I was going to install armbian on a new vim 3 board but it seems that krescue no longer exists.
Is there another way to install armbian to a vim 3?   Does the vim 4 have the same problem?
Boot from SD card and install it classic way (armbian-install) doesn't work?
I had tried, but when it didnt work  I read the directions for the board which say to get krescue still.
I still have manjaro running on my other board from june.  So i never did get armbian on my other vim3.
I just did find a krecovery image and booted into that. Flashing armbian again to another sdcard, the image seems fine. Ill try manjaro next. Id rather have armbian.
Ive tried both armbian downloads, and the original manjaro.  None do anything.
I end up in android only the krecover
Image has actually booted from sd.
Im doing something wrong but i dont know what.
I should report that I successfully installed bookworm on the vim3 pro by wiping emmc and spi with my old version of krescue.
I still have no answer without krescue.
I installed minimal, then xorg and xmonad.
No dm or desktop.
It seems stable, but with xorg it only runs a while before there is a run away process and it locks up and overheats. It could be anything, but i run a barebones xmonad, emacs setup.   Still running on sdcard.
Fully updated.
The link to the krescue image on Armbian's Khadas-VIM3 page does not work (anymore). It needs to be replaced with https://dl.khadas.com/firmware/Krescue/dump/ (note the lower-case f in "/firmware/"). Confusingly, other firmware images are still available below https://dl.khadas.com/Firmware with upper-case F.
To prevent the image from getting lost again, I've asked the internet archive to archive the latest krescue sd card image for VIM3: https://web.archive.org/web/20240426161033/https://dl.khadas.com/firmware/Krescue/system/versions/VIM3.krescue.sd.220110_266.img.gz
Yes. I have krescue. It still hasn't worked.
I have a vim3 from a year ago that I have manjaro booting from sdcard.  I'd like it to be armbian, but havent managed to get an armbian sdcard to boot in it.
Its my only working vim3.  I bought a Vim4 recently. But it was DOA.  Now I'm travelling and have no recourse but to keep using manjaro which Kind-of sucks.
I left the android only vim3 at home.
