Armbian uses g_serial by default with a modern kernel. With old, I lost track. I assume you only need to exchange it with g_ether? /etc/modules
I'm actually very new to all these so can you please point out how I can exchange g_serial with g_ether?
I actually wrote the exact procedure :) Edit /etc/modules. Remove g_serial and add g_ether instead .... save and reboot.
But remember, it's still only a theory. I haven't tested this.
I changed g_serial to g_ether and my board is being detected as USB Ethernet/RNDIS Gadget on my pc but there is no connection. How do I ssh to the device? I tried with hostname.local but couldn't connect. :(
change your /etc/network/interfaces file to look like:
auto eth0
iface eth0 inet static
    address 192.168.100.1
    netmask 255.255.255.0
and type
sudo ifdown eth0 && ifup eth0
With that you should be able to ssh into the device using ssh USER@192.168.100.1
I changed /etc/network/interfaces to this
auto lo
iface lo inet loopback
auto eth0
and ran
but still there is no connection.
auto eth0
and type
I think - you have to replace here eth0 with usb0 :)
The following page is for the Raspberry, but could also help your OPi with the /etc/network/interfaces or the configuration within windows:
https://learn.adafruit.com/turning-your-raspberry-pi-zero-into-a-usb-gadget/ethernet-gadget
BTW: this forum is searchable. It's pretty easy to search for g_ether and then end up here for example:
