nanopi R3S armbian noble upgrade breaks boot
Go to solution Solved by Igor,
Hello there !
- nanopi R3S 2GB ram / 32 GB SD card and 32GB MMC here.
- Image running: Armbian_25.5.1_Nanopi-r3s-lts_noble_current_6.12.33
An upgrade (armbian-upgrade or apt-get upgrade), both on SD card or MMC, breaks boot of the system, reboot or cold start fails, stuck in system red-light.
Both SD or MMC boot at broken. Need to reflash the SD and boot + reinstall.
See attached some logs.
Thanks !
nan0r
r3s-armbian-apt-upgrade.log r3s-armbian-armbian-upgrade.log
According to ur log. It's pulling down an older kernel. This kernel does not have the DTB required so it's failing to boot.
After purging the kernel on the current IMG available and installing the kernel from apt.
https://paste.armbian.com/orokufexik
The result is a missing DTB.
root@nanopi-r3s-lts:~# ls /boot/dtb/rockchip/rk3566-nanopi-*
/boot/dtb/rockchip/rk3566-nanopi-r3s.dtb
  • Solution
Packages are in the update process - few hours from now it will be ok.
1 hour ago, Werner said:
Cannot reproduce
It fails only on first images, which were avail for few days.
1 minute ago, nan0r said:
Or should I download a new .img image and re-flash ?
If you plan to start from scratch and you don't want to wait hours until repository is updated, yes, rather download and use latest image. Upcoming fix will solve this problem for everyone that still use old image.
