Updated my bananapi pro to from 5.30 minutes ago...but now it doesnt boot ;-(
Any possibility to get my system back without setting up completely new? Never had this with all update before.....
Seems to be problem with network (using it headless), last line bootscreen says IPv6 ADDRCONF (NETDEV_CHANGE)  : eth0: link becomes ready. In line before it states link is up, ipscan shows no bananapro...
Everything is solvable ... but we need more information to help. It might be a problem with u-boot. From where you did upgrade?
25 minutes ago, tahaea1 said:
Same problem on SuperPi. Can get console with UART but get no networking at all.
Which image?
4 minutes ago, tahaea1 said:
Banana Pi Jessie mainline
upgraded with apt-get
using usb hdd as root
Which kernel version and from which Armbian version you made update? Did you start from clean image? You have to tell me everything! btw. Super Pi is not supported even I am almost sure it's exactly the same as Banana Pi ... I never saw one of those ... some minor changes can lead to improper Ethernet initialisation. I also need to wait for others to report - on supported boards.
I don't really remember the kernel version. Armbian version was 5.25 or 5.24. Clean image as in what? I was using 5.25 for about 2 months I think? was apt updating regularly and it updated to 5.30 today.
OK. I'll try to reproduce.
In the mean time, you can try to flash (downgrade) u-boot from http://apt.armbian.com/pool/main/l/linux-u-boot-bananapi-default/linux-u-boot-bananapi_5.25_armhf.deb to see if that helps. Extract  u-boot-sunxi-with-spl.bin and write to SD card:
dd if=u-boot-sunxi-with-spl.bin of=/dev/yoursdcard bs=1024 seek=8 status=noxfer
Using latest 5.25, jessie,  with 4.9.7 mainline kernel here. Will try downgrade u-boot if i found time and got running linux machine ;-)
Bananapi armbian 5.27 mainline upgrade to 5.30. Cannot log in remotely from putty.. When connect to hdmi monitor, it boot up normally and can log in. Everything seems ok but no response when attempt to log in remotely (putty). Very strange.
5 minutes ago, wsian said:
Bananapi armbian 5.27 mainline upgrade to 5.30. Cannot log in remotely from putty.. When connect to hdmi monitor, it boot up normally and can log in. Everything seems ok but no response when attempt to og in remotely (putty). Very strange.
Most likely u-boot configuration which initialised network is broken for Bananapi. Still checking if this is it. U-boot upgrade has been removed until this is not resolved.
Bananapi M1+
Upgrade from 5.24 / 4.7.9 -> 5.30 / 4.11.4: no problems with network. Tested with 100 / 1000Mbit switch.
The more I test, the less I know :( This test image works fine on M1+, while network doesn't come up (properly) on: M1, PRO and R1 :)
15 minutes ago, Wolf2000 said:
Hi Igor
With my Banana Pi 1 nothing more about HDMI I see only the cursor flashes.
What could I do?
Or is it death?
Even you wait until network timeouts ?
If you did an update, you need to rollback u-boot to 5.25
I can confirm, on a BPi M1 the internal ethernet is broken with armbian 5.30.
I'm using the BPi M1 as bridge with a second USB ethernet port. After update to armbian 5.30 (from 5.26), the internal BPi ethernet port had 80% packet loss, but the USB ethernet adapter works just fine.
Regards
I have been just installed Armbian 5.30 ubuntu flavor on my Banana Pi (the first model). Unfortunately, it's impossible to start a SSH session. The session freeze before to get the prompt.
64 bytes from 192.168.1.37: icmp_seq=1 ttl=64 time=0.487 ms
64 bytes from 192.168.1.37: icmp_seq=4 ttl=64 time=0.267 ms
64 bytes from 192.168.1.37: icmp_seq=6 ttl=64 time=0.287 ms
64 bytes from 192.168.1.37: icmp_seq=7 ttl=64 time=0.271 ms
64 bytes from 192.168.1.37: icmp_seq=8 ttl=64 time=0.334 ms
From 192.168.1.57 icmp_seq=10 Destination Host Unreachable
64 bytes from 192.168.1.37: icmp_seq=13 ttl=64 time=1028 ms
64 bytes from 192.168.1.37: icmp_seq=15 ttl=64 time=0.246 ms
64 bytes from 192.168.1.37: icmp_seq=22 ttl=64 time=0.318 ms
64 bytes from 192.168.1.37: icmp_seq=74 ttl=64 time=0.297 ms
64 bytes from 192.168.1.37: icmp_seq=76 ttl=64 time=0.308 ms
304 packets transmitted, 85 received, +5 errors, 72% packet loss, time 310268ms
rtt min/avg/max/mdev = 0.208/24.450/1028.213/155.519 ms, pipe 11
As you can see, a lot of packets are lost.
On my Nanopi, I got other network issues with this kernel. I think the 4.11 kernel cannot be used correctly with these boards now.
Is the problem related to the BananaPi (family) only? I've just upgraded my OrangePi PC, but didn't reboot yet.
This problem should not be related ... if you report the problem, we need all possible details :)
Hi, its a my first post here :-)
same issue with update from Armbian 5.25 to 5.30 bootloop on Banana Pi.
Have now done backup back, Will now wait until the problem is solved...
OrangePi PC update was successfully. A reboot succeeded. Thanks for the update!
59 minutes ago, zador.blood.stained said:
Please try testing after recompiling the u-boot now.
M1 and PRO are O.K., will check R1 and M1+ too
Using u-boot from previous version is a way to go - you have to update it on another computer if you already issued an update.
You are welcome.
I tried
but had not worked,  Had possibly flashed wrong drive mmcblk0p1 instead of mmcblk0  ??
