Tamas Koszta Posted November 15, 2023 Posted November 15, 2023 Hi, just installed 23.8.1 on my odroid M1, and I get poor network perf when using 1G port speed. iperf to another machine (iperf -c <server>, M1 sends traffic) gives the following: [ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 8.15 MBytes 6.84 Mbits/sec 631 sender [ 5] 0.00-10.04 sec 7.86 MBytes 6.57 Mbits/sec receiver reverse direction, M1 receives traffic: iperf -R -c <server> [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.04 sec 1.10 GBytes 937 Mbits/sec 587 sender [ 5] 0.00-10.00 sec 1.09 GBytes 938 Mbits/sec receiver same exists with older releases. also tried with older kernel (6.1.12-rk3568-odroid) when I set the network port on switch side to 100Mbps / full, then send, receive side is ok, can fill 100Mbps. Can you please help? BR, Tamas 0 Quote
j0ta Posted November 15, 2023 Posted November 15, 2023 (edited) I've notice it while moving files via gftp in ssh2 the network speed transfer is really slow (1GB port used) Edited November 15, 2023 by j0ta 0 Quote
Gergő Koszta Posted November 16, 2023 Posted November 16, 2023 Hi Bro, Today after trying a lot of distros and images (uboot part as well) it turned out one specific uboot is working fine stock Debian and Armian image as well. I followed this how to: https://github.com/inindev/odroid-m1/tree/main/uboot with the latest loader from this repo: https://github.com/inindev/odroid-m1/releases Have to be checked what is the difference between this and armbian uboot images. 0 Quote
j0ta Posted November 18, 2023 Posted November 18, 2023 (edited) confirmed @Gergő Koszta U-Boot SPL 2023.07.02-00034-g2717ce87b0 (Aug 18 2023 - 09:35:34 +0000) U-Boot phase U-Boot Just installed it is compatible with armbian bullseye the board boots well, hopefully this u-boot will fix the nvme boot problem I have. Later I'll comment when I've got some free time to make a new installation of the system Cheers ! Edited November 18, 2023 by j0ta 0 Quote
usual user Posted November 18, 2023 Posted November 18, 2023 4 hours ago, j0ta said: hopefully this u-boot will fix the nvme boot problem I have. Just out of curiosity, does this firmware build work? For a test it is sufficient to put it on an otherwise empty microSD card and old the SPI recovery button (RCY) while powering up. No modifications are necessary to the existing system. 0 Quote
j0ta Posted November 18, 2023 Posted November 18, 2023 hey @usual user tomorrow I'll give a try if nvme boots with the 2023.07.02-00034 if not I'll give a try on your u-boot the problem I have with nvme is present in this thread (there's video) I've no idea what's going wrong 0 Quote
j0ta Posted November 19, 2023 Posted November 19, 2023 The board boots sucessfull from nvme now. Many thanks @Gergő Koszta 0 Quote
Styby Posted November 5, 2024 Posted November 5, 2024 Hello, i have recently installed last recomended version of the armbian into NVME disk ODDROID M1 stybyk@Droiderone:~/MyDocker$ cat /etc/os-release PRETTY_NAME="Armbian 24.8.4 bookworm" NAME="Debian GNU/Linux" VERSION_ID="12" VERSION="12 (bookworm)" VERSION_CODENAME=bookworm ID=debian stybyk@Droiderone:~/MyDocker$ lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Armbian 24.8.4 bookworm Release: 12 Codename: bookworm stybyk@Droiderone:~/MyDocker$ hostnamectl Operating System: Armbian 24.8.4 bookworm Kernel: Linux 6.6.51-current-rockchip64 Architecture: arm64 And i found out that there is still same issue. Measuring by iperf from M1 > RPI4 [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 8.73 MBytes 7.32 Mbits/sec 954 sender [ 5] 0.00-10.00 sec 8.47 MBytes 7.11 Mbits/sec receiver Measuring from RP4 to M1 [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.09 GBytes 938 Mbits/sec 0 sender [ 5] 0.00-10.01 sec 1.09 GBytes 935 Mbits/sec receiver Is it the way how to solve it ? Or do i need to re-install completely with different OS from the scratch ? 0 Quote
Igor Posted November 5, 2024 Posted November 5, 2024 2 hours ago, Styby said: Is it the way how to solve it ? Switch to nightly build and try. Or just wait few weeks for 2024.11 update. Are you perhaps booting with petitboot? We fixed this some time ago: https://github.com/armbian/build/pull/7245 0 Quote
Styby Posted November 6, 2024 Posted November 6, 2024 Quote Or just wait few weeks for 2024.11 update. How long is estimated time which should i wait ? Does it have some solid date ? Or anytime in this month ? I dont remember all my "try actions" with the Oddroid, but last attemts to solve this ruin my disk anyway so now i had to start from begining as my backup was incidentaly too old 🤕 But in this my try, i had selected option in the armbian-install with boot from sd card system on NVMe. But I dont know how I can identify which type of bootloader I have running. I think i have t U-boot. 0 Quote
Igor Posted November 6, 2024 Posted November 6, 2024 1 hour ago, Styby said: Or anytime in this month ? Usually catching last week. 1 hour ago, Styby said: I think i have t U-boot. If you have followed instructions on download site, https://www.armbian.com/odroid-m1/, then you have u-boot. Which is fine. 0 Quote
rmrf Posted November 24, 2024 Posted November 24, 2024 Hi, my Odroid-M1 is running Armbian 24.11.1 and kernel 6.6.60-current so the fix you mention in the thread above should be in. Nevertheless the network speed is way slower when the M1 sends data. I have tried different client machines for the test as well as network cables on the M1 already, it makes no difference. iperf3 -c odroidm1 [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.09 GBytes 936 Mbits/sec 0 sender [ 5] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec receiver iperf3 -R -c odroidm1 [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 391 MBytes 328 Mbits/sec 5242 sender [ 5] 0.00-10.00 sec 391 MBytes 328 Mbits/sec receiver I played around with ethtool -C tx-usecs and could tune it to ~450 Mbits but still far from the bandwith in the other direction, so is this a different problem? 0 Quote
Styby Posted December 2, 2024 Posted December 2, 2024 Hello, that yours speed is still much more acceptable than mine. I am not abble to backup it due to the slowness. Last time i tried also to install server image which i keep running now. Operating System: Armbian 24.11.2 noble Kernel: Linux 6.6.63-current-rockchip64 FROM ODDROID TO RPI [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 4.88 MBytes 4.09 Mbits/sec 633 sender [ 5] 0.00-10.00 sec 4.87 MBytes 4.08 Mbits/sec receiver FROM RPI TO ODDOID [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.09 GBytes 936 Mbits/sec 0 sender [ 5] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec receiver I am scared to play with that without backup. 0 Quote
Styby Posted December 12, 2024 Posted December 12, 2024 Hello, i tried all now. Armbian 24.11.1 Noble Gnome Kernel: 6.6.60, Server images with Armbian Linux v6.6 Rolling imagges, too. I tried also external source from Oddoid forum https://forum.odroid.com/viewtopic.php?t=48230 But all seems to have same problem with the kernel or drivers of the network chip. Upload 1 - 4 MBit 0 Quote
usual user Posted December 12, 2024 Posted December 12, 2024 Works for me as for @rmrf. iperf3 -c ... [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec 0 sender [ 5] 0.00-10.01 sec 1.09 GBytes 938 Mbits/sec receiver iperf3 -R -c ... [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 412 MBytes 345 Mbits/sec 485 sender [ 5] 0.00-10.00 sec 410 MBytes 344 Mbits/sec receiver 0 Quote
flyescke Posted December 19, 2024 Posted December 19, 2024 Hi, I have the same issue. Used to run fine on Ubuntu 22.04 with 4.19 kernel but I just upgraded to armbian. Connecting to host 192.168.2.10, port 5201 [ 5] local 192.168.2.50 port 57993 connected to 192.168.2.10 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.01 sec 80.8 MBytes 668 Mbits/sec [ 5] 1.01-2.00 sec 95.6 MBytes 813 Mbits/sec [ 5] 2.00-3.01 sec 39.6 MBytes 330 Mbits/sec [ 5] 3.01-4.01 sec 107 MBytes 898 Mbits/sec [ 5] 4.01-5.01 sec 71.4 MBytes 601 Mbits/sec [ 5] 5.01-6.00 sec 70.6 MBytes 594 Mbits/sec [ 5] 6.00-7.01 sec 84.2 MBytes 702 Mbits/sec [ 5] 7.01-8.00 sec 57.8 MBytes 488 Mbits/sec [ 5] 8.00-9.01 sec 85.2 MBytes 710 Mbits/sec [ 5] 9.01-10.01 sec 89.6 MBytes 749 Mbits/sec Connecting to host 192.168.2.10, port 5201 Reverse mode, remote host 192.168.2.10 is sending [ 5] local 192.168.2.50 port 58028 connected to 192.168.2.10 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.01 sec 512 KBytes 4.13 Mbits/sec [ 5] 1.01-2.00 sec 256 KBytes 2.12 Mbits/sec [ 5] 2.00-3.01 sec 512 KBytes 4.16 Mbits/sec [ 5] 3.01-4.01 sec 896 KBytes 7.35 Mbits/sec [ 5] 4.01-5.01 sec 896 KBytes 7.30 Mbits/sec [ 5] 5.01-6.00 sec 640 KBytes 5.30 Mbits/sec [ 5] 6.00-7.01 sec 384 KBytes 3.12 Mbits/sec [ 5] 7.01-8.00 sec 640 KBytes 5.28 Mbits/sec [ 5] 8.00-9.01 sec 256 KBytes 2.08 Mbits/sec [ 5] 9.01-10.01 sec 384 KBytes 3.16 Mbits/sec 0 Quote
flyescke Posted December 23, 2024 Posted December 23, 2024 I've installed Debian 12 via PetitBoot and I get similar issues... 0 Quote
usual user Posted December 23, 2024 Posted December 23, 2024 (edited) I'm currently at: # uname -a Linux micro-015 6.13.0-0.rc1.20241204gitfeffde684ac2.17.fc42.aarch64 #1 SMP PREEMPT_DYNAMIC Sat Dec 7 11:18:10 CET 2024 aarch64 GNU/Linux And with better wired up in DTB I get: Spoiler # iperf3 -c odroid-m1 Connecting to host odroid-m1, port 5201 [ 5] local odroid-n2+ port 34366 connected to odroid-m1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 112 MBytes 941 Mbits/sec 0 461 KBytes [ 5] 1.00-2.00 sec 112 MBytes 941 Mbits/sec 0 510 KBytes [ 5] 2.00-3.00 sec 113 MBytes 945 Mbits/sec 0 560 KBytes [ 5] 3.00-4.00 sec 111 MBytes 934 Mbits/sec 0 585 KBytes [ 5] 4.00-5.00 sec 112 MBytes 943 Mbits/sec 0 684 KBytes [ 5] 5.00-6.00 sec 111 MBytes 928 Mbits/sec 0 718 KBytes [ 5] 6.00-7.00 sec 112 MBytes 944 Mbits/sec 0 718 KBytes [ 5] 7.00-8.00 sec 112 MBytes 935 Mbits/sec 0 792 KBytes [ 5] 8.00-9.00 sec 111 MBytes 933 Mbits/sec 0 830 KBytes [ 5] 9.00-10.02 sec 113 MBytes 928 Mbits/sec 0 830 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.02 sec 1.09 GBytes 938 Mbits/sec 0 sender [ 5] 0.00-10.02 sec 1.09 GBytes 937 Mbits/sec receiver iperf Done. # iperf3 -R -c odroid-m1 Connecting to host odroid-m1, port 5201 Reverse mode, remote host odroid-m1 is sending [ 5] local odroid-n2+ port 36326 connected to odroid-m1 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 87.8 MBytes 735 Mbits/sec [ 5] 1.00-2.00 sec 73.6 MBytes 618 Mbits/sec [ 5] 2.00-3.00 sec 94.2 MBytes 791 Mbits/sec [ 5] 3.00-4.00 sec 90.2 MBytes 757 Mbits/sec [ 5] 4.00-5.00 sec 88.5 MBytes 742 Mbits/sec [ 5] 5.00-6.00 sec 86.0 MBytes 721 Mbits/sec [ 5] 6.00-7.00 sec 87.4 MBytes 733 Mbits/sec [ 5] 7.00-8.00 sec 83.2 MBytes 698 Mbits/sec [ 5] 8.00-9.00 sec 86.0 MBytes 721 Mbits/sec [ 5] 9.00-10.00 sec 79.4 MBytes 666 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 858 MBytes 720 Mbits/sec 196 sender [ 5] 0.00-10.00 sec 856 MBytes 718 Mbits/sec receiver iperf Done. Edited January 5, 2025 by usual user 0 Quote
Tamas Koszta Posted May 28, 2025 Author Posted May 28, 2025 Still the same with armbian 25.2.3 kernel: 6.12.22-current-rockchip64 #1 SMP PREEMPT Mon Apr 7 08:08:37 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux u-boot-version: # cat /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version" 2025.01-armbian-2025.01-S6d41-P41ad-H4cab-V390e-Bb703-R448a u-boot,version WARNING: could not set u-boot,version %s. # iperf3 -R -c odroidm1 Connecting to host odroidm1, port 5201 Reverse mode, remote host odroidm1 is sending [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 79.2 KBytes 649 Kbits/sec [ 5] 1.00-2.00 sec 84.8 KBytes 695 Kbits/sec [ 5] 2.00-3.00 sec 206 KBytes 1.69 Mbits/sec [ 5] 3.00-4.00 sec 228 KBytes 1.87 Mbits/sec [ 5] 4.00-5.00 sec 115 KBytes 938 Kbits/sec [ 5] 5.00-6.00 sec 181 KBytes 1.48 Mbits/sec [ 5] 6.00-7.00 sec 163 KBytes 1.33 Mbits/sec ^C[ 5] 7.00-7.36 sec 9.90 KBytes 226 Kbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-7.36 sec 0.00 Bytes 0.00 bits/sec sender [ 5] 0.00-7.36 sec 1.04 MBytes 1.19 Mbits/sec receiver when changing u-boot back to older u-boot (same kernel), it works as expected # cat /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version" 2023.04-00035-g7dd5eb0228 u-boot,version WARNING: could not set u-boot,version %s. # iperf3 -R -c odroidm1 Connecting to host odrdoidm1, port 5201 Reverse mode, remote host odroidm1 is sending [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 110 MBytes 921 Mbits/sec [ 5] 1.00-2.00 sec 110 MBytes 926 Mbits/sec [ 5] 2.00-3.00 sec 110 MBytes 926 Mbits/sec [ 5] 3.00-4.00 sec 110 MBytes 921 Mbits/sec [ 5] 4.00-5.00 sec 111 MBytes 929 Mbits/sec [ 5] 5.00-6.00 sec 111 MBytes 927 Mbits/sec [ 5] 6.00-7.00 sec 110 MBytes 919 Mbits/sec ^C[ 5] 7.00-7.79 sec 87.0 MBytes 925 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-7.79 sec 0.00 Bytes 0.00 bits/sec sender [ 5] 0.00-7.79 sec 858 MBytes 924 Mbits/sec receiver iperf3: interrupt - the client has terminated ethtool output: ~# ethtool end0 Settings for end0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supported pause frame use: Symmetric Receive-only Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Link partner advertised pause frame use: No Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Auto-negotiation: on master-slave cfg: preferred slave master-slave status: slave Port: Twisted Pair PHYAD: 0 Transceiver: external MDI-X: Unknown Supports Wake-on: ug Wake-on: d Current message level: 0x0000003f (63) drv probe link timer ifdown ifup Link detected: yes 0 Quote
aleksandriusz Posted March 30 Posted March 30 Hi, looks like the issue still persists, but I have a temporary solution in case if your upload speed drops *way* beyond yours (2 Mbps for me). You can force-use a 100 Mbps link speed. `iperf3` results below. Literally 50x speed increase in my case! I've performed these benchmarks connecting to my VPS via wireguard: ``` $ cat /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version"` U-Boot: 2026.01_armbian-2026.01-S127a-Pc2e6-H706e-Vab81-B2eb2-R448a ``` Linux 6.18.10-current-rockchip64 Standard operation (1000 Mbps): ```root@odroidm1 ~# ethtool -s eth0 speed 1000 duplex full root@odroidm1 ~# iperf3 -c 10.0.3.1 Connecting to host 10.0.3.1, port 5201 [ 5] local 10.0.3.2 port 42538 connected to 10.0.3.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 384 KBytes 3.14 Mbits/sec 5 14.7 KBytes [ 5] 1.00-2.00 sec 384 KBytes 3.15 Mbits/sec 5 6.68 KBytes [ 5] 2.00-3.00 sec 384 KBytes 3.14 Mbits/sec 2 13.4 KBytes [ 5] 3.00-4.00 sec 256 KBytes 2.10 Mbits/sec 6 9.35 KBytes [ 5] 4.00-4.43 sec 128 KBytes 2.42 Mbits/sec 0 22.7 KBytes ``` Dirty fix, link capped at 100 Mbps at most: ``` root@odroidm1 ~# ethtool -s eth0 speed 100 duplex full root@odroidm1 ~# iperf3 -c 10.0.3.1 Connecting to host 10.0.3.1, port 5201 [ 5] local 10.0.3.2 port 42354 connected to 10.0.3.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 11.4 MBytes 95.3 Mbits/sec 0 1.03 MBytes [ 5] 1.00-2.00 sec 10.5 MBytes 88.1 Mbits/sec 0 1.03 MBytes [ 5] 2.00-3.00 sec 11.4 MBytes 95.4 Mbits/sec 0 1.10 MBytes [ 5] 3.00-4.00 sec 10.2 MBytes 86.0 Mbits/sec 0 1.10 MBytes [ 5] 4.00-4.48 sec 5.00 MBytes 87.4 Mbits/sec 0 1.10 MBytes ``` So.. yeah. While using Wireshark I also saw *a lot* of TCP retransmissions too, which usually don't happen that at 100 Mbps link in my configuration. 0 Quote
aleksandriusz Posted March 31 Posted March 31 Just a quick update for those who are following this thread, looks like there was a pull request for U-Boot with this fix (2026-02-02): https://github.com/armbian/build/pull/9333 Waiting for the U-Boot update i guess (i'm using `linux-u-boot-odroidm1-edge/sid` currently). 0 Quote
aleksandriusz Posted 3 hours ago Posted 3 hours ago (edited) No difference on an installation with `linux-u-boot-odroidm1-edge/sid,now 26.8.0-trunk.12` and `linux-image-edge-rockchip64/sid` (7.0.8-edge-rockchip64 ), 1000 Mbps link is still heavily degraded, especially on packets leaving my gateway router. Could anyone subscribed to this thread confirm that's still the case? Thanks! 1000 Mbps link: root@odroidm1 ~# ethtool -s eth0 speed 1000 duplex full autoneg on root@odroidm1 ~ [1]# iperf3 -c 10.0.3.3 Connecting to host 10.0.3.3, port 5201 [ 5] local 10.0.3.2 port 51448 connected to 10.0.3.3 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 1.00 MBytes 8.38 Mbits/sec 12 22.8 KBytes [ 5] 1.00-2.00 sec 384 KBytes 3.15 Mbits/sec 2 11.4 KBytes [ 5] 2.00-3.00 sec 0.00 Bytes 0.00 bits/sec 1 10.4 KBytes [ 5] 3.00-4.00 sec 256 KBytes 2.10 Mbits/sec 0 19.9 KBytes 100 Mbps link: root@odroidm1 ~# ethtool -s eth0 speed 100 duplex full autoneg off root@odroidm1 ~# iperf3 -c 10.0.3.3 Connecting to host 10.0.3.3, port 5201 [ 5] local 10.0.3.2 port 38436 connected to 10.0.3.3 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 6.00 MBytes 50.3 Mbits/sec 0 2.38 MBytes [ 5] 1.00-2.00 sec 8.38 MBytes 70.3 Mbits/sec 0 7.87 MBytes [ 5] 2.00-3.00 sec 9.25 MBytes 77.6 Mbits/sec 0 7.87 MBytes # grep -a --null-data U-Boot /dev/mtd0ro U-Boot SPL 2026.01_armbian-2026.01-S127a-P2477-H8652-Vab81-Bd0d2-R448a (May 15 2026 - 06:45:08 +0000) Edited 2 hours ago by aleksandriusz 0 Quote
usual user Posted 1 hour ago Posted 1 hour ago 1 hour ago, aleksandriusz said: Could anyone subscribed to this thread confirm that's still the case? Since I haven't restarted the M1 for some time, I am currently still at: # uptime 12:56:23 up 115 days, 1:51, 5 users, load average: 1.76, 1.26, 0.92 # uname -a Linux micro-015 6.18.0-65.fc44.aarch64 #1 SMP PREEMPT_DYNAMIC Sun Dec 7 20:40:45 CET 2025 aarch64 GNU/Linux I still get: Spoiler # iperf3 -c odroid-m1 Connecting to host odroid-m1, port 5201 [ 5] local odroid-m2 port 38866 connected to odroid-m1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 114 MBytes 959 Mbits/sec 0 553 KBytes [ 5] 1.00-2.00 sec 113 MBytes 946 Mbits/sec 0 648 KBytes [ 5] 2.00-3.00 sec 112 MBytes 941 Mbits/sec 0 684 KBytes [ 5] 3.00-4.00 sec 111 MBytes 930 Mbits/sec 0 809 KBytes [ 5] 4.00-5.00 sec 113 MBytes 949 Mbits/sec 0 809 KBytes [ 5] 5.00-6.00 sec 112 MBytes 943 Mbits/sec 0 809 KBytes [ 5] 6.00-7.00 sec 112 MBytes 940 Mbits/sec 0 809 KBytes [ 5] 7.00-8.00 sec 112 MBytes 940 Mbits/sec 0 809 KBytes [ 5] 8.00-9.00 sec 112 MBytes 935 Mbits/sec 0 850 KBytes [ 5] 9.00-10.00 sec 112 MBytes 942 Mbits/sec 0 850 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec 0 sender [ 5] 0.00-10.01 sec 1.09 GBytes 940 Mbits/sec receiver iperf Done. # iperf3 -R -c odroid-m1 Connecting to host odroid-m1, port 5201 Reverse mode, remote host odroid-m1 is sending [ 5] local odroid-m2 port 50806 connected to odroid-m1 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 92.2 MBytes 773 Mbits/sec [ 5] 1.00-2.00 sec 89.0 MBytes 746 Mbits/sec [ 5] 2.00-3.00 sec 88.1 MBytes 739 Mbits/sec [ 5] 3.00-4.00 sec 73.6 MBytes 618 Mbits/sec [ 5] 4.00-5.00 sec 89.5 MBytes 751 Mbits/sec [ 5] 5.00-6.00 sec 89.9 MBytes 754 Mbits/sec [ 5] 6.00-7.00 sec 77.5 MBytes 650 Mbits/sec [ 5] 7.00-8.00 sec 83.5 MBytes 701 Mbits/sec [ 5] 8.00-9.00 sec 84.6 MBytes 709 Mbits/sec [ 5] 9.00-10.00 sec 84.0 MBytes 705 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 853 MBytes 715 Mbits/sec 214 sender [ 5] 0.00-10.00 sec 852 MBytes 715 Mbits/sec receiver iperf Done. So nothing to complain about. 0 Quote
eselarm Posted 1 hour ago Posted 1 hour ago 12 minutes ago, usual user said: So nothing to complain about. What U-Boot/bootloader is in the MTD? 0 Quote
usual user Posted 55 minutes ago Posted 55 minutes ago 37 minutes ago, eselarm said: What U-Boot/bootloader is in the MTD? The one from my firmware build. 0 Quote
