constantius Posted March 11, 2017 Posted March 11, 2017 hello. I have found that you made firmware for MiQi board ( Rockchip RK3288 ). Is this firmware compatibile with Tinker Board ASUS ? It has the same SOC.
tkaiser Posted March 11, 2017 Posted March 11, 2017 It should but since ASUS is not interested in Armbian support and no one so far tried it out... it's up to you to test through
TonyMac32 Posted March 12, 2017 Posted March 12, 2017 @tkaiser I wouldn't bet on anyone in that forum being an ASUS rep. [EDIT] @Mikerr is the forum owner, he's posted in here asking about progress on the Tinker Board. [/EDIT]That said, Asus hasn't demonstrated a lot of interest in their own product, at least not publicly... I tried the MiQi image on my tinkerboard, no HDMI output and no power to any peripherals. I'm guessing it's the Rockchip power management IC (RK808), since everything else is directly tied to the SoC. I don't have a 64-bit machine to dedicate to Ubuntu for building Armbian, but I'll see what I can scratch up. First things first is to tap into tty0
constantius Posted July 12, 2017 Author Posted July 12, 2017 "to boot from SD card you need to press and hold a button on the back side of the board and power on. This erases bootloader on eMMC and now you can boot from SD." which button? There is only one button on the back side.. i have pressed it and nothing is happens.. Could you make a photo ?
Igor Posted July 12, 2017 Posted July 12, 2017 1 hour ago, constantius said: "to boot from SD card you need to press and hold a button on the back side of the board and power on. This erases bootloader on eMMC and now you can boot from SD." which button? There is only one button on the back side.. i have pressed it and nothing is happens.. Could you make a photo ? https://github.com/mqmaker/docs/wiki/miqi-installing-firmwares
