2 hours ago, Thanh Tu said:
How to update new image?
What do you mean by that? Images that are currently available are still from 25.2 ... new will be created soon. But you can anyway update them standard way: apt update + apt upgrade.
FYI: The following refers to a supervised installation done with armbian-config (starting from "community_25.5.0-trunk.370"). Not sure if the ready homeassistant Armbian images behave differently.
Before apt-upgrading the system running homeassistant (supervised), I recommend a) doing a full image backup and b) locking homeassistant-supervised ("apt mark hold homeassistant-supervised"):
Updating homeassistant-supervised with apt-upgrade first showed a selection box of the used hardware (none of them matched my rockchip64/rock 4c+ AFAIK - in despair I chose qemu-aarch64), afterwards homeassistant went into first initialization setup (the "wait ~20 minutes to set up" message). Not sure, if it would have somehow fixed itself - I reverted to the (full-image) backup once I saw that message.
Having locked the supervised package beforehand, "apt upgrade" was able to update the system without breaking homeassistant (at least it looks like that so far).
I see. This package is done bad in first place. No wonder they decide to simply drop everything ... Most of people anyway use embedded HAOS.
Then we should not adding updated packages to the repository anymore.
Hi, I've just ordered a Rock 3A and would install Debian 12 (Bookworm) with Home Assistant Application from your site as soon as the board arrives. My question: I also want to use evcc (another home automation appliance). It is available as an HA add-on but it is also mentioned in the docs as its own Armbian package. What is the right way to go? Install it as an add-on on Home Assistant or install it as an Armbian package?
I would suggest you to download clean Debian minimal image and proceed this way:
https://docs.armbian.com/User-Guide_Armbian-Software/HomeAutomation/#home-assistant
EVCC can be installed this way - official Docker container:
https://docs.armbian.com/User-Guide_Armbian-Software/HomeAutomation/#evcc
How to deal with EVCC from HA, no idea. This is application level knowledge and I am just an average user of HA. I assume addon will want to connect to the service which runs on some IP address and some port. IMO this part is similar as official HAOS image.
Current application images are not yet rebuild with latest stable base, so until then its better going clean Debain + armbian-config way.
10 minutes ago, guy cal said:
Which image can be used for a orangepipc2
Well, for Home Assistant, Armbian / Debian Bookworm image is required. That we usually provide for all variants, supported and not supported. Since this hardware is not actively maintained, we don't know if there are any hardware level issues related to this board. Here you are on your own, hope for / wish you luck. Usually things works ... Next step is this: https://docs.armbian.com/User-Guide_Armbian-Software/HomeAutomation/#home-assistant It will provide the same result as image with pre-loaded Home Assistant.
Hi! I recently tried to install an image with pre-installed HA and, to put it briefly, I failed.
Then I decided to go back to a clean installation of Armbian and install a supervised version of HA on it.
I have already done this before, but I wanted to optimize the process with your images.
And now I see that the HA team considers the supervised method unsupported.
I do not have enough experience to bypass these restrictions in the future. Therefore, I decided to go back to your version.
The issue is that these images do not have a boot partition. I tried to install using a flash drive with a boot partition from pure Armbian. But this trick did not work.
Maybe this is completely impossible, but I hope you can tell me how to install it correctly.
I am specifically interested in the image for Odroid C4, since it is for the same processor as the current TV box on Amlogic s903 x3.
This method will keep working for years and I will try to fix problems as long as they won't take too much time.
Most of Armbian images doesn't have boot partition as it is not needed.
Most of boards does not support boot from flash drive, but from SD card.
I have absolutely no clue. There is a whole section of Armbian community forums that are dealing with the complexity of booting weird TV box hardware. I suggest you to start here:
https://forum.armbian.com/forum/189-faq/
It is enough that board uses different memory modules and device won't give any sign of life. When you manage to boot Armbian Bookworm with help from TV box section, use armbian-config.
If you follow the instructions earlier in this thread, you can use the Armbian build framework to build an image for aml-s9xx-box with the HA additions, or just use armbian-config to add it.  I haven't tested any of those, as I just install the regular docker based HA on my home TV box to run HA.
Got it, I'll study this forum some more. Thanks for the detailed answers. I figured out how to download these strange TV boxes. They are also loaded mainly from the sd card. The only thing I wanted to clarify with you, just to understand how the boards are loaded from the sd card if there is no boot partition on it?
That isn't as simple of a question as you may think it is.  It depends.  But since you are dealing with a TV box, that would be better asked in a question over in the TV box forums as it is off topic for this thread.
Hello! I'm new to the Armbian world! I have successfully downloaded and got my OrangePi Zero 3 working on my end, but I do not know how to do updates. I've done apt update + apt upgrade and armbian-upgrade and they went fine, but I still see V25.2.3 upon entering the SSH session. To upgrade to latest V25.5.1 I need to to something else, or maybe wait until you update, or I need a fresh reinstall?
Sorry if this seems a basic question. Anyways, thanks for your contribution Igor! I can run other things along Home Assistant with this image!
Welcome!
This question is a bit off topic here as general Armbian updates are not part of HA extension. As this is community supported hardware, stable BSP upgrades - where OS version is stored - might not be generated, while kernel and everything else is getting upgrades. tl;dr; Don't worry about this. For board related topics proceed here https://forum.armbian.com/forum/173-allwinner-sunxi/
Hello, everyone.
I'm using Armbian_25.5.2_Orangepizero3_bookworm_current_6.12.30-homeassistant_minimal on 4GB OpiZero3.
When booting from sd, the bluetooth controller is initialized correctly.
I made a boot from usb-ssd via armbian-config: everything works fine, but the bluetooth controller is not initialized.
/sys/class/bluetooth is empty.
Switch back to sd - it works again.
Boot from ssd - no.
I compared whether it transferred the distribution correctly from sd to ssd - all files are the same.
What could be the problem?
Hello, I'm getting an error when building the kernel.
Цитата
[💲|🌿] Enabling extension [ ha ]
[💲|🔨]   ERR: Extension problem -- cant find extension 'ha' anywhere - called by /mnt/d/homeassistant/rk3528-tvbox/build/lib/functions/general/extensions.sh
[💲|💥] Exiting with error 17 [ at /mnt/d/homeassistant/rk3528-tvbox/build/lib/functions/general/extensions.sh:1
               enable_extension() --> lib/functions/general/extensions.sh:1
   initialize_extension_manager() --> lib/functions/general/extensions.sh:145
          do_main_configuration() --> lib/functions/configuration/main-config.sh:331
                do_with_logging() --> lib/functions/logging/section-logging.sh:81
    do_with_conditional_logging() --> lib/functions/logging/section-logging.sh:111
    prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:29
         cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22
        armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136
                 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208
                           main() --> compile.sh:50
[💲|💥] Cleaning up [ please wait for cleanups to finish ]
[💲|] Repeat Build Options [ ./compile.sh build BOARD=rk3528-tvbox BRANCH=legacy BUILD_DESKTOP=no BUILD_MINIMAL=yes ENABLE_EXTENSIONS=ha EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm ]
Hello.
I installed armbian trixie on orangepzero 2w. OK.
I'd like to install Homeassistant on this machine. I went to armbian-config -> Software -> HomeAutomation -> Home Assistant.
Installation went smooth< as far as I see. Then I asked to reboot system to enable AppArmor. I did that. After reboot I tried to connect to the machine via Firefox http://192.168.1.16:8123
Nothing happened.
Should I issue some commands or do some actions to continue installation?
Thanks you you advance.
Alexei
Same here:
Installed Home Assistant using armbian-config on a Rock 5b with Armbian Trixie  (v26.2.1 for Rock 5B running Armbian Linux 6.18.32-current-rockchip64). I switched from NetworkManager to systemd-networkd.
Reboot to enable AppArmor left a system not accessible via ssh after more than 100s. Do we have to wait somewhat longer, or is there currently an issue with the installation of Home Assistant on Armbian Trixie ?
to enable AppArmor
This topic is 2 years old and HA formally does not support supervised anymore.
And doing 2 such modifications and then hoping all will be fine is false hope IMO. If you don't have a serial console cable to watch kernel en journal log etc to see what your system is doing, maybe it is time now to get one. I have an old supervised inatsllation (not use for many months, but it is plain Debian and a VM so I have free/easy CLI console.
The installation of Home Assistant through armbian-config ends with a reboot in order to enable AppArmor. No modification.
If that installation does not work out of the box I will leave it for now as it would not provide a solid basis for the automation of an entire home.
48 minutes ago, ebin-dev said:
No modification.
Really?
You changed the network config, installed a massive application AND enabled apparmor in the same boot...
Cmon dude...
It probably does, if you don't also change the network.
I am running mine on Trixie, installed about a year ago. Then it worked ...
Core is running inside Docker container so functionality should be O.K., but we might currently have some problem ... I will look into this when I am about to reinstall my setup, but I plan to add Docker install only, which should work well, but it has certain limitations.
HA supervised needs Network Manager AFAIK. No idea why, didn't look deeper.
Thanks for looking into this. As the docker install does not have access to apps it would be quite restricted and not really usable for many. I would certainly not use it.
May be you could try to set up the supervised install (I know it is not supported anymore by HA) ? That would bring a lot of attention to Armbian ...
Sitrep / confirmed fix for “unhealthy: privileged” on Armbian Home Assistant Supervised
After installing Home Assistant Supervised via Armbian on an Orange Pi 4 LTS, Supervisor was blocking add-on installation with:
‘AppManager.install’ blocked from execution, system is not healthy - privileged
ha resolution info showed:
unhealthy:
privileged
unsupported:
os
However Docker itself showed the Supervisor container was already privileged:
docker inspect hassio_supervisor –format ‘{{.HostConfig.Privileged}}’
Output:
true
So the problem was not Docker missing –privileged.
The Supervisor log also showed:
Not privileged to run udev monitor!
I checked the Supervisor AppArmor profile:
sudo grep -n ‘deny network raw’ /var/lib/homeassistant/apparmor/hassio-supervisor
It returned:
8:  deny network raw,
70:    deny network raw,
Removing those deny network raw, lines from the AppArmor profile, reloading the profile, and restarting Supervisor fixed it.
Commands used:
sudo cp -a /var/lib/homeassistant/apparmor/hassio-supervisor /root/hassio-supervisor.apparmor.bak.$(date +%Y%m%d-%H%M%S)
sudo sed -i ‘/^[[:space:]]deny network raw,[[:space:]]$/d’ /var/lib/homeassistant/apparmor/hassio-supervisor
sudo apparmor_parser -r /var/lib/homeassistant/apparmor/hassio-supervisor
sudo docker restart hassio_supervisor
After restart:
ha resolution info
ha supervisor info
Now shows:
unhealthy: []
healthy: true
unsupported:
os
supported: false
I also tested the failing udev/netlink path directly:
sudo docker exec hassio_supervisor python3 -c ‘import pyudev; pyudev.Monitor.from_netlink(pyudev.Context())’
It returned silently with no error.
Conclusion: on this install, the “privileged” unhealthy state was caused by AppArmor blocking raw netlink access via deny network raw, in the hassio-supervisor profile. Docker was already privileged. Removing that AppArmor deny rule fixed Supervisor health and cleared the add-on install blocker.
The remaining unsupported: os warning is expected for Armbian/Supervised and is separate from the privileged health failure.
