So...Is it included in the official images now? I just downloaded the Ubuntu image for Banana Pi, and I'm getting about 40Mbit speeds.
I have an Olimex Lime 2 connected to a router that has GLan ports.
My notebook is connected to the router but has only a 100 MBit ethernet port.
When I run iperf3 as a server on my notebook I have the full speed.
[ ID] Interval           Transfer     Bandwidth       Retr
[  4]   0.00-10.00  sec   110 MBytes  92.1 Mbits/sec  152             sender
[  4]   0.00-10.00  sec   110 MBytes  92.0 Mbits/sec                  receiver
But when I run iperf3 as a server on the board I have this result.
[  4]   0.00-10.00  sec  4.62 MBytes  3.88 Mbits/sec                  sender
[  4]   0.00-10.00  sec  4.62 MBytes  3.88 Mbits/sec                  receiver
When this happens I restart the board and I have the full speed again on both direction. Sometimes I have to restart the board two or three times to have again the full speed. This works for days or weeks and then I have to restart the board again if I need a fast speed.
I can't understand where is the problem.
Can you post armbianmonitor -u ... There were some network related problems in the past.
Wrote on mobile phone
Yes, first things which is strange is that you don't use latest build, neither for kernel neither for u-boot. I don't know if this particular combination of u-boot and kernel makes troubles, but it's possible. First do an update, than do repeat tests. We already solved some problems since:
ii linux-u-boot-lime2 5.00 armhf Uboot loader 2016.01
If you want to use vanilla kernel than uninstall this u-boot and install
linux-u-boot-lime2-next
After the Igor's post I switched to mainline kernel.
I also installed the u-boot with the path of the DRAM_CLK
I've seen the other difference in the patch but I don't understand it.
The lan works properly for a while and then I have to restart the board to see the full speed (with the previous kernel and u-boot). The changes in the patch can produce this behavior?
With the new kernel and uboot (http://beta.armbian.com/pool/main/l/linux-u-boot-lime2-next/linux-u-boot-next-lime2_5.24.161101_armhf.deb) I haven't seen net problems yet. Igor said that this has DRAM_CLK patch. I don't know if it has also the ethernet path.
