StarSurfer Posted March 17 Posted March 17 (edited) Hi folks, I've been trying to compile an image for the EspressoBin since yesterday. Unfortunately I get the following error every time I run it. Other boards work fine. Armbian-unofficial_25.05.0-trunk_Khadas-vim2_bookworm_edge_6.13.7.img Armbian-unofficial_25.05.0-trunk_Rockpro64_bookworm_edge_6.14.0-rc4.img Why is this only with the EspressoBin can someone help me ? Kind regards StarSurfer Spoiler [💲|🔨] trusted-secure-firmware.bin trusted-secure-firmware-uart.bin trusted-secure-firmware-emmc.bin \ [💲|🔨] untrusted-secure-firmware.bin untrusted-secure-firmware-emmc.bin [💲|🔨] make -C wtmi CROSS_CM3=/usr/bin/arm-linux-gnueabi- LTO=1 wtmi_app.bin [💲|🔨] make[1]: Entering directory '/home/starsurfer/build/cache/sources/mox-boot/wtmi' [💲|🔨] CC avs.c [💲|🔨] CC board.c [💲|🔨] CC clock.c [💲|🔨] CC crc32.c [💲|🔨] CC crypto.c [💲|🔨] CC crypto_hash.c [💲|🔨] CC ddr.c [💲|🔨] CC ebg.c [💲|🔨] CC efuse.c [💲|🔨] CC gpio.c [💲|🔨] CC irq.c [💲|🔨] CC mbox.c [💲|🔨] CC mdio.c [💲|🔨] HOSTCC bin2c.c [💲|🔨] make[2]: Entering directory '/home/starsurfer/build/cache/sources/mox-boot/wtmi/reload_helper' [💲|🔨] CC reload.c [💲|🔨] LD reload_helper.elf [💲|🔨] OBJCOPY reload_helper.bin [💲|🔨] BIN2C reload_helper.c [💲|🔨] make[2]: Leaving directory '/home/starsurfer/build/cache/sources/mox-boot/wtmi/reload_helper' [💲|🔨] CC reload.c [💲|🔨] make[2]: Entering directory '/home/starsurfer/build/cache/sources/mox-boot/wtmi/a53_helper' [💲|🔨] CC main.c [💲|🔨] make[2]: aarch64-unknown-linux-gnu-gcc: No such file or directory [💲|🔨] make[2]: *** [Makefile:48: main.o] Error 127 [💲|🔨] make[2]: Leaving directory '/home/starsurfer/build/cache/sources/mox-boot/wtmi/a53_helper' [💲|🔨] make[1]: *** [Makefile:152: a53_helper/a53_helper.c] Error 2 [💲|🔨] make[1]: Leaving directory '/home/starsurfer/build/cache/sources/mox-boot/wtmi' [💲|🔨] make: *** [Makefile:52: wtmi/wtmi_app.bin] Error 2 [💲|💥] Cleaning up [ please wait for cleanups to finish ] [💲|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-ccd84804-e65c-4906-8c70-09db07187085.log.ans ] [💲|🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-ccd84804-e65c-4906-8c70-09db07187085.log.ans https://paste.armbian.com/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-ccd84804-e65c-4906-8c70-09db07187085.log.ans https://paste.armbian.de/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-ccd84804-e65c-4906-8c70-09db07187085.log.ans https://paste.next.armbian.com/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-ccd84804-e65c-4906-8c70-09db07187085.log.ans https://paste.armbian.eu/log ] Edited March 17 by StarSurfer 0 Quote
Werner Posted March 17 Posted March 17 excerpts are useless. Provide full logs with the curl command suggested. 0 Quote
bschnei Posted March 21 Posted March 21 Quote aarch64-unknown-linux-gnu-gcc: No such file or directory Suggests you don't have the 64-bit ARM cross compiler installed or the location of its executable is not on PATH. 0 Quote
Igor Posted March 22 Posted March 22 On 3/17/2025 at 9:31 AM, StarSurfer said: I've been trying to compile an image for the EspressoBin since yesterday. We had to gave up with maintaining this hardware so there is absolutely no warranty that it builds and boots. To verify if your build environment is operational, try to build some supported targets by using a switch ARTIFACT_IGNORE_CACHE=yes This will force recompilation and will tell you if everything is alright. Try with Raspberry Pi or any other supported target to see if things are right at your side. 0 Quote
metalhard Posted 2 hours ago Posted 2 hours ago diff --git a/config/sources/families/mvebu64.conf b/config/sources/families/mvebu64.conf index 90b0a97d4..1a78ace60 100644 --- a/config/sources/families/mvebu64.conf +++ b/config/sources/families/mvebu64.conf @@ -28,7 +28,8 @@ BOOTSCRIPT_OUTPUT='boot.scr' OVERLAY_DIR="/boot/dtb/marvell/overlay" ATFSOURCE='https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git' ATFDIR='arm-trusted-firmware-espressobin' -ATFBRANCH='tag:v2.8' +ATFBRANCH='tag:v2.10' +#ATFBRANCH='tag:v2.8' ATF_USE_GCC='> 7.2' if [[ "${SKIP_EXTERNAL_TOOLCHAINS}" == "yes" ]]; then @@ -126,7 +127,7 @@ uboot_custom_postprocess() { local atfdir="$SRC/cache/sources/$ATFDIR/${ATFBRANCH##*:}" local ubootdir="$SRC/cache/sources/u-boot-worktree/$BOOTDIR/${BOOTBRANCH##*:}" local moxbootdir="$SRC/cache/sources/mox-boot" - cd $atfdir + cd $atfdir if [[ $BOARD = macchiatobin-doubleshot ]]; then run_host_command_logged make distclean @@ -139,6 +140,9 @@ uboot_custom_postprocess() { run_host_command_logged cp -pv build/a80x0_mcbin/release/flash-image.bin $ubootdir/$FILENAME else cd $moxbootdir +#$HL + [[ -f Makefile ]] && sed -i "s/aarch64-unknown-linux-gnu-/aarch64-linux-gnu-/" Makefile + [[ -f wtmi/a53_helper/Makefile ]] && sed -i "s/aarch64-unknown-linux-gnu-/aarch64-linux-gnu-/" wtmi/a53_helper/Makefile make clean # @TODO: rpardini: why? run_host_command_logged "CFLAGS=-fdiagnostics-color=always" pipetty make CROSS_CM3=$ATF2 wtmi_app.bin cd $atfdir diff --git a/lib/functions/compilation/atf.sh b/lib/functions/compilation/atf.sh index 2c6b55408..7205c0366 100644 --- a/lib/functions/compilation/atf.sh +++ b/lib/functions/compilation/atf.sh @@ -71,7 +71,8 @@ compile_atf() { display_alert "Binutils version for ATF" "${binutils_version}" "info" if linux-version compare "${binutils_version}" ge "2.39"; then display_alert "Binutils version for ATF" ">= 2.39, adding --no-warn-rwx-segment" "info" - binutils_flags_atf="-Wl,--no-warn-rwx-segment" + #binutils_flags_atf="-Wl,--no-warn-rwx-segment" + binutils_flags_atf="--no-warn-rwx-segment" fi # - ENABLE_BACKTRACE="0" has been added to workaround a regression in ATF. Check: https://github.com/armbian/build/issues/1157 with the patch, I am able to generate a image to run a espressobin v5 board, it should be ok for v7 board. 0 Quote
Werner Posted 1 hour ago Posted 1 hour ago 42 minutes ago, metalhard said: with the patch, I am able to generate a image to run a espressobin v5 board, it should be ok for v7 board Would you mind sending this as pull request? https://github.com/armbian/build/pulls 0 Quote
