Stanislav Chizhik Posted 19 hours ago Posted 19 hours ago I just installed Armbian_community_26.2.0-trunk.732_Rockpi-4bplus_trixie_current_6.18.22_minimal on a Rockpi-4bplus. How do I install the correct Linux headers? The standard apt install linux-headers-$(uname -r) method doesn't work for armbian. OK, there's a corresponding option in armbian-config, and it seems to run successfully, but for some reason, I only see linux-headers-6.12.74+deb13+1-arm64 and linux-headers-6.12.74+deb13+1-common in /usr/src. 0 Quote
Werner Posted 11 hours ago Posted 11 hours ago We don't ship headers for each and every trunk image. Way too much data. Simplest solution is to use the framework to create a complete set of kernel deb packages. Those will include matching headers. 0 Quote
Stanislav Chizhik Posted 1 hour ago Author Posted 1 hour ago Thanks, @Werner! I believe I can do it once I find clear instructions. There's still a lot I don't understand—where all needed things are. I'd appreciate it if you could just provide a link that could point me in the right direction. Meanwhile, yesterday I somehow managed to install the headers using apt-get install linux-headers-current-rockchip64 . At least, for now, this allowed me to build the packages that needed the headers. It seems like this might be a bit of a dirty trick (no?). So, I'd still like to do it right. 0 Quote
Werner Posted 10 minutes ago Posted 10 minutes ago Okay so then we have some issues here 19 hours ago, Stanislav Chizhik said: armbian-config, and it seems to run successfully, but for some reason, I only see linux-headers-6.12.74+deb13+1-arm64 and linux-headers-6.12.74+deb13+1-common in /usr/src This is clearly wrong since these packages come from upstream Debian and cannot/will not work with Armbian kernels. This shall be reported here: https://github.com/armbian/configng/ 1 hour ago, Stanislav Chizhik said: sing apt-get install linux-headers-current-rockchip64 Then you were lucky some working headers were present 1 hour ago, Stanislav Chizhik said: a link that could point me in the right direction https://docs.armbian.com/Developer-Guide_Build-Preparation/ Or in very short: git clone the repo ./compile.sh BOARD=rockpi-4bplus BRANCH=current kernel Check output/debs for your packages Install via dpkg -i on the target board 0 Quote
