Posted (edited)
Hello,
Recently the HDD Cable Harness for my Helios64 malfunctioned.
SATA Ports 1 and 2 are both no longer getting power/HDDs are not spinning up.
I confirmed that it was power by plugging the SATA cable into ports 3, 4, and 5 on the motherboard which all function.
I also iterated through the system by removing all the HDD's and testing each HDD slot one at a time.  All 5 HDDs fucntion individually in a USB drive enclosure, and all 5 function in my server system and I can mount the RAID array.
My question is, does anyone know how to contact the Helios/Kobol team so I can purchase a replacement HDD Harness Cable?
I checked on Aliexpress and can't find anything similar so I presume that the cable is custom.
Thank you.
Edited by grendel
silly typos
  • grendel changed the title to Helios64 HDD Cable Harness issue
That is surprising.  I don't think they are custom.  Isn't this what you need?  Or this one for just 1€.  Search for "SATA power cable" and skip the 4-pin ones.
I've already performed that search.
The connector on the motherboard is a Mini Molex 8 Pin connector.
Here is a link to the Kobol website with an image of the harness.
HDD Cable Harness
Oh, my bad.  That does indeed look very custom-made.
Just an idea, maybe get yourself a Molex 4-Pin IDE to SATA power cable (this one even has five power outlets) and then power the HDD separately?  Maybe there is 12V on the board somewhere you can tap into.  I am not an electrical engineer so better verify.  You will likely have to come up with a unique solution at this point.
I have looked at a lot of other 4 and 8 PIN cables and considered using multiple single SATA power connector to double connectors but I have reservations because the harness cable included with the Helios64 has those capacitors.  I am not certain what their purpose is and I am concerned if I do some sort of unique solution I will damage the motherboard.
Also this was being used as an offsite NAS for a production environment backup data and so stablity is essential.
I've asked this question in multiple places, I am at the point that I am just going to have to order a new NAS unit that doesn't use custom cables.
If tester is not available, I'd try powering failing ports with their respective cables but feeding them from pins powering other ports (eg with wires from some molex cable, just need to be careful with polarity and shortcuts) and then powering working ports from pins on the board feeding failing ports - to exclude failure of the power rail feeding these ports on the board.
If cables are faulty, I'd check them for electrical connections and if they are ok, would replace capacitors.
