The Posted April 3, 2020 Posted April 3, 2020 1007M swap. I don't know... This is from dmesg: [ 24.553452] Adding 1030140k swap on /var/swap. Priority:-2 extents:5 across:3536892k SSFS 20 minutes ago, Igor said: This is my torrent server on the same 8Gb SD card. /dev/mmcblk0p1 7458672 1058648 6297556 15% / /dev/sdb1 7752457508 6878909040 482830824 94% /ext I saw with lsblk, that sda1 has no mountpoint... that could be the reason. I will check it out. 0 Quote
The Posted May 18, 2020 Posted May 18, 2020 I found the error. It was the mount point. Everything's working fine now for almost 7 weeks. 1 Quote
MacBreaker Posted June 7, 2020 Posted June 7, 2020 Hello Igor, since years i seed Armbian torrents but i noticed that i'm running out of space. My hdd was 248GB till now... Looking for further information and saw in the first post is written 512GB. Maybe you can add a big ">NOTE!< since Version 20.05.xx you need 512GB free space". Also after you installed transmission by ->Software ->Softy ->Transmission you get asked to seed Armbian torrents. Here a screen: You have to change the number from 80GB to 512GB. Just my thinking about this.. Markus 2 Quote
Werner Posted June 7, 2020 Posted June 7, 2020 5 minutes ago, MacBreaker said: Hello Igor, since years i seed Armbian torrents but i noticed that i'm running out of space. My hdd was 248GB till now... Looking for further information and saw in the first post is written 512GB. Maybe you can add a big ">NOTE!< since Version 20.05.xx you need 512GB free space". Also after you installed transmission by ->Software ->Softy ->Transmission you get asked to seed Armbian torrents. Here a screen: You have to change the number from 80GB to 512GB. Just my thinking about this.. Markus Yeah that number is a bit outdated. But you can see how much the project has grown over the years. 0 Quote
MacBreaker Posted June 7, 2020 Posted June 7, 2020 Quote Yeah that number is a bit outdated. But you can see how much the project has grown over the years. Yes, and you all can be proud of this... 1 Quote
Igor Posted June 7, 2020 Author Posted June 7, 2020 512Gb is "a bit" future proof. Current real number is 259G and can cleaned up to fit 256GB drive size ... but its a manual work. 0 Quote
MacBreaker Posted June 7, 2020 Posted June 7, 2020 OK, i'm prepaired with my 500GB HDD on a Cubietruck right now... 2 Quote
Werner Posted August 22, 2020 Posted August 22, 2020 The current torrent size is 283,x GB atm for those who are interested: https://werner.armbian.de/_offtopic/torrent_statistics.txt 0 Quote
usb-driver Posted September 4, 2020 Posted September 4, 2020 Hello there, I'm trying to adapt the cron script to deluged and I came out with this #!/bin/bash # # armbian torrents auto update # # download latest torrent pack TEMP_DIR=$(mktemp -d || exit 1) chmod 700 ${TEMP_DIR} trap "rm -rf \"${TEMP_DIR}\" ; exit 0" 0 1 2 3 15 wget -qO- -O ${TEMP_DIR}/armbian-torrents.zip https://dl.armbian.com/torrent/all-torrents.zip # test zip for corruption unzip -t ${TEMP_DIR}/armbian-torrents.zip >/dev/null 2>&1 [[ $? -ne 0 ]] && echo "Error in zip" && exit # extract zip unzip -o ${TEMP_DIR}/armbian-torrents.zip -d ${TEMP_DIR}/torrent-tmp >/dev/null 2>&1 # create list of current active torrents deluge-console 'info' | sed '1d; $d' > ${TEMP_DIR}/torrent-tmp/active.torrents # loop and add/update torrent files for f in ${TEMP_DIR}/torrent-tmp/*.torrent; do deluge-console "add ${f}" > /dev/null 2>&1 # remove added from the list pattern="${f//.torrent}"; pattern="${pattern##*/}"; sed -i "/$pattern/d" ${TEMP_DIR}/torrent-tmp/active.torrents done # remove old armbian torrents while read i; do [[ $i == *Armbian_* || $i == *gcc-linaro-* || $i == *tar.lz4 ]] && deluge-console "rm $(echo "$i" | awk '{print $1}';) --remove_data" done < ${TEMP_DIR}/torrent-tmp/active.torrents I'm not sure with the "active.torrents" part because i don't have transmission and i don't know how the informations from the "-l" are listed. For now the adding part is working and the "active.torrents" file is written! 2 Quote
Werner Posted October 1, 2020 Posted October 1, 2020 There was an issue with the torrent network which lead into adding torrents to the queue that were no longer existing. This has been fixed. If you have setup your transmission-daemon with the update script mentioned at the first post you will receive the fix automatically or already might have. 1 Quote
amontero Posted October 6, 2020 Posted October 6, 2020 Is there any way of seeding only some files? I would love to contribute some bw, but I'm a bit short on disk space. Thanks. 0 Quote
Igor Posted October 6, 2020 Author Posted October 6, 2020 3 hours ago, amontero said: Is there any way of seeding only some files? I would love to contribute some bw, but I'm a bit short on disk space. Thanks. Files are changing at each update so this makes little sense. Current share size is 262 Gb. 0 Quote
LD-Geek Posted January 3, 2021 Posted January 3, 2021 i'm very pleasure to share the torrent file for armbian ,but please don't use the /var/lib/..... location,it's not friendly use the settings.json location and automatic move to new location will be fine. 0 Quote
Igor Posted January 3, 2021 Author Posted January 3, 2021 37 minutes ago, LD-Geek said: use the settings.json location and automatic move to new location will be fine. If this is yet another task for us, it can easily take years ... https://github.com/armbian/config/blob/master/debian-software#L708-L762 https://docs.armbian.com/Process_Contribute/ 0 Quote
Glock24 Posted January 19, 2021 Posted January 19, 2021 Hello, what's the disk space needed to seed the torrents? On a side note, would creating a repository mirror also help? 0 Quote
djurny Posted January 19, 2021 Posted January 19, 2021 3 hours ago, Glock24 said: Hello, what's the disk space needed to seed the torrents? On a side note, would creating a repository mirror also help? Hi, I would also be interested in finding out what it would take to host a local repository mirror. Over the past few weeks I did try to rsync the repo to local storage, but I'm not sure if that will affect anything on the 'other' side. Had to break off the rsync as it appeared to sync extremely slow. Groetjes, 0 Quote
Werner Posted January 19, 2021 Posted January 19, 2021 3 hours ago, Glock24 said: Hello, what's the disk space needed to seed the torrents? As mentioned in the first post of this topic the recommended disk space is 512GB. 0 Quote
Igor Posted January 19, 2021 Author Posted January 19, 2021 @djurny @Glock24 Stop by on our IRC channel(s), #armbian or #armbian_server to discuss details. Look for me @lanefu or @TheLinuxBug 5 hours ago, djurny said: Had to break off the rsync as it appeared to sync extremely slow. Try this one: rsync -av rsync://mirrors.dotsrc.org/armbian-dl/ . and rsync -av rsync://mirrors.dotsrc.org/armbian-apt/ . 0 Quote
Igor Posted January 24, 2021 Author Posted January 24, 2021 Support project https://gitlab.com/open-transmit/transupdate 0 Quote
Werner Posted September 14, 2021 Posted September 14, 2021 The size requirements have been updated. Since we now share images with various desktop environments as well the size of all torrents have now grown to around 500GB. To become future-proof again the free space requirement has been raised to 1TB. For those who did not notice yet. It became rather simple to become an Armbian http/s mirror as well if you do not like torrent stuff: https://github.com/armbian/mirror 1 Quote
Nuts_ Posted April 19, 2022 Posted April 19, 2022 Broken seeds? ---- Some days ago I decided to join to seeding of whole Armbian torrents pack, using some of my old junk hardware. I added cron script without problems and all wend well but i detected some very strange torrents, it lopped on downloading, geting more and more corupted data (as Transmission says) progress bar value Increased and decreased i spend 1,5TB incoming traffic to upload one of this torrent with 1GB size and it still not completed i spend some time to play with hardware, software and different internet providers as i find some broken files can be downloaded sometimes, sometimes - not all this files not begining from "Armbian" (alll Arbian* is OK) for example bullseye-minimal-amd64.e5fbf1963190f2b3a9a677d778a7e3f2.tar.lz4 i having at lest 2 different instances of this file but all of them unpucking with error --------- So Guys, what going wrong? It seems like its not problem of my hardware, isn it? at all, Not big help, if i downloading much more then uploading 0 Quote
Igor Posted April 19, 2022 Author Posted April 19, 2022 52 minutes ago, Nuts_ said: So Guys, what going wrong? It seems like its not problem of my hardware, isn it? Its a bug in Torrent protocol when using web seeds which dramatically speeds up download. I have removed them. Restart service in about 1h that your torrent files will be refreshed. Perhaps you will need to manually remove them all before (without removing files). Some files will be downloaded again ... that is normal. 0 Quote
Nuts_ Posted April 20, 2022 Posted April 20, 2022 19.04.2022 в 12:20, Igor сказал: Its a bug in Torrent protocol when using web seeds which dramatically speeds up download. Well, aftter update, this day downloading going well from peers, now but no so fast Most downloaded via webseeds was OK and download speed was maximum for my ISP. I thinking some files on different webseeds can be unsynced 0 Quote
Igor Posted April 20, 2022 Author Posted April 20, 2022 34 minutes ago, Nuts_ said: I thinking some files on different webseeds can be unsynced I think problems started this way. Each time we generate caches, already generated ones are checked for integrity and if that fails for some reason, cache is deleted and its made again but if one program in this package is updated or if there is any other change in the rootfs, which usually is, torrent and its hash is different with the same filename. File on primary server is changed, but not (yet) all others. When you start downloading, you always get latest torrent files which has (had) weblinks. URL to files, which have the same hash but are not the same. This is not treated properly as corruption and download never finishes ... A better hash re-generation mechanism, that would render out this corner case, and we could enable this back. But since 34 minutes ago, Nuts_ said: but no so fast we are already full of work and this is not that critical problem I choose to just disable web links ... 0 Quote
