philippe perquin Posted March 7 Posted March 7 (edited) Hi, it seem that Armbian_community_25.5.0-trunk.185_Orangepi5-max build break the HDMI output, in gnome and bookworm. I try to boot the two with SD card. existing sytem that make an apt upgrade, the 185 also seem to broke all the system. regards, Edited March 7 by philippe perquin 0 Quote
mando Posted March 7 Posted March 7 I also can't get gnome or bookworm to boot with Mar 6 releases 0 Quote
SuperKali Posted March 7 Posted March 7 Could you please share your dmesg log? Which kernel version are you using? Please provide some information to help us understand the issue. 0 Quote
philippe perquin Posted March 8 Author Posted March 8 it's the version from download link seem to 6.12. i can't give you log, from card no acces and updated version from ssd will stay on error now. regards, 0 Quote
Erez Alster Posted March 9 Posted March 9 Are you able to boot your sbc? I'm getting constant green light. there is nothing to see in the UART. Previous images with kernel 6.1.99 are working correctly. Any idea? 0 Quote
mando Posted March 18 Posted March 18 Quick update New builds dated 17th March don't work either. Exactly the same problem - no boot. All I get is a flashing blue light. The February build works fine - no wifi - but at least it boots 0 Quote
mando Posted April 7 Posted April 7 Ubuntu and Debian versions dated 3rd April work fine until updated, then wifi disappears 0 Quote
Glibbr Posted April 9 Posted April 9 (edited) I can confirm that 25.5.0-trunk.256 and following work but all trunks after 256 (301 and 334) break WiFi and BT. Edited April 9 by Glibbr 0 Quote
mando Posted April 20 Posted April 20 Apr15th Ubuntu and Debian versions still behaving the same way - wifi works fine until updates then disappears 0 Quote
philippe perquin Posted 10 hours ago Author Posted 10 hours ago there is annoucement for a better support in, but they not give the build : 0 Quote
Werner Posted 9 hours ago Posted 9 hours ago 26 minutes ago, philippe perquin said: but they not give the build https://docs.armbian.com/User-Guide_FAQ/#why-is-there-no-image-for-board-with-bookwormjammynobletrixie-and-minimalclignomekdexfce-with-vendorlegacycurrentedge-kernel 0 Quote
