fabian Posted March 15, 2018 Posted March 15, 2018 I trying all version on Orange Pi H5 Zero and nothing working. Only one green light start and after 3 second stop lighting. Before i use Armbian on this machine (meybe update firmware)
guidol Posted March 15, 2018 Posted March 15, 2018 Which Orange Pi with H5 do you have and which image did you use?
Igor Posted March 15, 2018 Posted March 15, 2018 And checking this: https://docs.armbian.com/User-Guide_Getting-Started/ and this
fabian Posted March 17, 2018 Author Posted March 17, 2018 I use good Power. (2.1A) My machine working one time. I download second time iso file and dont run it. I'm trying many times many images, from orange pi and from armbian. nothing working.
guidol Posted March 17, 2018 Posted March 17, 2018 48 minutes ago, fabian said: I use good Power. (2.1A) My machine working one time. I download second time iso file and dont run it. I'm trying many times many images, from orange pi and from armbian. nothing working. There is no .iso for a Orange Pi only a .img Did you unzip the .img file? Which program did you use to write to the sd-card (etcher, win32diskimager, usb-it oder dd?)
fabian Posted March 17, 2018 Author Posted March 17, 2018 yes, i unzip. this is not funny, I use raspbery pi, orange pi zero h2 and many other now i use linux on macintosh machine. i check sha and verify. tell me what file working for You.
chwe Posted March 17, 2018 Posted March 17, 2018 Then there is probably something faulty with your setup, otherwise at least one image should work (otherwise this subforum would be flouted with people complaining that none of the images provided by Armbian works). Do you have a multimeter (in case yes, measure between GND and 5V on pinheader)? Did you check your SD-Card first with F3 H2testw (as described in the getting started)? What is connected to your board? Do you own a USB-UART dongle to see when it struggles during boot?
