Khadas Posted April 9, 2024 Posted April 9, 2024 After upgrading from the official version with kernel 6.1 to the CSC version with kernel 6.6 I noticed an increase in CPU temperature of as much as 10 degrees. Is this normal? Honestly, seeing 52 degrees at idle worries me a bit 0 Quote
mc510 Posted April 10, 2024 Posted April 10, 2024 Came to the forum today because my Zero has been weird for the past week or two (I use it for streaming audio, and it's been freezing up) and I just noticed that it's super hot. I have no idea how to troubleshoot this, but I've changed nothing for over a year, other than running apt upgrade. 0 Quote
Solution Khadas Posted April 10, 2024 Author Solution Posted April 10, 2024 I think you have the same problem as me, let's wait for someone who can help us. The alternative is to put the latest 6.1 kernel back and try to see if the temperatures return to normal. If we solve this, we need to block kernel updates with the armbian config tool. I await suggestions. any help is appreciated 0 Quote
mc510 Posted April 10, 2024 Posted April 10, 2024 (edited) Hmm, what is involved in downgrading the kernel; is that something that can be done via armbian-config? BTW, when I say that it has been freezing up on me, what I mean is that audio streaming stops and it disappears from my router’s connected devices, but the green LED remains on. I don’t know if the system has actually frozen or if WiFi just crashed. Edited April 10, 2024 by mc510 0 Quote
SteeMan Posted April 10, 2024 Posted April 10, 2024 47 minutes ago, mc510 said: is that something that can be done via armbian-config? Yes armbian-config has a section on selecting kernel versions as well as freezing kernel updates. 0 Quote
mc510 Posted April 10, 2024 Posted April 10, 2024 (edited) Okay, I've downgraded to kernel 6.1 and seems like the problem has gone away. I'm happy to return to 6.6 to assist with any troubleshoot, but at least for now I've got a working system. (I've been streaming audio with mpd for a couple of hours; device is reporting 26C and feels warm but not crazy hot like before.) Edited April 10, 2024 by mc510 0 Quote
going Posted April 11, 2024 Posted April 11, 2024 13 часов назад, mc510 сказал: device is reporting 26C and feels warm but not crazy hot like before I'm wondering how you measure the temperature? The readings of armbianmonitor and a finger touch? If the finger on the radiator feels warm, it means that the temperature is in the range of 35-45 degrees Celsius. At the same time, the readings in 26 C are false. 0 Quote
mc510 Posted April 11, 2024 Posted April 11, 2024 (edited) Yes, a finger touch tells me if it’s basically room temp, a little warm, pretty warm, very warm, or hot. The system message when I ssh in tells me a specific number in Celsius, but I take your point that if it feels a bit warm it must be more than 26C Edited April 11, 2024 by mc510 0 Quote
going Posted April 11, 2024 Posted April 11, 2024 @mc510 I tried to fix this situation. There are ready-made kernel packages here. Can you check it out? Just install the kernel package. The DTB package is not required. 0 Quote
mc510 Posted April 11, 2024 Posted April 11, 2024 (edited) 2 hours ago, going said: I tried to fix this situation. There are ready-made kernel packages here. Can you check it out? Just install the kernel package. The DTB package is not required. You mean your kernel aims to fix the running-hot problem? Or the incorrect-temp-reporting problem? I just download linux-image-edge-sunxi_6.4.14-Armbian.23.10_armhf.deb and "apt install" it? Edited April 11, 2024 by mc510 0 Quote
Khadas Posted April 12, 2024 Author Posted April 12, 2024 While waiting to know something more about the 6.6 kernel of the current CSC version, I'm also thinking of going back to the latest 6.1 kernel. The board is more responsive but without a heatsink with or without a fan the risk of thermal throttling is real in case of intense use of the CPU. 0 Quote
going Posted April 12, 2024 Posted April 12, 2024 11 часов назад, mc510 сказал: You mean your kernel aims to fix the running-hot problem? Or the incorrect-temp-reporting problem? The problem with displaying the actual temperature was noticed a long time ago and I fixed it in this core for the A83T processor. I did not notice any overheating problems during normal no-load operation. You just need to check if this will work for the H3 processor. You will be able to return to the 6.1 kernel in the same way if there are problems. And then just delete it using apt. 09.04.2024 в 20:38, Khadas сказал: After upgrading from the official version with kernel 6.1 to the CSC version with kernel 6.6 I noticed an increase in CPU temperature of as much as 10 degrees. Is this normal? Honestly, seeing 52 degrees at idle worries me a bit Is 52 degrees the real temperature? How did you measure it? What does htop say? armbianmonitor? 0 Quote
Khadas Posted April 19, 2024 Author Posted April 19, 2024 Unfortunately for the second time I found my home server blocked and this time the heat deformed the printed ABS case, I decided that I will put the latest 6.1.53 kernel image starting from scratch with the installation and I will deactivate the kernel updates 0 Quote
mc510 Posted April 19, 2024 Posted April 19, 2024 4 hours ago, Khadas said: Unfortunately for the second time I found my home server blocked and this time the heat deformed the printed ABS case, I decided that I will put the latest 6.1.53 kernel image starting from scratch with the installation and I will deactivate the kernel updates OG Zero has been doing just fine on community support since it stopped having official support, but I think we may be at the point where we will start to see the limitations of community support. If this overheating issue is a quirk specific to Orange Pi Zero, it may never get fixed. Or at least we may have to hope that it gets fixed in the mainline kernel, rather than in the Armbian image. Do you know if it's possible to switch to the nightly kernel as easily as you can switch to the legacy kernel? 0 Quote
Khadas Posted April 19, 2024 Author Posted April 19, 2024 nightly kernel? I think you are talking about nightly releases that are not yet stable or tested. Unfortunately I don't have time to test kernels and wait for any bugs. 0 Quote
RobArmbian Posted April 26, 2024 Posted April 26, 2024 (edited) Same problem for me, I tried everything because my OpiZero became really hot. I thought it was the SD card or another problem... How to change the kernel without reinstalling everything? EDIT: sudo armbian-config > System settings > Other Edited April 26, 2024 by RobArmbian 0 Quote
mc510 Posted April 26, 2024 Posted April 26, 2024 @RobArmbian remember to also select the option to ❄️freeze❄️ the kernel so that apt won't update it back to 🔥6.6🔥 0 Quote
mc510 Posted April 27, 2024 Posted April 27, 2024 I just went off to look at the download page to see who is the maintainer for this board, and it's no longer listed at all. At least not the way it used to be, as Orange Pi Zero. There now is an entry for Orange Pi Zero+ (H5), Orange Pi Zero +2 H3, and Orange Pi Zero +2 H5. I've actually never heard of these boards before (but Orange Pi has such an absurdly large number of different boards, that's not surprising). Not sure if one of these images supports the OG Zero, or if Community Support has stopped. 0 Quote
SteeMan Posted April 27, 2024 Posted April 27, 2024 @mc510 It is still there: https://www.armbian.com/orange-pi-zero/ 0 Quote
mc510 Posted April 27, 2024 Posted April 27, 2024 44 minutes ago, SteeMan said: @mc510 It is still there: https://www.armbian.com/orange-pi-zero/ Ohhh, I see; it's listed under Standard Support, but I was looking under Community! It's not actual back on standard support though, is it? 0 Quote
Khadas Posted April 27, 2024 Author Posted April 27, 2024 Hi @SteeMan, is official support back for orange pi zero? Not long ago the releases page clearly indicated CSC support but now I read standard support. The kernel I had problems with was 6.6.16 and now I see 6.6.20 available, who knows if they have solved the temperature problem with the new kernel. 0 Quote
mc510 Posted May 7, 2024 Posted May 7, 2024 On 4/27/2024 at 12:27 AM, Khadas said: Hi @SteeMan, is official support back for orange pi zero? https://github.com/armbian/os#latest-smoke-tests-results still shows "community." It's a mystery as to why the download page has it categorized as Standard Support. 0 Quote
Igor Posted May 7, 2024 Posted May 7, 2024 59 minutes ago, mc510 said: It's a mystery as to why the download page has it categorized as Standard Support. Because some features on website still has to be done manually. For which we don't have sufficient man power, org resources or coding resources to complete automation. If you are PHP / Python coder and want to contribute resolving this problem, PM. 0 Quote
mc510 Posted June 8, 2024 Posted June 8, 2024 On 4/27/2024 at 12:27 AM, Khadas said: The kernel I had problems with was 6.6.16 and now I see 6.6.20 available, who knows if they have solved the temperature problem with the new kernel. @Khadas what are you running on your Zero now, and how is it working? I've left mine on the legacy kernel (frozen) because it was working fine, but I just ran apt upgrade and I can't ssh into it, ping mostly fails, none of the audio server stuff on it is working. Hoping that connecting it by ethernet rather than wifi will allow me in; if not I'm really hosed. 0 Quote
Khadas Posted June 8, 2024 Author Posted June 8, 2024 I'm using the latest kernel from the official armbian release: Kernel version: Linux 6.1.53-current-sunxi armv7l I must say that stability and temperatures are now normal.I disabled kernel updates from armbian config Honestly, I don't want to experiment with the current release kernel, i.e. CSC 6.6.x, again. I don't want to find random crashes and loose plastic cases due to the CPU having temperatures out of control. For now the 6.1 kernel lets me run everything and is still modern. 0 Quote
mc510 Posted June 27, 2024 Posted June 27, 2024 Just report that, since I had to restore anyways, I let it update to the latest 6.6.31 kernel and temperatures have been running normally for a few weeks. 0 Quote
Khadas Posted July 1, 2024 Author Posted July 1, 2024 Great news!!! thanks. If I can I want to try a new image with kernel 6.6 on another micro SD and see what happens. Perhaps it was a bug in the first kernel after the official release and the transition to the CSC releases. Over the years it has already happened to me twice to find the board blocked and the plastic of the case melted and this time I didn't want to do further tests but I left the latest kernel 6.1 of the official release. 0 Quote
