IngwiePhoenix Posted March 11, 2024 Posted March 11, 2024 Hello there! Over the past month and more I have been making many experiments - and right now, I am waiting for a finished product; a Docker container with musl-libc and gcc to serve as a "clean slate build environment". Initially, I had intended for this to be the environment for Alpine Linux - because I want the `alpine:3.19` container so half my software, including k3s, stops complaining xD - but figured, I made all those configs and have gathered all of this experience AND have a board right here - which is where I am putting my container together, too. Yep, those four cores are working overtime, since a month straight, between dozen revisions and rebuilds. I still have to finalize my U-Boot and OpenSBI config; but this is what my kernel has right now: ``` # cat /boot/config-6.6.0-g076ede06c00a | grep -E "JH7110|JH7100|SIFIVE|STARFIVE|VISIONFIVE" # CONFIG_SOC_SIFIVE is not set CONFIG_ARCH_STARFIVE=y CONFIG_SOC_STARFIVE=y CONFIG_ERRATA_SIFIVE=y CONFIG_ERRATA_SIFIVE_CIP_453=y CONFIG_ERRATA_SIFIVE_CIP_1200=y CONFIG_PCIE_STARFIVE_HOST=y CONFIG_DWMAC_STARFIVE=y CONFIG_SERIAL_SIFIVE=y CONFIG_SERIAL_SIFIVE_CONSOLE=y CONFIG_HW_RANDOM_JH7110=y CONFIG_SPI_SIFIVE=m CONFIG_PINCTRL_STARFIVE_JH7100=y CONFIG_PINCTRL_STARFIVE_JH7110=y CONFIG_PINCTRL_STARFIVE_JH7110_SYS=y CONFIG_PINCTRL_STARFIVE_JH7110_AON=y # CONFIG_GPIO_SIFIVE is not set CONFIG_STARFIVE_WATCHDOG=y CONFIG_DRM_VERISILICON_STARFIVE_HDMI=y CONFIG_SND_SOC_STARFIVE=y CONFIG_SND_SOC_JH7110_PWMDAC=y CONFIG_SND_SOC_JH7110_TDM=y CONFIG_USB_CDNS3_STARFIVE=y CONFIG_MMC_DW_STARFIVE=y CONFIG_VIDEO_STARFIVE_CAMSS=y CONFIG_CLK_STARFIVE_JH71X0=y CONFIG_CLK_STARFIVE_JH7100=y CONFIG_CLK_STARFIVE_JH7100_AUDIO=y CONFIG_CLK_STARFIVE_JH7110_PLL=y CONFIG_CLK_STARFIVE_JH7110_SYS=y CONFIG_CLK_STARFIVE_JH7110_AON=y CONFIG_CLK_STARFIVE_JH7110_STG=y CONFIG_CLK_STARFIVE_JH7110_ISP=y CONFIG_CLK_STARFIVE_JH7110_VOUT=y CONFIG_STARFIVE_JH7110_TIMER=y CONFIG_SIFIVE_CCACHE=y # CONFIG_PWM_SIFIVE is not set CONFIG_SIFIVE_PLIC=y CONFIG_RESET_STARFIVE_JH71X0=y # CONFIG_RESET_STARFIVE_JH7100 is not set CONFIG_RESET_STARFIVE_JH7110=y CONFIG_PHY_STARFIVE_JH7110_DPHY_RX=y CONFIG_PHY_STARFIVE_JH7110_PCIE=y CONFIG_PHY_STARFIVE_JH7110_USB=y CONFIG_CRYPTO_DEV_JH7110=y ``` And those are required. There is a porting page about the currently outstanding patches that have yet to be accepted into mainline, so I am just effectively living on this: https://github.com/starfive-tech/linux/tree/JH7110_VisionFive2_upstream (note the branch). This is Linux 6.6.0. I am also working on merging Imaginary's GPU drivers - currently based on 6.6.0-rc1 - into this tree, but Github won't let me post it... Oh well; the merge is just four files. Aside from that, there are also repos for MESA and the linux-firmware; constituting two packages specific to this board - or rather, this GPU. I wish they had made the driver itself a DKIM one... would've been more portable, I suppose. Anyway; with all of this said, I have a few questions: 1. Where does one apply for maintainership? The VF2 currently has none. 2. How, in the automated build process (`compile.sh` in the `armbian/build` repo), do I specify config snippets for this specific soc/board for kernel, u-boot and openspi? 3. Anything else I need? Kind regards, Ingwie 1 Quote
Solution SteeMan Posted March 12, 2024 Solution Posted March 12, 2024 I'd recommend starting by submitting PRs for the board. Build up some knowledge and experience with Armbian development and processes. Then when you feel comfortable with the requirements expected of a maintainer, make that final commitment (https://docs.armbian.com/Board_Maintainers_Procedures_and_Guidelines/) 0 Quote
IngwiePhoenix Posted March 13, 2024 Author Posted March 13, 2024 Apologies for the late reply; tapped the solution button whilst on the train ^^ I will sit down and work this out; currently working on somehow getting the merged kernel posted to Github. Both of them - ImaginaryGPU and StarFive - have "stopped" as they await merges, which ought to take a while. In fact, the kernel setup is what "worries" me most. The rest? Probably easy-peasy. Anyways, thanks for the pointers - time to get to work! 0 Quote
libriunc Posted January 25, 2025 Posted January 25, 2025 I want to revert to the community build of vf2 (server ubuntu/debian) because I don't need a GUI. Noticed that the jh7110 of openwrt can be built normally, using the 6.6.x kernel. So what can I do to revert to the community rolling release for this board?🤔 0 Quote
Igor Posted January 25, 2025 Posted January 25, 2025 2 hours ago, libriunc said: what can I do to revert to the community rolling release for this board? Make them build & boot able within the build framework https://github.com/armbian/build When you confirms, open a PR https://github.com/armbian/build/pulls and change config file from .eos to .csc and automation will become to produce images. 1 Quote
