Today I installed Armbian_5.35_Odroidc2_Debian_jessie_default_3.14.79 on my Odroid C2
Installation went fine and I got a DHCP-IP
But now neither armbian-config will configure me a IP to eth0 (only device lo) nor /etc/network/interfaces would be "read" when I manually edit it to eth0
So I cleared the file.
nmtui does let me configure a connection and I could activate this connection. At this time I got a/the right IP.
But after a reboot this IP wouldnt reconnected.
Every boot I do get an additional connection eth0 generated.
Before boot
root@odroidc2:~# nmcli con show
NAME   UUID                                  TYPE            DEVICE
guido  2b96719d-bbee-4fef-9848-8663cda99dcc  802-3-ethernet  eth0
eth0   3888b480-d230-4bf7-a3b3-076f4b61b35b  802-3-ethernet  --
After next boot
eth0   569592fe-7704-4054-bb6a-74567526cd72  802-3-ethernet  --
So I named "my" connection guido and did try the following in the /etc/rc.local
nmcli con down eth0
nmcli con up guido
but on startup the boot-log (not in dmesg) shows me:
[FAILED] Failed to start /etc/rc.local Compatibility.
[EDIT] as workaround it does work with these 2 nmcli config-lines if I put a "sleep 1" before them in the /etc/rc.local
but this shouldnt be the final solution :)
But manually these command does work:
Connection successfully activated (D-Bus active path: /org/freedesktop/NetworkManager/ActiveConnection2)
root@odroidc2:~# armbianmonitor -u
System diagnosis information will now be uploaded to http://sprunge.us/ADIU
I have the same problem after updating from 5.25 to 5.35. IP was given the first time. After SSH login, modified the password and reboot, failed to get ip. Any solution instead of workaround?
If you have internet access please provide the output of: armbianmonitor -u
Also good to know: uname -a
Hi Igor,
Here is what I have the first time I logged in. After changing root password and creating a user account, and reboot, failed to get ip. I don't have this issue when I retried version 5.25 from the fresh.
Linux odroidc2 3.14.79-odroidc2 #4 SMP PREEMPT Wed Nov 22 16:09:18 CET 2017 aarch64 GNU/Linux
System diagnosis information will now be uploaded to <html>
 <head>
  <title>500 Internal Server Error</title>
 </head>
 <body>
  <h1>500 Internal Server Error</h1>
  The server has either erred or is incapable of performing the requested operation.<br /><br />
 </body>
</html>Please post the URL in the forum where you've been asked for.
I'm having the same problem on a new install of Armbian_5.35_Odroidc2_Debian_jessie_default_3.14.79 on an Odroid C2. Networking is fine on first boot, but after setting root password, creating new user, and reboot, eth0 doesn't connect.
Output from   # armbianmonitor -U   is here:  http://sprunge.us/EOZQ
Output from  # uname -a   is this:   Linux odroidc2 3.14.79-odroidc2 #4 SMP PREEMPT Wed Nov 22 16:09:18 CET 2017 aarch64 GNU/Linux
After quite a bit of fiddling using nmcli, renaming devices and connections, and several reboots, this seems to have resolved itself and it now connects and gets an IP via dhcp.
I've foudn solution to be commenting of the line where MAC address is assigned on OdroidC2 in /etc/network/interfafces
It should not cause a problem but my guess is something is causing incompatibility recently and if user defined MAC address is asigned to the adapter (so that it would get always same DHCP IP address) ... things are going awry. Not sure if it is caused by some changes in Kernel over last 1-2 months or something else ... but that is the solution ... my OdroidC2 seems to show always same MAC address upon boot so i don't need it.
This kind of problem would not it be due to the fact that now it is that the network is configured by systemd?  the Predictable Network Interface Names does not just prevent this kind of problem of confusion of the kernel at boot?
https://www.freedesktop.org/wiki/Software/systemd/PredictableNetworkInterfaceNames/ :
"The classic naming scheme for network interfaces applied by the kernel is to simply assign names beginning with "eth0", "eth1", ... to all interfaces as they are probed by the drivers. As the driver probing is generally not predictable for modern technology this means that as soon as multiple network interfaces are available the assignment of the names "eth0", "eth1" and so on is generally not fixed anymore and it might very well happen that "eth0" on one boot ends up being "eth1" on the next. This can have serious security implications, for example in firewall rules which are coded for certain naming schemes, and which are hence very sensitive to unpredictable changing names.
To fix this problem multiple solutions have been proposed and implemented. For a longer time udev shipped support for assigning permanent "ethX" names to certain interfaces based on their MAC addresses. This turned out to have a multitude of problems, among them: this required a writable root directory which is generally not available; the statelessness of the system is lost as booting an OS image on a system will result in changed configuration of the image; on many systems MAC addresses are not actually fixed, such as on a lot of embedded hardware and particularly on all kinds of virtualization solutions. The biggest of all however is that the userspace components trying to assign the interface name raced against the kernel assigning new names from the same "ethX" namespace, a race condition with all kinds of weird effects, among them that assignment of names sometimes failed. As a result support for this has been removed from systemd/udev a while back."
Network is not configured by systemd by default, unless you create files in /etc/systemd/network and enable several additional services.
Predictable names rely on devices having HW MAC addresses, and most SBC devices have no hardware MAC addresses and usually have different methods for generating a persistent MAC based on CPU serial number or storing a randomly generated MAC somewhere. Sometimes this does not work as intended.
