Erica Posted January 9 Posted January 9 I was going to install armbian on a new vim 3 board but it seems that krescue no longer exists. Is there another way to install armbian to a vim 3? Does the vim 4 have the same problem? 0 Quote
Erica Posted January 9 Author Posted January 9 I just realized i asked this in june and there is still no resolution. Sorry. Erica 0 Quote
Igor Posted January 9 Posted January 9 1 hour ago, Erica said: but it seems that krescue no longer exists. Boot from SD card and install it classic way (armbian-install) doesn't work? 0 Quote
Erica Posted January 9 Author Posted January 9 Not so far. Power button reset button trick takes me to android recovery. That menu doesnt seem helpful. 0 Quote
Erica Posted January 9 Author Posted January 9 I tried going to the bootloader from there but it just hangs with the khadas logo. 0 Quote
Erica Posted January 9 Author Posted January 9 I had tried, but when it didnt work I read the directions for the board which say to get krescue still. I still have manjaro running on my other board from june. So i never did get armbian on my other vim3. 0 Quote
Erica Posted January 9 Author Posted January 9 I just did find a krecovery image and booted into that. Flashing armbian again to another sdcard, the image seems fine. Ill try manjaro next. Id rather have armbian. 0 Quote
Erica Posted January 10 Author Posted January 10 Ive tried both armbian downloads, and the original manjaro. None do anything. I end up in android only the krecover Image has actually booted from sd. Im doing something wrong but i dont know what. 0 Quote
Erica Posted January 29 Author Posted January 29 I should report that I successfully installed bookworm on the vim3 pro by wiping emmc and spi with my old version of krescue. I still have no answer without krescue. I installed minimal, then xorg and xmonad. No dm or desktop. It seems stable, but with xorg it only runs a while before there is a run away process and it locks up and overheats. It could be anything, but i run a barebones xmonad, emacs setup. Still running on sdcard. Fully updated. 0 Quote
SomeArmbianForumUser Posted April 26 Posted April 26 The link to the krescue image on Armbian's Khadas-VIM3 page does not work (anymore). It needs to be replaced with https://dl.khadas.com/firmware/Krescue/dump/ (note the lower-case f in "/firmware/"). Confusingly, other firmware images are still available below https://dl.khadas.com/Firmware with upper-case F. To prevent the image from getting lost again, I've asked the internet archive to archive the latest krescue sd card image for VIM3: https://web.archive.org/web/20240426161033/https://dl.khadas.com/firmware/Krescue/system/versions/VIM3.krescue.sd.220110_266.img.gz 0 Quote
Erica Posted May 2 Author Posted May 2 Yes. I have krescue. It still hasn't worked. I have a vim3 from a year ago that I have manjaro booting from sdcard. I'd like it to be armbian, but havent managed to get an armbian sdcard to boot in it. Its my only working vim3. I bought a Vim4 recently. But it was DOA. Now I'm travelling and have no recourse but to keep using manjaro which Kind-of sucks. I left the android only vim3 at home. 0 Quote
