June 14Jun 14 6 hours ago, Scritch said: Usbip modules are gone: https://github.com/armbian/build/pull/9971
June 14Jun 14 Wow, this is great! Thanks for the super fast response. Could this be also enabled in edge builds?
June 14Jun 14 How did you determine which configs to edit? Can I simply send a PR without testing? I guess there is a CI behind which takes care of testing? Edited June 14Jun 14 by Scritch
June 14Jun 14 I'd check all "edge" configs for the presence of usbip. at one of those at least a build test should occur
June 14Jun 14 I see. I will check. Furthermore: The usbip config was present but got lost between Armbian 26.2 and 26.5. I see frequent PRs which do "Automatic: kernel config rewrite". How can we make sure these changes get persisted and not lost again? However the automated kernel config rewrite works, also needs to consider usbip. Edit: In concrete, it got removed with PR 9381: https://github.com/armbian/build/pull/9381/changes?mode=single#diff-9a3979f7f80525cd7ddd10a00d15aa3e4156c49357184ef9405432599e85a588 The PR talks about "groundhog day". I guess there is a process behind to "generate" a more than 100k lines PR? Edited June 14Jun 14 by Scritch
June 14Jun 14 2 hours ago, Scritch said: "groundhog day". hehe, yes. because on every new major kernel version the same stuff occurs: rollover and adjust the (huge) patchset to the new version. Because patches were copied, this resulted in these large line numbers. in any case, kernel rewrite addresses things like unmet dependencies, hence throwing stuff out which would not work this way anyway. to make sure it is persistent, use kernel-config to spawn a menu config and enable the necessary options. The resulting kernel config should persist.
June 14Jun 14 vor 2 Stunden schrieb Werner: to make sure it is persistent, use kernel-config to spawn a menu config and enable the necessary options Sorry, I dont know how to do this. Either I will need more guidance in how to do it, or we will have live with adding the usbip module options also to the edge configs and keep the fingers crossed future major kernel versions will have a better merge outcome.
June 14Jun 14 I have sent a new pr. basically you do something like this: ./compile.sh BOARD=orangepioneplus BRANCH=edge kernel-config This will spawn a kernel menuconfig where you can modify the kernel config. This menu also takes all necessary dependencies into account. Once everything is done the kernel config file in config/kernel is modified. If you use a tool like vscode this will automatically visualize. If you manually change the kernel config file and want to check if your settings are persistent to rewriting you can use the rewrite-kernel-config command similar to the one above.
October 11Oct 11 Orange pi 5 Ultra. (v26.11 rolling for Orange Pi 5 Ultra running Armbian Linux 6.18.55-current-rockchip64) Armbian_community_26.11.0-trunk.83_Orangepi5-ultra_trixie_current_6.18.55_minimal.img.xz Boot reliability and reboot Working Networking (Ethernet, Wi-Fi, Bluetooth) Ethernet working, wifi not working Display and GPU, if applicable N/a Minimal image Installer and first-boot experience Working Bluetooth failing. Iperf3 ethernet speed test [SUM] 0.00-10.00 sec 2.75 GBytes 2.36 Gbits/sec 5 sender [SUM] 0.00-10.00 sec 2.74 GBytes 2.35 Gbits/sec receiver Armbian-debug https://paste.armbian.com/atetutadec Edited October 11Oct 11 by Dex2
