I would like to add the Orange Pi Lite 2 into the discussion of boards to support.
Info from Orange Pi site - http://www.orangepi.org/Orange Pi Lite 2/
Hardware specification
CPU
H6 Quad-core 64-bit ARM Cortex™-A53
GPU
• High-performance multi-core GPU Mali T720
• OpenGL ES3.1/3.0/2.0/1.1
• Microsoft DirectX 11 FL9_3
• ASTC(Adaptive Scalable Texture Compression)
• Floating point operation greater than 70 GFLOPS
Memory (SDRAM)
1GB LPDDR3 (shared with GPU)
Onboard Storage
TF card (Max. 32GB) /MMC card slot
WIFI+BT
AP6255, IEEE 802.11 AC/bb/g/n, BT4.1
Audio Input
MIC
Audio Output
HDMI 2.0a
Video Input
A CSI input connector Camera:
Support 8 bit digital camera interface
Maximum still capture resolution for parallel interface to 5M
Video Decoding
H265/HEVC Main/Main10 profile@Level5.2 High-tier ;4K@60fps, up to 6Kx4K@30fps
H264/AVC BP/MP/HP@level5.1, MVC, 4K@30fps
VP9,Profile 0/2, 4K@30fps
AVS+/AVS JIZHUN profile@level 6.0, 1080P@60fps
Video Outputs
HDMI 2.0a TX with HDCP 2.2 output
Power Source
DC input, USB OTG input can supply power
PMU
AXP805
USB 2.0 Ports
One USB 2.0 Host, one Micro USB 2.0
USB 3.0 Ports
One USB 3.0 Host
Low-level peripherals
26 Pins Header
GPIO(1x3) pin
UART, ground.
LED
Power led & Status led
IR Receiver
Yes
Key
Power(K1)
Supported OS
Android, Ubuntu, Debian
Interface definition
Product size
69 mm × 48mm
Weight
50g
Orange Pi™ is a trademark of the Shenzhen Xunlong Software CO., Limited
IMHO a board bring up proposal for a new SoC, like the H6 should be a bit more informative than just copy paste the information provided by the boardmaker... Especially when they are two threads about H6 boards still here:
I think it's to early for a 'board bring up'. Both boards available at the moment are of minor interest (OPi One doesn't provide USB3,  OPi Lite2 doesn't provide GbE). The first interesting board IMHO is the PineH64: http://wiki.pine64.org/index.php/PINE_H64_Main_Page#Software_and_OS_Image_Downloads
Edit: Ok, pine64h is also available https://www.pine64.org/?product=pine-h64-2gb-board
Thank you for the criticism regarding the board bring up process, this was unknown to me.
I don't have any further information regarding this board aside from what is publicly available as this is not my area of expertise.  My hope was to begin the discussion and offer my assistance where I can.  FWIW, I do have this board and am more than willing to loan it out / assist with testing where possible.
Your thoughts on it not being of much interest may be true but I disagree personally.  While it doesn't provide GbE, it does offer the USB 3.0 port so expansion possibilities are there.  I've tested the stock Android image from Orange Pi with a USB 3.0 hub / GbE combo adapter and it worked great allowing me to mount several USB sticks and provided GbE networking I have not yet tested throughput on the GbE adapter using this board but previous iperf tests on other devices put it at about 900 Mbit/s.
My personal goal for this board is to use it as a media player on my TV so ultimately, a working Android image is all I need but considering it's low price and USB 3.0 line, I think having Armbian support for this board would be a great option for others.
Hi.
Yes, I also waiting for "clean server" OS for new OrangePi Lite2 (H6) to setup docker & other stuff to use USB3 and/or AC wifi.
Lite2 Board boots raspbian from OnePlus (H6+Gbe) with no problems but You can do nothing w/o network :(  OPi does not provide Lite2 raspbian, do not know why...
I got one on my hands as of yesterday, I played around with OPi provided Ubuntu server image, but it is terrible.
I would love to start working on support for this board as for me it looks as quite interesting option.
Wireless chip there reports 2(!) bands and AP+managed mode combination, which means I can use it as Wi-Fi extender and other nice things.
I also have orange pi lite 2 and one plus. Very cheap cost models. Ubuntu 16.04 downloaded from orangepi www works, i mean boot up..... they are beta version. should works only without GUI.
1GB of RAM and 64 bit system it is a misunderstooding. I installed XFCE4 and mate but when you install firefox or qupzilla, browsers eat your memory and hung system. In my opinion it is wasting of money.  Only 32 bit armbian can help these boards.... But i dont know if we will wait..
PS H6 1.8GHZ is very fast i must say.
1 hour ago, radek said:
Igor Could you build 32bit  armbian for H6 orange one plus? Please
At this moment we don't support 32bit target for 64bit CPU's and we don't support this board either. Perhaps in a few weeks or months. If you want to get things done quicker, take over some work:
https://forum.armbian.com/topic/6751-v543-desktop-on-top-of-cli-xu4-next-upgrade/
https://www.armbian.com/get-involved/
https://docs.armbian.com/Process_Contribute/
29 minutes ago, Palmaborn said:
Ok guys. SSH it's ok. But I want X! :) I need GUI)) It's impossible?
Even this was near to impossible.
You need to stay with Allwinner stock 3.10.y kernel, which we will not touch, for next couple of weeks/months if you want to have X. According to my experiences, this kernel will remain labeled as development/testing at least by the end of this year.
It is "simple": start porting video drivers (they are actually already developed but need to get matured) and push your solution to the build script.
ok i have made donation 20 euro for you.... i can build img file for pine H64 or Orange pi based on H6 allwinner cpu. I have free time but iam not developer.  do you have prepared build for pine H64? Im intereresting debian 9  also Ubuntu bionic 18.04 + X window xfce support
i just copied pine64.sophine and edit...
pineh64.conf.:
# H6 quad core 4GB SoC GBE
BOARD_NAME="PineH64"
BOARDFAMILY="sun50iw6p1"
BOOTCONFIG_DEFAULT="sun50iw6p1_config"
BOOTCONFIG="pineh64_baseboard_defconfig"
MODULES="sunxi_codec sunxi_i2s sunxi_sndcodec 8723bs"  ???????????????????
MODULES_NEXT=""
KERNEL_TARGET="default,next,dev"
CLI_TARGET="bionic:default"   ???????????????????
DESKTOP_TARGET="YES"
CLI_BETA_TARGET=""
DESKTOP_BETA_TARGET=""
RECOMMENDED="Ubuntu_bionic_default:90" ???????????????/
BOARDRATING=""
CHIP="http://docs.armbian.com/Hardware_Allwinner-H5-A64/"
HARDWARE="https://linux-sunxi.org/PineH64"
REVIEW="http://forum.armbian.com/index.php/topic/1917-armbian-running-on-pine64-and-other-a64h5-devices/#entry14642"
FORUMS="http://forum.armbian.com/index.php/forum/11-other-boards/"
please correct
12
Thank you. Remember, donations are unconditional, like love.
Well, we still need to find another 99.9% to get your wish funded or we do it virtually for free :P Since most of the work is done for free it is done when it is done.
1 minute ago, constantius said:
there is not pineh64 in config/boards
i guess orange pi lite 2 and one plus also
1
First build is months away from end users level and there is nothing I can do. Build targets are hidden to limit down wasteful support questions. If you are not a developer, there is a test build and that's about it. Remember, we don't provide any support for development versions since this is stupid, wasteful and expensive. Supporting development - teaching and explaining one to one (since they are unable to use search) to newbies - you need to double the expenses of the development.
8 minutes ago, constantius said:
please correct
You are wasting time.
as I said, I'm not a programmer. So I'm basically not useful .... sory
You wanted to start with almost the most difficult problem which is hard even for a group of most experienced programmers :) In case you want to contribute to the project, there are plenty things to do for people who are not technically skilled. I already expose a few and yet another very specific one:
Upgrade whatever build you have to the latest beta (rather few different version since the output is kernel and board dependent) and update the manual for armbian config. This way you help programmers which have to write this down: (and they usually hate doing it, while some people love this job)
https://github.com/armbian/documentation/blob/master/docs/User-Guide_Armbian-Config.md (in case you are perhaps skilled video producer, do a video)
How to edit: https://docs.armbian.com/Process_Contribute/
I can upgrade some builds for example for orangepi boards... I can even test it because i have orangepi H3, H5 A64, H6. tinkerboard and miqi. But when something go wrong i will have stupid questions...you have no time to answer you are not for me to help.. I understand it. i dont know.... i downloaded build environment and i can build armbians debian stretch and ubuntu bionic... and update the manual.
I am disabled and currently not working. I have free time. I have a damaged left hand so writing is bothering me. But I will be releasing new updates, whether it's the kernel itself or new imgs. I know little linux. Bionic was supposed to go out today. I can build img based on bionic ...
Hello.
I've tried to build an image for pi lite 2 and it was built, but it doesn't work. I plugged in a SD card with this image to the Orange, but nothing happened,  the power is only 0.17/0.2 A. If I use the original image from Orange everything is ok.
Can you help me?
Did anyone test that image?
Quite normal. Upstream u-boot and kernel changes are severe and things break all the time at boards which are under development. IMO they are at least half a year away from the end user stage.
Automated builds made for developers and testers are never tested. Manual testing is expensive and nobody covers that. This build might work: https://dl.armbian.com/orangepilite2/Debian_stretch_dev_nightly.7z
A modern kernel is still far away from stock functionality. Video driver does not exist yet, so you need to use a serial console.
On 8/1/2018 at 9:39 AM, Benno Eigenmann said:
Has anyone been able to boot Orange Pi Lite 2 with any armbian image.
Images from http://www.orangepi.org/downloadresources/ work fine
Thanks
Ok it boot into serial console debug only
Yes. This is normal and noted at the download page. We work only with a modern kernel on many of those boards and there for this chip, the video driver is not yet developed.
Anyone has tried kernel 5.2rc1?
I think Cedrus driver support should be available by now.
Even in 5.1.y kernel the VPU part was working, as sunxi said.
Anyway, Has anybody tried desktop build? If I want to, is there a repository or something else I can download the image from instead of building it myself?
