aosos Posted June 24, 2024 Posted June 24, 2024 I tried installing the OS using SD card and EMMC, but both failed. Orange Pi OS (Arch) on the official website ran normally. However, I installed focal_desktop_xfce or jammy_desktop_gnome from Ubuntu Image, but they all failed. After inserting the image into the SD card, the symptom is a black screen and no booting. Does it only support SSD? Because it is entered through a translator, there may be unnatural sentences. If you reply about that, I will get back to you. 0 Quote
Solution Igor Posted June 24, 2024 Solution Posted June 24, 2024 1 hour ago, aosos said: Orange Pi OS (Arch) on the official website ran normally. Orangepi OS (Arch) is custom / re-branded Manjaro and Manjaro is not doing much else then shipping (selling) their Arch derived OS while taking our and community work on kernel maintainace. This is the story how Orangepi "supports" open source - by primarily supporting code dealers that already mainly have negative contribution to open source development. But who cares other then small group of people called "developers"? In general, HW vendors have interest to block or at least control other OS providers and it is possible they purposefully compiled SPI boot-loader to not load anything else then their OS. This would explain why you can't load our OS. Manjaro already provided (or tried to) this "solution" to Pine64, so average users would have troubles changing OS. Details: https://blog.brixit.nl/why-i-left-pine64/ For us, this is easy to work-around, but bulk of people might still need to stick to their official promo/spy/pirate-ware. Solution? Debian based OS: sudo apt update sudo apt install mtd-utils sudo flash_eraseall /dev/mtd0 Arch based OS: sudo pacman -Syy sudo pacman -S mtd-utils sudo flash_erase /dev/mtd0 Then boot armbian from SD card and run: sudo armbian-install And choose "update MTD boot-loader" or "Install it to NVME", which will also update boot-loader and transfer image to SSD. Tested right now with Opi5 lying on my desk. 2 Quote
Trinom Posted September 2, 2024 Posted September 2, 2024 I just tried the suggested steps on my new Orange Pi 5 Max (the newest board with RK3588) and unfortunatelly, it doesn't work. I followed every single step (using Debian), erased mtd0, but the Raspbian never booted when I swapped the SD cards. Indicator has solid cyan color (the same color as if no card is present). Apparently it's looking for something extra on the SD card, which it can't find, so it doesn't boot at all. 0 Quote
Werner Posted September 3, 2024 Posted September 3, 2024 9 hours ago, Trinom said: Raspbian I doubt that Raspian supports this board. 0 Quote
Igor Posted September 3, 2024 Posted September 3, 2024 9 hours ago, Trinom said: Orange Pi 5 Max For all those boards you need a dedicated image in order to boot it. This is not a PC or Raspberry Pi. If image is not here https://www.armbian.com/download/?device_support=Standard support&tx_maker=xunlong you will need to stick to terrible OS provided by Orangepi until someone will adopt this hardware https://docs.armbian.com/Developer-Guide_Adding-Board-Family/ 0 Quote
Trinom Posted September 5, 2024 Posted September 5, 2024 Technically, 5Max is a combination of 5Plus and 5B (RK3588 CPU and 5B peripherals). So if 5B and 5Plus is supported, 5Max should be supported as well, right? Or do they do something stupid with a bootloader? I don't think so, as their images work between different 5-series boards just fine. I will probably further investigate their SW tools they provide for burning the image onto SD/EMMC/SSD. 0 Quote
SteeMan Posted September 5, 2024 Posted September 5, 2024 2 hours ago, Trinom said: So if 5B and 5Plus is supported, 5Max should be supported as well, right? Not right at all. Every SBC that has different hardware configuration requires a different dtb file that describes the hardware to the Linux kernel. So every SBC needs it's own build ( sometimes dtb overlays can be used to shortcut this). And similar issues can exist at the uboot level too. 1 Quote
notheld Posted September 19, 2024 Posted September 19, 2024 Hello everyone. this is my first post so please forgive me if I need to create a new post or if it makes sense to use this tread. I have a pi 5 plus 16gb and I managed to install the image Armbian_24.8.1_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop.img on the SD card and emmc. But it doesn't work on the pcie, I'm using the wd black SN750 SE. I can't understand why this is happening. I can run Joshua's ubuntu-24.04-preinstalled-desktop-arm64-orangepi-5-plus.img.xz image in nvme and it works perfectly, but I wanted to be able to run the armbian image because I really like the project. So using SD crad I ran the commands to delete /dev/mtd0 and ran the armbian-install command to install it on nvme. But it didn't work in the same way and now Joshua's image has also stopped working.Armbian starts to run but doesn't finish booting and is stuck waiting for some action. This is the boot log: done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Loading, please wait... Starting systemd-udevd version 255.4-1ubuntu8.4 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... BusyBox v1.36.1 (Ubuntu 1:1.36.1-6ubuntu3.1) built-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) To get Joshua's image working again, I had to redo the manufacturer's SPI flush using the files from this link https://drive.google.com/drive/folders/19SMZHj1Y8l_Vvr6_SMDHYdJHi41hMgsI. I'm applying the rk3588_linux_pcie.cfg and MiniLoaderAll.bin configuration and putting rkspi_loader in uboot. By doing this, nvme worked again with the Joshua image and Armbian did not. Whenever I delete the contents of /dev/mtd0 everything stops working, only the SD card works, emmc and nvme stop working, not just the armbian images but any image I try to use. I tried to use only the option update MTD boot-loader and then Install it to NVME I invested a whole day trying to solve this but I was unsuccessful, I tried several different ways but the result is always the same. Please, would anyone have any different ideas or tell me what I'm doing wrong? I've run out of ideas. 0 Quote
Werner Posted September 19, 2024 Posted September 19, 2024 Just guessing. Sometimes armbian-install seem to fail to populate /boot or the UUID of the nvme is wrong. Try this: clear mtd and nvme, boot from fresh image from microsd, maybe remove emmc if not needed. Do armbian-install and let it move OS to nvme and flash spi. Do not reboot. Mount the nvme again somewhere and check if /boot is populated. If not, copy everything manually from microsd/boot to nvme/boot, then use lsblk or similar command to get the uuid of the nvme and edit the freshly copied armbianEnv.txt to match the uuid. If /boot on nvme is populated already make sure the uuid is correct. Then shutdown, unplug, remove sd and power up again. For best chances debugging boot issues set verbosity to 7 in armbianEnv.txt and check the video at https://debug.armbian.de 2 Quote
notheld Posted September 20, 2024 Posted September 20, 2024 Thank you very much for your reply, Werner. Everything is working now. It was necessary to copy the /boot of the SD card to the /boot of the nvme as you suggested. By doing this and changing the UUID to the correct one everything worked. Thank you very much for your help!!! Now I can use armbian on my nvme as I always wanted. But only one strange behavior remained, if I perform a reboot I am redirected to the BusyBox again and running a blkid does not show the UUID of the nvme. It seems that nvme is not recognized. But if I remove the power cable and put it back in, everything is back to normal. I just found this behavior very curious but it won't affect my use, I just always have to turn it off and on again if I need to reboot. 0 Quote
Werner Posted September 20, 2024 Posted September 20, 2024 Odd. I have an OPi5 with nvme and vendor kernel as well and it survives reboots. It is not up to date though. Also cannot check on which version it is atm. 0 Quote
Hooutoo Posted November 2, 2024 Posted November 2, 2024 @Igor, I've read several of your posts concerning uefi and Armbian. I have an opi5+ and would like to find a way to install a current version of armbian arm64. I'm using orangepi-5plus_UEFI_Release_v0.11.2.img and have already enable configuration menu -> ACPI / Device Tree and setting Config Table Mode to Device Tree but by default, the firmware installs a DTB compatible with (most) Rockchip SDK Linux 5.10 legacy kernel variants. Is there a guide on how to install/use dtb for a more current kernal and a uefi armbian image to go along with it? Thanks in advance. 0 Quote
Sam McBride Posted December 9, 2024 Posted December 9, 2024 My OPi 5B has the Android tablet software pre-installed I cannot do anything. The onboard memory has the Android tablet software. I cannot get to a terminal at all. I cannot boot from an SD card or a USB stick. All I can do is boot this thing to something useless. It has Chrome, Camera, Calendar, and something else, but hitting the Cntl-A does get me to apps, but there is absolutely nothing that will give me a terminal to change things. Do I just trash this thing? I will never buy a 5B again with onboard memory and pre-installed OS. I hate this unit. My OPi 5 plus is just fine though. 0 Quote
Sam McBride Posted December 9, 2024 Posted December 9, 2024 Looks like I can log into Google Play and install Termux or Andronix. I will try that today and see if I can get past this issue. 0 Quote
Igor V Posted December 10, 2024 Posted December 10, 2024 (edited) The proposed solution doesn't work for me. I have the same experience the the author of this post - distributives provided by Orange Pi work, while Armbian doesn't load and there is no output on the display. I followed the proposed steps and flashed SD by Ubuntu from Orange Pi and erased /dev/mtd0 by executing: sudo apt update sudo apt install mtd-utils sudo flash_eraseall /dev/mtd0 Then I flashed SD with Armbian and symptoms are the same - no boot and black screen. I tried to flash SD again with Ubuntu from Orange Pi and it loads with no problems. How to proceed? Do I need to connect UART and check the output? Update: Armbian has been installed successfully. After cleaning bootloader as descried above, I tried to install Joshua Riek's distribution and it loaded. Then I returned back to Armbian downloads and tried Armbian 24.11.2 Noble Gnome with kernel 6.1.75 (the one highlighted) and it worked! And I migrated everything to eMMC by using armbian-config - that was easy. So to summarize - I'm not sure that /dev/mtd0 cleanup was really required, but I did it. The problem was with the distribution I tried to run. Armbian Ubuntu 24.04 (Noble) (Desktop images with Armbian Linux v6.12) was the wrong choice. Edited December 10, 2024 by Igor V 0 Quote
vanbinsbergen Posted December 24, 2024 Posted December 24, 2024 (edited) @1-igor i just got this message: sudo flash_eraseall /dev/mtd0 flash_eraseall has been replaced by `flash_erase <mtddev> 0 0`; please use it Erasing 16384 Kibyte @ 0 -- 100 % complete it worked, but its updated Edited December 24, 2024 by vanbinsbergen 0 Quote
Tomas Posted July 17, 2025 Posted July 17, 2025 (edited) @1-igor I followed your guide, I ereased the spi flash. But after rebooting the OPi 5 wont even boot to the previously working ssd m.2. Even no orange pi screen before boot. Is there any fix? No longer needed. Fixed. Edited July 17, 2025 by Tomas 0 Quote
ArmBoy1988 Posted July 17, 2025 Posted July 17, 2025 What did you do to fix it? Others that come across this may find it useful. 0 Quote
nexusguy59 Posted December 15, 2025 Posted December 15, 2025 (edited) @Trinom I know this post is really old but I have to chime in on this. The instructions that @Igor gave you says to use Armbian to boot the device with then use the commands given to install Armbian. Raspbian is not Armbian. Just sayin' Just trying to figure out what or where you were reading. Edited December 15, 2025 by nexusguy59 0 Quote
Jaume Sancho Posted Monday at 08:26 AM Posted Monday at 08:26 AM I'll add my 2 cents with my more recent findings. Mind that I am using an Orange PI 5 Plus, your mileage might vary with other models. I started booting the official Orange PI (Arch) distro to clear the SPI bootloader, as suggested by @Igor sudo pacman -Syy sudo pacman -S mtd-utils sudo flash_erase /dev/mtd0 I've tried multiple flavours of the available downloads for Armbian, but I've found that all versions with kernel 6.12.58 would fail to load (the LED stays red, instead of flashing red & blue). This includes both Debian trixie and Ubuntu noble, with their desktop and minimal editions. Back in December 20204 @Igor V described similar boot issues that got resolved with kernel 6.1.75, the one that was highlighted in green at the time. So that led me to try with kernel 6.1.115 instead, and that has worked just fine. Not sure if this is an issue introduced with the newer kernel, or whether it's to be expected as it has not been officially stabilised yet. Anyway, I thought I'd share in case this can help others in the future. 0 Quote
