Errors while trying to run 'sudo apt upgrade'
Go to solution Solved by Igor,
I'm getting the following errors when trying to upgrade
rob@orangepi5:~$ uname -a
Linux orangepi5 6.1.75-vendor-rk35xx #1 SMP Wed Aug 21 11:45:59 UTC 2024 aarch64 GNU/Linux
rob@orangepi5:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 armbian-bsp-cli-orangepi5 : Depends: armbian-bsp-cli-orangepi5-current (= 24.8.2) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
rob@orangepi5:~$ sudo apt --fix-broken install
Correcting dependencies... Done
The following additional packages will be installed:
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/430 kB of archives.
After this operation, 1,435 kB of additional disk space will be used.
Do you want to continue? [Y/n]
(Reading database ... 104089 files and directories currently installed.)
Preparing to unpack .../armbian-bsp-cli-orangepi5-current_24.8.2_arm64.deb ...
Armbian 'armbian-bsp-cli-orangepi5-current' for '1-PC868b-V1187-H21c6-B199a-R7697': 'preinst' starting.
Armbian 'armbian-bsp-cli-orangepi5-current' for '1-PC868b-V1187-H21c6-B199a-R7697': 'preinst' finishing.
Unpacking armbian-bsp-cli-orangepi5-current (24.8.2) ...
dpkg: error processing archive /var/cache/apt/archives/armbian-bsp-cli-orangepi5-current_24.8.2_arm64.deb (--unpack):
 trying to overwrite '/etc/X11/xorg.conf.d/01-armbian-defaults.conf', which is also in package armbian-bsp-cli-orangepi5-legacy 24.5.1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Armbian 'armbian-bsp-cli-orangepi5-current' for '1-PC868b-V1187-H21c6-B199a-R7697': 'postrm' starting.
Armbian 'armbian-bsp-cli-orangepi5-current' for '1-PC868b-V1187-H21c6-B199a-R7697': 'postrm' finishing.
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
You have quite some mix-up in your system. You are running vendor, trying to install something from current (why?) and also still some legacy packages.  interferences are expected.
I suggest home housekeeping.
All I've done is apt update and somehow it got in this state. Any suggestions on how to fix? I tried the following but didn't work:
rob@orangepi5:~$ sudo apt remove armbian-bsp-cli-orangepi5-legacy
 armbian-bsp-cli-orangepi5 : Depends: armbian-bsp-cli-orangepi5-current (= 24.8.2) but it is not going to be installed
rob@orangepi5:~$
rob@orangepi5:~$
Here's the legacy packages that are installed:
rob@orangepi5:~$ apt list --installed| grep legacy
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
armbian-bsp-cli-orangepi5-legacy/bookworm,now 24.5.1 arm64 [installed]
linux-dtb-legacy-rk35xx/bookworm,now 24.5.1 arm64 [installed]
linux-headers-legacy-rk35xx/bookworm,now 24.5.1 arm64 [installed]
linux-image-legacy-rk35xx/bookworm,now 24.5.1 arm64 [installed]
linux-u-boot-orangepi5-legacy/bookworm,now 24.5.1 arm64 [installed]
56 minutes ago, SteeMan said:
Can you run:
apt list --installed| grep armbian
apt list --installed| grep linux
Here you go:
rob@orangepi5:~$ apt list --installed| grep armbian
armbian-bsp-cli-orangepi5/bookworm,now 24.8.2 arm64 [installed]
armbian-config/bookworm,bookworm,bookworm,now 24.8.2 all [installed]
armbian-firmware/bookworm,bookworm,bookworm,now 24.8.2 all [installed]
armbian-plymouth-theme/bookworm,bookworm,bookworm,now 24.8.2 all [installed]
armbian-zsh/bookworm,bookworm,bookworm,now 24.8.2 all [installed]
hostapd/now 3:2.10-6~armbian22.02.3+1 arm64 [installed,local]
rob@orangepi5:~$ apt list --installed| grep linux
binutils-aarch64-linux-gnu/stable,now 2.40-2 arm64 [installed,automatic]
console-setup-linux/stable,stable,now 1.221 all [installed]
libselinux1/stable,now 3.4-1+b6 arm64 [installed]
linux-base/stable,stable,now 4.9 all [installed]
linux-dtb-vendor-rk35xx/bookworm,now 24.8.2 arm64 [installed]
linux-image-vendor-rk35xx/bookworm,now 24.8.2 arm64 [installed]
linux-libc-dev/now 23.02.2 arm64 [installed,local]
util-linux-extra/stable,stable-security,now 2.38.1-5+deb12u1 arm64 [installed,automatic]
util-linux/stable,stable-security,now 2.38.1-5+deb12u1 arm64 [installed]
