happyzax Posted June 15, 2017 Posted June 15, 2017 I am trying to test the ap6212-bluetooth script in the latest desktop image for the Orange Pi Zero +2 (H5), but am having no luck... Is there something I am missing about running this script?
Igor Posted June 15, 2017 Posted June 15, 2017 Most likely only UART port is disabled in board configuration, but it can also be something else ...
martinayotte Posted June 15, 2017 Posted June 15, 2017 Also, BT enable handling (BT-WAKE-AP and BT-RST-N) in DT need to be added. (It is not currently present, because no body added it)
happyzax Posted June 16, 2017 Author Posted June 16, 2017 OK, it sounds like I need to get the latest Armbian source and start poking around the build. I doubt I will be able to figure out much on my own at this point, but I will give it a try. Thanks.
