송호상 Posted March 30, 2024 Posted March 30, 2024 (edited) Hey, @jock! After selecting led-conf7 (R29 MXQ, R2B MXQ, H20) in rk322x-config, the screen was displayed immediately without the need to boot from the SD card. Thank you for helping me install Armbian on my tv box. Edited March 30, 2024 by 송호상 1 Quote
Junyo Lau Posted March 30, 2024 Posted March 30, 2024 (edited) Hi, @jock. I have a same tv box as this https://forum.armbian.com/topic/34923-csc-armbian-for-rk322x-tv-box-boards/?do=findComment&comment=113935 But I can not boot from multitool, what can I do ? I'm pretty sure that my tf card is ok. Because I've checked by H2testw and I flash multitool by balenaEtcher without error. Edited March 31, 2024 by Junyo Lau 0 Quote
Caio Lima Viana Posted March 30, 2024 Posted March 30, 2024 (edited) Hi, I've been using Armbian on TVBox RK322x for some time. Basically a test that went wrong broke my system and I was forced to reinstall Armbian and all the programs I had before. To prevent something similar from happening again, I thought about saving the image to the SD card, configuring everything, installing all the programs and finally, creating a backup image of the SD card and writing Armbian to the internal EMMC. However, when I tried to write the system in the internal emmc, only the option to write the bootloader in sd/emmc appeared, thinking it was something related to the legacy kernel I was using, I upgraded to the mainline, and even then the option to write the system to emmc didn't show up. The legacy kernel is essential because I need the onboard wifi drivers, the plan was to upgrade the kernel, write to emmc, and then downgrade the kernel. The armbian that is running from the sd card was a debian buster version with a legacy kernel, so I froze the firmware and kernel, and upgraded to bookworm by changing the apt repositories and performing a full upgrade. My question is: from this bootable system via sd card, how can I install it on the internal emmc? I have already tried writing the sd card image to emmc using multitool but the box does not boot. Edited March 30, 2024 by Caio Lima Viana 0 Quote
jock Posted March 31, 2024 Author Posted March 31, 2024 17 hours ago, Junyo Lau said: Hi, @jock. I have a same tv box as this https://forum.armbian.com/topic/34923-csc-armbian-for-rk322x-tv-box-boards/?do=findComment&comment=113935 But I can not boot from multitool, what can I do ? I'm pretty sure that my tf card is ok. Because I've checked by H2testw and I flash multitool by balenaEtcher without error. Hello, sorry but without logs or detailed symptoms it is impossible to give any advice 0 Quote
jock Posted March 31, 2024 Author Posted March 31, 2024 @Caio Lima Viana Hello, should be easier to install the system on the eMMC via multitool, configure at your pleasure and then do a backup of the eMMC with the multitool ? 0 Quote
Caio Lima Viana Posted March 31, 2024 Posted March 31, 2024 Hi, thanks for the answer, you're right, I should have done that, but in theory, it should work to copy a bootable image from the sd card to the emmc, right? Where should I start looking to find out why it won't boot? I don't have a lot of experience on the subject, do you think I should do a clean installation on emmc using multitool? I would really like not to lose the settings and apps from my current system, would copying the rootfs to the new installation work? 0 Quote
jock Posted March 31, 2024 Author Posted March 31, 2024 @Caio Lima Viana Yes, copying sdcard to emmc should work, there is no difference. About the reason it does not boot, if you don't get any output on the HDMI and the board does not answer on the network, serial UART is the essential tool to get some clue about. You can surely do a clean installation on eMMC with multitool, then "transplant" the whole rootfs, but if you don't know where the issue is, you may transfer the problem too and get stuck again. 0 Quote
Caio Lima Viana Posted March 31, 2024 Posted March 31, 2024 unfortunately I don't have access to the serial UART of the TV box, I didn't find any pad with the tx rx labels on the PCB, I'm going to try to replace the rootfs, in the functional Armbian image, with the exception of the boot directory, then write it using multitool , I'll post here if this works. Thank you very much for the tips and quick responses 0 Quote
SteeMan Posted March 31, 2024 Posted March 31, 2024 @Caio Lima Viana If you post pictures of the front and back of your board, someone on here may be able to identify the uart connection points 0 Quote
Caio Lima Viana Posted March 31, 2024 Posted March 31, 2024 (edited) Thank you, looking more calmly, I found the headers marked as G, R, T. Would these be: ground, tx, rx? I think I'm confusing it with my second TVbox which has a slightly different PCB, if this is the UART interface, I'll solder headers and connect my USB adapter, at what baud rate should I listen? It worked, it was these pads, here is the output with booting from the SD card: DDR Version V1.10 20190926 In ID:0xFFF 660MHz DDR3 Bus Width=16 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB mach:2 OUT U-Boot SPL 2021.04-armbian (May 06 2021 - 19:15:25 +0000) Trying to boot from MMC2 I/TC: I/TC: Non-secure external DT found I/TC: Switching console to device: /serial@11030000 I/TC: OP-TEE version: 3.10.0-40-ga1d5c81f (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #6 Wed Sep 16 21:36:15 UTC 2020 arm I/TC: Primary CPU initializing M/TC: Not protecting region 1: 0x68400000-0x68600000 I/TC: Primary CPU switching to normal world boot U-Boot 2021.04-armbian (May 06 2021 - 19:15:25 +0000) Model: Generic Rockchip rk322x TV Box board DRAM: 992 MiB MMC: dwmmc@30000000: 1, dwmmc@30020000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@11030000 Out: serial@11030000 Err: serial@11030000 Model: Generic Rockchip rk322x TV Box board Net: eth0: ethernet@30200000 starting USB... Bus usb@30040000: USB DWC2 Bus usb@30080000: USB EHCI 1.00 Bus usb@300c0000: USB EHCI 1.00 Bus usb@30100000: USB EHCI 1.00 scanning bus usb@30040000 for devices... 1 USB Device(s) found scanning bus usb@30080000 for devices... 1 USB Device(s) found scanning bus usb@300c0000 for devices... 1 USB Device(s) found scanning bus usb@30100000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2909 bytes read in 5 ms (567.4 KiB/s) ## Executing script at 60000000 Boot script loaded from mmc 1 238 bytes read in 5 ms (45.9 KiB/s) 6094752 bytes read in 282 ms (20.6 MiB/s) 8771448 bytes read in 475 ms (17.6 MiB/s) 50042 bytes read in 10 ms (4.8 MiB/s) 786 bytes read in 7 ms (109.4 KiB/s) Applying kernel provided DT overlay rk322x-emmc.dtbo 1286 bytes read in 7 ms (178.7 KiB/s) Applying kernel provided DT overlay rk322x-led-conf1.dtbo 232 bytes read in 7 ms (32.2 KiB/s) Applying kernel provided DT fixup script (rk322x-fixup.scr) ## Executing script at 600f0000 ## Loading init Ramdisk from Legacy Image at 64000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 6094688 Bytes = 5.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 61f00000 Booting using the fdt blob at 0x61f00000 EHCI failed to shut down host controller. EHCI failed to shut down host controller. Using Device Tree in place at 61f00000, end 61f74fff Starting kernel ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot I/TC: Secondary CPU 3 initializing I/TC: Secondary CPU 3 switching to normal world boot Armbian 24.2.1 bookworm ttyS2 rk322x-box login: this is the emmc boot output running the same image from the sd card written on it: ⸮⸮DDR Version V1.10 20190926 In ID:0xFFF 660MHz DDR3 Bus Width=16 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB mach:2 OUT U-Boot SPL 2021.04-armbian (May 06 2021 - 19:15:25 +0000) Trying to boot from MMC2 I/TC: I/TC: Non-secure external DT found I/TC: Switching console to device: /serial@11030000 I/TC: OP-TEE version: 3.10.0-40-ga1d5c81f (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #6 Wed Sep 16 21:36:15 UTC 2020 arm I/TC: Primary CPU initializing M/TC: Not protecting region 1: 0x68400000-0x68600000 I/TC: Primary CPU switching to normal world boot U-Boot 2021.04-armbian (May 06 2021 - 19:15:25 +0000) Model: Generic Rockchip rk322x TV Box board DRAM: 992 MiB MMC: dwmmc@30000000: 1, dwmmc@30020000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@11030000 Out: serial@11030000 Err: serial@11030000 Model: Generic Rockchip rk322x TV Box board Net: eth0: ethernet@30200000 starting USB... Bus usb@30040000: USB DWC2 Bus usb@30080000: USB EHCI 1.00 Bus usb@300c0000: USB EHCI 1.00 Bus usb@30100000: USB EHCI 1.00 scanning bus usb@30040000 for devices... 1 USB Device(s) found scanning bus usb@30080000 for devices... 1 USB Device(s) found scanning bus usb@300c0000 for devices... 1 USB Device(s) found scanning bus usb@30100000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 Card did not respond to voltage select! : -110 Device 0: unknown device switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... libfdt fdt_check_header(): FDT_ERR_BADMAGIC 7[r[999;999H[6n8Card did not respond to voltage select! : -110 Scanning disk dwmmc@30000000.blk... Disk dwmmc@30000000.blk not ready Scanning disk dwmmc@30020000.blk... Found 2 disks No EFI system partition BootOrder not defined EFI boot manager: Cannot load any image ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-8e-44-db-3b-e1-5d ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-rk322x-rk322x-box ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-rk322x ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/default ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 Config file not found ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 => Edited March 31, 2024 by Caio Lima Viana 0 Quote
jock Posted March 31, 2024 Author Posted March 31, 2024 @Caio Lima Viana great job! Now it looks to me that u-boot is unable to work with the eMMC (it is dwmmc@30020000 device, or mmc0 in the uboot log), or for some reason is unable to find the device tree (FDT_BAD_MAGIC). It seems that there is something off with: the internal eMMC: the u-boot version is an old one, I wonder if your board is a recent one with eMCP (see first page) chip instead of regular eMMC the filesystem installed on the eMMC: you can use an sdcard with the multitool and get a shell, run fsck.ext4 /dev/mmcblk2p1 and see if finds errors; you can even mount the partition and inspect manually if /boot files are in place At the moment I have no more ideas, but these two above worth trying. 0 Quote
moddien Posted April 2, 2024 Posted April 2, 2024 Little update from my side: I got a serial adapter but was not able to find the points. I checked that 5 pin socket and the 3 pins near the infrared receiver. User @audio kees has the same board with the same name and CPU. After erasing emmc, I was able to boot Armbian 24.5 but after some seconds it turned off again. Also I got no video output but thats not important for me. I tried flashing 21.02 as suggested, but with rkdeveloptool because multitool doesnt stay on long enough to do anything useful. One question here: Where am I supposed to get the rk322x_loader.bin ? I did not flash any loader but proceeded with flashing the armbian image, hoping this loader is integrated or so but after hitting enter, nothing happened. I thought it's maybe copying very slow so i let it run over night but nothing changed. Now I cannot get it to loader mode anymore, I think I have to ask someone to solder me a wire to that clock pin cause my soldering level is too low for that tiny contact. 0 Quote
jock Posted April 4, 2024 Author Posted April 4, 2024 @moddien Why did you try to burn the image in the eMMC without being sure it would have worked? If you can boot multitool again, clean the eMMC and start fresh. I have prepared an armbian bookworm image with opensource optee in place of the proprietary one, you can download from here; I have not tested it at all, so can't guarantee it works. If you want to try it, first clean the eMMC with multitool and then try to run the image from an sdcard to see the outcome. 2 Quote
moddien Posted April 4, 2024 Posted April 4, 2024 (edited) Am 4.4.2024 um 20:58 schrieb jock: armbian bookworm image with opensource optee very nice, it boots up and doesnt crash! Thank you very much! Do I still have to prevent bootloader updates? Anything else you want me to test? And yes, i flashed without testing. I was uncautious but lesson learned, I now use my SD until I am sure I want to keep the image. edit: It is still running after 10h, I installed iobroker and test-replaced my Pi, works fine. Noticed there is still no HDMI and Armbian shows 959MB Ram instead of 2GB. I used ledconf7 - the LED now flickers when accessing the SD which is nice. edit2: i made an image of my SD with Win32DiskImager and flashed it with rkdeveloptool in WSL2 Debian. It didnt boot but now I can use multitool without crashing. I found out I have a 1GB RAM & 8GB flash device instead of 2/16 as written on the sticker. The same sticker also says Android 12 but it came with 7. Somewhere else on the packaging it says 64bit CPU, I didnt look any further... edit3: used pishrink with -s on my image (in wsl too), flashed it via multitool to the emmc. works! I know I could have used a fresh image but I had a few things set up already and was curious if this will work. /usr/lib/armbian/armbian-resize-filesystem start to expand the filesystem again. final edit (so far): rkdeveloptool also works, I just tried to flash a too big image and it didnt throw an error. Here's how to connect USB devices to WSL VM. Also I used raxda's rkdeveloptool, the original one gave me an error during make. The windows versions of rkdevtool really are cursed. There was exactly one combination of driver and tool that let me erase the flash (see earlier post), I never got it to write to it. Edited April 6, 2024 by moddien 0 Quote
DarthMirous Posted April 11, 2024 Posted April 11, 2024 (edited) Hey guys! I carried out the procedure on an MXQ 4k Pro 5G. The NAND warning message did not appear, so I followed the eMMC procedure. After flashing the image, I turned it off, removed the micro SD and turned it on. No image appeared and after a few seconds the orange LED (I believe it is from the network card) starts to blink. Can you help me? Edit: I already managed to do the recovery. I will try again to run the armbian image. Edited April 11, 2024 by DarthMirous I already managed to do the recovery. 0 Quote
fabiobassa Posted April 11, 2024 Posted April 11, 2024 @DarthMirous have you read the whole thread ? This problem has been already discussed, such as has been discussed that commercial names (MXQ 4k Pro 5G) have no meaning at all Go back at least , let's say , 10 pages starting from this searching for problems similar to yours , and also post photos of the board inside with particular attention to version of the board 0 Quote
PLaume Posted April 13, 2024 Posted April 13, 2024 (edited) Hi Guys, i am completly new to this topic. First of all i was smart enough to never safe the original OEM OS... Its not that bad since it was for free due shipping issues and i bought it for playing anyway. I have a very strange behavior on my Box MXQ Pro 5G 4K (officially 2G/16G in according to Armbian 1G/8G), it starts the multitool without any problems via SD-Card and i can install Armbian without any Problems on the Flash of the Box, but now there is the weird part the Armbian boots only the first time after installation without any problems like the GUI and everything works just fine, but if there is a powerloss it will never boot again without a complete reinstall of Armbian (or at least it looks like it doesnt boot maybe just the HDMI-Video Part doesnt wokr anymore). I think i found a way to avoid that problem by not completly set up the OS. Like: -Boot Armbian -Set up User -Set up root -Not set up Wifi (and dont connect to LAN) -Powerloss the Device Now it will start after boot into the CLI instead of an GUI, now i can install xinit and start the GUI manually (startx) if i remain in the CLI without starting the GUI the following messages will be shown: hdmi-audio-codec hdmi-audio-codec.2.auto: only one simultaneous stream supported hdmi-audio-codec hdmi-audio-codec.3.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 and ssv wlan driver ssv 6200: failed to initialize mac, ret=-1 Since i cant upload images: https://ibb.co/60gJpCW https://ibb.co/18kXVq9 According to my informations the Board is an RK3229Q-221P-V1.3 but the Chips seems to be different to the ones of other users posted here. So in the end it works for me, but i wonder if that could be fixed. Edited April 13, 2024 by PLaume Adding Informations about the Box 0 Quote
jock Posted April 13, 2024 Author Posted April 13, 2024 @PLaume Hello! Well, a power loss is a power loss... you won't know what will be gone when the cache is not flushed. I read from the eMCP the code "JY941" or "JY94I", but according to micron part decoder (https://www.micron.com/sales-support/design-tools/fbga-parts-decoder), that chip does not exist. Perhaps it is a fake chinese chip with "micron" printed on it with unknown reliability? About the errors, the hdmi "error" is rather an information and does not affect any feature. The ssv6200 error instead says that the wifi chip does not work because the driver only support ssv6051p chip and not the ssv6256p your board has. 0 Quote
PLaume Posted April 14, 2024 Posted April 14, 2024 Hi @jock, the chip seems truly suspicious, in reality the plastic even looks like it has some kind of rust or had too much heat on it. I think I didn't explained the power loss part well, the power loss takes place after an shutdown (but the led will be on, even after the shutdown). But after some tries I could reproduce the problem at the regular initialization process and have also found a solution. Generally I used the device with a 1024x600 (wsvga ia the weirdest resolution I know) HDMI Touch screen. If I boot the device on a regular powered on full hd screen and switch to the touch screen it works without any problems. If I boot without a screen (and switch to the touch screen) or with the touch screen already connected it will show nothing. So I guess its just some kind graphic driver problem. Since i want to let it run 24/7 it's completely fine. 0 Quote
im_chc Posted April 26, 2024 Posted April 26, 2024 On 7/7/2023 at 7:49 PM, jock said: Surely the SOC itself is not capable to boot from USB, there should be a piece of software installed on the SPI (read: uboot) that will do that. If you put an sdcard in a USB dongle and then the USB dongle in the USB port clearly you're trying to boot from USB, so it won't work Hi @jock! Recently I do really look into the rockchip docs and try to work on that little dongle toy a bit. And then I look back at my original post, and I realize that at that time I totally didn't know what I was doing At that time, after trying and failing the other rkdeveloptool commands (rfi, ppt etc), I did have execute rkdeveloptool db rk322x_loader_v1.10.256.bin at that time, but I was not aware that these commands would now work after the loader bin file had been loaded, and then I stopped trying. OK, these are what I have tried this time: root@debianvm:~# ./rkdeveloptool/rkdeveloptool ld DevNo=1 Vid=0x2207,Pid=0x320b,LocationID=101 Maskrom root@debianvm:~# ./rkdeveloptool/rkdeveloptool db /home/h__c___g/rk322x_loader_v1.10.256.bin Downloading bootloader succeeded. root@debianvm:~# ./rkdeveloptool/rkdeveloptool ul /home/h__c___g/rk322x_loader_v1.10.256.bin Upgrading loader succeeded. root@debianvm:~# ./rkdeveloptool/rkdeveloptool rfi Flash Info: Manufacturer: SAMSUNG, value=00 Flash Size: 0 MB Flash Size: 0 Sectors Block Size: 512 KB Page Size: 2 KB ECC Bits: 0 Access Time: 40 Flash CS: root@debianvm:~# ./rkdeveloptool/rkdeveloptool rci Chip Info: 41 32 32 33 FF FF FF FF FF FF FF FF FF FF FF FF root@debianvm:~# ./rkdeveloptool/rkdeveloptool rcb Capability:07 00 00 00 00 00 00 00 Direct LBA: enabled Vendor Storage: enabled First 4m Access: enabled Read Com Log: enabled I realize that the Flash Size read 0 mb. I obtain rk322x_loader_v1.10.256.bin by commenting out the rm -f line in the (github) rkbin/scripts/checkpatch.sh file. Maybe the loader firmware did not support SPI? But before I do the ul line, I do try dumping the storage using rkdeveloptool rl 0 xxxxx dump.bin and then strings dump.bin, and nothing comes out; but after I do the ul line, the strings really do spit out many random lines, and I think it is evidence that I can use the rkdeveloptool binary to write bytes to the SPI... Is there any chance for me to make this dongle sort of working by using the rockchip proprietary binaries to pack up the uboot.img, trust.img and boot.img files, and then flash them in? 0 Quote
jock Posted April 28, 2024 Author Posted April 28, 2024 @im_chc AFAIK the loader firmwares around do not support anything else than sdcard and emmc, but I may wrong: I have never seen a rk322x device with SPI flash memory, so I can't bet on my affirmation. Perhaps you should have a look to the rockchip repository on github or search around to see if there is a rk322x loader for SPI memories. 1 Quote
im_chc Posted April 29, 2024 Posted April 29, 2024 (edited) 14 hours ago, jock said: @im_chc AFAIK the loader firmwares around do not support anything else than sdcard and emmc, but I may wrong: I have never seen a rk322x device with SPI flash memory, so I can't bet on my affirmation. Perhaps you should have a look to the rockchip repository on github or search around to see if there is a rk322x loader for SPI memories. @jock I don't know, I found this rockchip document, it said (p.24, in chinese) something like "RK SPI supported in uboot", and points me to this source file: https://github.com/rockchip-linux/u-boot/blob/next-dev/drivers/spi/rk_spi.c In the source the rk32 series SoC mentioned is only rk3288, what do you think? Here is the equivalent in the kernel source (found rk3228 in it): https://github.com/rockchip-linux/kernel/blob/develop-4.4/drivers/spi/spi-rockchip.c All of these might be irrelevant though Btw, I have also tested writing some files to it using rkdeveloptool wl, the next immediate rl seems to be able to dump out the data, but this didn't survive a reboot. Maybe it is only writing to the DDR. Edited April 29, 2024 by im_chc Tagging a user, add content 0 Quote
jock Posted April 29, 2024 Author Posted April 29, 2024 @im_chc those source code files are irrelevant for the boot issue: the rk322x has a SPI bus where the board maker can connect anything other than a flash memory. Those drivers handle the low level communications along that bus, but whatever is connected to that (a flash memory, a wifi devices, a led strip, a led panel driver, or whatever...). You need a loader (specifically, the miniloader), which is engaged before uboot and the kernel, which should support reading from the SPI to load u-boot. You also will need u-boot and kernel compiled to read and write to the SPI flash of course, but the first step is the miniloader. 0 Quote
R Tech Posted May 3, 2024 Posted May 3, 2024 (edited) I recently purchased a cheap TV box (RK3228A) on AliExpress and I'm trying to boot up MULTITOOL for installing Armbian. However, it's not starting. Steps followed: - Flashed the multitool.img onto an SD card using BalenaEtcher. - Removed the SD card from the Computer and inserted it into the TV BOX slot. - Connected the power cable to the BOX. Result: - No event occurred. - The red light on the BOX lit up. - However, MULTITOOL didn't start. - The monitor shows "HDMI no signal". I tried using another multitool.img, but also without success. Could anyone help me? I'm not an expert on this matter. TV BOX: https://i.ibb.co/NsZ12LT/tvbox.jpg | https://i.ibb.co/ScwRG4V/tvbox2.jpg Edited May 3, 2024 by R Tech 0 Quote
fabiobassa Posted May 3, 2024 Posted May 3, 2024 (edited) @R Tech Definetly not Easy tò answer what Is going wrong with no booting without any support from uart ( USB/ttl adapter). Let see if somebody else has experienced trouble with this board like your, very recent board Btw It has ecmp chip Edited May 3, 2024 by fabiobassa 0 Quote
suser Posted May 5, 2024 Posted May 5, 2024 (edited) Hello all, I have here R29_MXQ_221_V1.0_1008, WiFi is RTL8723AS. I used this image: Armbian_24.2.5_Rk322x-box_jammy_current_6.6.22.img Added line in /boot/armbianEnv.txt >> overlays=led-conf7 as respected @jock advice. Now Armbian boot from uSD, but no WiFi, i have a backup of Android kernel, from where i can extract DTB if needed. What should i do about the Wifi ? I can even try to change the WiFi module with another HW... Edited May 5, 2024 by suser hw 0 Quote
jock Posted May 5, 2024 Author Posted May 5, 2024 4 hours ago, suser said: What should i do about the Wifi ? I can even try to change the WiFi module with another HW... Hello! The problem is the missing driver for the rtl8723as. Actually, there is a driver floating around, but adapting and keeping it working on every kernel release require a lot of effort. I don't even have a board with such chip, so it is indeed very difficult, but it may become unworthy of the time spent because realtek drivers are very messy. You could find the source code and compile it yourself, or perhaps desoldering the wifi module and change the chip with another one is easier! It would be even easier to attach an USB wifi device. BTW, in the forum thread there is a success story with rlt8723as driver, you may want to search with forum tools or google. 1 Quote
RaptorSDS Posted May 5, 2024 Posted May 5, 2024 (edited) vor 5 Stunden schrieb suser: Now Armbian boot from uSD, but no WiFi, Please can you be more clear did armbian boot befor without hdmi but with wifi ? or only android had wifi ? did you have a bootlog or dmesg with dmesg | grep 8723 or dmesg | sdio ; maybe dmesg | grep - i 8723 if this is positiv than only a driver issue , else also DTS/DTB maybe dont activate the wifi sdio Edited May 5, 2024 by RaptorSDS 1 Quote
suser Posted May 5, 2024 Posted May 5, 2024 (edited) 17 minutes ago, RaptorSDS said: Please can you be more clear did armbian boot befor without hdmi but with wifi ? or only android had wifi ? Without using led-conf7 overlay no HDMI, IDK about WiFi, but strongly doubt it has, even didn't check it and no boot logs. WiFi was working on Android with some old 3.x kernel. I think i should listen to @jock and finally once and forever to forgot about some WiFi problems when they arise, as i spent much time on that, instead of just using LAN or USB WiFi, but if you need some debug info i could sent a log. If the driver is not included in Linux kernel, which i think, as i believe in @jock and i have to compile all i am just off... Edited May 5, 2024 by suser 0 Quote
