I have started on Armbian Ubuntu on a Orange Pi PC and have some difficults to follow the
tiny font on the terminal emulator.
In order to change the fontsize, I used the command "dpkg-reconfigure console-setup" and choosed
the Terminus font with a bigger size. But no effect after reboot.
With which trick a modification can be performed?
What is with the fonts marked with "framebuffer"?
If a modification is not possible with the Armbian terminal emulator, can I use an alternative?
So I miss a property button as available on Raspian.
Thanks for yor help and best regards
Walter
Which image, which kernel? Provide logs (armbianmonitor -u), when you report a problem. HDMI console or desktop Xterm emulator?
Hello  Igor,
Many thanks for your quick reply.
Image: Ubuntu Xenial Legacy 3.4.113
Console: HDMI
armhwinfo.log : attached
Hope this helps.
Walter
armhwinfo.log
What if you just change screen resolution with h3disp to some lower one?
Hello Igor,
I have already tested it with a lower resolution, but it dos'nt look good.
There are so many fonts on the system and I am disappointed not to use a proper one.
I need a crisp display for screenshots even with black characters on white background,
because I write an article about MQTT and Node-RED.
Best regards
Walter
I have solved my problem by the installation of gnome-terminal.
This terminal has large, more readable black fonts on white background.
And it supports cut and paste!
I am surprised that Armbian has such a lausy default terminal,
my recommendation is: implement gnome-terminal!
Best regards
Walter
Expand
When you got if solved via the gnome-Terminal its sound you used a X/Desktop.
console-setup does only change the console at boot before the desktop-manager
