  • 0
Armbian 5.25 on OrangePI PC: The gc2035 video camera doesn't work
IgZero
Question
After update from armbian5.23 to armbian5.25 driver for gc2035 not work. The device isn't defined.
=========== Armbian 5.25 ==============
root@orangepipc:~# ls /dev/video*
/dev/video0  /dev/video1
Where: /dev/video0 and /dev/video1 - v4l2loopback
root@orangepipc:~# cat /etc/modules
#8189es
#rfcomm
#w1-sunxi
#w1-gpio
#w1-therm
gc2035
vfe_v4l2
#sunxi-cir
v4l2loopback
root@orangepipc:~# modinfo vfe_v4l2
filename:       /lib/modules/3.4.113-sun8i/kernel/drivers/media/video/sunxi-vfe/vfe_v4l2.ko
description:    Video front end driver for sunxi
license:        Dual BSD/GPL
author:         raymonxiu
depends:        videobuf-core,vfe_os,vfe_subdev,videobuf-dma-contig,cci
intree:         Y
vermagic:       3.4.113-sun8i SMP preempt mod_unload modversions ARMv7 p2v8
parm:           ccm:string
parm:           i2c_addr:uint
parm:           act_name:string
parm:           act_slave:uint
parm:           define_sensor_list:uint
parm:           vfe_i2c_dbg:uint
parm:           isp_log:uint
parm:           vips:uint
root@orangepipc:~# modinfo gc2035
filename:       /lib/modules/3.4.113-sun8i/kernel/drivers/media/video/sunxi-vfe/device/gc2035.ko
license:        GPL
description:    A low-level driver for GalaxyCore gc2035 sensors
author:         @lex
author:         leonardo lontra
author:         raymonxiu
alias:          i2c:gc2035
depends:        cci,vfe_subdev
intree:         Y
parm:           hres:hres=0 (640x480|1280x720|1600x1200 - 15 FPS), hres=1 (800x600|1600x1200 - 10 FPS), hres=2 (320x240|640x480|800x600 - 20 FPS), hres=3 (320x240|352x288|640x480 - 15 FPS) (default=0) (uint)
parm:           mclk:mclk override (default=0) (uint)
parm:           frate:frate override (default=0) (uint)
root@orangepipc:~# dmesg | grep GC2035
[    5.938267] [CSI_ERR][GC2035]sensor_read err at sensor_detect!
[    5.938289] [CSI_ERR][GC2035]chip found is not an target chip.
root@orangepipc:~# uname -a
Linux orangepipc 3.4.113-sun8i #28 SMP PREEMPT Thu Feb 2 02:01:28 CET 2017 armv7l armv7l armv7l GNU/Linux
root@orangepipc:~# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepipc
BOARD_NAME="Orange Pi PC"
VERSION=5.25
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
IMAGE_TYPE=stable
root@orangepipc:~#
Under armbian5.23 the gc2035 driver works. The device is defined.
=========== Armbian 5.23 ==============
/dev/video0  /dev/video1  /dev/video2
Where: /dev/video0 and /dev/video1 - v4l2loopback, /dev/video2 - gc2035
#8189es
#gpio_sunxi
#w1-sunxi
#w1-gpio
#w1-therm
gc2035
vfe_v4l2
#sunxi-cir
v4l2loopback
filename:       /lib/modules/3.4.112-sun8i/kernel/drivers/media/video/sunxi-vfe/vfe_v4l2.ko
author:         raymonxiu
intree:         Y
vermagic:       3.4.112-sun8i SMP preempt mod_unload modversions ARMv7 p2v8
parm:           ccm:string
parm:           i2c_addr:uint
parm:           isp_log:uint
parm:           vips:uint
filename:       /lib/modules/3.4.112-sun8i/kernel/drivers/media/video/sunxi-vfe/device/gc2035.ko
license:        GPL
author:         @lex
author:         raymonxiu
alias:          i2c:gc2035
intree:         Y
[    5.353480] [CSI][GC2035]V4L2_IDENT_SENSOR=2035
[    5.780057] [CSI][GC2035]disalbe oe!
Linux orangepipc 3.4.112-sun8i #10 SMP PREEMPT Sun Oct 23 16:06:55 CEST 2016 armv7l GNU/Linux
BOARD=orangepipc
VERSION=5.23
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
root@orangepipc:~#
P.S.: Settings of parameters in section [csi0] are identical in both versions of the orangepipc.fex file
Link to comment
Share on other sites
  • 0
twi2 not used
[twi2]
twi_used = 0
Link to comment
  • 0
hmmm, ok.
Is still a i2c issue, may be i2c has been updated on 5.25?
Please, double check your fex, decompile fex from 5.23 and 5.25 and see if there are other changes.
Link to comment
  • 0
hmmm, ok.
Has double-checked orangepipc.fex, hasn't found fundamental differences. The file is attached.
My personal opinion that a problem in the vfe_v4l2 module.
When loading the gc2035 module no error messages arise.
root@orangepipc:~# modprobe gc2035
...SKIP...
[   18.819559] [drm] Initialized mali_drm 2.1.1 20101111 on minor 1
[   20.825372] vmouse_input_dev_open
[   23.340048] eth0: no IPv6 routers present
[   23.867915] Bluetooth: Core ver 2.16
[   23.868004] NET: Registered protocol family 31
[   23.868014] Bluetooth: HCI device and connection manager initialized
[   23.868026] Bluetooth: HCI socket layer initialized
[   23.868036] Bluetooth: L2CAP socket layer initialized
[   23.868062] Bluetooth: SCO socket layer initialized
root@orangepipc:~#
When loading the vfe_v4l2 module error messages appear.
root@orangepipc:~# modprobe vfe_v4l2
...SKIP...
[ 2078.177814] [iSP] isp platform_id = 5!
[ 2078.248173] [CSI_ERR][GC2035]sensor_read err at sensor_detect!
[ 2078.248195] [CSI_ERR][GC2035]chip found is not an target chip.
root@orangepipc:~#
In attempt to unload the vfe_v4l2 module
root@orangepipc:~# modprobe -r -v vfe_v4l2
rmmod vfe_v4l2
Segmentation fault
root@orangepipc:~#
Link to comment
  • 0
I am still on 5.23 on my board and this works.
I would suggest to @Igor / @zador.blood.stained to build a dev image with all CSI / VFE debugging enabled , this could help to track down possible errors.
I can't think anything else to try. I have searched for the commits that could possible break the CSI / VFE, but have not seen anything relevant.
Don't know if a change on kernel defconfig could break it.
Link to comment
  • 0
Problem is solved.
1) I make Armbian5.20 image from source code ( https://github.com/igorpecovnik/lib/archive/v2016.09.tar.gz )
2) Write image to SD card
3) Boot from SD card
4) After initial initialization of system it is necessary to execute:
sudo apt-get update
sudo apt-get upgrade
sudo reboot
5) Boot orangepi and login
sudo modprobe gc2035
sudo modprobe vfe_v4l2
The camera /dev/video0 present
...SKIP...
[  414.935853] [iSP] isp platform_id = 5!
[  415.007804] [CSI][GC2035]V4L2_IDENT_SENSOR=2035[CSI][GC2035]disalbe oe!
root@orangepipc:~# ls /dev/vid*
/dev/video0
root@orangepipc:~# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 8.7 (jessie)
Release:        8.7
Codename:       jessie
Linux orangepipc 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l GNU/Linux
BOARD=orangepipc
VERSION=5.25
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
IMAGE_TYPE=stable
Link to comment
  • 0
...skip...
After that what did you did to get it work to 5.25?
Just apt-get update and apt-get upgrade ?
Yes.
I built from the source code because, there where I now am (Far North of Russia) very slow Internet. From a older image (armbian 5.20) too everything shall turn out.
Link to comment
  • 0
Thanks IgZero. After failing in every other direction I went, I accepted my fate, downgraded and followed your instructions. For the first time, my camera is visible to linux.  Now I can finally start playing with the project I bought the damn orange for.. :-)
Link to comment
  • 0
Ok pinned the problem : it is the boot.cmd/boot.scr which is NOT updated with a straight upgrade from 5.20 to >=5.25.
Let's resume this :
- if you load the original boot.cmd from 5.20, gc2035/vfe_v4l4 simply work.
- if you load the updated boot.cmd from 5.25/5.26/5.27 gc2035/vfe_v4l2 stop to work (croaking about CSI not able to detect a target chip).
That's all folks!
Now should someone versed in u-boot parameters arcanes invest some time to see what's the real difference which impacts gc2035/vfe_v4l2, and eventually corrects/documents it to everybody potentially banging their head about this in the future ?
Regards,
Link to comment
  • 0
Previously in the boot script there was a command to enable CSI related regulator by setting a GPIO pin. This was removed some time ago since this is not a good way to deal with this, it has to be solved by a kernel driver modification that uses FEX configuration.
Link to comment
  • 0
Hi, well is it not a module problem? As it sounds like it is a  boot configuration problem as graki said, but zador.blood.stained explained different. I was fiddeling quite a while without making it work. I recompiled the kernel with newest sources -> did not make any differences. So what is the action to take to make it work?
Thanks a lot
Link to comment
  • 0
Hello, tried what you suggested like that:
freshly booted into:  (lsb_release -a)
Description:    Debian GNU/Linux 8.8 (jessie)
Release:    8.8
Codename:    jessie
with kernel: 3.4.113-sun8i
modprobe gc_2035
modprobe vfe_v4l2
and dmesg after that looked like:
[ISP] isp platform_id = 5!
and I got a orange PI with H3 and 1GB
any help would be supergreat.
all the best
Link to comment
  • 0
Can be either Plus or PC and IIRC both use different GPIO pins for CSI. I was asking for the following but that is only save on an OPi PC:
sudo modprobe -r vfe_v4l2
sudo modprobe -r gc_2035
sudo sunxi-pio -m PG11'<default><default<default><1>'
sudo modprobe gc_2035 hres=1
sudo modprove vfe_v4l2
Link to comment
  • 0
Hi, it is not Plus, just a https://linux-sunxi.org/Orange_Pi_PC to make sure we talk about the same.
Just tried it and it didn't do anything different as before...
and if I try to remove the drivers, vfe_v4l2 then crash and burn:
[ 2395.772436] [<c03b5688>] (device_del+0x120/0x184) from [<c03b9f10>] (platform_device_del+0x28/0x5c)
[ 2395.772436] [<c03b9f10>] (platform_device_del+0x28/0x5c) from [<c03b9f60>] (platform_device_unregister+0x1c/0x28)
[ 2395.772436] [<c03b9f60>] (platform_device_unregister+0x1c/0x28) from [<bf3902c4>] (vfe_exit+0x88/0x174 [vfe_v4l2])
[ 2395.772436] [<bf3902c4>] (vfe_exit+0x88/0x174 [vfe_v4l2]) from [<c007fab0>] (sys_delete_module+0x1ac/0x24c)
[ 2395.772436] [<c007fab0>] (sys_delete_module+0x1ac/0x24c) from [<c000df60>] (ret_fast_syscall+0x0/0x30)
[ 2395.772436] Code: eb345031 e594313c e284101c e59f0064 (e5932034)
[ 2397.972548] ---[ end trace 8d60e35500ae2068 ]---
Link to comment
  • 0
I am having the same issue trying to use my camera with my Orange Pi Lite.
Unfortunately, I have no idea how to fix it.
Link to comment
  • 0
Nope, it didn't work (just imaged and booted), will try with 5.20 now.
root@orangepipc:~# sunxi-pio -m PG11'<default><default<default><1>'
root@orangepipc:~# modprobe gc2035 hres=1
root@orangepipc:~# tail /var/log/syslog
Jul  8 08:42:39 localhost systemd[1]: Starting User Manager for UID 0...
Jul  8 08:42:40 localhost systemd[1890]: user@0.service: Failed at step PAM spawning /lib/systemd/systemd: Operation not permitted
Jul  8 08:42:40 localhost systemd[1]: Started User Manager for UID 0.
Jul  8 08:42:41 localhost systemd[1]: Started Session 1 of user root.
Jul  8 08:42:58 localhost rsyslogd-2007: action 'action 9' suspended, next retry is Sat Jul  8 08:43:28 2017 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jul  8 08:45:01 localhost rsyslogd-2007: action 'action 9' suspended, next retry is Sat Jul  8 08:45:31 2017 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jul  8 08:45:01 localhost CRON[2163]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Jul  8 08:45:04 localhost kernel: [  730.871462] [ISP] isp platform_id = 5!
Jul  8 08:45:04 localhost kernel: [  730.948212] [CSI_ERR][GC2035]sensor_read err at sensor_detect!
Jul  8 08:45:04 localhost kernel: [  730.948229] [CSI_ERR][GC2035]chip found is not an target chip.
Link to comment
  • 0
Hi Guys, I've solved the problem and got it working on OPI0+2 H3 :) (tested on 5.32, but it should for all versions). I have noticed that my camera does not receive any voltage. I mean exaclty these lines: VCC_CSI and VDD1V5_CSI.  As we can see there are two LDOs which needs an external high state on the enable pin. It should come from MCU, however the driver does not handle it before ask through i2c if there is some camera.
You should set high state on the lines VCC_CSI and VDD1V5_CSI before using the camera. I did not do that by software because I am still waiting for schematic for my board, however if you have solder iron, you can connect these two lines to AFVCC_CSI (5.0V) on the extension board. Of course, you need to cut the PCB lines which comes from MCU (otherwise you can damage MCU -  I assume it is not 5V compliant). If you know exact name of lines, do that by software and do not make a mess on the extension board :)
Cheers!
Robert
Link to comment
Answer this question...
