martinayotte Posted January 15, 2019 Posted January 15, 2019 1 hour ago, technik007_cz said: Kernel version 4.19.13-sunxi does not accept param_w1_pin= As I said in the other thread, it is not the kernel that manage those DT parameters, it is u-boot responsible to load them, so, we need to see in early u-boot log (before kernel started) if the fixup.scr apply succeeded or not . You need USB-TTL Serial dongle to watch those early logs ... 0 Quote
teknoid Posted February 6, 2019 Posted February 6, 2019 I successfully tested rotary encoder device overlay with armbian-add-overlay. Source is here https://github.com/teknoid/dac/blob/master/misc/gpio-rotary.dts @zador.blood.stained you may add this to the example directory on github. 0 Quote
spaceship Posted February 15, 2019 Posted February 15, 2019 Where do i find the corresponding driver on the kernel source code , pertaining to the following dts file:https://github.com/armbian/sunxi-DT-overlays/blob/master/sun7i-a20/sun7i-a20-i2s0.dts 0 Quote
zador.blood.stained Posted February 15, 2019 Author Posted February 15, 2019 11 hours ago, spaceship said: Where do i find the corresponding driver on the kernel source code , pertaining to the following dts file:https://github.com/armbian/sunxi-DT-overlays/blob/master/sun7i-a20/sun7i-a20-i2s0.dts https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/sound/soc/sunxi/sun4i-i2s.c 0 Quote
windysea Posted March 20, 2019 Posted March 20, 2019 I had submitted a PR last year that was committed to the tree at https://github.com/armbian/sunxi-DT-overlays but this doesn't seem to have made it to the mainline nor is it included in any pine64 pre-built kernels. It is a very simple one-line correction from For now I've been using a local user patch when rebuilding kernels. Would I need to submit a separate PR for the linux mainline as well? Or would a PR to add a bundled patch in the armbian build tree be better/preferred? 0 Quote
martinayotte Posted March 20, 2019 Posted March 20, 2019 28 minutes ago, windysea said: but this doesn't seem to have made it to the mainline The sunxi-DT-overlays is some kind of backup repository, but the real place that you fix should be in the patches, in the present case here : https://github.com/armbian/build/blob/master/patch/kernel/sunxi-dev/general-sunxi-overlays.patch#L5071 Feel free to submit another PR for that file, we will merge it quickly ... 0 Quote
windysea Posted March 21, 2019 Posted March 21, 2019 Thanks! I've submitted the a PR with two separate commits, one each for -dev and -next, with the exact same change. I didn't know if you would accept PRs on -next and meant to create two PRs but the second commit was merged with the first PR that had already been submitted. . . 0 Quote
martinayotte Posted March 21, 2019 Posted March 21, 2019 9 hours ago, windysea said: I've submitted the a PR with two separate commits Merged : https://github.com/armbian/build/commit/af76626fac3994f63d000bfda8109c4ecfba9440 0 Quote
TomiISP Posted June 6, 2019 Posted June 6, 2019 (edited) On 1/8/2018 at 3:58 PM, dorchain said: /dts-v1/; /plugin/; / { compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,su n8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5"; /* * Aliases can be used to set the external RTC as rtc0 * Needs supplying the correct path to the I2C controller RTC is connect ed to, * this example is for I2C1 on A20 */ fragment@0 { target-path = "/aliases"; __overlay__ { rtc1 = "/soc@01c00000/rtc@01c20d00"; }; }; fragment@1 { target-path = "/aliases"; __overlay__ { rtc0 = "/soc@01c00000/i2c@01c2b400/ds3231@68"; }; }; fragment@2 { target = <&i2c2>; __overlay__ { #address-cells = <1>; #size-cells = <0>; ds3231@68 { compatible = "maxim,ds3231"; reg = <0x68>; status = "okay"; }; }; }; }; Hi, can anybody help me adapt this overlay to H5 cpu (Pi PC2) ? I experiment myself and make this workable for DS3231 but it is still registered as RTC1. I change: - rtc0 = "/soc@01c00000/i2c@01c2b400/ds3231@68"; to rtc0 = "/soc@01c00000/i2c@01c2b000/ds3231@68"; ( I2C0 = i2c@01c2b000 ) - target = <&i2c1>; to target = <&i2c0>; As I said, it works, it register DS3231 at boot and it works include HWMON but it is still as RTC1. Have anybody idea how to set it and replace RTC0 ? (RTC0 on H5 is on 1f00000) And can anybody explain me a bit what is meaning with addresses "/soc@01c00000/rtc@01c20d00" ? Kernel: 4.19.38-sunxi64 #5.86 SMP Thanks /Tomi Edited June 6, 2019 by TomiISP kernel info 0 Quote
slole Posted April 6, 2020 Posted April 6, 2020 Hello, I have found an issue with the audio device on allwinner H2+/H3 boards. The internal audio DAC works just fine on Armbian Stretch, but on Armbian Buster the audio device appears as mono-only in pulseaudio. When trying to run 'speaker-test -c 2' the audio channels appear to be flipped? I figured this is an issue with the device tree? This seems to be a common issue: my post: This issue affects the Buster and Bionic builds. I have a few extra SD cards, so I can test stuff out or give you any required console outputs. 0 Quote
Igor Posted April 24, 2020 Posted April 24, 2020 On 4/6/2020 at 5:08 PM, slole said: The internal audio DAC works just fine on Armbian Stretch, but on Armbian Buster the audio device appears as mono-only in pulseaudio. Were you using same kernel on Stretch and Buster? And which. "Buster" and "Stretch" tells us little to nothing. 0 Quote
maz-1 Posted August 24, 2020 Posted August 24, 2020 (edited) hello, I am running armbian focal on Bananapi M64. When I was on kernel 5.4, I can get ir device named "sunxi-ir" under /dev/input/event1 by running getevent (https://github.com/ndyer/getevent), however after I upgraded kernel to 5.7 the ir device is no longer available. I am not sure if its a problem with kernel or device tree. I tried to modprobe sunxi_cir with no luck. Edited August 24, 2020 by maz-1 add description 0 Quote
ilario Posted October 31, 2023 Posted October 31, 2023 Hello! Using Debian packaged by the Olimex people (not Armbian, see their image here) I tried your 1-wire DTS plugin but it did not work. Trying to understand why, I contacted the linux-sunxi developers who considered that your DTS plugin is outdated. See the discussion here. Their suggestions resulted in this DTS file that should work also on Armbian. I did not make a pull request towards your overlay repository as I am not able to update the param_w1_pin_int_pullup setting code in the sun50i-a64-fixup.scr-cmd file. 1 Quote
hexzhen3x7 Posted November 17, 2024 Posted November 17, 2024 whats about sun8i-r40 / v40 overlays? 0 Quote
