balbes150 Posted August 28, 2023 Author Posted August 28, 2023 18 часов назад, AndyW сказал: Everything was fine except didn't get desktop on HDMI once with the xfce image. 17 часов назад, AndyW сказал: Can't get 20230825-current xfce desktop to boot. I have 8G. Note I'm still on u-boot 3.1.5. as I can't update using your updater, as per previous posts. I am testing the launch only with the u-boot that comes from the factory (with a single launch of the update), I do not control why the new versions of u-boot do not work correctly. Perhaps the reason for the incorrect operation of HDMI is errors in u-boot 3.x, try to roll back u-boot to version 2.11.5, NVMe works in this version and there have been no reports of problems with HDMI. 17 часов назад, AndyW сказал: Which is the "correct file"? The one on the SD Card appears to be the same as the one I downloaded today: 25.08.2023 в 11:17, balbes150 сказал: for those who want to launch the "official" Armbian (image versions from the official download page), this is very easy to do. Update u-boot according to the instructions in the first message (if you have already done this, you can skip this step). Download the official Armbian image, unpack, burn to the SD card, download 0 Quote
balbes150 Posted August 29, 2023 Author Posted August 29, 2023 Version 20230829-current with kernel 6.5. Expanded the list of sound modules and codecs (USB\PCIe). 0 Quote
AndyW Posted September 3, 2023 Posted September 3, 2023 On 8/28/2023 at 2:24 AM, balbes150 said: try to roll back u-boot to version 2.11.5 Sorry about the delay, was on vacation. I did install 2.11.5 and your updater then worked. However, I am still unable to run anything with kernel 6.5. All other releases work fine. I played a bit and found that with kernel 6.5, if I replace the regular dtb (jh7110-starfive-visionfive-2-v1.3b.dtb) with the 4Gig one (jh7110-starfive-visionfive-2-v1.3b-4gb.dtb), unplug the video and start the board it starts okay, and if I then plug in the video it works. But if I leave the video plugged in it fails the same way as with the regular dtb. The console output is the same as I provided before. If I leave the video unplugged with the 8Gig dtb it also fails as before. Maybe I have a defective board. 0 Quote
balbes150 Posted September 7, 2023 Author Posted September 7, 2023 03.09.2023 в 23:28, AndyW сказал: I did install 2.11.5 and your updater then worked. However, I am still unable to run anything with kernel 6.5. All other releases work fine. I have not tested the work of u-boot 2.11.5, but with the default u-boot + update, everything works with all kernel versions, including 6.5. Show the UART log of running kernel 6.5 from 2.11.5. 0 Quote
AndyW Posted September 8, 2023 Posted September 8, 2023 15 hours ago, balbes150 said: Show the UART log of running kernel 6.5 from 2.11.5 I've included a few files in case it helps. This is just after downgrading to 2.11.5, rebooting to u-boot, then defaulting and saving the environment: 1 - 2.11.5-UBoot-clean-before-update-printenv.log 2 - 2.11.5-Doing-update-and-printenv.log 3 - 6.5-Normal-startup-fails.log - normal startup with monitor, keyboard and mouse plugged in. This fails. 4 - 6.5-Startup-HDMI_KB_Mouse_Unplugged.log - starts okay, get login prompt on UART console. Plug in monitor, no video. Login and neofetch below (doesn't show up well in log with my terminal emulator): Armbian 23.06 Lunar ttyS0 starfive2 login: root Password: __ ___ _ _____ _ ____ \ \ / (_)___(_) ___ _ __ | ___(_)_ _____|___ \ \ \ / /| / __| |/ _ \| '_ \| |_ | \ \ / / _ \ __) | \ V / | \__ \ | (_) | | | | _| | |\ V / __// __/ \_/ |_|___/_|\___/|_| |_|_| |_| \_/ \___|_____| Welcome to Armbian 23.06 Lunar with Linux 6.5.0-rc1-star64 No end-user support: built from trunk System load: 2% Up time: 16 min Memory usage: 1% of 7.76G IP: 192.168.2.164 CPU temp: 37°C Usage of /: 2% of 58G [ Menu-driven system configuration (beta): sudo apt update && sudo apt install a rmbian-config ] Last login: Thu Sep 7 18:49:20 EDT 2023 on ttyS0 root@starfive2:~# neofetch root@starfive2 -------------- O O OS: Armbian 23.06 Lunar riscv64 ##### Host: StarFive VisionFive 2 v1.3B ####### Kernel: 6.5.0-rc1-star64 ########## Uptime: 16 mins ############ Packages: 352 (dpkg) ############ Shell: bash 5.2.15 ## ########### # Terminal: /dev/ttyS0 ###### ####### ###### CPU: (4) ####### ##### ####### Memory: 88MiB / 7948MiB ##### ##### root@starfive2:~# I've also tried the same steps with u-boot 3.0.4 and 3.1.5, but it makes no difference. 2.11.5-UBoot-clean-before-update-printenv.log 2.11.5-Doing-update-and-printenv.log 6.5-Normal-startup-fails.log 6.5-Startup-HDMI_KB_Mouse_Unplugged.log 0 Quote
balbes150 Posted September 9, 2023 Author Posted September 9, 2023 08.09.2023 в 03:12, AndyW сказал: 3 - 6.5-Normal-startup-fails.log - normal startup with monitor, keyboard and mouse plugged in. This fails. which monitor do you use ? 0 Quote
AndyW Posted September 9, 2023 Posted September 9, 2023 5 hours ago, balbes150 said: which monitor do you use ? I have a Philips 227E-QPH, 1080p IPS display. I also thought this may be the issue so tried my main monitor, an AOC AGON AG271QX 1440p monitor, but it makes no difference. 0 Quote
balbes150 Posted September 20, 2023 Author Posted September 20, 2023 Version 20230920-legacy with kernel 5.15.130 0 Quote
AndyW Posted September 21, 2023 Posted September 21, 2023 Tested 5.15.130, lunar and sid and both worked fine. 0 Quote
balbes150 Posted September 22, 2023 Author Posted September 22, 2023 Version 20230922-edge with kernel 6.6-rc1 I also added images to update the latest official version of u-boot 3.6.1 for SPI\Flash to easily run any system on VF2 from an SD card and NVMe. After switching to u-boot-3.6.1 and updating using the provided update images, you can easily install Armbian on NVMe and run the entire system with NVMe. The procedure for switching to u-boot is 3.6.1. Update u-boot in SPI\Flash according to the instructions from the official VF2 documentation page. Download, write to the SD card and run two images sequentially - first run reset-default-env-uboot-visionfive2-3.6.1.img (after launching the update, wait 10-20 seconds and turn off the power), then write to the SD card and run update_uboot-visionfive2-3.6.1.img (after launching the update, wait 10-20 seconds and turn off the power). After these procedures, you can easily run Armbian SD cards or install it on NVMe (using the standard armbian-config mechanism and choose the installation option on MTD\SATA\NVMe). Please note, for proper installation on NVMe, a section must be prepared there, i.e. the installation process corresponds to the description of the Armbian installation documentation on NVMe. It is possible to add the u-boot upgrade procedure to the standard armbian-config procedure for installing the system on NVMe, so that the whole process takes place automatically, but I have not yet decided whether to add it or leave the u-boot upgrade process in SPI, as described in the documentation for VF2 Please note that these updates do not violate the previous official launch procedure in u-boot SPI\Flash. Link image update https://disk.yandex.ru/d/O4lr6WrGdUvydw 0 Quote
AndyW Posted September 23, 2023 Posted September 23, 2023 @balbes150 Tried the above but it didn't work for me. As per your instructions above I: - Changed firmware to 3.6.1 - Burned SD card with "reset-default-env-uboot-visionfive2-3.6.1.img" and booted, then turned device off. Attached file "boot-reset-default.txt" shows this. - Burned SD card with "update_uboot-visionfive2-3.6.1.img" and booted, then turned device off. Attached file "boot-update-uboot.txt" shows this - Booted again (stopped autoboot by hitting key) and did a "printenv" so you can see if the changes above worked, then turned device off. Attached file "boot-printenv.txt" shows this - Burned SD card with "Armbian_23.09_Starfive2_lunar_edge_6.6.0.img.xz" and booted, which failed. Attached file "boot-lunar_edge_6.6.0-failed.txt" shows this So, had a look at the "printenv" output and found nothing "runs" your new env variables "boot_mmc_new", "boot_emmc_new", or "boot_nvme_new"! I also noticed that in the failed boot log the message "## Error: "boot2" not defined". So I booted again, stopped autoboot, did a "setenv boot2 run boot_mmc_new", then "env save", booted again and it worked! Attached file "boot-lunar_edge_6.6.0-worked.txt" shows this. I don't think this is the correct way to "fix" this issue, but it works. Let me know if I did something wrong. boot-reset-default.txt boot-update-uboot.txt boot-printenv.txt boot-lunar_edge_6.6.0-failed.txt boot-lunar_edge_6.6.0-worked.txt 1 Quote
balbes150 Posted September 24, 2023 Author Posted September 24, 2023 17 часов назад, AndyW сказал: Booted again (stopped autoboot by hitting key) and did a "printenv" so you can see if the changes above worked, then turned device off. Attached file "boot-printenv.txt" shows this Thanks for testing, I see the bootcmd variable has not been updated. It looks like one line was lost when creating the variable update image. Now I will fix the images and upload them to the site. Replaced the images with corrected versions. Run both images again (reset settings and update variables). After that, everything should work without manual additions. 0 Quote
AndyW Posted September 24, 2023 Posted September 24, 2023 @balbes150 No problem on testing as that's what I do for work, along with maintaining an old C++/MFC program. Yes, that change did it, thanks. Still learning the boot environment so good to know how "bootcmd" is used. 0 Quote
balbes150 Posted September 24, 2023 Author Posted September 24, 2023 Version 20230924-current with kernel 6.1.31 work HDMI USB LAN etc 0 Quote
AndyW Posted September 25, 2023 Posted September 25, 2023 Tested "Armbian_23.09_Starfive2_lunar_current_6.1.31_xfce_desktop.img.xz" and it works well. Video appears to be a bit better as I can play back a 720p video, though not full 720p size. Sound is still great on HDMI and crackly on the jack. Did you want feedback on which programs work/don't work? __ ___ _ _____ _ ____ \ \ / (_)___(_) ___ _ __ | ___(_)_ _____|___ \ \ \ / /| / __| |/ _ \| '_ \| |_ | \ \ / / _ \ __) | \ V / | \__ \ | (_) | | | | _| | |\ V / __// __/ \_/ |_|___/_|\___/|_| |_|_| |_| \_/ \___|_____| Welcome to Armbian 23.09 Lunar with Linux 6.1.31-star64 No end-user support: built from trunk System load: 44% Up time: 5 min Memory usage: 5% of 7.72G IP: 192.168.2.164 CPU temp: 39°C Usage of /: 8% of 58G [ General system configuration (beta): armbian-config ] Last login: Sun Sep 24 16:58:11 EDT 2023 on ttyS0 root@starfive2:~# neofetch root@starfive2 -------------- ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ OS: Armbian (23.09) riscv64 ¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦ Host: StarFive VisionFive V2 __¦¦ ¦¦__ Kernel: 6.1.31-star64 __¦¦ ¦¦¦¦¦¦¦¦¦¦¦ ¦¦__ Uptime: 6 mins __¦¦ ¦¦ ¦¦ ¦¦__ Packages: 1514 (dpkg) __¦¦ ¦¦ ¦¦ ¦¦__ Shell: bash 5.2.15 __¦¦ ¦¦ ¦¦ ¦¦__ Resolution: 1920x1080 __¦¦ ¦¦¦¦¦¦¦¦¦¦¦¦¦ ¦¦__ Terminal: /dev/ttyS0 __¦¦ ¦¦ ¦¦ ¦¦__ CPU: (4) @ 1.500GHz __¦¦ ¦¦ ¦¦ ¦¦__ Memory: 425MiB / 7908MiB __¦¦ ¦¦ ¦¦ ¦¦__ __¦¦ ¦¦__ ¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ root@starfive2:~# 1 Quote
bigtreeman Posted September 30, 2023 Posted September 30, 2023 Now able to boot Armbian from usb, with my u-boot mods boot order sd, usb, nvme, emmc, but unable to test emmc. Armbian_23.8.1_Visionfive2_jammy_edge_5.15.0.img Therefore TZ='Australia/Brisbane' will be used. Selected time is now: Fri Sep 1 05:10:21 AEST 2023. Universal Time is now: Thu Aug 31 19:10:21 UTC 2023. Is the above information OK? 1) Yes 2) No #? 1 Generating locales: en_AU.UTF-8 root@visionfive2:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 1 28.7G 0 disk └─sda1 8:1 1 28.4G 0 part /var/log.hdd / mtdblock0 31:0 0 256K 0 disk mtdblock1 31:1 0 3M 0 disk mtdblock2 31:2 0 1M 0 disk nvme0n1 259:0 0 238.5G 0 disk ├─nvme0n1p1 259:1 0 16M 0 part └─nvme0n1p4 259:2 0 238.4G 0 part 0 Quote
balbes150 Posted September 30, 2023 Author Posted September 30, 2023 6 часов назад, bigtreeman сказал: Armbian_23.8.1_Visionfive2_jammy_edge_5.15.0.img These images are not relevant to this topic. 0 Quote
Arkadi Posted October 20, 2023 Posted October 20, 2023 (edited) Thank you for your work! I've tested Armbian_23.09_Starfive2_lunar_current_6.1.31_xfce_desktop.img.xz Armbian_23.09_Starfive2_lunar_legacy_5.15.131_xfce_desktop.img.xz images on a 8GB VisionFive 2 with stock U-Boot (2021.10, Dec 19 2022) and it works reasonably well, modulo minor oddities with mouse cursor offset in Xfce. I also upgraded SPI flash to 3.7.5 via TFTP, presumably keeping the env, and the board booted successfully (from an SD card). Any particular reason now to choose legacy over current image? Also, could be generic Armbian issue yet during initial setup when I agreed to set timezone and locale from auto-detected location, the ~user/.xsessionrc file were created with root:root ownership. --------EEPROM INFO-------- Vendor : StarFive Technology Co., Ltd. Product full SN: VF7110B1-2253-D008E000-00001794 data version: 0x2 PCB revision: 0xb2 BOM revision: A Edited October 20, 2023 by Arkadi 0 Quote
jiapei100 Posted November 13, 2023 Posted November 13, 2023 (edited) My ESWIN 6600U is detected but nmcli device show doesn't show anything related to wireless, say wlan0 ??? % ip link set dev wlan0 up gave me an output: Cannot find device "wlan0" Does Armbian_23.09_Starfive2_sid_edge_6.6.0.img.xz working already build in the driver for ESWIN 6600U? Cheers Edited November 13, 2023 by jiapei100 No Markdown? 0 Quote
jiapei100 Posted November 19, 2023 Posted November 19, 2023 How to build Linux Kernel 6.6.1 for VisionFive2 ? https://www.armbian.com/visionfive2/ comes with a kernel 5.x? And I followed https://rvspace.org/en/project/Building_StarFive_Debian_Image, However, the default kernel provided by is of version 5.15. But, you NEWEST release is of kernel 6.6.0 . So, can you please provide a documentation? And how did you manage to build this out? Can you @balbes150 please help??? Thank you .. 0 Quote
balbes150 Posted November 20, 2023 Author Posted November 20, 2023 14.11.2023 в 00:59, jiapei100 сказал: doesn't show anything related to wireless, say wlan0 ??? I don't have such equipment, I have no idea what it requires. 0 Quote
balbes150 Posted November 24, 2023 Author Posted November 24, 2023 Ver 20231123 legacy and current 0 Quote
Arkadi Posted November 29, 2023 Posted November 29, 2023 (edited) @jiapei100 speaking from experience: ESWIN driver is bad software put someone in a haste from proprietary legacy drivers for the purpose of shipping some Wi-Fi with VisionFive 2 and then abandoned -- it's slow, buggy, lock-ups after little use and then oops the kernel. Suggest a different well supported USB stick that has in-tree driver, or a wire. https://github.com/eswincomputing/eswin_6600u Edited November 29, 2023 by Arkadi 0 Quote
Arkadi Posted June 18, 2024 Posted June 18, 2024 FTR, ESWIN driver disappeared from GitHub - here is a copy: https://github.com/arkadijs/eswin_6600u 0 Quote
rupy Posted August 22, 2024 Posted August 22, 2024 Hi, has anyone tried the GPU? Does glxgears work f.ex.? 0 Quote
Arkadi Posted September 4, 2024 Posted September 4, 2024 (edited) Short answer: no, there are no proper GPU drivers. 1. With latest Armbian Desktop image from Download section it's XFCE, Xorg and modesetting driver with Glamor accel enabled (by default) on softpipe making it extremely siow. To disable Glamor: /etc/X11/xorg.conf.d/00-no-glamor.conf Section "Device" Identifier "gpu" Driver "modesetting" Option "AccelMethod" "none" EndSection 2. With the official Debian image from StarFive it's GNOME, Wayland and proprietary PowerVR driver. Driver: pvr (Imagination Technologies PVR DRM) version 1.19.6345021 (20170530) -- GPU Driver: starfive (VeriSilicon DRM driver) version 1.0.0 (20191101) -- CRTC and Encoders There is some Vulkan 1.0 but it's not working, no OpenGL, and flaky OpenGL ES. Imagination Technologies produced Mesa driver via powervr-next initiative for 3 Rogue GPUs, but not the model used in JH7110 (BXE-4-32). I guess StarFive are doing their best with what they have been handed over -- an unmaintained binary driver from ImgTec. If history is of any indication, then similar approach went nowhere with Creator CI20 MIPS SBC, from the ImgTec themselves in 2015. https://forum.rvspace.org/t/visionfive-2-debian-202405-released/4329/57 https://forum.rvspace.org/t/opensuse-tumbleweed-with-ati-radeon-r9-290-mainline-kernel/4545 Edited September 4, 2024 by Arkadi 0 Quote
