olivluca Posted October 20, 2017 Share Posted October 20, 2017 It turns out that after a few hours of running motion the captured image have a green tint (not like the above sample at 1600x1200, just a normal image with almost no red-blue components). Since I'm using the beta repository I though it was a problem of the kernel of the day, in fact updating and rebooting solved the issue. It turns out that's enough to stop and start motion to get a normally coloured image. Do you think it's an hardware or driver issue? Link to comment Share on other sites More sharing options...
Seven30Four Posted October 31, 2017 Share Posted October 31, 2017 So, if I'm reading things correctly, the problem is resolved with an older version? I can't test this out due to the fact that 5.2.0 is no longer available in the archive. Would anyone be so kind as to upload it elsewhere? Link to comment Share on other sites More sharing options...
Dimak Posted November 4, 2017 Share Posted November 4, 2017 On 01.09.2017 at 6:36 PM, garlic said: I had solved this problem by my friend. Run this script sunxi-pio -m "PG11<1><0><1><1>" modprobe gc2035 modprobe vfe_v4l2 The most import is that don't load gc2035 & vfe_v4l2 before. So you had better remove it in /etc/modules This is my /etc/modules #w1-sunxi #w1-gpio #w1-therm #gc2035 #vfe_v4l2 #sunxi-cir #v4l2loopback you may see /dev/video0, but when you reboot, it lose again I add my scrip to /etc/rc.local this is my /etc/rc.local sunxi-pio -m "PG11<1><0><1><1>" modprobe gc2035 modprobe vfe_v4l2 sleep 5 modprobe v4l2loopback devices=2 /root/vidcopy/vidcopy -w 640 -h 480 -r 30 -i /dev/video0 -o /dev/video1 -f UYVY sleep 5 /root/vidcopy/vidcopy -w 640 -h 480 -r 30 -i /dev/video1 -o /dev/video2 -f UYVY exit 0 Thanks my friend: "虚耗" It's not helped for me. Armbian 5.31 don't want to make camera active. Why you work with PG11 pin? Maybe here is the difference beetween OPi PC and OPi One? It's likely PE11 in OPi One. Anyway, /dev/video0 is not created. Link to comment Share on other sites More sharing options...
Dimak Posted November 4, 2017 Share Posted November 4, 2017 Anyone, please, help me to activate camera. It's not power up at all. What address line needs to make HIGH to turn it on?? I was add to rc.local: sunxi-pio -m "PD14<1><default><default><1>" sunxi-pio -m "PE14<1><default><default><1>" sunxi-pio -m "PE15<1><default><default><0>" sunxi-pio -m "PA17<1><default><default><1>" sunxi-pio -m "PG11<1><0><1><1>" modprobe gc2035 modprobe vfe_v4l2 But still have not /dev/video0, and have: [ 5.358154] [CSI_ERR][GC2035]sensor_read err at sensor_detect! [ 5.358170] [CSI_ERR][GC2035]chip found is not an target chip. Camera connected right. Seller said it works under Armbian 5.20. What is the different in initialization?? Is anyone have script.bin of Armbian 5.20 for OPi One? I can't find old images. The older only 5.25. And who can say what means <drive level> at sunxi-pio command? Is it different voltage levels (1.5,1.8,2.8,3.3)? Thanks! Link to comment Share on other sites More sharing options...
olivluca Posted November 5, 2017 Share Posted November 5, 2017 AFAIK drive level refers to the current that a gpio configured as output can supply, unfortunately I don't remember where I read it and cannot find the documentation right now. Link to comment Share on other sites More sharing options...
Dimak Posted November 6, 2017 Share Posted November 6, 2017 I think it is driver problem, but I can misstake. The thing is, if I turn on lines below in rc.local, when driver starts it's turns off - no power, reset is low. sunxi-pio -m "PG11<1><0><1><1>" #AVDD,DOVDD,DVDD sunxi-pio -m "PE15<1><0><1><0>" #Power_Down sunxi-pio -m "PE14<1><0><1><1>" #reset Please, can anybody give me some advice to fix it? Link to comment Share on other sites More sharing options...
Dimak Posted November 6, 2017 Share Posted November 6, 2017 On 05.11.2017 at 5:04 PM, olivluca said: AFAIK drive level refers to the current that a gpio configured as output can supply, unfortunately I don't remember where I read it and cannot find the documentation right now. Thanks olivluca! But as I understand all service signals ok. Two questions: 1. Can I see camera on a i2c bus when do i2cdetect - y 0/1? 2. What address on twi is right? I have =120 in my script.bin, but tryed to change on = 0x78. Or it is the same? Thanks! Link to comment Share on other sites More sharing options...
Dimak Posted November 6, 2017 Share Posted November 6, 2017 Ok guys, I found the answer! 1. DO NOT touch /etc/modules. Leave it like that: #w1-sunxi #w1-gpio #w1-therm #gc2035 #vfe_v4l2 2. rc.local: modprobe gc2035 hres=0 modprobe vfe_v4l2 sunxi-pio -m "PG11<1><0><1><1>" #DOVDD sunxi-pio -m "PE15<1><0><1><0>" #Power_Down sunxi-pio -m "PE14<1><0><1><1>" #reset And it works! $fswebcam -r 1600x1200 -p YUV420P /home/dimak/qwe.jpg I got image. Thanks for all!!! 1 Link to comment Share on other sites More sharing options...
Dmitriy Voitenko Posted November 8, 2017 Share Posted November 8, 2017 I try this method. But /dev/video0 ... No such file or directory. Armbian 5.31 LTS 3.3.113 After reconect fpc cable and reboot camera work. Thank your. Link to comment Share on other sites More sharing options...
Dimak Posted November 17, 2017 Share Posted November 17, 2017 On 08.11.2017 at 12:17 PM, Dmitriy Voitenko said: I try this method. But /dev/video0 ... No such file or directory. Armbian 5.31 LTS 3.3.113 After reconect fpc cable and reboot camera work. Thank your. Reboot is necessarily! rc.local applyes parametrs at boot. Link to comment Share on other sites More sharing options...
hauptmech Posted November 28, 2017 Share Posted November 28, 2017 Following this thread I got an Orange Pi Zero Plus 2 H3 with Armbian 5.35 jessie working. My rc.local file looks like: sunxi-pio -m "PA8<1><0><1><1>" #DOVDD sunxi-pio -m "PE15<1><0><1><0>" #Power_Down sunxi-pio -m "PE14<1><0><1><1>" #reset modprobe gc2035 modprobe vfe_v4l2 sleep 5 modprobe v4l2loopback Link to comment Share on other sites More sharing options...
zukol21 Posted December 29, 2017 Share Posted December 29, 2017 following the thread i've tried to find the way to make it work on opiLite. Armbian 5.35, no chance to get 5.20. I tried different GPIO's settings with no success. Anybody succeed with this setup? Any knowlege on pins? Link to comment Share on other sites More sharing options...
chwe Posted December 30, 2017 Share Posted December 30, 2017 On 4.11.2017 at 12:43 PM, Dimak said: On 1.9.2017 at 5:36 PM, garlic said: I had solved this problem by my friend. Run this script sunxi-pio -m "PG11<1><0><1><1>" modprobe gc2035 modprobe vfe_v4l2 The most import is that don't load gc2035 & vfe_v4l2 before. So you had better remove it in /etc/modules This is my /etc/modules #w1-sunxi #w1-gpio #w1-therm #gc2035 #vfe_v4l2 #sunxi-cir #v4l2loopback you may see /dev/video0, but when you reboot, it lose again I add my scrip to /etc/rc.local this is my /etc/rc.local sunxi-pio -m "PG11<1><0><1><1>" modprobe gc2035 modprobe vfe_v4l2 sleep 5 modprobe v4l2loopback devices=2 /root/vidcopy/vidcopy -w 640 -h 480 -r 30 -i /dev/video0 -o /dev/video1 -f UYVY sleep 5 /root/vidcopy/vidcopy -w 640 -h 480 -r 30 -i /dev/video1 -o /dev/video2 -f UYVY exit 0 Thanks my friend: "虚耗" did you tried this one? according to schematics there shouldn't be a difference between OPi One and OPi PC Plus Link to comment Share on other sites More sharing options...
zukol21 Posted December 30, 2017 Share Posted December 30, 2017 Thanks for the reply. im using OPI Lite as i've mentioned before. i've tried the scripts you point to, but i didnt menage to modprobe v4l2loopback devices=2 i cannot install the module. I stuck on make and make and install part of importing. But i thought v4l2loopback just forwards the dev/video0 signal to dev/video1 virtual path, but after running your script i still cannot find dev/Video0 device. Link to comment Share on other sites More sharing options...
ledfreak3d Posted January 2, 2018 Share Posted January 2, 2018 has this been fixed in 5.36 ? i am uable to get the camera working at all Link to comment Share on other sites More sharing options...
Konstantinos Brokalakis Posted January 12, 2018 Share Posted January 12, 2018 Hello! I have the same problem with 5.36, I cannot make it work and I've tried all the proposed solutions from this topic. anyone solved it yet? Link to comment Share on other sites More sharing options...
chwe Posted January 13, 2018 Share Posted January 13, 2018 3 hours ago, Konstantinos Brokalakis said: I've tried all the proposed solutions from this topic sure? OPi PC+ just weeks ago... Link to comment Share on other sites More sharing options...
Konstantinos Brokalakis Posted January 13, 2018 Share Posted January 13, 2018 Thank you!! 20 hours ago, chwe said: sure? OPi PC+ just weeks ago... I didn't connect the camera properly! I had the my OPi One away in the basement connected on the network and today that I visited it again I realized what was happening. Thanks for indicating the exact message from @informer15 that made it work, and made me realize that it should work! Here is the output from my camera! OPi One, Armbian 5.36, Kernel 3.4.113 Link to comment Share on other sites More sharing options...
ledfreak3d Posted January 16, 2018 Share Posted January 16, 2018 it wil detect it and work in motion but it wont work in mjpg_streamer Link to comment Share on other sites More sharing options...
dbalster Posted January 17, 2018 Share Posted January 17, 2018 Hint: check the orientation of your cable! Hi guys, I also came here after purchasing a cheap orangepione + camera, had the same error dmesg but all the GPIO magic did not work for me. Then I checked the camera connection and the cable end at the camera board was flipped - it came pre-assembled and I assumed it was right, but it wasn't. Google with image search and verify your cable connection. My cable had blue markers, they are facing up now (before it was flipped at the camera side). hope it helps. Link to comment Share on other sites More sharing options...
StuxNet Posted February 9, 2018 Share Posted February 9, 2018 The actual better ending to this story is not a post of the working camera but actually the underlying issue in the first place. I'm not a newb but I also don't know every schema of every board I own. Does the cable connect N/E/S/W on OPi/NPi/RPi/BPi? Perhaps include a picture of the correct orientation of the connected camera's ribbon cable? No one seems to ever talk about that. Not going to spend the next 4 hours yakshaving the cam across 6+ boards, 3 OS's in an attempt to port, decipher posts and problem solve. Multiply every attempt by 3 because I wonder "is the camera actually connected properly?". Just to document [accurately on GitHub] a more universal method for all. Moderators hate it when they go out of their way to provide software solutions to newbs with simple hardware problems. Strike that, reverse it. Link to comment Share on other sites More sharing options...
schlaubi666 Posted March 11, 2018 Share Posted March 11, 2018 i run an orange pi one , with the camera module sudo modprobe gc2035 sudo modprobe vfe_v4l2 works but sudo modprobe v4l2loopback >modprobe: FATAL: Module v4l2loopback not found in directory /lib/modules/3.4.113-sun8i so i ran "sudo apt install v4l2loopback-dkms" reboot sudo modprobe v4l2loopback >modprobe: FATAL: Module v4l2loopback not found in directory /lib/modules/3.4.113-sun8i result is the same , some tips ??? uname -a >Linux orangepione 3.4.113-sun8i #18 SMP PREEMPT Wed Jan 24 22:10:49 CET 2018 armv7l armv7l armv7l GNU/Linux Link to comment Share on other sites More sharing options...
Ucino Posted March 17, 2018 Share Posted March 17, 2018 Hello, I'm trying to use the CSI Orange Pi camera on orange Pi PC+, with motionEye, with Armbian Legacy Ubuntu desktop stable for OrangePiPC+ ( 5.38 | armhf | armv7l | 3.4.113-sun8i ) here is the armbianmonitor -u http://ix.io/YDB I wasn't able to use the camera but running with this in the terminal, it works ! Thanks. su root sunxi-pio -m "PG11<1><0><1><1>" modprobe gc2035 modprobe vfe_v4l2 However, when I reboot it is not working, and I have to reenter these commands. Doing this : su root nano /etc/rc.local I tried all the modification described in this thread (copy past, without modifying it, and alwas leaving the "exit 0" at the end) of rc.local but it's not working by defaut, I have to manually enter su root sunxi-pio -m "PG11<1><0><1><1>" modprobe gc2035 modprobe vfe_v4l2 in order to use the camera. Someone have any tips on how can I make the camera working by default ? Maybe I have to adapt the commands of the rc.local ? If yes, someone know I can find some information in order to adapt it ? @StuxNet here a photo : https://lightpics.net/i/PyuE Thanks Link to comment Share on other sites More sharing options...
Ucino Posted March 20, 2018 Share Posted March 20, 2018 Ok I think I have understood the problem : There is a difference between boot and reboot... nano /etc/rc.local is for booting but not for reboot. So if I add : sunxi-pio -m "PG11<1><0><1><1>" modprobe gc2035 modprobe vfe_v4l2 exit 0 to /etc/rc.local with root user AND I shutdown the system, it's working, If iI just reboot, it's not working after having edited /etc/rc.local , we have to shutdown and boot... Link to comment Share on other sites More sharing options...
olivluca Posted March 22, 2018 Share Posted March 22, 2018 On 11/9/2017 at 12:22 PM, olivluca said: I'm getting weird results with motion: If I set 800x600 the image is OK but flipped horizontally If I set 640x480 the image is OK if I set 1600x1200 this is what I get: Any news/hint on this issue? (fswebcam-gc2035 does the same) Link to comment Share on other sites More sharing options...
olivluca Posted March 29, 2018 Share Posted March 29, 2018 I compiled the module from here https://github.com/avafinger/gc2035 (gc2035.c, without trying to apply the patch in the same repository) and it works much better than the one included in armbian (though it has other quirks, see below). I tried many of the advertised resolutions and they all work: 640 x 480 (flipped horizontally) 800x600 (ok) 1280x720 (slightly washed up) 1600x1200 (too much for motion) Let's see if it lasts or if it causes more problems, but if nobody is going to fix the current driver I propose to revert to the older one. Link to comment Share on other sites More sharing options...
Felix Schuster Posted April 5, 2018 Share Posted April 5, 2018 I'am also trying to get this run all day long. I tried all the things in this post and finally found out, that I have connection problems of the ribbon cable. I' am using the OPi Lite and therefore I need to connect the camera on one side withe blank contacts of the ribbon facing the pcb and on the other side facing away from the pcb, like in the attached pic. Measuring on the camera pcb I found out that the 5v on the outer lines doesn't arrive. What am I doing wrong? Removing the blck plastic part and positioning the ribbon loose i could measure the 5V. But still I get the error : [ 26.658416] [CSI_ERR][GC2035]sensor_read err at sensor_detect! [ 26.658436] [CSI_ERR][GC2035]chip found is not an target chip. Maybe you have an advice for me? I am almost throwing everything in the trash. Best regards Link to comment Share on other sites More sharing options...
Ucino Posted April 6, 2018 Share Posted April 6, 2018 Hello, Have you tried to connect the ribbon differently ? For me only as this it was working : https://lightpics.net/i/PyuE Link to comment Share on other sites More sharing options...
jps Posted September 2, 2018 Share Posted September 2, 2018 Excuse my clumsiness, but I don't know what to do with the files in https://github.com/avafinger/gc2035 i can not find the paths related in this link.... i can not make the camera work in last Armbian. Thanks any help... Link to comment Share on other sites More sharing options...
olivluca Posted September 3, 2018 Share Posted September 3, 2018 On 9/2/2018 at 5:57 PM, jps said: Excuse my clumsiness, but I don't know what to do with the files in https://github.com/avafinger/gc2035 To compile it as an out of tree module I had to borrow some files from the full kernel source (I don't remember the details though, it's been a while). However On 9/2/2018 at 5:57 PM, jps said: .. i can not make the camera work in last Armbian. Thanks any help... if by latest armbian you mean the one based on the 4.x kernel, I don't think it has the required csi driver. Link to comment Share on other sites More sharing options...
