RES:1920x1080
[    8.554419@0]
[    8.555994@0] get_cali_name_id@:97 SUBDEV_IQ(CRIT) :Loading Calibration for OS08A10_IPC
[    8.564049@0]
[    8.565645@0] iq_ioctl@:260 SUBDEV_IQ(CRIT) :soc_iq get config os08a10 according to sensor drv
[    8.575232@0] general_set_wdr_mode@:490 GENERAL(CRIT) :Setting Linear Binary Sequence
[    8.581978@2]
[    8.584555@2] sbuf_mgr_alloc_sbuf@:175 SBUF(CRIT) :sbuf: len_needed: 238132, len_alloc: 245759, len_used: 2416.
[    8.600289@2] sbuf_calibration_init@:495 SBUF(CRIT) :sbuf_calibration wdr_mode updated: 65535 -> 0.
[    8.613379@2] connection_thread@:105 GENERIC(CRIT) :[    8.613418@3] connection_thread@:105 GENERIC(CRIT) :
[    8.613419@3] isp_fw_process@:123 GENERIC(CRIT) :
[    8.613421@3] isp_fw_process start
[    8.613421@3]
[    8.615218@5] sensor_get_id@:479 GENERIC(CRIT) :
[    8.615220@5] sensor_get_id: Failed to read sensor id
[    8.615221@5]
[    8.639961@2] connection_thread start
[    8.643648@2]
[    8.644273@0] logd.daemon: reinit
[    8.827085@3] android.hardware.health@2.0-impl: wakealarm_init: timerfd_create failed
[    8.892724@3] type=1400 audit(1293883206.604:11): avc: denied { setattr } for pid=2438 comm="init" name="media1
[    8.901617@4] VID: VD1 off
[    8.902279@4] hdmitx: system: set hdcp_pwr 1
[    8.923703@4] type=1400 audit(1293883207.632:12): avc: denied { read } for pid=3204 comm="systemcontrol" name=1
[    8.936327@1] unifykey: amlkey_init_gen() enter!
[    8.944748@0] hdmitx: system: restore hdcp_pwr 0
[    8.947879@3] hdmitx: system: sname = 1080p60hz
[    8.947881@3] hdmitx: system: char_clk = 148500
[    8.947882@3] hdmitx: system: cd = 6
[    8.947883@3] hdmitx: system: cs = 2
[    8.947886@3] hdmitx: RX tmds clk: 225   Calc clk: 222
[    8.994911@3] fb: osd_open, 1514, fb_index=0,fb_rmem_size=26738688
[    8.995552@3] fb: osd_open, 1514, fb_index=1,fb_rmem_size=1048576
[    9.001663@3] fb: osd_open, 1514, fb_index=2,fb_rmem_size=1048576
[    9.007745@3] fb: vpu clkc clock is 199 MHZ
[    9.011809@3] fb: osd_open, 1514, fb_index=3,fb_rmem_size=8388608
[    9.032950@4] emmc_key_read:114, read ok
[    9.032991@4] unifykey: amlkey_init_gen() storagekey_info.buffer=ffffffc005080000, storagekey_info.size = 4000!
[    9.075698@4] vfm_map_store.part.1:rm default
[    9.075879@4] vfm_map_store.part.1:add default decoder ppmgr deinterlace amvideo
[    9.085548@3] file system registered
[    9.085752@3] audit: audit_lost=1 audit_rate_limit=5 audit_backlog_limit=64
[    9.087849@5] vout: vout_io_open
[    9.095482@3] audit: rate limit exceeded
[    9.102684@3] assign_ffs_buffer FFS_BUFFER_MAX=100!!!
[    9.105810@4] cpufreq_interactive: cpufreq_hmp_boost_start.part.8()
[    9.110685@4] cpufreq_interactive: hmp boost cpu:0 cluster:1
[    9.116348@4] cpufreq_interactive: hmp boost cpu:1 cluster:1
[    9.121939@4] cpufreq_interactive: hmp boost cpu:2 cluster:0
[    9.127580@4] cpufreq_interactive: hmp boost cpu:3 cluster:0
[    9.133204@4] cpufreq_interactive: hmp boost cpu:4 cluster:0
[    9.138865@4] cpufreq_interactive: hmp boost cpu:5 cluster:0
[    9.161389@2] [DI] load 0x3e00 pq table len 424 later.
console:/ $ [    9.280426@3] read descriptors
[    9.280457@3] read strings
[    9.619886@3] isp_v4l2_stream_try_format@:1321 GENERIC(CRIT) :[Stream#0] format 0x00000000 is not supported, s.
[    9.627997@1]
[    9.632292@3] vout: vout_io_open
[    9.632324@3] vout: vout_ioctl: cmd_dir = 0x2, cmd_nr = 0x0
[    9.632912@2] isp_v4l2_stream_try_format@:1321 GENERIC(CRIT) :[Stream#0] format 0x00000000 is not supported, s.
[    9.632913@2]
[    9.651993@3] vout: vout_io_release
[    9.753272@2] avc open
[    9.753300@2] amvenc_avc  check CMA pool success, max instance: 3.
[    9.756735@2] allocating phys 0x5a400000, size 20480k, wq:ffffffc03c357800.
[    9.763166@2] amvenc_avc  memory config success, buff start:0x5a400000, size is 0x1400000, wq:ffffffc03c357800.
[    9.773789@5] avc release, wq:ffffffc03c357800
[    9.777650@5] remove  encode_work_queue ffffffc03c357800 success, _destroy_encode_work_queue line 3786.
[    9.787189@5] [+] vpu_open
[    9.790733@5] allocating phys 0x5a400000, virt addr 0x0, size 65536k
[    9.796150@5] [-] vpu_open, ret: 0
[    9.799385@5] vpu_release
[    9.801962@5] vpu_free_buffers
[    9.804993@5] vpu_free_instances
[    9.808193@5] vpu_release, s_video_memory 0x5a400000
[    9.941159@3] aml_tdm_open
[    9.945959@5] loopback_dai_startup
[    9.946467@5] loopback_dai_shutdown
[    9.947692@5] aml_tdm_open
[    9.950940@5] aml_spdif_open
[    9.953182@5] aml_spdif_close
[    9.956502@5] aml_tdm_open
[   10.003357@3] aml_tdm_open
[   10.003385@3] Not init audio effects
[   10.069562@3] hdmitx: audio: aout notify format CT_PCM
[   10.069592@3] hdmitx: hw: set audio
[   10.072622@3] hdmitx: hw: hdmitx tx_aud_src = 0
[   10.077125@3] hdmitx: fs = 3, cd = 6, tmds_clk = 148352
[   10.082720@3] hdmitx: hw: aud_n_para = 11648
[   10.086562@3] hdmitx: hw: set channel status
[   10.090799@3] hdmitx: hw: [0x10e3] = 0xf
[   10.094693@3] hdmitx: audio: Audio Type: PCM
[   10.098919@3] hdmitx: audio: set audio param
[   10.240217@2] es8316 spk_ctl_gpio 1
[   10.240252@2] es8316 spk_mute_gpio 0
[   10.242256@2] asoc-aml-card auge_sound: tdm playback enable
[   10.887491@2] fb: osd[0] enable: 1 scale:0x10001 (HwBinder:3217_2)
[   10.888030@2] fb: osd[0] enable: 1 scale:0x10001 (HwBinder:3217_2)
[   10.896828@0] fb: free_scale_switch to fb0, mode: 0x10001
[   10.899652@2] fb: set logo loaded
[   11.179164@4] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[   11.992222@3] early_suspend_state=0
[   12.268275@4] vout: aml_tvout_mode_work: monitor_timeout
[   13.145536@5] acc_open
[   13.145563@5] acc_release
[   13.482280@0] meson6-dwmac ff3f0000.ethernet eth0: fail to init PTP.
[   13.485162@0] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.596091@4] sdcardfs version 2.0
[   13.596125@4] sdcardfs: dev_name -> /data/media
[   13.598476@4] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,g5
[   13.610863@4] sdcardfs: mnt -> ffffffc0444f0aa0
[   13.617033@4] sdcardfs: mounted on top of /data/media type ext4
[   13.620109@4] Remount options were mask=23,gid=9997 for vfsmnt ffffffc0444f1c20.
[   13.627031@4] sdcardfs : options - debug:1
[   13.634869@4] sdcardfs : options - gid:9997
[   13.634948@4] sdcardfs : options - mask:23
[   13.639387@4] Remount options were mask=7,gid=9997 for vfsmnt ffffffc0149968e0.
[   13.646844@4] sdcardfs : options - debug:1
[   13.651589@4] sdcardfs : options - gid:9997
[   13.655314@4] sdcardfs : options - mask:7
[   13.921008@3] binder: unexpected work type, 4, not freed
[   13.921044@3] binder: undelivered TRANSACTION_COMPLETE
[   13.925844@3] binder: undelivered transaction 6865, process died.
[   13.965127@0] aml_wifi wifi: [usb_power_control] Set WiFi power down
[   13.965880@0] meson-mmc: [sdio_notify] finish
[   14.171969@4] aml_wifi wifi: [usb_power_control] Set WiFi power on !
[   14.265415@1] audio_dsp: dts_dec_control/0x0
[   14.378820@4] init: Could not find service hosting interface android.hardware.radio@1.0::IRadio/slot1
[   14.382474@3] meson-mmc: [sdio_notify] finish
[   14.383768@0] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   14.383772@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   14.384811@0] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   14.384815@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   14.389748@0] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   14.389752@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   14.416244@3] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   14.416262@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   14.438871@4] init: Could not find service hosting interface android.hardware.radio@1.0::IRadio/slot1
[   14.440964@3] sdio: queuing unknown CIS tuple 0x80 (2 bytes)
[   14.443995@3] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   14.446907@3] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   14.452072@3] sdio: queuing unknown CIS tuple 0x80 (7 bytes)
[   14.461948@3] sdio: queuing unknown CIS tuple 0x81 (9 bytes)
[   14.479881@5] sensors 4-000e: set sensor poll time to 66ms
[   14.482384@1] sensors 4-000e: sensor on: starting poll sensor data 64ms
[   14.567451@3] meson-aml-mmc ffe03000.sdio: divider requested rate 200000000 != actual rate 199999997: ret=0
[   14.571771@3] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[   14.578043@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000245
[   14.584343@3] meson-mmc: Data 1 aligned delay is 0
[   14.589045@3] meson-mmc: sdio: clk 199999997 tuning start
[   14.603872@3] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   14.603904@3] meson-mmc: step:4, delay1:0x4104104, delay2:0x4004104
[   14.621223@3] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   14.621257@3] meson-mmc: step:8, delay1:0x8208208, delay2:0x8008208
[   14.636038@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   14.636072@3] meson-mmc: step:12, delay1:0xc30c30c, delay2:0xc00c30c
[   14.655114@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   14.655148@3] meson-mmc: step:16, delay1:0x10410410, delay2:0x10010410
[   14.669245@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   14.669279@3] meson-mmc: step:20, delay1:0x14514514, delay2:0x14014514
[   14.682293@3] meson-mmc: sdio: adj_win: < 0 2 3 4 >
[   14.682331@3] meson-mmc: left:3, right:0, mid:4, size:4
[   14.686864@3] meson-mmc: step:0, delay1:0x0, delay2:0x0
[   14.692135@3] meson-mmc: sdio: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x32000
[   14.700390@3] meson-mmc: delay1:0x0, delay2:0x0
[   14.712593@3] sdio: new ultra high speed SDR104 SDIO card at address 0001
[   14.713862@3] sdio: clock 199999997, 4-bit-bus-width
 [   14.719507@4] meson-mmc: [sdio_reinit] finish
[   14.723210@4] aml_wifi wifi: [usb_power_control] Set WiFi power on !
[   14.730657@4] aml_wifi wifi: [pci_reinit] pci wifi reinit!
[   14.735387@4] aml_wifi wifi: [wifi_power_ioctl] Set sdio wifi power up!
[   14.742601@4] aml_wifi wifi: [wifi_power_ioctl] wifi interface dev type: sdio, length = 4
[   14.750658@2] type=1400 audit(1293883211.496:47): avc: denied { getattr } for pid=3468 comm="android.ui" path=1
[   14.774293@2] type=1400 audit(1293883213.488:48): avc: denied { write } for pid=3230 comm="wifi@1.0-servic" na1
[   14.795829@2] type=1400 audit(1293883213.488:48): avc: denied { write } for pid=3230 comm="wifi@1.0-servic" na1
[   14.817141@2] type=1400 audit(1293883213.488:49): avc: denied { add_name } for pid=3230 comm="wifi@1.0-servic"1
[   14.836937@2] type=1400 audit(1293883213.488:49): avc: denied { add_name } for pid=3230 comm="wifi@1.0-servic"1
[   14.850739@3] [dhd] dhd_module_init: in Dongle Host Driver, version 100.10.545.11 (r826445-20200610-1)
[   14.850756@3] [dhd] ======== dhd_wlan_init_plat_data ========
[   14.850759@3] [dhd] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=70, oob_irq_flags=0x418
[   14.850760@3] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1
[   14.850762@3] [dhd] dhd_wifi_platform_load: Enter
[   14.850764@3] [dhd] Power-up adapter 'DHD generic adapter'
[   14.850770@3] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[   14.850772@3] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[   14.850801@3] aml_wifi wifi: [extern_wifi_set_enable] WIFI  Disable! 482
[   14.912539@1] type=1400 audit(1293883213.488:50): avc: denied { create } for pid=3230 comm="wifi@1.0-servic" n1
[   14.934138@1] type=1400 audit(1293883213.488:50): avc: denied { create } for pid=3230 comm="wifi@1.0-servic" n1
[   14.951642@1] type=1400 audit(1293883213.488:51): avc: denied { read write } for pid=3230 comm="wifi@1.0-servi1
[   14.973282@5] type=1400 audit(1293883213.488:51): avc: denied { read write } for pid=3230 comm="wifi@1.0-servi1
[   14.995281@5] type=1400 audit(1293883213.488:52): avc: denied { open } for pid=3230 comm="wifi@1.0-servic" pat1
[   15.044311@0] BT_RADIO going: on
[   15.044374@0] AML_BT: going ON
[   15.058187@4] aml_wifi wifi: [extern_wifi_set_enable] WIFI  Enable! 482
[   15.264994@2] binder: send failed reply for transaction 16648 to 3468:3703
[   15.464664@0] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 0 to 9600
[   15.467151@0] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 9600 to 9600
[   15.475693@0] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 9600 to 115200
[   15.486048@5] Now can use cma, free:11920, wm:11935
[   15.488676@2] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 2000000
[   15.564212@3] [dhd] wifi_platform_bus_enumerate device present 1
[   15.564591@3] [dhd] ======== Card detection to detect SDIO card! ========
[   15.571568@3] sdio_reset_comm():
[   15.574778@3] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   15.580428@3] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   15.612308@2] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   15.612527@2] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   15.638273@4] sdio: queuing unknown CIS tuple 0x80 (2 bytes)
[   15.641063@5] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   15.646689@4] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   15.655076@5] sdio: queuing unknown CIS tuple 0x80 (7 bytes)
[   15.661356@3] sdio: queuing unknown CIS tuple 0x81 (9 bytes)
[   15.761082@1] meson-aml-mmc ffe03000.sdio: divider requested rate 200000000 != actual rate 199999997: ret=0
[   15.765324@1] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[   15.771582@1] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000245
[   15.778092@1] meson-mmc: Data 1 aligned delay is 0
[   15.783583@1] meson-mmc: sdio: clk 199999997 tuning start
[   15.796643@5] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   15.796675@5] meson-mmc: step:4, delay1:0x4104104, delay2:0x4004104
[   15.809951@4] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   15.809985@4] meson-mmc: step:8, delay1:0x8208208, delay2:0x8008208
[   15.821703@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   15.821736@3] meson-mmc: step:12, delay1:0xc30c30c, delay2:0xc00c30c
[   15.835172@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   15.835205@3] meson-mmc: step:16, delay1:0x10410410, delay2:0x10010410
[   15.849638@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   15.849671@3] meson-mmc: step:20, delay1:0x14514514, delay2:0x14014514
[   15.861200@3] meson-mmc: sdio: adj_win: < 0 2 3 4 >
[   15.861232@3] meson-mmc: left:3, right:0, mid:4, size:4
[   15.865728@3] meson-mmc: step:0, delay1:0x0, delay2:0x0
[   15.870876@3] meson-mmc: sdio: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x32000
[   15.879311@3] meson-mmc: delay1:0x0, delay2:0x0
[   15.883832@3] meson-mmc: [sdio_reinit] finish
[   15.904389@4] [dhd] bcmsdh_register: register client driver
[   15.904626@4] [dhd] bcmsdh_sdmmc_probe: Enter num=1
[   15.909435@4] [dhd] bcmsdh_sdmmc_probe: Enter num=2
[   15.914121@4] [dhd] bus num (host idx)=2, slot num (rca)=1
[   15.919824@4] [dhd] found adapter info 'DHD generic adapter'
[   15.925188@4] Wifi: bcmdhd_mem_prealloc: sectoin 3, size 139264
[   15.931106@4] succeed to alloc static buf
[   15.935057@4] Wifi: bcmdhd_mem_prealloc: sectoin 4, size 0
[   15.940815@4] [dhd] sdioh_attach: set sd_f2_blocksize 256
[   15.945937@4] [dhd] sdioh_attach: sd clock rate = 0
[   15.951127@4] [dhd] dhdsdio_probe : no mutex held. set lock
[   15.956774@2] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 2000000 to 115200
[   15.956791@4] [dhd] F1 signature read @0x18000000=0x17294359
[   15.961574@4] [dhd] F1 signature OK, socitype:0x1 chip:0x4359 rev:0x9 pkg:0x2
[   15.962217@4] [dhd] DHD: dongle ram size is set to 917504(orig 917504) at 0x160000
[   15.962286@4] Wifi: bcmdhd_mem_prealloc: sectoin 7, size 31624
[   15.962307@4] [dhd] dhd_conf_set_chiprev : chip=0x4359, chiprev=9
[   15.962353@4] Wifi: bcmdhd_mem_prealloc: sectoin 0, size 10320
[   15.962822@4] Wifi: bcmdhd_mem_prealloc: sectoin 5, size 65536
[   15.963269@4] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   15.963274@4] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   15.963276@4] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   15.963277@4] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   15.963279@4] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   15.963281@4] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   15.963283@4] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   15.963503@4] Wifi: bcmdhd_mem_prealloc: sectoin 19, size 65712
[   15.963549@4] Wifi: bcmdhd_mem_prealloc: sectoin 20, size 262144
[   15.963590@4] Wifi: bcmdhd_mem_prealloc: sectoin 22, size 65536
[   15.963603@4] [dhd] dhd_log_dump_init: kernel log buf size = 512KB; logdump_prsrv_tailsize = 80KB; limit prsrvB
[   15.963607@4] [dhd] dhd_log_dump_init : Try to allocate memory total(4194304) special(8192)
[   15.963611@4] Wifi: bcmdhd_mem_prealloc: sectoin 15, size 4194304
[   15.964271@4] Wifi: bcmdhd_mem_prealloc: sectoin 16, size 8192
[   15.964360@4] dhd_attach(): thread:dhd_watchdog_thread:fc0 started
[   15.964436@4] dhd_attach(): thread:dhd_dpc:fc1 started
[   15.964536@4] dhd_attach(): thread:dhd_rxf:fc2 started
[   15.964544@4] [dhd] dhd_deferred_work_init: work queue initialized
[   15.964551@4] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[   15.964652@4] [dhd] get_mem_val_from_file: File [/data/vendor/misc/wifi/.memdump.info] doesn't exist
[   15.964657@4] [dhd] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[   15.964663@4] [dhd] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[   15.982713@4] Wifi: bcmdhd_mem_prealloc: sectoin 1, size 10300
[   15.982720@4] Wifi: bcmdhd_mem_prealloc: sectoin 2, size 65536
[   15.982782@4] [dhd] dhdsdio_probe_init: making DHD_BUS_DOWN
[   15.983120@4] [dhd] Dongle Host Driver, version 100.10.545.11 (r826445-20200610-1)
[   15.983762@4] [dhd] Register interface [wlan0]  MAC: 6c:21:a2:9b:19:78
[   15.983762@4]
[   15.984763@4] [dhd] dhd_dbg_detach_pkt_monitor, 2099
[   15.984771@4] [dhd] dhd_bus_devreset: == Power OFF ==
[   15.986988@4] [dhd] dhd_bus_stop: making DHD_BUS_DOWN
[   15.987027@4] [dhd] bcmsdh_oob_intr_unregister: Enter
[   15.987028@4] [dhd] bcmsdh_oob_intr_unregister: irq is not registered
[   15.987034@4] [dhd] dhd_bus_devreset: making dhdpub up FALSE
[   15.987038@4] [dhd] dhd_txglom_enable: enable 0
[   15.987041@4] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[   15.987043@4] [dhd] dhd_bus_devreset:  WLAN OFF DONE
[   15.987214@4] [dhd] wifi_platform_set_power = 0, delay: 0 msec
[   15.987220@4] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========
[   15.987244@4] [dhd] dhd_ifname: ifidx 16 out of range
[   15.987247@4] [dhd] <if_bad>: set cur_etheraddr failed
[   15.987249@4] [dhd] dhd_ifname: ifidx 16 out of range
[   15.987253@4] [dhd] dhd_register_if: _dhd_set_mac_address() failed
[   15.987846@4] [dhd] Register interface [wlan1]  MAC: 6e:21:a2:9b:19:78
[   15.987846@4]
[   15.987851@4] [dhd] dhdsdio_probe : the lock is released.
[   15.987967@4] [dhd] dhd_module_init: Exit err=0
[   16.087242@4] [dhd] dhd_open: Enter wlan0
[   16.087244@4] [dhd] dhd_open : no mutex held. set lock
[   16.087250@4] [dhd]
[   16.087250@4] Dongle Host Driver, version 100.10.545.11 (r826445-20200610-1)
[   16.087259@4] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[   16.087262@4] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[   16.087267@4] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[   16.087291@4] aml_wifi wifi: [extern_wifi_set_enable] WIFI  Disable! 482
[   16.288185@4] aml_wifi wifi: [extern_wifi_set_enable] WIFI  Enable! 482
[   16.551687@4] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 2000000
[   16.556823@0] meson6-dwmac ff3f0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   16.804217@2] sdio_reset_comm():
[   16.804298@2] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   16.807632@2] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   16.844282@5] meson-mmc: actual_clock :400000, HHI_nand: 0x880
[   16.844500@5] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x1000023c
[   16.982940@0] meson-aml-mmc ffe03000.sdio: divider requested rate 200000000 != actual rate 199999997: ret=0
[   16.987664@0] meson-mmc: actual_clock :199999997, HHI_nand: 0x880
[   16.994236@1] meson-mmc: [meson_mmc_set_ios_v3] after clock: 0x10000245
[   17.000607@5] meson-mmc: Data 1 aligned delay is 0
[   17.004679@5] meson-mmc: sdio: clk 199999997 tuning start
[   17.014781@3] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   17.014809@3] meson-mmc: step:4, delay1:0x4104104, delay2:0x4004104
[   17.026075@3] meson-mmc: sdio: adj_win: < 1 2 3 4 >
[   17.026107@3] meson-mmc: step:8, delay1:0x8208208, delay2:0x8008208
[   17.036662@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   17.037039@3] meson-mmc: step:12, delay1:0xc30c30c, delay2:0xc00c30c
[   17.048630@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   17.048659@3] meson-mmc: step:16, delay1:0x10410410, delay2:0x10010410
[   17.060336@3] meson-mmc: sdio: adj_win: < 0 1 2 3 4 >
[   17.060368@3] meson-mmc: step:20, delay1:0x14514514, delay2:0x14014514
[   17.071074@4] meson-mmc: sdio: adj_win: < 0 2 3 4 >
[   17.071273@4] meson-mmc: left:3, right:0, mid:4, size:4
[   17.076509@4] meson-mmc: step:0, delay1:0x0, delay2:0x0
[   17.081715@4] meson-mmc: sdio: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x32000
[   17.090157@4] meson-mmc: delay1:0x0, delay2:0x0
[   17.094705@4] [dhd] sdioh_start: set sd_f2_blocksize 256
[   17.100292@4] [dhd]
[   17.100292@4]
[   17.100292@4] dhd_bus_devreset: == Power ON ==
[   17.108331@3] [dhd] F1 signature read @0x18000000=0x17294359
[   17.117164@3] [dhd] F1 signature OK, socitype:0x1 chip:0x4359 rev:0x9 pkg:0x2
[   17.121567@3] [dhd] DHD: dongle ram size is set to 917504(orig 917504) at 0x160000
[   17.128499@3] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[   17.133850@3] [dhd] dhdsdio_probe_init: making DHD_BUS_DOWN
[   17.140294@4] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/wifi/4359/config.txt
[   17.147923@4] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/wifi/4359/fw_bcm4359c0_ag.bin
[   17.157270@4] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/wifi/4359/nvram_ap6398s.txt
[   17.166327@4] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/wifi/4359/clm_bcm4359c0_ag.blob
[   17.175869@4] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/wifi/4359/config.txt
[   17.185480@4] [dhd] dhd_os_open_image1: /vendor/etc/wifi/4359/fw_bcm4359c0_ag.bin (662637 bytes) open success
[   17.277904@4] [dhd] dhd_os_open_image1: /vendor/etc/wifi/4359/nvram_ap6398s.txt (6090 bytes) open success
[   17.282267@4] [dhd] NVRAM version: AP6398S_NVRAM_V2.0_20191009A
[   17.288619@4] [dhd] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   17.484587@4] [dhd] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   17.485698@4] [dhd] bcmsdh_oob_intr_register: HW_OOB irq=70 flags=0x8
[   17.495415@2] [dhd] get_mem_val_from_file: File [/data/vendor/misc/wifi/.memdump.info] doesn't exist
[   17.501275@2] [dhd] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[   17.506979@2] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 -> mode 1
[   17.514515@2] [dhd] dhd_apply_default_clm: Ignore clm file /vendor/etc/wifi/4359/clm_bcm4359c0_ag.blob
[   17.524857@4] [dhd] Firmware up: op_mode=0x0405, MAC=6c:21:a2:9b:19:78
[   17.533285@4] [dhd] dhd_preinit_ioctls: event_log_max_sets: 26 ret: -23
[   17.543748@4] [dhd]   Driver: 100.10.545.11 (r826445-20200610-1)
[   17.543748@4]   Firmware: wl0: Feb 22 2022 19:34:20 version 9.87.51.11.82 (g383358a) FWID 01-cd4b2098
[   17.543748@4]   CLM: 9.7.6 (2022-02-22 19:33:51)
[   17.558646@4] [dhd] dhd_preinit_ioctls wlc_ver failed -23
[   17.563753@4] [dhd] dhd_txglom_enable: enable 1
[   17.567872@4] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy
[   17.573947@4] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[   17.581396@4] [dhd] dhd_conf_set_txglom_params : txinrx_thres=128, dhd_txminmax=-1
[   17.588942@4] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[   17.596561@4] [dhd] dhd_conf_get_disable_proptx : fw_proptx=0, disable_proptx=1
[   17.605522@4] [dhd] dhd_pno_init: Support Android Location Service
[   17.635724@4] [dhd] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[   17.638876@4] [dhd] dhd_rtt_init : FTM is not supported
[   17.644607@4] [dhd] dhd_rtt_ftm_config : failed to set config
[   17.651555@4] [dhd] failed to set WNM capabilities
[   17.667561@4] [dhd] dhd_preinit_ioctls: Failed to get preserve log # !
[   17.668774@4] [dhd] dhd_conf_map_country_list : CN/38
[   17.673494@4] [dhd] dhd_conf_set_country : set country CN, revision 38
[   17.682381@2] [dhd] dhd_conf_set_country : Country code: CN (CN/38)
[   17.694952@3] [dhd] CONFIG-ERROR) dhd_conf_set_intiovar : txbf setting failed -23
[   17.696880@3] [dhd-wlan0] wl_android_wifi_on : Success
[   17.742274@3] [dhd] dhd_open : the lock is released.
[   17.742300@3] [dhd] dhd_open: Exit wlan0 ret=0
[   17.746085@3] [dhd] [wlan0] tx queue started
[   17.752327@0] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   17.759009@0] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[   17.784807@4] audit: audit_lost=23 audit_rate_limit=5 audit_backlog_limit=64
[   17.786220@4] audit: rate limit exceeded
[   17.837024@2] Process ip granted CAP_NET_ADMIN from Android group net_admin.
[   17.838751@2]   Please update the .rc file to explictly set 'capabilities NET_ADMIN'
[   17.846300@2]   Implicit grants are deprecated and will be removed in the future.
[   17.853723@2] Process ip granted CAP_NET_ADMIN from Android group net_admin.
[   17.860953@2]   Please update the .rc file to explictly set 'capabilities NET_ADMIN'
[   17.868379@2]   Implicit grants are deprecated and will be removed in the future.
[   17.876322@2] Process ip granted CAP_NET_ADMIN from Android group net_admin.
[   17.882852@2]   Please update the .rc file to explictly set 'capabilities NET_ADMIN'
[   17.890580@2]   Implicit grants are deprecated and will be removed in the future.
[   17.898601@3] [dhd] P2P interface registered
[   17.902298@3] [dhd] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc009b68200, wdev->net:           (null)
[   17.922507@2] [dhd] WLC_E_IF: NO_IF set, event Ignored
[   17.969975@4] [dhd] Random MAC OUI to be used - da:1:19
[   17.981886@3] [dhd] dhd_dbg_attach_pkt_monitor, 1501
[   17.983473@3] [dhd] net_os_enable_packet_filter: val = 0
[   17.987543@3] [dhd] net_os_rxfilter_add_remove: add_remove = 0, num = 2
[   17.994906@3] [dhd] net_os_enable_packet_filter: val = 1
[   17.999008@3] [dhd] net_os_enable_packet_filter: val = 0
[   18.004623@3] [dhd] net_os_rxfilter_add_remove: add_remove = 0, num = 3
[   18.011882@4] [dhd] net_os_enable_packet_filter: val = 1
[   18.016133@5] [dhd] dhd_set_suspend: Remove extra suspend setting
[   18.022187@5] [dhd] dhd_enable_packet_filter: enter, value = 0
[   18.169018@0] selinux: avc:  denied  { set } for property=dhclient.ipaddress.wlan0 pid=3468 uid=1000 gid=1000 1
[   18.169018@0]
[   19.615616@0] audit: audit_lost=128 audit_rate_limit=5 audit_backlog_limit=64
[   19.617168@0] audit: rate limit exceeded
[   20.636781@4] zram0: detected capacity change from 0 to 268435456
[   20.670188@4] mkswap: Swapspace size: 262140k, UUID=9d72054c-2ea1-4580-8f37-f7f8585bfb18
[   20.670771@3] type=1400 audit(1293883218.344:174): avc: denied { write } for pid=4052 comm="dhclient" path="so1
[   20.670790@3] type=1400 audit(1293883219.408:176): avc: denied { getattr } for pid=4088 comm="preinstall.sh" p1
[   20.720419@4] Adding 262140k swap on /dev/block/zram0.  Priority:-1 extents:1 across:262140k SS
[   20.729291@4] type=1400 audit(1293883219.408:176): avc: denied { getattr } for pid=4088 comm="preinstall.sh" p1
[   20.752001@3] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 0, bssidx: 0
[   20.760285@4] type=1400 audit(1293883219.468:177): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   20.827322@5] type=1400 audit(1293883219.468:177): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   20.827490@4] selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)
[   20.827490@4]
[   20.829320@4] selinux: SELinux: Skipping restorecon_recursive(/data/misc_ce/0)
[   20.829320@4]
[   20.855935@5] type=1400 audit(1293883219.564:178): avc: denied { setattr } for pid=2438 comm="init" name="env"1
[   20.936986@3] type=1400 audit(1293883219.564:178): avc: denied { setattr } for pid=2438 comm="init" name="env"1
[   20.951259@3] type=1400 audit(1293883219.672:179): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   21.277405@4] audit: audit_lost=129 audit_rate_limit=5 audit_backlog_limit=64
[   21.277475@3] type=1400 audit(1293883219.672:179): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   21.295150@4] audit: rate limit exceeded
[   22.023376@5] adc_keypad adc_keypad: del older key => home:102:2:108:40
[   22.024402@5] adc_keypad adc_keypad: add newer key => home:3:2:108:40
[   26.274908@0] type=1400 audit(1687519094.107:196): avc: denied { open } for pid=3468 comm="CpuTracker" path="/1
[   26.292063@0] type=1400 audit(1687519096.115:197): avc: denied { write } for pid=4052 comm="dhclient" path="so1
[   26.317211@0] type=1400 audit(1687519096.115:197): avc: denied { write } for pid=4052 comm="dhclient" path="so1
[   26.337812@2] type=1400 audit(1687519096.115:198): avc: denied { sendto } for pid=4052 comm="dhclient" path="/1
[   26.356406@2] type=1400 audit(1687519096.115:198): avc: denied { sendto } for pid=4052 comm="dhclient" path="/1
[   26.375714@2] type=1400 audit(1687519096.115:199): avc: denied { create } for pid=4052 comm="dhclient" scontex1
[   26.396090@2] type=1400 audit(1687519096.115:199): avc: denied { create } for pid=4052 comm="dhclient" scontex1
[   26.412349@2] type=1400 audit(1687519096.115:200): avc: denied { ioctl } for pid=4052 comm="dhclient" path="so1
[   26.436330@3] type=1400 audit(1687519096.115:200): avc: denied { ioctl } for pid=4052 comm="dhclient" path="so1
[   26.459132@3] type=1400 audit(1687519096.115:201): avc: denied { write } for pid=4052 comm="dhclient" lport=541
[   40.761631@0] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 1, bssidx: 0
[   41.435903@0] type=1400 audit(1687519098.623:203): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   41.446833@5] type=1400 audit(1687519111.275:204): avc: denied { search } for pid=3468 comm="CpuTracker" name=1
[   41.467349@5] type=1400 audit(1687519111.275:204): avc: denied { search } for pid=3468 comm="CpuTracker" name=1
[   41.486976@5] type=1400 audit(1687519111.275:205): avc: denied { read } for pid=3468 comm="CpuTracker" name="s1
[   41.507656@5] type=1400 audit(1687519111.275:205): avc: denied { read } for pid=3468 comm="CpuTracker" name="s1
[   41.527212@5] type=1400 audit(1687519111.275:206): avc: denied { open } for pid=3468 comm="CpuTracker" path="/1
[   41.789934@4] type=1400 audit(1687519111.275:206): avc: denied { open } for pid=3468 comm="CpuTracker" path="/1
[   41.805526@4] type=1400 audit(1687519111.631:207): avc: denied { search } for pid=3468 comm="android.bg" name=1
[   41.826225@4] type=1400 audit(1687519111.631:207): avc: denied { search } for pid=3468 comm="android.bg" name=1
[   41.845957@4] type=1400 audit(1687519111.631:208): avc: denied { read } for pid=3468 comm="android.bg" name="s1
[   48.012357@3] type=1400 audit(1687519113.647:211): avc: denied { sigchld } for pid=1 comm="init" scontext=u:ob1
[   48.023249@3] type=1400 audit(1687519117.851:212): avc: denied { getpgid } for pid=1 comm="init" scontext=u:r:1
[   48.039671@3] type=1400 audit(1687519117.851:212): avc: denied { getpgid } for pid=1 comm="init" scontext=u:r:1
[   48.057307@3] type=1400 audit(1687519117.851:213): avc: denied { sigkill } for pid=1 comm="init" scontext=u:r:1
[   62.572250@4] fb: mem_free_work, free memory: addr:800000
[   80.764092@1] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 2, bssidx: 0
1 час назад, NicoD сказал:
I've got the full output of Armbian on SD and Android on eMMC
Tnx. I saw the reason what is missing to run Armbian if the default Android firmware is used. ^)
@balbes150 This is armbian on sd with empty eMMC and SPI. Boot loop.
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 12:28:00
Press CTRL-A Z for help on special keys
G12B:BL:6e7c85:2a3b91;FEAT:E0F83180:402000;POC:F;RCY:0;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:0;SD:.
        1
bl2_stage_init 0x81
hw id: 0x0000 - pwm id 0x01
bl2_stage_init 0xc1
bl2_stage_init 0x02
no sdio debug board detected
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 494759
BL2 Built : 19:23:21, Sep 18 2020. g12b g9fde858 - gongwei.chen@droid11-sz
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 0007d58b
board id: 6
Load FIP HDR DDR from SD, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
Get wrong ddr fw magic! Error!!
fw parse done
PIEI prepare done
fastboot data verify
result: 255
Cfg max: 12, cur: 1. Board id: 255. Force loop cfg
LPDDR4 probe
LPDDR4_PHY_V_0_1_22-Built : 14:57:26, Sep  1 2020. g12b g3c95fed - gongwei.chen@droid11-sz
ddr clk to 1608MHz
dmc_version 0001
Check phy result
INFO : ERROR : Training has failed!
Check phy result
Check phy result
INFO : End of initialization
1D training failed
Cfg max: 12, cur: 2. Board id: 255. Force loop cfg
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
INFO : End of CA training
INFO : Training has run successfully!
Check phy result
INFO : End of read enable training
INFO : End of fine write leveling
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of Write leveling coarse delay
INFO : End of read delay center optimization
Check phy result
INFO : End of write delay center optimization
INFO : End of max read latency training
1D training succeed
Check phy result
INFO : End of 2D read delay Voltage center optimization
INFO : End of 2D write delay Voltage center optimization
soc_vref_reg_value 0x 00000021 0000001f 00000021 00000023 00000020 00000021 00000021 0000001f 00000021 00000020 0
 dram_vref_reg_value 0x 00000048
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002cDDR size: 2048MB
cs0 DataBus test pass
cs0 AddrBus test pass
non-sec scramble use zero key
ddr scramble enabled
100bdlr_step_size ps== 409
result report
boot times 0Enable ddr reg access
Load FIP HDR from SD, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from SD, src: 0x00078200, des: 0x01768000, size: 0x000a2400, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
[Image: g12b_v1.1.3390-6ac5299 2019-09-26 14:10:05 luan.yuan@droid15-sz]
OPS=0x10
ring efuse init
chipver efuse init
29 0b 10 00 01 0c 0c 00 00 03 37 30 4e 42 4e 50
[0.018961 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):4fc40b1
NOTICE:  BL31: Built : 15:58:17, May 22 2019
NOTICE:  BL31: G12A normal boot!
NOTICE:  BL31: BL33 decompress pass
ERROR:   Error initializing runtime service opteed_fast
<debug_uart>
U-Boot 2022.07-armbian (May 27 2023 - 19:30:32 +0000) khadas-vim3
Model: Khadas VIM3
SoC:   Amlogic Meson G12B (A311D) Revision 29:b (10:2)
DRAM:  2 GiB
Core:  398 devices, 33 uclasses, devicetree: separate
MMC:   sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@ff3f0000
Card did not respond to voltage select! : -110
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
8147 bytes read in 3 ms (2.6 MiB/s)
## Executing script at 08000000
U-boot default fdtfile: amlogic/meson-g12b-a311d-khadas-vim3.dtb
Current variant:
224 bytes read in 1 ms (218.8 KiB/s)
Current fdtfile after armbianEnv: amlogic/meson-g12b-a311d-khadas-vim3.dtb
Mainline bootargs: root=UUID=bf2b5748-1fdf-468e-8f90-9eb3f62d8337 rootwait rootfstype=ext4 splash plymouth.ignore1
23250284 bytes read in 1050 ms (21.1 MiB/s)
27034112 bytes read in 1216 ms (21.2 MiB/s)
78594 bytes read in 8 ms (9.4 MiB/s)
232 bytes read in 3 ms (75.2 KiB/s)
Applying kernel provided DT fixup script (meson-fixup.scr)
## Executing script at 32000000
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   uInitrd
   Data Size:    23250220 Bytes = 22.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 04080000
   Booting using the fdt blob at 0x4080000
   Loading Ramdisk to 7a8ec000, end 7bf1852c ... OK
   Loading Device Tree to 000000007a870000, end 000000007a8ebfff ... OK
"Synchronous Abort" handler, esr 0x96000004
elr: 0000000001072cac lr : 00000000010625b8 (reloc)
elr: 000000007dfa6cac lr : 000000007df965b8
x0 : 78db79e78a1788c3 x1 : 000000007dfae958
x2 : 0000000000000010 x3 : 000000007bf433e0
x4 : 0000000000000000 x5 : 78db79e78a1788c3
x6 : 0000000005000000 x7 : 0000000000000007
x8 : 0000000000000000 x9 : 0000000000000008
x10: 00000000000001b4 x11: 000000007bf1cdfc
x12: 00000000000000a0 x13: 000000007bf1cdb8
x14: 000000007a870000 x15: 0000000000000020
x16: 000000007df3e264 x17: 0000000000000000
x18: 000000007bf31da0 x19: 000000007af1d040
x20: 000000007df34b18 x21: 000000007dfae958
x22: 0000000000000300 x23: 000000007bf43330
x24: 000000007dfd3cf0 x25: 0000000000300000
x26: 0000000005000000 x27: 0000000000000000
x28: 0000000000000300 x29: 000000007bf1cdc0
Code: eb04005f 54000061 52800000 14000006 (386468a3)
Resetting CPU ...
resetting ...
bl31 reboot reason: 0xd
bl31 reboot reason: 0x0
system cmd  1.
        1
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 279894
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 00048e3a
board id: 6
fw parse done
PIEI prepare done
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000021 0000001f 00000021 00000023 00000020 00000021 00000021 00000020 00000021 00000020 0
 dram_vref_reg_value 0x 00000047
2D training succeed
DDR cs1 size: 0MB
result report
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[1.091273 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
Current variant:
224 bytes read in 2 ms (109.4 KiB/s)
78594 bytes read in 7 ms (10.7 MiB/s)
   Image Name:   uInitrd
Resetting CPU ...
resetting ...
system cmd  1.
        1
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 279920
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 00048e54
board id: 6
fw parse done
PIEI prepare done
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000022 0000001f 00000021 00000023 00000020 00000021 00000020 0000001f 00000021 00000020 0
2D training succeed
DDR cs1 size: 0MB
result report
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[1.090845 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
Current variant:
   Image Name:   uInitrd
Resetting CPU ...
resetting ...
system cmd  1.
        1
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 281221
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 00049369
board id: 6
fw parse done
PIEI prepare done
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000022 0000001f 00000021 00000023 00000020 00000021 00000021 0000001f 00000021 00000020 0
2D training succeed
DDR cs1 size: 0MB
result report
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[1.092170 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
Current variant:
   Image Name:   uInitrd
Resetting CPU ...
resetting ...
system cmd  1.
        1
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 281342
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 000493e3
board id: 6
fw parse done
PIEI prepare done
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000021 0000001f 00000020 00000023 00000020 00000021 00000021 00000020 00000021 00000020 0
2D training succeed
DDR cs1 size: 0MB
100bdlr_step_size ps== 398
result report
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[1.092292 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
Current variant:
78594 bytes read in 6 ms (12.5 MiB/s)
   Image Name:   uInitrd
Resetting CPU ...
resetting ...
system cmd  1.
        1
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 280639
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 00049123
board id: 6
fw parse done
PIEI prepare done
result: 255
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
2D training succeed
DDR cs1 size: 0MB
100bdlr_step_size ps== 403
result report
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[1.091677 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
Current variant:
With this, too, everything is clear, tomorrow I will try to send you a correction.
3 hours ago, balbes150 said:
That works.
Empty eMMC and empty SPI with latest Armbian on SD :
OPTIONS: I18n
Port /dev/ttyUSB0, 19:23:38
G12B:BL:6e7c85:2a3b91;FEAT:E0F83180:402000;POC:F;RCY:0;EMMC:0;READ:0;0.
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 248088
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 000411fc
eMMC boot @ 0
sw8 s
board id: 6
Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
 NO find ddr boot_info from eMMC
result: 255
LPDDR4 probe
ddr clk to 1608MHz
00000000
emmc switch 0 ok
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000021 0000001f 00000020 00000022 00000020 00000021 00000020 0000001f 00000021 0000001f 0
2D training succeed
DDR cs1 size: 0MB
result report
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000a8400, part: 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[0.018960 Inits done]
secure task start!
high task start!
low task start!
run into bl31
U-Boot 2021.04 (Dec 29 2022 - 05:09:22 +0000) khadas-vim3
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
fusb302_init: Device ID: 0x91
CC connected in 1 as UFP
fusb302 detect chip.port_num = 0
Failed to load 'splash.bmp'
** Invalid partition 2 **
Can't set block device
1080138 bytes read in 26 ms (39.6 MiB/s)
DISPLAY: setup failsave FullHD mode
starting USB...
Bus usb@ff500000: Register 3000140 NbrPorts 3
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 3 USB Device(s) found
Setting bus to 0
Hit SPACE in 2 seconds to stop autoboot
Device 0: unknown device
Scanning mmc 1:1...
Welcome to ARMBIAN!
Documentation: https://docs.armbian.com | Community: https://forum.armbian.com
IP address:
Create root password:
I will now install Android on eMMC and see if that also boots. Thank you.
14 часов назад, NicoD сказал:
Also works with Android on the eMMC
Can you check the installation on eMMC and show the startup log UART from eMMC, after installing Armbian on eMMC on the original Android ? To install, use armbian-install.
22.06.2023 в 21:46, NicoD сказал:
There's also no HDMI-audio but a dummy output. I'd like to see that fixed too if possible. Cheers.
To fix the sound, need to check the kernel. Is there a version of the image where the sound worked?
@balbes150 Unable to install to eMMC
"Partition too small. Needed: 5124 MB Available: MB"
I've formatted the eMMC and created a partition but still the same. The eMMC is 16GB, so should be enough.
43 минуты назад, NicoD сказал:
What size SD card do you use? Which installation option do you choose ? Which partition table did you use (msdos or gpt) for eMMC? Try to create an MS DOS table and not create any partitions on eMMC. This error is another confirmation that the images from the MAIN branch are useless junk.
64GB sd but only 5GB is needed.  16GB eMMC
Boot from eMMC system on eMMC
It now works after installing Ubuntu 22.04 with OOWOW on eMMC and then boot Armbian from sd and do armbian-install to eMMC
But it doesn't boot the image from eMMC and doesn't boot the sd-card anymore either with Armbian +  boot.ini file on.
I can still boot the OOWOW sd-card. Will try again to install Ubuntu, boot armbian from sd, delete partition on eMMC and create a MS DOS table and no partition...
@balbes150 I now was able to install Armbian on eMMC from sd-card with Ubuntu 22.04 on eMMC.
But after the install it doesn't boot from eMMC. Boot-loop.
Here the output :
OPTIONS: I18n
Port /dev/ttyUSB0, 14:53:13
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 154705
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 0002a535
eMMC boot @ 0
sw8 s
board id: 6
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
result: 255
LPDDR4 probe
ddr clk to 1608MHz
00000000
emmc switch 0 ok
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000021 0000001f 00000020 00000023 00000020 00000021 00000020 0000001f 00000021 00000020 0
2D training succeed
DDR cs1 size: 0MB
result report
00000000
emmc switch 3 ok
00000000
emmc switch 0 ok
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000a2400, part: 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
resetting ...
system cmd  1.
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 153084
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 00029ee1
eMMC boot @ 0
sw8 s
board id: 6
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
result: 255
LPDDR4 probe
ddr clk to 1608MHz
00000000
emmc switch 0 ok
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000021 0000001f 00000020 00000023 00000020 00000021 00000020 0000001f 00000021 00000020 00000020 00000021 00000021 00000022 00000021 00000021 00000022 00000023 00000022 00000020 00000021 00000020 00000021
2D training succeed
DDR cs1 size: 0MB
result report
00000000
emmc switch 3 ok
00000000
emmc switch 0 ok
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[0.864765 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
mmc2(part 0) is current device
Scanning mmc 2:1...
8147 bytes read in 2 ms (3.9 MiB/s)
Current variant:
Mainline bootargs: root=UUID=415b019c-7094-46d2-a6f5-451718fbf1e4 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart=0eed7ada-01
23249039 bytes read in 507 ms (43.7 MiB/s)
27034112 bytes read in 590 ms (43.7 MiB/s)
78594 bytes read in 4 ms (18.7 MiB/s)
232 bytes read in 2 ms (113.3 KiB/s)
   Image Name:   uInitrd
   Data Size:    23248975 Bytes = 22.2 MiB
   Loading Ramdisk to 7a8ec000, end 7bf1804f ... OK
x0 : 25879f511fd592ba x1 : 000000007dfae958
x4 : 0000000000000000 x5 : 25879f511fd592ba
Resetting CPU ...
resetting ...
system cmd  1.
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 152754
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 00029d96
eMMC boot @ 0
sw8 s
board id: 6
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
result: 255
LPDDR4 probe
ddr clk to 1608MHz
00000000
emmc switch 0 ok
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
soc_vref_reg_value 0x 00000022 0000001f 00000021 00000023 00000020 00000021 00000020 0000001f 00000021 00000020 00000020 00000021 00000021 00000022 00000021 00000021 00000023 00000023 00000022 00000020 00000021 00000020 00000021
2D training succeed
DDR cs1 size: 0MB
result report
00000000
emmc switch 3 ok
00000000
emmc switch 0 ok
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[0.864855 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 2:1...
8147 bytes read in 1 ms (7.8 MiB/s)
Current variant:
78594 bytes read in 3 ms (25 MiB/s)
   Image Name:   uInitrd
Resetting CPU ...
resetting ...
system cmd  1.
        bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:20000703
L2:00008067
L3:14000000
B2:00402000
B1:e0f83180
TE: 152763
Board ID = 6
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 00029da0
eMMC boot @ 0
sw8 s
board id: 6
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
result: 255
LPDDR4 probe
ddr clk to 1608MHz
00000000
emmc switch 0 ok
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 1608MHz
dmc_version 0001
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
2D training succeed
DDR cs1 size: 0MB
result report
00000000
emmc switch 3 ok
00000000
emmc switch 0 ok
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x10
ring efuse init
chipver efuse init
[0.864444 Inits done]
secure task start!
high task start!
low task start!
run into bl31
<debug_uart>
Model: Khadas VIM3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 2:1...
Current variant:
