ずっと一人 Posted May 26 Posted May 26 I have built and used it with the latest source and still HDMI audio and analog audio does not work. Is there any way to get HDMI audio to work other than using the vendor kernel? 0 Quote
Werner Posted May 26 Posted May 26 May work once rockchip64 has been bumped to 6.15 https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md 0 Quote
Guest Posted May 26 Posted May 26 The hardware driver support listed at Collabora in the Linux kernel will have nothing to do with the Linux distro base, like Debian or Ubuntu? 0 Quote
ずっと一人 Posted May 27 Author Posted May 27 I built and tested it with the rc version of kernel 6.15 it works. Waiting for Armbian to support 6.15😄 0 Quote
ricardo_brz Posted June 1 Posted June 1 Armbian already is! uname -a Linux orangepi5-plus 6.15.0-edge-rockchip64 #1 SMP PREEMPT Sun May 25 23:09:23 UTC 2025 aarch64 GNU/Linux Itś on edge, but it's working fine here, apart from the analog audio... 0 Quote
EricaLina Posted June 4 Posted June 4 That doesn't work then. The point is to get audio working. We still have a bit of a wait until a proper 6.15 kernel is there. 0 Quote
Werner Posted June 4 Posted June 4 HDMI audio has been merged into 6.15. Board may need additional device tree nodes to make it work. Analog audio should work already as well bug may also need additional nodes. Collabora sent for Rock5B and 5B+ only upstream. https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md 0 Quote
ricardo_brz Posted June 6 Posted June 6 (edited) I think I wasn't clear: HDMI audio is working, built-in audio is not. I'm using the latest edge image from Armbian that is 6.15. It's strange that I can see in Gnome Config the audio ports correctly HDMI and Built-In. Edited June 6 by ricardo_brz 0 Quote
Igor Posted June 6 Posted June 6 19 minutes ago, ricardo_brz said: built-in audio is not I think this is handled with overlay "audio" "analogue" or something similar. https://docs.armbian.com/User-Guide_Armbian-Config/System/#device-tree-overlays 0 Quote
The Tall Man Posted August 16 Posted August 16 (edited) ES-8388 Analog Audio Works At Fractional Volume (a possible solution) The issue of no ES-8388 analog audio output has been dragging on for months, and in all three kernel flavors (vendor, mainline, edge). I've discovered, at least with the latest edge kernel (as of Armbian 25.8.1 today), that the audio through the ES-8388 IS actually coming out, and the sound is clear. It's just that the volume that can be heard is extremely low and barely perceptible if all volume controls are maxed out and the audio file itself is at full volume range. This Bug Is From The Kernel / Driver Development Before It Gets To Armbian This is not new, I'd discovered this earlier and on other operating systems as well. So I know the issue is coming from the kernel / driver development, before it gets to Armbian. My Thought: The Audio Is Bit-Shifted by 7 or 8 bits I would venture an educated guess that the audio is 1/128 or 1/256 the correct levels (i.e. bit-shifted by 7 or 8 bits). This could be caused by, for example, a 24-bit audio integer value being copied into a 32-bit integer buffer without bit-shifting by 8 bits to align the MSBs (most significant bytes). The sign bit could be why it may be 7 instead of 8. The Easy Fix (for someone familiar w/ the source code) If this is the case, then someone familiar with the source code, who knows where this is - it would be a real simple fix. On Fedora KDE, I was able to crank up the volume even beyond max settings to try to make it louder, and it got clamped instead. My thought is that this confirms that the issue is the final mix is going to the device, which would make sense. Edited August 16 by The Tall Man 0 Quote
Igor Posted August 16 Posted August 16 51 minutes ago, The Tall Man said: on other operating systems as well 51 minutes ago, The Tall Man said: Before It Gets To Armbian Armbian is Debian or Ubuntu with focus into hardware support. https://docs.armbian.com/#what-is-armbian Many operating systems in this segment are derived or use Armbian kernel (development & support) maintained by our team and surrounding community. I do agree with your findings, but this is expected in this world. Achieving and keeping full functionality on custom hardware is hard without substantiation investments or big enough crowd of volunteers / random people that knows special stuff. Both is limited. 51 minutes ago, The Tall Man said: I would venture an educated guess that the audio is 1/128 or 1/256 the correct levels ALSA is a complex part of engineering that I only understand to some small degree. For most people, including me - is hard to comment. I hope your findings are valuable for someone that knows where to look. 51 minutes ago, The Tall Man said: then someone familiar with the source code, who knows where this is - it would be a real simple fix Isn't always like this? Sadly, in most cases, problems are solved by investing time for research - code / structure complexity is often extreme, also for people that live source code. Welcome to Armbian forum! 0 Quote
The Tall Man Posted August 17 Posted August 17 (edited) On 8/16/2025 at 2:20 AM, Igor said: Welcome to Armbian forum! Thanks!! On 8/16/2025 at 2:20 AM, Igor said: Armbian is Debian or Ubuntu with focus into hardware support. https://docs.armbian.com/#what-is-armbian Many operating systems in this segment are derived or use Armbian kernel (development & support) maintained by our team and surrounding community. Thanks for the overview. ES8388 Codec Driver Something to add to my previous comment here (2 comments up). I've noticed that, with the edge kernel, ALSA calls the ES8388 the 8328 instead. I've also seen the 8328 referenced in the devicetree .dtb file (via a hex viewer). I happened across where it appears to be, in two repositories: https://github.com/armbian/linux-rockchip/tree/rk-6.1-rkr5.1/sound/soc/codecs https://github.com/torvalds/linux/tree/master/sound/soc/codecs In both of those directories, there is an es8328.c, es8328.h and other es-... numbers in that range, but no es8388 file. To any developer reading this, it might be worthwhile to create es8388.h and es8388.c as copies of their respective es8328 counterparts, then have the es8388 files used in the build and referenced in the devicetrees instead of the es8328. This would create the clear (and correct) workspace to make the necessary modification(s) to fix the issue (of the volume apparently being right-shifted by 7 or 8 bits - re my previous comment). I've noticed in the es8328.h file, there are several configuration constants defined. It could be as simple as modifying one of those in the es8388.h to match the actual es8388 codec. Hardware Datasheets / Schematics While these are likely more low-level and off the path than practically useful for the simple fix that's likely needed here, it's good to have the datasheets available in one's toolbox: Everest-Semi (ES) Hardware Datasheet For ES8388: http://www.everest-semi.com/pdf/ES8388 DS.pdf Orange PI 5 Plus Schematic: I don't see how the way they have this schematic formatted would be of much practical use to anyone, but the ES8388 is on page 29. I didn't find any interface between it and the RK3588 there or on any other pages. There's a link to the schematic on this page, under Official Resources: http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-Pi-5-plus-32GB.html Edited August 17 by The Tall Man 0 Quote
dimaxus Posted Friday at 08:30 PM Posted Friday at 08:30 PM The most interesting thing is that everything works fine for joshua-riek Ubuntu 24.04 with the 6.1 kernel https://joshua-riek.github.io/ubuntu-rockchip-download/boards/orangepi-5-plus.html 0 Quote
The Tall Man Posted Friday at 09:54 PM Posted Friday at 09:54 PM 1 hour ago, dimaxus said: The most interesting thing is that everything works fine for joshua-riek Ubuntu 24.04 with the 6.1 kernel Thanks, I am aware of that. But that's an Ubuntu that's using the barebones vendor kernel. I need a fuller kernel than that, and Debian. As it turns out, in looking at recent updates here, it looks like the audio issue has been addressed within the past few days, and that it's an easy fix (as I thought it would be): https://patchwork.kernel.org/project/linux-rockchip/list/ I have yet to try that out, but it looks like I can either wait for the update in the bleeding edge kernel (if it's not already present) or modify the devicetree myself with the fix they discovered. 0 Quote
dimaxus Posted 20 hours ago Posted 20 hours ago If you can solve the problem, please share it with the community. 0 Quote
The Tall Man Posted 10 hours ago Posted 10 hours ago 9 hours ago, dimaxus said: If you can solve the problem, please share it with the community. It's already been my intention to do so. 0 Quote
