Armbian for Amlogic S805 and S802/S812
masteripper
Balbes150, thank you for the mailing list link, it's very informative.
For SDHC support on xdarklight's latest kernel on the meson-mx-integration-5.8-20200411 branch, (Linux-5.6.0-367105-ge753682cfb70) it's necessary to enable MMC_MESON_MX_SDHC and COMMON_CLK_MESON_MX_SDHC for SDHC support.
I had made the mistake of using multi_v7_defconfig, which of course does not include such new options. Now I made a meson32 .config from scratch.
There is still much work for me to do on the DTB necessary to get regulator, DVFS, frequency scaling and all interrupts working correctly, but the iperf3 tests show about 94 Mbit/sec on 100Mbit link in each direction, with no re-tries.
Emulti
@Emulti It looks like you have a lot of experience with DTS/DTB, I'm still trying to activate my wlan chip(RTL8723) that runs on SDIO. I've already taken a lot of information from the DTS in the kernel 3.xx but it's still not recognized(IRQ ; GPIO; SELECT PIN). Have you already read or reached something in this direction ?
Good news. :)
Thanks to the work done by Martin and the developers of Libreelec (Chewitt etc). An early alpha version of Libreelec with a 5.6 core is now available.This version is intended for General evaluation of the system's ability to run on s805\s802\s812. This version uses a new DTB configuration mechanism that is common with the latest Armbian versions for all RK+AW+AML platforms. You need to edit the file to configure it (uEnv.txt). If you want to test this system, I can give you a link to the images (provided that there is a report on the results of the launch). If multi-loading is already enabled on your device, the system should start automatically after setting up DTB.
18 minutes ago, balbes150 said:
Good news. :)
Good news. :)
Is it possible to test S812H (Wetek Core)? As i understood its version of dualboot LibreElec and Armbian?
Little request. Is there any simple step by step guid how to enable multi-boot? I read almost all and there are just links to other links. I didnt find guid how to enable it. Is it one file?
On 4/30/2020 at 1:33 PM, RaptorSDS said:
is the change back to ambian without problems ? i read that sometime people start libreelec and than have problems booting armbian again on 3.xx kernel
There are no compatibility problems between Libreelec and Armbian in principle (these are friendly systems that help each other develop). You may have confused it with the launch of corelec. Yes, there is a big problem from this launch on the AML s9xx platform. After that, you need to completely restore the regular Android firmware and re-activate the universal multi-boot.
This should also work on Wetek (s812).
No, it's not two systems together. This is an option to run both of these systems on S8xx (if multi-boot is enabled). As part of  image LE is files to activate the multi-boot. But for Wetek (if I'm not confused), additional steps are needed (and perhaps add file). Details on how to activate multi-boot on Wetek is on the forum LE in the topic about s812 (there you can also take the necessary file).
Test Image LE for s8xx (s805 s802 s812) dir *-s8xx
https://yadi.sk/d/8vNYuuxynz1L0w
UART LOG with meson8m2-m8s.dtb
Spoiler
QA9:A;SVN:74E;POC:3FF;STS:0;BOOT:0;INIT:0;READ:0;CHECK:0;PASS:0;
no sdio debug board detected
TE : 25587
BT : 10:46:23 Sep 25 2015
PMU:rn5t618
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
DC01 v:1100, 0x[36]: 00 -> 28
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
DC02 v:1150, 0x[37]: 00 -> 2c
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
DC03 v:1500, 0x[38]: 00 -> 48
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
LDO01 v:2900, 0x[4c]: 00 -> 50
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
LDO02 v:1800, 0x[4d]: 00 -> 24
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
LDO03 v:1800, 0x[4e]: 00 -> 30
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
LDO04 v:2850, 0x[4f]: 00 -> 4e
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
LDO05 v:1800, 0x[50]: 00 -> 24
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
LDO0a v:2700, 0x[56]: 00 -> 28
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
LDO0b v:900, 0x[57]: 00 -> 00
-- i2c error, CTRL:
0798d019
CPU clock is 1200MHz
CPU type: M8M2
DDR info: 2GB(auto) @ 792MHz(1T)
DDR channel: DDR 0 + DDR 1
DDR init use : 12264 us
HHH
ucl decompress...pass
0x12345678
Boot from internal device 1st NAND
TE : 218338
System Started
U-boot-00000-g23a3562-dirty(m8_k200_v1@23a35625) (Sep 25 2015 - 10:46:14)
clr h-ram
DRAM:  2 GiB
relocation Offset is: 6fec0000
show partition table:
part: 0, name :       logo, size : 2000000
part: 1, name :   recovery, size : 2000000
part: 2, name :       misc, size : 2000000
part: 3, name :       boot, size : 2000000
part: 4, name :     system, size : 40000000
part: 5, name :      cache, size : 20000000
part: 6, name :       data, size : end
aml_card_type=0x100
MMC:   [mmc_register] add mmc dev_num=0, port=1, if_type=6
[mmc_register] add mmc dev_num=1, port=2, if_type=6
SDIO Port B: 0, SDIO Port C: 1
[RN5T618]rn5t618_read: i2c transfer failed, ret:-5
[RN5T618]rn5t618_write: i2c transfer failed, ret:-5
PMU fault status:
-- N_OEPOF
reg[0x9A] = 0x81
[RN5T618]rn5t618_reads: i2c transfer failed, ret:-5
LSI version:00, OTP version:00
PMU type:RN5T618
[RN5T618]rn5t618_writes: i2c transfer failed, ret:-5
register usb cfg[0][1] = 7ff6fc9c
register usb cfg[2][0] = 7ff731ac
NAND:  NAND BOOT: boot_device_flag 1
Nand PHY driver Version: 1.01.001.0004 (c) 2013 Amlogic Inc.
amlnf_phy_init : amlnf init flag 0
NAND device id: 45 de 94 93 76 57 9 4
detect NAND device: A serials NAND 8GiB SDTNQGAMA-008G
nand chip ce mask 1
AML_NAND_NEW_OOB : new oob
bus_cycle=6, bus_timing=8,system=4.7ns,flash->T_REA =20,flash->T_RHOH=25
NAND CKECK  : arg nbbt: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0
NAND CKECK  : arg ncnf: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 0
NAND CKECK  : arg nkey: arg_valid= 1, valid_blk_addr = 8, valid_page_addr = 13
i=0,register --- nand_key
NAND CKECK  : arg nenv: arg_valid= 1, valid_blk_addr = 7, valid_page_addr = 115
nfboot    : offset: 0x000000000000 -0x000001000000 : partitons 0 : single_chip single_plane
nfcache   : offset: 0x00000d000000 -0x000026000000 : partitons 1 : single_chip multi_plane
nfcode    : offset: 0x000033000000 -0x000053000000 : partitons 5 : single_chip multi_plane
nfdata    : offset: 0x000086000000 -0x00017a000000 : partitons 1 : single_chip multi_plane
bad block count = 0
bad block count = 0
bad block count = 0
bad block count = 0
amlnf_logic_init: START
aml_nftl_start:117,size_in_blk=76,tmp_block=65,part->free_block_num=11
aml_nftl_start:117,size_in_blk=163,tmp_block=144,part->free_block_num=19
amlnf_logic_init:  COMPLETE
get_boot_device_flag: init_ret 0
get_boot_device_flag NAND BOOT:
NAND BOOT,nand_env_relocate_spec : env_relocate_spec 49
uboot env amlnf_env_read : ####
set_storage_device_flag: store 1
      Multi dtb tool version: v2 .
      Multi dtb detected, support 6 dtbs.
        aml_dt soc: m8m2 platform: n200 variant: 2G
        dtb 0 soc: m8                 plat: k200               vari: 2gsdhc
        dtb 1 soc: m8                 plat: k200               vari: 2gsdio
        dtb 2 soc: m8                 plat: k200               vari: sdhc
        dtb 3 soc: m8                 plat: k200               vari: sdio
        dtb 4 soc: m8m2               plat: n200               vari: 1G
        dtb 5 soc: m8m2               plat: n200               vari: 2G
      Find match dtb: 5
vpu driver detect cpu type: m8m2
vpu clk_level in dts: 7
set vpu clk: 364000000Hz, readback: 364000000Hz(0x700)
Net:   Meson_Ethernet
init suspend firmware done. (ret:0)
cvbs trimming.1.v5: 0xa0, 0x0
cvbs performance use table = 0
vdac open.1 = 0x1, 0x0
config HPLL
config HPLL done
reboot_mode=charging
efuse version is not selected.
Hit Enter key to stop autoboot -- :  0
exit abortboot: 0
(Re)start USB(0)...
USB:   dwc_usb driver version: 2.94 6-June-2012
USB (1) peri reg base: c1108820
USB (1) use clock source: XTAL input
USB (1) base addr: 0xc90c0000
Force id mode: Host
dwc_otg: Fullspeed device found !
scanning bus for devices... dwc_otg: submit_control_msg: control status phase error (ret = -1)
No USB Device found
       scanning bus for storage devices... 0 Storage Device(s) found
** Invalid boot device **
 sdio_detect return 1
[mmc_init] SDIO Port B:0, if_type=7, initialized OK!
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Name: Tran Speed: 20000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7780433920
Boot Part Size: 0
Bus Width: 4-bit
reading s805_autoscript
744 bytes read
## Executing script at 11000000
start amlogic old u-boot
mode = 8  vic = 16
set HDMI vic: 16
config HPLL
config HPLL done
reconfig packet setting done
reading uEnv.txt
167 bytes read
reading /KERNEL
13944280 bytes read
reading /dtb/amlogic/meson8m2-m8s.dtb
25398 bytes read
## Booting kernel from Legacy Image at 14000000 ...
   Image Name:   Linux-5.6.0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    13944216 Bytes = 13.3 MiB
   Load Address: 00208000
   Entry Point:  00208000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 11800000
   Booting using the fdt blob at 0x11800000
board_usb_stop cfg: 0
   Loading Kernel Image ... OK
OK
uboot time: 6418449 us.
EFUSE machid is not set.
Using machid 0xf81 from environment
faild to get aml_reserved_end address
the default relocate ramdisk and fdt address-relocate_addr: 0x20000000
   Loading Device Tree to 1fff6000, end 1ffff335 ... OK
Starting kernel ...
[    0.119768] lima d00c0000.gpu: IRQ ppmmu3 not found
[    0.119896] lima d00c0000.gpu: IRQ ppmmu7 not found
[    0.124051] lima d00c0000.gpu: IRQ pp3 not found
[    0.128601] lima d00c0000.gpu: IRQ pp7 not found
[    0.133450] debugfs: Directory 'd00c0000.gpu-mali' with parent 'VDD_EE' already present!
[    0.153194] dummy-irq: no IRQ given.  Use irq=N
[    0.154964] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.168076] thermal thermal_zone0: binding zone soc with cdev thermal-cpufreq-0 failed:-22
[    0.198267] remoteproc remoteproc0: request_firmware failed: -2
[    0.200727] no UART detected at 0x1
[    0.243451] meson-drm d0100000.vpu: meson_vclk_setup(0, 27000, 27000, 27000, 1)
[    1.389401] meson-mx-ao-arc-firmware ao-arc-firmware: Failed to request mbox channel #0
and log file with meson8m2-mxiii.dtb and meson8m2-mxiii-plus.dtb are same
Spoiler
TE : 25587
PMU:rn5t618
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
CPU type: M8M2
HHH
0x12345678
TE : 218338
System Started
clr h-ram
DRAM:  2 GiB
aml_card_type=0x100
PMU fault status:
-- N_OEPOF
reg[0x9A] = 0x81
PMU type:RN5T618
nand chip ce mask 1
bad block count = 0
bad block count = 0
bad block count = 0
bad block count = 0
      Find match dtb: 5
Net:   Meson_Ethernet
config HPLL
config HPLL done
exit abortboot: 0
(Re)start USB(0)...
Force id mode: Host
No USB Device found
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
744 bytes read
mode = 8  vic = 16
set HDMI vic: 16
config HPLL
config HPLL done
reading uEnv.txt
167 bytes read
reading /KERNEL
13944280 bytes read
25398 bytes read
OK
Starting kernel ...
TE : 25587
PMU:rn5t618
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
CPU type: M8M2
DDR init use : 12257 us
HHH
0x12345678
TE : 218316
System Started
clr h-ram
DRAM:  2 GiB
aml_card_type=0x100
PMU fault status:
-- N_OEPOF
reg[0x9A] = 0x81
PMU type:RN5T618
nand chip ce mask 1
bad block count = 0
bad block count = 0
bad block count = 0
bad block count = 0
      Find match dtb: 5
Net:   Meson_Ethernet
config HPLL
config HPLL done
exit abortboot: 0
(Re)start USB(0)...
Force id mode: Host
No USB Device found
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
744 bytes read
mode = 8  vic = 16
set HDMI vic: 16
config HPLL
config HPLL done
reading uEnv.txt
174 bytes read
reading /KERNEL
13944280 bytes read
reading /dtb/amlogic/meson8m2-mxiii-plus.dtb
24824 bytes read
OK
uboot time: 6298513 us.
   Loading Device Tree to 1fff6000, end 1ffff0f7 ... OK
Starting kernel ...
[    0.144704] dummy-irq: no IRQ given.  Use irq=N
[    0.146437] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.156499] VCCK: failed to get the current voltage(-6)
[    0.156539] rn5t618-regulator rn5t618-regulator: failed to register DCDC1 regulator
[    0.195941] remoteproc remoteproc0: request_firmware failed: -2
[    0.196630] meson-saradc c1108680.adc: failed to get vref regulator
[    0.204195] no UART detected at 0x1
[    0.250540] meson-drm d0100000.vpu: meson_vclk_setup(0, 27000, 27000, 27000, 1)
[    0.403067] meson-mx-ao-arc-firmware ao-arc-firmware: Failed to request mbox channel #0
[    0.406165] meson-saradc c1108680.adc: failed to get vref regulator
[    0.426656] meson-saradc c1108680.adc: failed to get vref regulator
2 hours ago, balbes150 said:
What TV is the device connected to ?
first try was headless
after you question i connect to my Samsung TV ( FHD 32 inch)
with meson8m2-m8s.dtb it is like above no output , same error
with meson8m2-mxiii-plus.dtb i got libreelec logo and shell but after 30 sek restart and than shutdown (log attached)
error was
[   73.004257] [1087]: Failed to unmount /flash: Device or resource busy
[   73.010621] systemd-shutdown[1]: Failed to finalize  file systems, loop devices, ignoring
[   73.044806]QA9:A;SVN:74E;POC:3FF;STS:0;BOOT:0;INIT:0;READ:0;CHECK:0;PASS:0;
than restart
[   76.956916] [1135]: Failed to unmount /flash: Device or resource busy
[   76.963401] systemd-shutdown[1]: Failed to finalize  file systems, loop devices, ignoring
than shutdown
Spoiler
[    6.887534@0] dwc_otg lm1: irq 63, io mem 0x00000000
[    6.892429@0] -------hcd->flags.d32 = 0
[    6.896283@0] Init: Port Power? op_state=1
[    6.900316@0] Init1: Power Port (0)
[    6.903857@0] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    6.910747@0] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.918111@0] usb usb1: Product: DWC OTG Controller
[    6.922943@0] usb usb1: Manufacturer: Linux 3.10.99 dwc_otg_hcd
[    6.928858@0] usb usb1: SerialNumber: lm1
[    6.933073@0] hub 1-0:1.0: USB hub found
[    6.936769@0] hub 1-0:1.0: 1 port detected
[    6.940892@0] dwc_otg lm0: dwc_otg_driver_probe(e0b8f600)
[    6.946222@0] usb0: type: 0, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000
[    6.954762@0] USB (0) use clock source: XTAL input
[    6.960546@0] dwc_otg lm0: base=0xfe040000
[    6.963597@0] dwc_otg lm0: dwc_otg_device=0xe0dce580
[    6.988597@0] Core Release: 3.10a
[    6.988653@0] Setting default values for core params
[    6.991248@0] curmode: 1, host_only: 0
[    7.034971@0] dwc_otg lm0: DMA config: BURST_DEFAULT
[    7.055151@0] Using Buffer DMA mode
[    7.055208@0] OTG VER PARAM: 1, OTG VER FLAG: 1
[    7.057540@0] Working on port type = OTG
[    7.061440@0] Current port type: SLAVE
[    7.065300@0] dwc_otg lm0: DWC OTG Controller
[    7.069514@0] dwc_otg lm0: new USB bus registered, assigned bus number 2
[    7.076215@0] dwc_otg lm0: irq 62, io mem 0x00000000
[    7.081145@0] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    7.088080@0] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.095444@0] usb usb2: Product: DWC OTG Controller
[    7.100277@0] usb usb2: Manufacturer: Linux 3.10.99 dwc_otg_hcd
[    7.106191@0] usb usb2: SerialNumber: lm0
[    7.110392@0] hub 2-0:1.0: USB hub found
[    7.114064@0] hub 2-0:1.0: 1 port detected
[    7.118243@0] Dedicated Tx FIFOs mode
[    7.121974@0] using timer detect id change, e0284000
[    7.126828@0] boot_device_flag : 1
[    7.130094@0] ===========================================amlnf_init:643,nand device tree ok,dev-name:nand
[    7.139632@0] Nand PHY driver Version: 2.01.001.0006 (c) 2013 Amlogic Inc.
[    7.146489@1] HOST mode
[    7.146514@0] amlnf_phy_init : amlnf init flag 0
[    7.146590@0] ######STS IRQ mode for nand driver
[    7.146643@0] NAND device id: 45 de 94 93 76 57 9 4
[    7.146648@0] detect NAND device: A serials NAND 8GiB SDTNQGAMA-008G
[    7.188948@0] probe: mircon_check_l0l3_mode
[    7.189219@0] bus_cycle=6, bus_timing=7,system=4.7ns,flash->T_REA =20,flash->T_RHOH=25
[    7.195447@0] new oob mode
[    7.198106@0] boot_device_flag = 1
[    7.202736@0] NAND CKECK  : arg nbbt: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0
[    7.204779@1] -------hcd->flags.d32 = 0
[    7.204800@1] Init: Port Power? op_state=1
[    7.204802@1] Init1: Power Port (0)
[    7.204804@1] set usb port power on (board gpio 15)!
[    7.234020@0] NAND CKECK  : arg ncnf: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 0
[    7.242067@0] nand shipped bbt at block 0
[    7.251044@0] NAND CKECK  : arg fbbt: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 0
[    7.289449@0] NAND CKECK  : arg phyp: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 1
[    7.334613@0] NAND CKECK  : arg nkey: arg_valid= 1, valid_blk_addr = 8, valid_page_addr = 13
[    7.342812@0] i=0,register --- nand_key
[    7.390797@0] NAND CKECK  : arg nenv: arg_valid= 1, valid_blk_addr = 7, valid_page_addr = 115
[    7.401130@0] amlnand_phydev_init,1203,phydev->offset=0,phydev->size=1000000
[    7.407407@0] amlnand_phydev_init,1203,phydev->offset=d000000,phydev->size=26000000
[    7.415029@0] amlnand_phydev_init,1203,phydev->offset=33000000,phydev->size=53000000
[    7.422729@0] amlnand_phydev_init,1203,phydev->offset=86000000,phydev->size=17a000000
[    7.430549@0] nfboot     : offset: 0x000000000000 -0x000001000000 : partitons 0 : single_chip single_plane
[    7.440168@0] nfcache    : offset: 0x00000d000000 -0x000026000000 : partitons 1 : single_chip multi_plane
[    7.449701@0] nfcode     : offset: 0x000033000000 -0x000053000000 : partitons 5 : single_chip multi_plane
[    7.459240@0] nfdata     : offset: 0x000086000000 -0x00017a000000 : partitons 1 : single_chip multi_plane
[    7.468767@0] amlnand_add_nftl:
[    7.473710@0] Creating 1 ntd partitions
[    7.478596@0] block_num 76
[    7.484815@0] ------init_ntd
[    7.489797@0] ntd: Giving out device 0 to nfcache
[    7.494669@0] Creating 5 ntd partitions
[    7.499537@0] block_num 166
[    7.507374@0] ntd: Giving out device 1 to nfcode
[    7.512176@0] Creating 1 ntd partitions
[    7.516984@0] block_num 756
[    7.535104@0] ntd: Giving out device 2 to nfdata
[    7.540357@0] Amlogic A/V streaming port init
[    7.545972@0] [tsync_pcr_init]init success.
[    7.550688@0] amvideocap_init_module
[    7.555443@0] amvideocap_probe,amvideocap
[    7.560122@0] cma size undefined.
[    7.564812@0] amvideocap_dev_register buf:0aa00000,size:800000.
[    7.569931@0] regist mpeg12 codec profile
[    7.574659@0] regist mpeg4 codec profile
[    7.579340@0] amvdec_vc1 module init
[    7.584009@0] regist vc1 codec profile
[    7.588613@0] amvdec_h264 module init
[    7.593275@0] regist h264 codec profile
[    7.597890@0] amvdec_h264mvc module init
[    7.602533@0] regist hmvc codec profile
[    7.607135@0] amvdec_h264_4k2k module init
[    7.611750@0] regist h264_4k2k codec profile
[    7.616332@0] amvdec_h265 module init
[    7.620925@0] regist hevc codec profile
[    7.625512@0] regist mjpeg codec profile
[    7.630012@0] amvdec_real module init
[    7.634534@0] amvdec_avs module init
[    7.639119@0] amvenc_avc memory resource undefined.
[    7.643611@0] encode_wq_init.
[    7.648089@0] encode start monitor.
[    7.652596@1] encode workqueue monitor start.
[    7.657231@0] jpegenc module init
[    7.661790@0] picdec share memory resource fail case 1.
[    7.666308@0] picdec: probe of picdec failed with error -14
[    7.671479@0] alloc_keep_buffer keep_y_addr dfe00000
[    7.676351@0] alloc_keep_buffer keep_u_addr e0300000
[    7.681267@0] alloc_keep_buffer keep_v_addr e0400000
[    7.686218@0] yaddr=dfe00000,u_addr=e0300000,v_addr=e0400000
[    7.692027@0] create_ge2d_work_queue video task ok
[    7.696711@0] video2_init enter
[    7.701370@0] module init
[    7.705871@0] efuse===========================================
[    7.710515@0] efuse: device efuse created
[    7.714972@0] efuse--------------------------------------------
[    7.720321@0] SARADC Driver init.
[    7.724821@0] __saradc_probe__
[    7.729842@0] saradc calibration: ref_val = 509
[    7.734228@0] saradc calibration: ref_nominal = 512
[    7.738633@0] saradc calibration: coef = 4096
[    7.743157@0] irblaster probe
[    7.747613@0] Remote Driver
[    7.752010@0] Remote platform_data g_remote_base=fe600580
[    7.756404@0] set drvdata completed
[    7.760745@0] device_create_file completed
[    7.765384@0] input: aml_keypad as /devices/platform/meson-remote/input/input0
[    7.771472@0] input_register_device completed
[    7.775905@0] [0xffffff00] = 0x1dd0190
[    7.780270@0] [0xffffff04] = 0xf800ca
[    7.784596@0] [0xffffff08] = 0x82006e
[    7.788914@0] [0xffffff0c] = 0x3c0030
[    7.793195@0] [0xffffff10] = 0x30fa0013
[    7.797481@0] [0xffffff18] = 0x6f19000
[    7.801744@0] [0xffffff1c] = 0xbe40
[    7.805995@0] [0x0] = 0xfa00a0
[    7.810186@0] [0x4] = 0xfa00a0
[    7.814321@0] [0x8] = 0xfa00a0
[    7.818446@0] [0xc] = 0x640030
[    7.822544@0] [0x10] = 0x30fa0013
[    7.826647@0] [0x18] = 0x961b800
[    7.830710@0] [0x1c] = 0x9740
[    7.834747@0] [0x20] = 0x104
[    7.838774@0] [0x24] = 0x0
[    7.842752@0] [0x28] = 0x0
[    7.846730@0] set_remote_mode[69]
[    7.850701@0] remote config major:232
[    7.854747@0] physical address:0x204ec000
[    7.858773@0] ADC Keypad Driver init.
[    7.862818@0] ==touch_ts_init==
[    7.866856@0] ==ft5x0x_ts_init==
[    7.870784@0] ==goodix_ts_init==
[    7.874697@0] i2c-core: driver [gslx680_compatible] using legacy suspend method
[    7.880278@0] i2c-core: driver [gslx680_compatible] using legacy resume method
[    7.887489@0] !!!ntp_ts: ret = 0.
[    7.891379@0] VTL ct36x TouchScreen driver, <george.chen@vtl.com.cn>.
[    7.897282@0] i2c-core: driver [ct36x] using legacy suspend method
[    7.903404@0] i2c-core: driver [ct36x] using legacy resume method
[    7.909489@0] VTL ct36x TouchScreen driver End.
[    7.913978@0] ==gsl_ts_init==
[    7.917942@0] ret=0
[    7.921932@0] i2c-core: driver [mir3da] using legacy suspend method
[    7.926426@0] i2c-core: driver [mir3da] using legacy resume method
[    7.932588@0] i2c-core: driver [lis3dh_acc] using legacy suspend method
[    7.939171@0] i2c-core: driver [lis3dh_acc] using legacy resume method
[    7.945703@0] i2c-core: driver [bma222] using legacy suspend method
[    7.951896@0] i2c-core: driver [bma222] using legacy resume method
[    7.958100@0] i2c-core: driver [dmard06] using legacy suspend method
[    7.964378@0] i2c-core: driver [dmard06] using legacy resume method
[    7.970655@0] lsm303d driver: init
[    7.974408@0] i2c-core: driver [dmard10] using legacy suspend method
[    7.980346@0] i2c-core: driver [dmard10] using legacy resume method
[    7.986607@0] stk8313_init
[    7.990301@0] ======stk831x init ok======
[    7.993991@0] stk831x_init
[    7.997702@0] mxc622x accelerometer driver: init
[    8.001424@0] i2c-core: driver [mxc622x] using legacy suspend method
[    8.006868@0] i2c-core: driver [mxc622x] using legacy resume method
[    8.013095@0] mxc6255xc accelerometer driver: init
[    8.017894@0] i2c-core: driver [mxc6255xc] using legacy suspend method
[    8.024362@0] i2c-core: driver [mxc6255xc] using legacy resume method
[    8.030797@0] stk8baxx_init: start
[    8.034541@0] cm3217 v.1.0.0.1
[    8.038169@0] i2c-core: driver [elan_epl6814] using legacy suspend method
[    8.043953@0] i2c-core: driver [elan_epl6814] using legacy resume method
[    8.050667@0] i2c-core: driver [LTR501] using legacy suspend method
[    8.056884@0] i2c-core: driver [LTR501] using legacy resume method
[    8.063075@0] GPIO Keypad Driver init.
[    8.066827@0] ==gpio_key_probe==
[    8.070386@0] gpio request set to High-Z status
[    8.074478@0] power key(116) registed.
[    8.078296@0] input: gpio_keypad as /devices/platform/gpio_keypad.6/input/input1
[    8.085650@0] gpio keypad register input device completed.
[    8.091112@0] gpio keypad major:231
[    8.094837@0] spi_nor_init
[    8.098505@0] amlogic_spi_nor_probe:
[    8.102119@0] amlogic_spi->state_name:default
[    8.105808@0] AMLOGIC_SPI_NOR cc000000.spi: master is unqueued, this is deprecated
[    8.112818@0] check_storage_device : spi boot_device_flag : -1
[    8.118609@0] spi_nor_probe
[    8.122255@0] spi_nor_probe 629 boot_device_flag -1 : do not init spi
[    8.127795@0] spi_nor: probe of apollospi:32766 failed with error -12
[    8.134190@0] amlogic_spi_nor_probe over
[    8.138194@0] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error
[    8.147933@0] host->base fe108c20
[    8.151731@0] pdata->caps 7
[    8.155514@0] pdata->caps2 0
[    8.159261@0] get property:                     port, value:0x00000001
[    8.163882@0] get property:                ocr_avail, value:0x00200000
[    8.170410@0] get property:                    f_min, value:0x000493e0
[    8.176911@0] get property:                    f_max, value:0x02faf080
[    8.183398@0] get property:                  f_max_w, value:0x02faf080
[    8.189913@0] get property:             max_req_size, value:0x00020000
[    8.196414@0] get property:                   irq_in, value:0x00000003
[    8.202901@0] get property:                  irq_out, value:0x00000005
[    8.209421@0] get property:                  gpio_cd, str:CARD_6
[    8.215400@0] get property:                  gpio_ro, str:GPIOZ_0
[    8.221452@0] get property:                  pinname, str:sd
[    8.227104@0] get property:                 jtag_pin, str:CARD_0
[    8.233067@0] get property:                card_type, value:0x00000005
[    8.239590@0] get property:                gpio_dat3, str:CARD_4
[    8.245578@0] normal card in
[    8.284810@0]  reg:2620,clearmask=80008,setmask=10001
[    8.288513@0] reg:2621,clearmask=ff000000,set pin=64
[    8.292831@0] reg:2623,clearmask=7000,setmask=7
[    8.297371@0]  reg:2620,clearmask=200020,setmask=1
[    8.302106@0] reg:2622,clearmask=ff00,set pin=64
[    8.306700@0] reg:2623,clearmask=700000,setmask=7
[    8.311542@0] pdata->caps 107
[    8.315268@0] pdata->caps2 0
[    8.318934@0] get property:                     port, value:0x00000000
[    8.323701@0] get property:                ocr_avail, value:0x00200000
[    8.330217@0] get property:                    f_min, value:0x000493e0
[    8.336733@0] get property:                    f_max, value:0x02faf080
[    8.343216@0] get property:             max_req_size, value:0x00020000
[    8.349735@0] get property:                  pinname, str:sdio
[    8.355535@2] get property:                card_type, value:0x00000003
[    8.385317@0] sd: new high speed SDHC card at address aaaa, clock 35416666, 4-bit-bus-width
[    8.391888@0] mmcblk0: sd:aaaa SL16G 14.8 GiB
[    8.425595@0]  mmcblk0: p1 p2
[    8.484778@2] [aml_sdio_probe] aml_sdio_probe() success!
[    8.489564@2] host->base fe108e00
[    8.493277@2] pdata->caps 80000547
[    8.496945@2] pdata->caps2 20
[    8.500591@2] get property:                     port, value:0x00000005
[    8.505153@2] get property:                ocr_avail, value:0x00200080
[    8.511645@2] get property:                    f_min, value:0x000493e0
[    8.518154@2] get property:                    f_max, value:0x05f5e100
[    8.524648@2] get property:             max_req_size, value:0x00020000
[    8.531160@2] get property:                  pinname, str:emmc
[    8.536979@2] get property:                card_type, value:0x00000001
[    8.543459@2] get property:                gpio_dat3, str:BOOT_3
[    8.549448@2] [is_emmc_exist] host->storage_flag=0, POR_BOOT_VALUE=7
[    8.555774@2] [aml_sdhc_probe]: there is not eMMC/tsd, skip sdhc_c dts config!
[    8.614777@2] [aml_sdhc_probe] aml_sdhc_probe() success!
[    8.618516@2] [dsp]DSP start addr 0xc5e00000
[    8.622356@2] [dsp]register dsp to char divece(257)
[    8.627389@2] amlogic audio spdif interface device init!
[    8.632534@2] name=nand_key nand_key
[    8.636936@2] register_aes_algorithm:488,new way
[    8.642000@2] key name:keyexample, key data:1234567890
[    8.646407@2] aml_rtc rtc.0: rtc core: registered aml_rtc as rtc0
[    8.654258@2] [AML1216]call aml1216_battery_init, ret = 0
[    8.658195@2] [AML1218]call aml1218_battery_init, ret = 0
[    8.663269@2] [RN5T618]call rn5t618_battery_init, ret = 0
[    8.668630@2] vdin_drv_init: major 229
[    8.672624@2] vdin0 mem_start = 0x8100000, mem_size = 0x100000
[    8.678165@2] vdin_drv_probe: driver initialized ok
[    8.683076@2] vdin1 mem_start = 0x8200000, mem_size = 0x1000000
[    8.688906@2] vdin_drv_probe: driver initialized ok
[    8.693807@2] amvdec_656in module: init.
[    8.697798@2] amvdec_656in_init_module:major 228
[    8.702429@2] amvdec_656in probe ok.
[    8.706595@2] amvdec_csi probe ok.
[    8.710576@2] [viuin..]viuin_init_module viuin module init
[    8.714727@2] [viuin..]viuin_probe probe ok.
[    8.719047@2] [isp..]isp_probe isp probe ok.
[    8.723138@2] sii5293, sii5293drv driver starting!
[    8.727906@2] sii5293, Version: CP5293-v0.90.01, Build: 16:47:42-Apr 14 2017
[    8.735009@2] sii5293, register_chrdev sii5293
[    8.739794@2] [sii9293_workqueue_init] workqueue init ok!
[    8.744807@2] sii5293, Starting sii-5293
[    8.748879@2] uart_ao is using the pin GPIOAO_0 as pinmux
[    8.754075@2] pinmux-m8 pinmux: request() failed for pin 0
[    8.759546@2] pinmux-m8 pinmux: pin-0 (amlogic:gpio:0) status -22
[    8.765611@2] HalInit gpio_request for GPIO 0 (H/W Reset) failed, status: -22
[    8.772708@2] Initialization of HAL failed, error code: 1
[    8.778122@2] sii5293 mhldrv initialized failed !
[    8.782917@2] sii5293 [SiiMhlInit] something wrong !
[    8.788169@2] amaudio2: device amaudio2 created
[    8.792358@2] Error: Didn't get power valid value --- wifi_power_probe 424
[    8.799074@2] Error: Didn't get suspend_power_off value --- wifi_power_probe 441
[    8.806440@2] wifi_power power_gpio is 6
[    8.810583@2] wifi_power power_gpio2 is 123
[    8.814836@2] amlogic rfkill init
[    8.818963@2] enter bt_probe of_node
[    8.823055@2] not get gpio_en
[    8.827128@2] not get gpio_wake
[    8.854832@2] wifi_request_32k_clk : OFF-->ON for bt_rfkill
[    8.858928@2] clock_32k_pin(122) : (null)
[    8.863010@2] clock_32k_pin(122) : sdio_wifi
[    8.975799@2] aml_aes aml_aes: Aml AES
[    8.980177@2] aml_tdes aml_tdes: Aml TDES
[    8.984563@2] enter rt5616_modinit
[    8.988702@2] dummy_codec_platform_probe
[    8.992846@2] == ES8323 == es8323_modinit()
[    8.996959@2] pcm2bt_codec_probe ok!
[    9.001318@2] enter aml_i2s_dai_probe
[    9.005322@2] i2s get no clk src setting in dts, use the default mpll 0
[    9.010314@2] [aml-i2s-dai]enterd aml_i2s_dai_probe,old_samplerate:0,sample_rate=48000
[    9.018316@2] enter aml_pcm_dai_probe
[    9.022438@2] [aml-spdif-dai]enter aml_dai_spdif_init
[    9.026881@2] [aml-spdif-dai]enterd aml_spdif_play,set_clock:-1,sample_rate=4
[    9.033975@2] audio_set_958_clk, freq=4,
[    9.038099@2] IEC958 16bit
[    9.042192@2] hdmitx: audio: aout notify rate 48000
[    9.046300@2] hdmitx: audio: aout notify size 16
[    9.050353@2] hdmitx: audio: aout notify format CT_PCM
[    9.055234@2] hdmitx: audio: audio channel num is 1
[    9.060064@2] hdmitx: audio: SPDIF
[    9.064098@2] hdmitx: audio: current VIC: 0
[    9.068140@2] hdmitx: audio: audio sample rate: 3
[    9.072282@2] hdmitx: audio: set audio N para
[    9.076629@2] hdmitx: audio: PCM out to HDMI
[    9.080864@2] hdmitx: audio: i2s_to_spdif_flag:1
[    9.085553@2] hdmitx: audio: Enable audio spdif to HDMI
[    9.090748@2] hdmitx: audio: Audio Type: PCM
[    9.095042@2] hdmitx: audio: set audio param
[    9.099303@2] [aml-spdif-dai]aml_spdif_probe
[    9.103589@2] test codec dummy_codec
[    9.107406@2] using external codec, index = 1
[    9.111375@2] using external dummy codec
[    9.115374@2] enter spdif_dit_probe
[    9.119189@2] aml_spdif_unmute
[    9.123142@2] codec_name = dummy_codec.0
[    9.127239@0] enter aml_set_bias_level level: 1
[    9.131160@0] enter aml_set_bias_level level: 1
[    9.131175@2] enter aml_set_bias_level level: 1
[    9.131179@2] enter aml_set_bias_level level: 1
[    9.131180@2] enter aml_set_bias_level level: 2
[    9.148431@0] enter aml_set_bias_level level: 2
[    9.152943@2] enter aml_asoc_init
[    9.156768@2] p_aml_audio->hp_disable=1
[    9.160578@2] falied to get spk event delay time paraments from dts file
[    9.166775@2] spk_event delay_time = 0
[    9.171695@2] aml-i2s 0:playback preallocate_dma_buffer: area=ef300000, addr=2f500000, size=524288
[    9.179756@2] aml-i2s 1:capture preallocate_dma_buffer: area=ef240000, addr=2f440000, size=65536
[    9.188202@2] aml_snd_m8 aml_m8_sound_card.5:  dummy_codec <-> aml-i2s-dai.0 mapping ok
[    9.196220@0] enter aml_set_bias_level level: 1
[    9.196224@1] enter aml_set_bias_level level: 1
[    9.196229@1] enter aml_set_bias_level level: 2
[    9.209707@0] enter aml_set_bias_level level: 2
[    9.214306@2] enter aml_pcm2bt_preallocate_dma_buffer stream: 0
[    9.220297@2] aml_pcm2bt_preallocate_dma_buffer allcoate buf->area: ef210000 buf->addr: 0x2f410000 buf->bytes: 65536
[    9.230575@2] enter aml_pcm2bt_preallocate_dma_buffer stream: 1
[    9.236663@2] aml_pcm2bt_preallocate_dma_buffer allcoate buf->area: ef260000 buf->addr: 0x2f460000 buf->bytes: 65536
[    9.246961@2] aml_snd_m8 aml_m8_sound_card.5:  pcm2bt-pcm <-> aml-pcm-dai.0 mapping ok
[    9.254885@2] enter aml_set_bias_level level: 1
[    9.259343@2] enter aml_set_bias_level level: 2
[    9.263884@2] enter aml_set_bias_level level: 1
[    9.268369@2] enter aml_set_bias_level level: 2
[    9.274042@1] aml-i2s 0:playback preallocate_dma_buffer: area=ef400000, addr=2f600000, size=524288
[    9.282122@1] aml-i2s 1:capture preallocate_dma_buffer: area=ef3a0000, addr=2f5a0000, size=65536
[    9.290574@1] aml_snd_m8 aml_m8_sound_card.5:  dit-hifi <-> aml-spdif-dai.0 mapping ok
[    9.298480@0] enter aml_set_bias_level level: 1
[    9.298490@2] enter aml_set_bias_level level: 1
[    9.298492@2] enter aml_set_bias_level level: 2
[    9.311993@0] enter aml_set_bias_level level: 2
[    9.316577@1] enter aml_set_bias_level level: 1
[    9.320975@1] enter aml_set_bias_level level: 2
[    9.325511@1] enter aml_set_bias_level level: 1
[    9.329989@1] enter aml_set_bias_level level: 2
[    9.335088@0] enter aml_set_bias_level level: 1
[    9.335097@1] enter aml_set_bias_level level: 1
[    9.335099@1] enter aml_set_bias_level level: 2
[    9.348057@0] enter aml_set_bias_level level: 2
[    9.352620@1] -----ext_codec=1---
[    9.356654@1] =aml_m8_pinmux_init==,aml_m8_pinmux_init done,---0
[    9.361903@1] GACT probability NOT on
[    9.365930@1] Mirror/redirect action on
[    9.369926@1] u32 classifier
[    9.373900@1]     Actions configured
[    9.377881@1] Netfilter messages via NETLINK v0.30.
[    9.381899@1] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    9.387662@1] ctnetlink v0.93: registering with nfnetlink.
[    9.392820@1] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    9.399894@1] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    9.406117@1] xt_time: kernel timezone is -0000
[    9.410451@1] ipip: IPv4 over IPv4 tunneling driver
[    9.415582@1] ip_tables: (C) 2000-2006 Netfilter Core Team
[    9.420791@1] arp_tables: (C) 2002 David S. Miller
[    9.425496@1] TCP: cubic registered
[    9.429543@1] Initializing XFRM netlink socket
[    9.433893@1] NET: Registered protocol family 10
[    9.438479@1] mip6: Mobile IPv6
[    9.442532@1] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    9.446773@1] sit: IPv6 over IPv4 tunneling driver
[    9.451935@1] NET: Registered protocol family 17
[    9.456063@1] NET: Registered protocol family 15
[    9.460605@1] Bridge firewalling registered
[    9.464831@1] Bluetooth: RFCOMM TTY layer initialized
[    9.469767@1] Bluetooth: RFCOMM socket layer initialized
[    9.475048@1] Bluetooth: RFCOMM ver 1.11
[    9.479090@1] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    9.484398@1] Bluetooth: BNEP filters: protocol multicast
[    9.489788@1] Bluetooth: BNEP socket layer initialized
[    9.494900@1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    9.500961@1] Bluetooth: HIDP socket layer initialized
[    9.506094@1] l2tp_core: L2TP core driver, V2.0
[    9.510585@1] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    9.515529@1] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[    9.521251@1] l2tp_netlink: L2TP netlink interface
[    9.526031@1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[    9.532091@1] l2tp_debugfs: L2TP debugfs support
[    9.536677@1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    9.543290@1] NET: Registered protocol family 35
[    9.548290@1] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    9.555689@1] Registering SWP/SWPB emulation handler
[    9.560593@1] enter meson_pm_init
[    9.564726@1] enter meson_pm_probe!
[    9.568764@1] ---meson_pm_probe----set output pin success
[    9.572815@1] meson_pm_probe done !
[    9.577120@1] aml_istbt_dev_ready NULL
[    9.581388@1] file system registered
[    9.585969@1] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    9.591443@1] android_usb gadget: Number of LUNs=2
[    9.596224@1]  lun0: LUN: removable file: (no medium)
[    9.601238@1]  lun1: LUN: removable file: (no medium)
[    9.606402@1] android_usb gadget: android_usb ready
[    9.611529@1] aml_rtc rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
[    9.618520@1] ### dt-test ### No testcase data in device tree; not running tests
[    9.625955@1] meson_cpufreq_probe:SYSPLL request to be fixed
[    9.631491@1] meson_cpufreq_probe:SYSPLL fix to target:1608000
[    9.637309@1] meson_cpufreq_probe, adj ok
[    9.641405@1] meson_cpufreq: no voltage_control prop
[    9.646233@1] voltage_control = 0
[    9.650361@1] [DVFS]aml_dvfs_do_voltage_change, no dvfs driver
[    9.655376@1] <<-GTP-INFO->> GTP driver installing...
[    9.660577@1] hdmitx: cec: CEC init
[    9.664859@1] input: cec_input as /devices/virtual/input/input2
[    9.669807@1] hdmitx: cec: hdmitx_device->cec_init_ready:0x1[    9.675197@1] hdmitx: cec: cec_func_config: 0x0; P_AO_DEBUG_REG0:0x0
[    9.683682@1] ALSA device list:
[    9.692071@1]   #0: AML-M8AUDIO
[    9.696950@1] Freeing unused kernel memory: 396K (c0be6000 - c0c49000)
[   10.452638@3] force enable DISCARD here for ext4 fs
[   10.475847@3] checked enable EXT4 DISCARD here
[   10.480379@3] EXT4-fs (mmcblk0p2): mounting with "discard" option, but the device does not support discard
[   10.488978@3] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
[   10.981593@2] systemd[1]: System time before build time, advancing clock.
[   11.015602@2] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[   11.058866@2] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   11.064804@0] key 116 up
[   11.081762@2] systemd[1]: Detected architecture arm.
[   11.117728@2] systemd[1]: Set hostname to <vegas812>.
[   11.167514@2] config uart_ao_ttyS0:: Character length 8bits/char
o▒  11.184808@2] Changing uart_ao_ttyS0: baud from 0 to 115200
[   11.619560@2] systemd[1]: Reached target Encrypted Volumes.
[   11.630462@2] systemd[1]: Listening on udev Kernel Socket.
[   11.640904@2] systemd[1]: Reached target Remote File Systems (Pre).
[   11.651941@2] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   11.664794@2] systemd[1]: Created slice User and Session Slice.
[   11.675596@2] systemd[1]: Listening on Journal Socket.
[   11.686142@2] systemd[1]: Listening on Syslog Socket.
[   11.696653@2] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.709253@2] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.720435@2] systemd[1]: Created slice System Slice.
[   11.731292@2] systemd[1]: Reached target Slices.
[   11.743492@2] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   11.760166@2] systemd[1]: Mounting Debug File System...
[   11.773352@2] systemd[1]: Starting Set console keymap...
[   11.785155@2] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   11.812052@2] systemd[1]: Starting Load Kernel Modules...
[   11.824410@2] systemd[1]: Started Trigger resolvconf update for networkd DNS.
[   11.838487@2] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   11.852231@2] systemd[1]: Starting Nameserver information manager...
[   11.864757@2] systemd[1]: Reached target Remote File Systems.
[   11.877203@2] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   11.890196@2] systemd[1]: Listening on udev Control Socket.
[   11.902373@2] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.907619@0] aml_nftl_dev: module license 'Proprietary' taints kernel.
[   11.908456@0] boot_device_flag : 1
[   11.908458@0] register_ntd_blktrans start
[   11.908462@0] ntd device 250!
[   11.908464@0] ntd->name: nfcache
[   11.908470@0] adjust_block_num : 4,reserved_block_ratio 10
[   11.908473@0] nftl version 160811a
[   11.908474@0] nftl build Aug 11 2016_14:19:06
[   11.909846@0] calculate device -- nfcache
[   11.909849@0] get the phy_dev_size=20000000H tmp_off_size=200000H phy_dev_block=41H
[   11.909852@0] nftl start:size_in_blk=76,free_block_num=11
[   11.909991@0] first
[   11.990786@2] systemd[1]: Starting Remount Root and Kernel File Systems...
[   11.994819@0] average_erase_count:0
[   11.994824@0] second 74,65
[   11.994826@0] part->max_discard_block = 4
[   12.025538@2] systemd[1]: Starting Restore / save the current clock...
[   12.028752@1] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
[   12.047408@2] systemd[1]: Starting of Arbitrary Executable File Formats File System Automount Point not supported.
[   12.069765@2] systemd[1]: Mounted Debug File System.
[   12.082798@2] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   12.085160@0] all block full!!
[   12.085162@0] all discard block full!!
[   12.085179@0] free block cnt = 62
[   12.085181@0] total write 0 pages
[   12.085183@0] new current block is 71
[   12.085184@0] total discard page count is 0
[   12.085187@0] create_part_list:1228,current_used_discard_block=0,current_discard_block_used_count=188
[   12.085454@0] unmappig_pages=15767,discarded_pages=0,mapping_pages=873
[   12.085455@0] nftl ok!
[   12.086347@0] Enable QUEUE_FLAG_DISCARD for NFTL
[   12.158176@0] aml_nftl_add_ntd ok
[   12.164343@0] ntd device 250!
[   12.164345@0] ntd->name: nfcode
[   12.164351@0] adjust_block_num : 4,reserved_block_ratio 10
[   12.164354@0] nftl version 160811a
[   12.164356@0] nftl build Aug 11 2016_14:19:06
[   12.167332@0] size_in_blk 166; total_block 163;
[   12.167334@0] calculate device -- nfcode
[   12.167338@0] get the phy_dev_size=48000000H tmp_off_size=480000H phy_dev_block=91H
[   12.167340@0] nftl start:size_in_blk=163,free_block_num=18
[   12.167569@0] first
[   12.235699@2] systemd[1]: Started Set console keymap.
[   12.250937@2] systemd[1]: Started Remount Root and Kernel File Systems.
[   12.265760@2] systemd[1]: Started Restore / save the current clock.
[   12.280927@2] systemd[1]: Started Nameserver information manager.
[   12.297480@2] systemd[1]: Time has been changed
[   12.304225@2] systemd[1]: Reached target Network (Pre).
[   12.319047@2] systemd[1]: Starting Load/Save Random Seed...
[   12.333416@2] systemd[1]: Activating swap /var/swap...
[   12.348601@0] average_erase_count:1
[   12.355167@0] second 151,145
[   12.361408@0] part->max_discard_block = 4
[   12.379710@2] systemd[1]: Starting udev Coldplug all Devices...
[   12.394582@2] systemd[1]: Starting Create Static Device Nodes in /dev...
[   12.409043@2] systemd[1]: Started Load/Save Random Seed.
[   12.510913@2] Adding 131068k swap on /var/swap.  Priority:-1 extents:2 across:139260k SS
[   12.519564@2] systemd[1]: Activated swap /var/swap.
[   12.532851@2] systemd[1]: Reached target Swap.
[   12.546388@2] systemd[1]: Started Create Static Device Nodes in /dev.
[   12.555818@0] all block full!!
[   12.555820@0] all discard block full!!
[   12.555867@0] free block cnt = 44
[   12.555872@0] total write 0 pages
[   12.555875@0] new current block is 23
[   12.555876@0] total discard page count is 0
[   12.555879@0] create_part_list:1228,current_used_discard_block=22,current_discard_block_used_count=271
[   12.556443@0] unmappig_pages=9795,discarded_pages=0,mapping_pages=27325
[   12.556445@0] nftl ok!
[   12.557514@0] Enable QUEUE_FLAG_DISCARD for NFTL
[   12.558039@0] Enable QUEUE_FLAG_DISCARD for NFTL
[   12.558584@0] Enable QUEUE_FLAG_DISCARD for NFTL
[   12.559077@0] Enable QUEUE_FLAG_DISCARD for NFTL
[   12.559491@0] Enable QUEUE_FLAG_DISCARD for NFTL
[   12.559813@0] aml_nftl_add_ntd ok
[   12.559816@0] ntd device 250!
[   12.559818@0] ntd->name: nfdata
[   12.559826@0] adjust_block_num : 4,reserved_block_ratio 10
[   12.559829@0] nftl version 160811a
[   12.559831@0] nftl build Aug 11 2016_14:19:06
[   12.574553@0] size_in_blk 756; total_block 750;
[   12.574556@0] calculate device -- nfdata
[   12.575544@0] the space is  size = -1first
[   12.704454@2] systemd[1]: Starting udev Kernel Device Manager...
[   12.716770@2] systemd[1]: Reached target Local File Systems (Pre).
[   12.739364@2] systemd[1]: Mounting /tmp...
[   12.758184@2] systemd[1]: Mounted /tmp.
[   12.795765@2] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   12.810388@2] systemd[1]: Starting Journal Service...
[   12.822198@2] systemd[1]: haveged.service: Main process exited, code=exited, status=225/NETWORK
[   12.831450@2] systemd[1]: haveged.service: Unit entered failed state.
[   12.837824@2] systemd[1]: haveged.service: Failed with result 'exit-code'.
[   12.845466@2] systemd[1]: Started udev Coldplug all Devices.
[   12.881232@2] systemd[1]: Started udev Kernel Device Manager.
[   12.887901@1] aml_nftl_open ok!
[   12.998237@1] systemd[1]: Started Journal Service.
[   13.051824@1] systemd-journald[268]: Received request to flush runtime journal from PID 1
[   13.116296@0] aml_nftl_open ok!
[   13.118094@3] aml_nftl_open ok!
[   13.119219@2] aml_nftl_open ok!
[   13.121304@3] aml_nftl_open ok!
[   13.121851@1] aml_nftl_open ok!
[   13.279598@3] aml_nftl_open ok!
[   13.279625@1] aml_nftl_open ok!
[   13.280498@0] aml_nftl_open ok!
[   13.288088@0] aml_nftl_open ok!
[   13.288384@2] aml_nftl_open ok!
[   13.289824@1] aml_nftl_open ok!
[   13.362758@0] aml_audio_i2s_mute_flag: flag=0
[   13.368087@0] aml_audio_set_spdif_mute: flag=0
[   13.368089@0] aml_spdif_unmute
[   13.368099@0] aml_m8_set_spk: aml_m8_spk_enabled=0
[   13.467752@1] BT_RADIO going: on
[   13.473490@1] BCM_BT: going ON
[   13.513914@0] as an end receiver
[   13.518548@1] ionvideo open
[   13.518824@1] ionvideo_stop_generating!!!!
[   13.518837@1] ionvideo release
[   13.544115@2] found discard block:754
[   13.545217@2] average_erase_count:8
[   13.545234@2] second 749,678
[   13.545235@2] part->max_discard_block = 4
[   13.514309@2] amlvideo openamlvideo close[   14.151115@0] eth0: device MAC address c4:c0:96:91:ee:c1
[   14.174313@0] mask interrupts MMC
[   14.178950@0] mask interrupts MMC
[   14.183339@0] mask interrupts MMC
[   14.187926@0] stmmac_open: failed PTP initialisation
[   14.477914@2] all block full!!
[   14.483200@2] currnet_discard_block1:754
[   14.580112@2] reach the last discard page:70
[   14.584649@2] free block cnt = 42
[   14.588723@2] total write 0 pages
[   14.592732@2] new current block is 618
[   14.596701@2] total discard page count is 70
[   14.600651@2] create_part_list:1228,current_used_discard_block=754,current_discard_block_used_count=2
[   14.610959@2] unmappig_pages=92931,discarded_pages=19869,mapping_pages=60768
[   14.616467@2] nftl ok!
[   14.621971@2] Enable QUEUE_FLAG_DISCARD for NFTL
[   14.626590@2] aml_nftl_add_ntd ok
[   14.628424@1] aml_nftl_open ok!
[   14.635086@2] init_aml_nftl end
[   14.938050@2] RTL871X: module init start
[   14.942059@2] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   14.947606@2] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   14.953767@2] wifi_setup_dt
[   14.958006@2] wifi_request_32k_clk : ON-->ON for sdio_wifi
[   14.962128@2] interrupt_pin(133) : (null)
[   14.966467@2]  reg:2620,clearmask=100010,setmask=0
[   14.970674@2] reg:2622,clearmask=ff,set pin=133
[   14.975160@2] reg:2623,clearmask=70000,setmask=4
[   14.980068@2] interrupt_pin(133) : sdio_wifi
[   14.984285@2] power_on_pin(6) : (null)
[   14.988728@2] power_on_pin(6) : sdio_wifi
[   14.992991@2] power_on_pin2(123) : (null)
[   14.997296@2] power_on_pin2(123) : sdio_wifi
[   15.001548@2] ######platform_wifi_power_on:
[   15.005771@2] WIFI  Disable! 6
[   15.514795@2] WIFI  Enable! 6
[   17.024793@1] [aml_sdio_timeout] time_start_cnt:999
[   17.024793@1] [aml_sdio_print_err] sdio: Timeout error, Cmd52 arg 0xc00, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x113, virqc=0x1f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940
Connect Timeout
[   17.199494@1] Device Not Connected/Responding
[   18.054786@1] [aml_sdio_timeout] time_start_cnt:991
[aml_sdio_print_err] sdio: Timeout error, Cmd52 arg 0x80000c08, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x13, virqc=0x3f001f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940
[   19.084795@0] [aml_sdio_timeout] time_start_cnt:991
[   19.084795@0] [aml_sdio_print_err] sdio: Timeout error, Cmd8 arg 0x1aa, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940
[   19.137963@0] sdio: new high speed SDIO card at address 0001, clock 35416666, 4-bit-bus-width
[   19.146961@0] The func support sdio data1 irq!
[   19.162291@2] [sdio_reinit] finish
[   19.237797@0] RTL871X: rtw_ndev_init(wlan0)
[   19.244709@0] RTL871X: module init ret=0
TE : 25586
PMU:rn5t618
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
CPU type: M8M2
DDR init use : 12262 us
HHH
0x12345678
TE : 218348
System Started
clr h-ram
DRAM:  2 GiB
aml_card_type=0x100
PMU fault status:
-- N_OEPOF
reg[0x9A] = 0x81
PMU type:RN5T618
nand chip ce mask 1
bad block count = 0
bad block count = 0
bad block count = 0
bad block count = 0
      Find match dtb: 5
Net:   Meson_Ethernet
config HPLL
config HPLL done
exit abortboot: 0
(Re)start USB(0)...
Force id mode: Host
dwc_otg: No USB device found !
Error, couldn't init Lowlevel part
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
744 bytes read
mode = 8  vic = 16
set HDMI vic: 16
config HPLL
config HPLL done
reading uEnv.txt
167 bytes read
reading /KERNEL
13944280 bytes read
25398 bytes read
OK
uboot time: 5339822 us.
Starting kernel ...
[    0.118898] lima d00c0000.gpu: IRQ ppmmu3 not found
[    0.119026] lima d00c0000.gpu: IRQ ppmmu7 not found
[    0.123171] lima d00c0000.gpu: IRQ pp3 not found
[    0.127755] lima d00c0000.gpu: IRQ pp7 not found
[    0.132591] debugfs: Directory 'd00c0000.gpu-mali' with parent 'VDD_EE' already present!
[    0.152317] dummy-irq: no IRQ given.  Use irq=N
[    0.154078] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.167211] thermal thermal_zone0: binding zone soc with cdev thermal-cpufreq-0 failed:-22
[    0.198471] remoteproc remoteproc0: request_firmware failed: -2
[    0.200842] no UART detected at 0x1
[    0.354198] meson-drm d0100000.vpu: meson_vclk_setup(1, 148500, 148500, 148500, 0)
[    0.354239] meson-drm d0100000.vpu: [drm] *ERROR* Failed to setup vendor infoframe: -22
[    1.613548] meson-mx-ao-arc-firmware ao-arc-firmware: Failed to request mbox channel #0
▒QA9:A;SVN:74E;POC:3FF;STS:0;BOOT:0;INIT:0;READ:0;CHECK:0;PASS:0;
TE : 25586
PMU:rn5t618
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
CPU type: M8M2
DDR init use : 12252 us
HHH
0x12345678
TE : 218350
System Started
clr h-ram
DRAM:  2 GiB
aml_card_type=0x100
PMU fault status:
-- N_OEPOF
reg[0x9A] = 0x81
PMU type:RN5T618
nand chip ce mask 1
bad block count = 0
bad block count = 0
bad block count = 0
bad block count = 0
      Find match dtb: 5
Net:   Meson_Ethernet
config HPLL
config HPLL done
exit abortboot: 0
(Re)start USB(0)...
Force id mode: Host
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
744 bytes read
mode = 8  vic = 16
set HDMI vic: 16
config HPLL
config HPLL done
reading uEnv.txt
167 bytes read
reading /KERNEL
13944280 bytes read
25398 bytes read
OK
uboot time: 5284433 us.
Starting kernel ...
[    0.120619] lima d00c0000.gpu: IRQ ppmmu3 not found
[    0.120747] lima d00c0000.gpu: IRQ ppmmu7 not found
[    0.124905] lima d00c0000.gpu: IRQ pp3 not found
[    0.129438] lima d00c0000.gpu: IRQ pp7 not found
[    0.134317] debugfs: Directory 'd00c0000.gpu-mali' with parent 'VDD_EE' already present!
[    0.154017] dummy-irq: no IRQ given.  Use irq=N
[    0.155832] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.168806] thermal thermal_zone0: binding zone soc with cdev thermal-cpufreq-0 failed:-22
[    0.200954] remoteproc remoteproc0: request_firmware failed: -2
[    0.203252] no UART detected at 0x1
[    0.356187] meson-drm d0100000.vpu: meson_vclk_setup(1, 148500, 148500, 148500, 0)
[    0.356229] meson-drm d0100000.vpu: [drm] *ERROR* Failed to setup vendor infoframe: -22
[    1.613441] meson-mx-ao-arc-firmware ao-arc-firmware: Failed to request mbox channel #0
TE : 25586
PMU:rn5t618
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
CPU type: M8M2
DDR init use : 12261 us
HHH
0x12345678
TE : 218495
System Started
clr h-ram
DRAM:  2 GiB
aml_card_type=0x100
PMU fault status:
-- N_OEPOF
reg[0x9A] = 0x81
PMU type:RN5T618
nand chip ce mask 1
bad block count = 0
bad block count = 0
bad block count = 0
bad block count = 0
      Find match dtb: 5
Net:   Meson_Ethernet
config HPLL
config HPLL done
exit abortboot: 0
(Re)start USB(0)...
Force id mode: Host
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
744 bytes read
mode = 8  vic = 16
set HDMI vic: 16
config HPLL
config HPLL done
reading uEnv.txt
174 bytes read
reading /KERNEL
13944280 bytes read
24824 bytes read
OK
uboot time: 5334261 us.
Starting kernel ...
[    0.157934] dummy-irq: no IRQ given.  Use irq=N
[    0.159694] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.169732] VCCK: failed to get the current voltage(-6)
[    0.169771] rn5t618-regulator rn5t618-regulator: failed to register DCDC1 regulator
[    0.209208] remoteproc remoteproc0: request_firmware failed: -2
[    0.209895] meson-saradc c1108680.adc: failed to get vref regulator
[    0.217472] no UART detected at 0x1
[    0.373345] meson-drm d0100000.vpu: meson_vclk_setup(1, 148500, 148500, 148500, 0)
[    0.373386] meson-drm d0100000.vpu: [drm] *ERROR* Failed to setup vendor infoframe: -22
[    0.644435] meson-mx-ao-arc-firmware ao-arc-firmware: Failed to request mbox channel #0
[    0.647522] meson-saradc c1108680.adc: failed to get vref regulator
[    0.667841] meson-saradc c1108680.adc: failed to get vref regulator
LibreELEC:/ # dir
/bin/sh: dir: not found
LibreELEC:/ # cd ..
LibreELEC:/ # cd ..
LibreELEC:/ # dir
LibreELEC:/ # lsmod
Module                  Size  Used by
LibreELEC:/ # lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
LibreELEC:/ # ls[   73.004257] [1087]: Failed to unmount /flash: Device or resource busy
TE : 25598
PMU:rn5t618
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
-- i2c error, CTRL:
0798d019
CPU type: M8M2
DDR init use : 12258 us
HHH
0x12345678
TE : 218491
System Started
clr h-ram
DRAM:  2 GiB
aml_card_type=0x100
PMU fault status:
-- N_OEPOF
reg[0x9A] = 0x81
PMU type:RN5T618
nand chip ce mask 1
bad block count = 0
bad block count = 0
bad block count = 0
bad block count = 0
      Find match dtb: 5
Net:   Meson_Ethernet
config HPLL
config HPLL done
exit abortboot: 0
(Re)start USB(0)...
Force id mode: Host
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
744 bytes read
mode = 8  vic = 16
set HDMI vic: 16
config HPLL
config HPLL done
reading uEnv.txt
174 bytes read
reading /KERNEL
13944280 bytes read
24824 bytes read
OK
uboot time: 5253148 us.
Starting kernel ...
[    0.148911] dummy-irq: no IRQ given.  Use irq=N
[    0.150702] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.160712] VCCK: failed to get the current voltage(-6)
[    0.160751] rn5t618-regulator rn5t618-regulator: failed to register DCDC1 regulator
[    0.200221] remoteproc remoteproc0: request_firmware failed: -2
[    0.200907] meson-saradc c1108680.adc: failed to get vref regulator
[    0.208469] no UART detected at 0x1
[    0.365268] meson-drm d0100000.vpu: meson_vclk_setup(1, 148500, 148500, 148500, 0)
[    0.365309] meson-drm d0100000.vpu: [drm] *ERROR* Failed to setup vendor infoframe: -22
[    0.639419] meson-mx-ao-arc-firmware ao-arc-firmware: Failed to request mbox channel #0
[    0.642507] meson-saradc c1108680.adc: failed to get vref regulator
[    0.663025] meson-saradc c1108680.adc: failed to get vref regulator
LibreELEC:/ # desmsh
/bin/sh: desmsh: not found
LibreELEC:/ # desmsg
/bin/sh: desmsg: not found
LibreELEC:/ # desmesg
/bin/sh: desmesg: not found
LibreELEC:/ # d[   76.956916] [1135]: Failed to unmount /flash: Device or resource busy
1 hour ago, balbes150 said:
After the first start and extension of the partition, the system automatically reboots. This is normal behavior. At the second start, the configuration wizard should appear.
i start with a fresh flash of sd card and make a new run
10 minutes ago, RaptorSDS said:
its boot to librelec logo and shell  ,no desktop
Perhaps the reason is the errors that I see in the u-boot log when it starts (errors of the u-boot itself). What is connected to the USB ports ?
nothing connect to usb
The new version of the images for s8xx (s805\s802\s812) kernel 5.x.
The main feature, there is support for a graphical desktop. Please note that there is no text console. The initial configuration must be performed either via UART or SSH. Starting the desktop takes a long time (until the image appears). The desktop background is dark and the mouse cursor is also dark, so the cursor is not visible on the desktop, it can only be seen if you move it to the menu bar at the top of the screen. This is a very early version and a lot of things don't work in it. This version is only for General evaluation of the HDMI launch.
https://yadi.sk/d/-MwoNitZonsRCg
Checked Out Debian. It works better, the cursor is displayed normally. :)
I tried to play a test video file. I used a USB card for sound. When you first connect the USB card, the system started to slow down after 10 seconds. Pulled out and plugged the USB again. The sound has started to work, but sometimes there are distortions. I checked YouTube in  browser. Video works with sound not full-screen, in a normal window. The test sample is Tronsmart MXIII-Plus (S812 2\16 1Gbit LAN + USB FAN + USB sound).
@RaptorSDS No, I am not an experienced Device Tree editor.
But, armed with a copy of the Device Tree specification and fragments of DTB that worked with the old Amlogic kernels and Android,  I hope to be able to learn enough to make some missing features work, if there is support in the code.
OK  i had same idea and use old dts part and take it to new dts for wifi but still no luck
During the tests, I found out that for USB audio to work, the USB card must be included in the TV box before power is turned on. In this mode, it works in Debian and Ubuntu.
In the current version, it is not advisable to connect and disconnect USB devices in the working system until the automatic USB management is fully operational. Power failures occur for the SD card and other devices. This causes damage to the file system and you have to write the image again.
Thank You very much for information. May be You know what is the name of enabling multiboot universal file?
A little succes. Archlinux.
S812_ArchLinux_20170924_3_10_99 has run on my s812H (Wetek Core). So universal multiboot (s805_autoscript <- is it this?) is enabled. At first asks me about alarm login nd password. Any one knows is it alam/alarm i found in net.
So i tried some more attemps to run Armbian as i know multiboot is enabled. Unfortunatelly most of Armbian images dont work. @balbes150 is any info i can give that You can tell whats wrong with Armbian and this Wetek (i have 2 boxes so i dont think both are damaged)?
Now i try Armbian_20.05.1_Aml-s812_buster_current_5.6.0_20200404.img.
I have to change default dtb_name in uEnv.ini. My box is meson8m2-n200C.dtb but i dont see this in dtb folder. Which meson8m2 i should use instead?
Edited by Junoxe
Additional question.
I am using S805 box. I am testing Armbian_20.05.3_Aml-s812_buster_legacy_5.6.0_desktop_20200501.img with meson8b-ec100.dtb. The box can boot and start GUI
- It can recognize USB devices
However, there is error:
Message from syslogd@localhost at May  3 06:40:02 ...
 kernel:[  284.025994] watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [kworker/0:1:12]
[  284.029429] CPU: 0 PID: 12 Comm: kworker/0:1 Not tainted 5.6.0-aml-s812 #20.05.3
[  284.029556] Hardware name: Amlogic Meson platform
[  284.030073] Workqueue: events dbs_work_handler
[  284.030453] PC is at skb_put+0x0/0x50
[  284.030880] LR is at stmmac_napi_poll_rx+0x8dc/0xca8
[  284.031070] pc : [<c0ebcb7c>]    lr : [<c0d00b04>]    psr: 400f0113
[  284.031242] sp : c02b3a60  ip : 00000000  fp : ed95c580
[  284.031413] r10: ed95d580  r9 : 000005e2  r8 : ec5029c0
[  284.031609] r7 : 00001fe0  r6 : ed95c580  r5 : 00000000  r4 : 000005e2
[  284.031802] r3 : 5ed5f3a9  r2 : 00000000  r1 : 000005e2  r0 : ec5029c0
[  284.032031] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[  284.032236] Control: 10c5387d  Table: 2b42c04a  DAC: 00000051
[  284.032513] CPU: 0 PID: 12 Comm: kworker/0:1 Not tainted 5.6.0-aml-s812 #20.05.3
[  284.032630] Hardware name: Amlogic Meson platform
[  284.032938] Workqueue: events dbs_work_handler
[  284.033685] [<c030f744>] (unwind_backtrace) from [<c030ab3c>] (show_stack+0x10/0x14)
[  284.034116] [<c030ab3c>] (show_stack) from [<c0a67020>] (dump_stack+0xc0/0xd4)
[  284.034559] [<c0a67020>] (dump_stack) from [<c03f0e64>] (watchdog_timer_fn+0x20c/0x280)
[  284.035014] [<c03f0e64>] (watchdog_timer_fn) from [<c03ad114>] (__hrtimer_run_queues+0x154/0x200)
[  284.035453] [<c03ad114>] (__hrtimer_run_queues) from [<c03ad950>] (hrtimer_interrupt+0x11c/0x2ac)
[  284.035896] [<c03ad950>] (hrtimer_interrupt) from [<c030e3a8>] (twd_handler+0x30/0x38)
[  284.036372] [<c030e3a8>] (twd_handler) from [<c0397d44>] (handle_percpu_devid_irq+0x78/0x138)
[  284.036885] [<c0397d44>] (handle_percpu_devid_irq) from [<c0391c50>] (generic_handle_irq+0x34/0x44)
[  284.037377] [<c0391c50>] (generic_handle_irq) from [<c039224c>] (__handle_domain_irq+0x5c/0xb4)
[  284.037928] [<c039224c>] (__handle_domain_irq) from [<c0a7ed20>] (gic_handle_irq+0x3c/0x78)
[  284.038397] [<c0a7ed20>] (gic_handle_irq) from [<c0300b0c>] (__irq_svc+0x6c/0x90)
[  284.038583] Exception stack(0xc02b3a10 to 0xc02b3a58)
[  284.038901] 3a00:                                     ec5029c0 000005e2 00000000 5ed5f3a9
[  284.039320] 3a20: 000005e2 00000000 ed95c580 00001fe0 ec5029c0 000005e2 ed95d580 ed95c580
[  284.039660] 3a40: 00000000 c02b3a60 c0d00b04 c0ebcb7c 400f0113 ffffffff
[  284.040147] [<c0300b0c>] (__irq_svc) from [<c0ebcb7c>] (skb_put+0x0/0x50)
[  284.040559] [<c0ebcb7c>] (skb_put) from [<00000000>] (0x0)
1 hour ago, Junoxe said:
None of dtb working with Wetek Core. May be You can look into dtb from Wetek Core that K200_Noob extracted? Its in pasted post.
I tried it as well (on both boxes i have), but no success.
Extracted files for the old kernel, they are not suitable for kernel 5.
For all. Added images of Focal and Bullseye. On Focal and Bulseye, the desktop runs close to the colors.
